[GRASS-SVN] r60286 - in grass/branches/releasebranch_7_0: gui/wxpython/core scripts/d.rast.leg
Sat May 17 08:25:51 PDT 2014
Author: neteler
Date: 2014-05-17 08:25:51 -0700 (Sat, 17 May 2014)
New Revision: 60286
   grass/branches/releasebranch_7_0/gui/wxpython/core/utils.py
   grass/branches/releasebranch_7_0/scripts/d.rast.leg/d.rast.leg.py
d.rast.leg/wxGUI: fix 'Unsupported command d.text' bug; fix font size
Modified: grass/branches/releasebranch_7_0/gui/wxpython/core/utils.py
--- grass/branches/releasebranch_7_0/gui/wxpython/core/utils.py	2014-05-17 15:25:26 UTC (rev 60285)
+++ grass/branches/releasebranch_7_0/gui/wxpython/core/utils.py	2014-05-17 15:25:51 UTC (rev 60286)
@@ -1001,7 +1001,8 @@
                  'd.histogram'    : 'histogram',
                  'd.colortable'   : 'colortable',
                  'd.graph'        : 'graph',
-                 'd.out.file'     : 'export'
+                 'd.out.file'     : 'export',
+                 'd.text'         : 'text'
 ltype2command = {}
 for (cmd, ltype) in command2ltype.items():
Modified: grass/branches/releasebranch_7_0/scripts/d.rast.leg/d.rast.leg.py
--- grass/branches/releasebranch_7_0/scripts/d.rast.leg/d.rast.leg.py	2014-05-17 15:25:26 UTC (rev 60285)
+++ grass/branches/releasebranch_7_0/scripts/d.rast.leg/d.rast.leg.py	2014-05-17 15:25:51 UTC (rev 60286)
@@ -118,7 +118,7 @@
     make_frame(f, 90, 100, 70, 100)
     # use map name without mapset suffix
     mapname = map.split('@')[0]
-    grass.run_command('d.text', color='black', size=50, at='5,50', align='cl', text=mapname)
+    grass.run_command('d.text', color='black', size=5, at='5,50', align='cl', text=mapname)
     #draw legend
