[GRASS-SVN] r60284 - grass-addons/grass6/raster/r.out.mbtiles_prep
svn_grass at osgeo.org
Sat May 17 05:23:07 PDT 2014
Author: hamish
Date: 2014-05-17 05:23:07 -0700 (Sat, 17 May 2014)
New Revision: 60284
grass-addons/grass6/raster/r.out.mbtiles_prep/r.out.mbtiles_prep
discard blank tiles (all-alpha and greyscale only);
too many .aux.xml files broke a single call to rm, so move it to a loop;
re-add the second zoom level below the center;
exporting imagery groups will only work from the current mapset;
deal with automatic naming when called from another mapset
Modified: grass-addons/grass6/raster/r.out.mbtiles_prep/r.out.mbtiles_prep
--- grass-addons/grass6/raster/r.out.mbtiles_prep/r.out.mbtiles_prep 2014-05-17 12:19:51 UTC (rev 60283)
+++ grass-addons/grass6/raster/r.out.mbtiles_prep/r.out.mbtiles_prep 2014-05-17 12:23:07 UTC (rev 60284)
@@ -82,7 +82,7 @@
fi
#### check if we have awk, gdalwarp, gdal2tiles, seq
-pgms="awk seq gdalwarp gdal2tiles.py"
+pgms="awk seq gdalwarp gdalinfo gdal2tiles.py"
for pgm in $pgms ; do
if [ ! -x "`which $pgm`" ] ; then
g.message -e "$pgm is required, please install it first."
@@ -96,7 +96,7 @@
if [ -n "$GIS_OPT_OUTPUT" ] ; then
OUTFILE="$GIS_OPT_OUTPUT"
else
- OUTFILE="$MAP_NAME"
+ OUTFILE=`echo "$MAP_NAME" | cut -f1 -d'@'`
fi
@@ -108,7 +108,7 @@
if [ $? -eq 0 ] ; then
MAP_TYPE=group
else
- g.message -e "Could not find [$MAP_NAME]"
+ g.message -e "Could not find <$MAP_NAME>"
exit 1
fi
fi
@@ -160,6 +160,12 @@
#gdalwarp -s_srs "`g.proj -jf`" -t_srs EPSG:900913 -dstalpha "$TMP_GTIFF" "$TMP_GMERC"
gdal_translate $QUIET -a_srs "`g.proj -jf`" "$TMP_GTIFF" "$TMP_GMERC"
else
+ if [ `echo "$MAP_NAME" | grep -c '@'` -gt 0 ] ; then
+ g.message -e "Imagery groups must exist in the current mapset, sorry."
+ cleanup
+ exit 1
+ fi
r.out.gdal input="$MAP_NAME" output="$TMP_GTIFF" format=GTiff
#gdalwarp -t_srs EPSG:900913 -dstalpha "$TMP_GTIFF" "$TMP_GMERC"
mv "$TMP_GTIFF" "$TMP_GMERC"
@@ -167,7 +173,7 @@
## gdalwarp -srcnodata -dstnodata -dstalpha ?
if [ $? -ne 0 ] ; then
- g.message -e "Problem running gdalwarp"
+ g.message -e "Problem exporting image"
cleanup
exit 1
fi
@@ -275,8 +281,16 @@
if [ -n "$GIS_OPT_ZOOM" ] ; then
ZOOM="$GIS_OPT_ZOOM"
+ # pick a mid-level zoom for the mapurl file
+ if [ `echo "$ZOOM" | grep -c '\-'` -gt 0 ] ; then
+ maxzoom=`echo "$ZOOM" | awk -F '-' '{print $1 + int(($2 - $1) / 2)}'`
+ else
+ maxzoom="$ZOOM"
+ fi
else
- # calc map scale from map extent and dpi
+ # auto-calc map scale from map extent and dpi
eval `g.region -gu`
eval `g.region -legu`
@@ -300,7 +314,7 @@
#echo "[$zoom 1 : $zoomscale]" # @ ${SCREEN_DPI}dpi]"
if [ "$zoomscale" -gt "$MAP_SCALE" ] ; then
maxzoom=`expr "$zoom" + 2`
- minzoom=`expr "$maxzoom" - 3`
+ minzoom=`expr "$zoom" - 2`
fi
done
@@ -344,8 +358,10 @@
fi
rm -f "$TMP_GMERC"
-rm -f `find $(dirname "$OUT_DIR") | grep .aux.xml`
+for file in `find $(dirname "$OUT_DIR") | grep .aux.xml` ; do
+ rm -f "$file"
+done
#### write out .mapurl file
@@ -376,8 +392,29 @@
request_type=run,fill,load,reset_metadata
EOF
+cd "$OUT_DIR"
+g.message "Scanning for blank tiles ..."
+# warping can leave a lot of left over border around the edges due to skew
+# MBTiles links these all to a single tile, but they're unsightly.
+# This takes a while so consider running in parallel, but it is probably
+# near-saturation already due to the large number of tiny processes creaded
+# and destroyed.
+i=0
+for file in `find . | grep '.png$'` ; do
+ # check if image is empty
+ COUNT=`gdalinfo -mm -noct -nomd "$file" | grep 'Min/Max' | \
+ cut -f2 -d= | tr ',' '\n' | uniq | wc -l`
+ if [ "$COUNT" -eq 1 ] ; then
+ rm -f "$file"
+ i=`expr $i + 1`
+ fi
+done
+if [ "$i" -gt 0 ] ; then
+ g.message "Removed $i blank tiles."
+fi
if [ "$GIS_OPT_FORMAT" = "jpeg" ] ; then
g.message "Converting to JPEG ..."
@@ -390,7 +427,6 @@
fi
done
- cd "$OUT_DIR"
outfile=`echo "$file" | sed -e 's/\.png$/.jpg/'`
pngtopnm "$file" | pnmtojpeg > "$outfile"
@@ -405,10 +441,9 @@
-e 's+extension="png"+extension="jpg"+' \
tilemapresource.xml.tmp > tilemapresource.xml
rm tilemapresource.xml.tmp
- cd - > /dev/null
fi
+cd - > /dev/null
mv "$OUT_DIR" "$OUTFILE"
mv "$OUTFILE"/*.mapurl "$OUTFILE"/..
