[GRASS-SVN] r60298 - grass/trunk/raster/r.stream.segment
svn_grass at osgeo.org
Sat May 17 15:13:59 PDT 2014
Author: hellik
Date: 2014-05-17 15:13:59 -0700 (Sat, 17 May 2014)
New Revision: 60298
grass/trunk/raster/r.stream.segment/r.stream.segment.html
r.stream.segment: manual cosmetics
Modified: grass/trunk/raster/r.stream.segment/r.stream.segment.html
--- grass/trunk/raster/r.stream.segment/r.stream.segment.html 2014-05-17 21:53:28 UTC (rev 60297)
+++ grass/trunk/raster/r.stream.segment/r.stream.segment.html 2014-05-17 22:13:59 UTC (rev 60298)
@@ -16,8 +16,8 @@
<em>r.stream.extract</em> may slightly differ in detail, it is required to use both stream
and direction map produced by the same module. Stream background shall have NULL
value or zero value. Background values of NULL are by default produced by
-<em>r.watershed</em> and <em>r.stream.extract</em>. If not 0 or NULL use <a
-href="r.mapcalc.html">r.mapcalc</a> to set background values to null.
+<em>r.watershed</em> and <em>r.stream.extract</em>. If not 0 or NULL use <em><a
+href="r.mapcalc.html">r.mapcalc</a></em> to set background values to null.
</dd>
<dt><b>direction</b></dt>
