[GRASS-SVN] r60291 - grass/trunk/raster/r.stream.channel
svn_grass at osgeo.org
Sat May 17 12:46:33 PDT 2014
Author: hellik
Date: 2014-05-17 12:46:33 -0700 (Sat, 17 May 2014)
New Revision: 60291
grass/trunk/raster/r.stream.channel/main.c
r.stream.channel: cosmetics
Modified: grass/trunk/raster/r.stream.channel/main.c
--- grass/trunk/raster/r.stream.channel/main.c 2014-05-17 18:29:35 UTC (rev 60290)
+++ grass/trunk/raster/r.stream.channel/main.c 2014-05-17 19:46:33 UTC (rev 60291)
@@ -105,7 +105,7 @@
opt_swapsize->key = "memory";
opt_swapsize->type = TYPE_INTEGER;
opt_swapsize->answer = "300";
- opt_swapsize->description = _("Max memory used in memory swap mode (MB)");
+ opt_swapsize->description = _("Maximum memory used in memory swap mode (MB)");
opt_swapsize->guisection = _("Memory settings");
flag_downstream = G_define_flag();
