[GRASS-SVN] r60331 - grass-addons/grass7/raster/r.bioclim
svn_grass at osgeo.org
Mon May 19 01:14:16 PDT 2014
Author: mmetz
Date: 2014-05-19 01:14:15 -0700 (Mon, 19 May 2014)
New Revision: 60331
Added:
grass-addons/grass7/raster/r.bioclim/Makefile
grass-addons/grass7/raster/r.bioclim/r.bioclim.html
grass-addons/grass7/raster/r.bioclim/r.bioclim.py
add r.bioclim
Added: grass-addons/grass7/raster/r.bioclim/Makefile
--- grass-addons/grass7/raster/r.bioclim/Makefile (rev 0)
+++ grass-addons/grass7/raster/r.bioclim/Makefile 2014-05-19 08:14:15 UTC (rev 60331)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM=r.bioclim
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Property changes on: grass-addons/grass7/raster/r.bioclim/Makefile
___________________________________________________________________
Added: svn:mime-type
+ text/x-makefile
Added: svn:eol-style
+ native
Added: grass-addons/grass7/raster/r.bioclim/r.bioclim.html
--- grass-addons/grass7/raster/r.bioclim/r.bioclim.html (rev 0)
+++ grass-addons/grass7/raster/r.bioclim/r.bioclim.html 2014-05-19 08:14:15 UTC (rev 60331)
@@ -0,0 +1,101 @@
+<h2>DESCRIPTION</h2>
+<em><b>r.bioclim</b></em> calculates various bioclimatic indices from
+monthly temperature and optional precipitation time series. The time
+series can be averages for several years or monthly values for a
+specific year. In any case all 12 months must be provided. It a precipitation
+time series is not provided, only those indices based on temperature
+are calculated. The names of the output maps are <output>.bio01, <output>.bio02,
+<output>.bio03, etc.
+<p>
+If the input temperatures are scaled, e.g. as input = Celsius * 10, then
+the <b>inscale</b> option must be set to 10. Similarly, the <b>outscale</b>
+option is by default 10, and temperature output is in this case Celsius * 10.
+Exceptions are BIO3, BIO4, and BIO15 which are always multiplied with 100 (see below).
+<dl>
+<dt><b>BIO 1</b>
+<dd>Annual mean temperature as the mean of the monthly temperatures.
+<dt><b>BIO 2</b>
+<dd>Mean diurnal range as the mean of monthly (max temp - min temp)
+<dt><b>BIO 3</b>
+<dd>Isothermality (BIO2/BIO7 * 100)
+<dt><b>BIO 4</b>
+<dd>Temperature Seasonality (standard deviation * 100)
+<dt><b>BIO 5</b>
+<dd>Max Temperature of Warmest Month
+<dt><b>BIO 6</b>
+<dd>Min Temperature of Coldest Month
+<dt><b>BIO 7</b>
+<dd>Temperature Annual Range (BIO5 - BIO6)
+<dt><b>BIO 8</b>
+<dd>Mean Temperature of Wettest Quarter
+<dt><b>BIO 9</b>
+<dd>Mean Temperature of Driest Quarter
+<dt><b>BIO 10</b>
+<dd>Mean Temperature of Warmest Quarter
+<dt><b>BIO 11</b>
+<dd>Mean Temperature of Coldest Quarter
+<dt><b>BIO 12</b>
+<dd>Annual Precipitation
+<dt><b>BIO 13</b>
+<dd>Precipitation of Wettest Month
+<dt><b>BIO 14</b>
+<dd>Precipitation of Driest Month
+<dt><b>BIO 15</b>
+<dd>Precipitation Seasonality (Coefficient of Variation * 100)
+<dt><b>BIO 16</b>
+<dd>Precipitation of Wettest Quarter
+<dt><b>BIO 17</b>
+<dd>Precipitation of Driest Quarter
+<dt><b>BIO 18</b>
+<dd>Precipitation of Warmest Quarter
+<dt><b>BIO 19</b>
+<dd>Precipitation of Coldest Quarter
+</dl>
+<h2>EXAMPLES</h2>
+Bioclimatic indices from worldclim data with 4 parallel processes:
+<div class="code"><pre>
+r.bioclim tmin=`g.mlist type=rast pat=tmin_* map=. sep=,` \
+ tmax=`g.mlist type=rast pat=tmax_* map=. sep=,` \
+ prec=`g.mlist type=rast pat=prec_* map=. sep=,` \
+ out=worldclim workers=4
+</pre></div>
+<h2>SEE ALSO</h2>
+<em>
+<a href="r.series.html">r.series</a>,
+<a href="r.mapcalc.html">r.mapcalc</a>,
+<a href="g.region.html">g.region</a>
+</em>
+<h2>AUTHOR</h2>
+Markus Metz
+<p>
+<i>Last changed: $Date$</i>
Property changes on: grass-addons/grass7/raster/r.bioclim/r.bioclim.html
+ text/html
Added: svn:keywords
+ Author Date Id
+ native
Added: grass-addons/grass7/raster/r.bioclim/r.bioclim.py
--- grass-addons/grass7/raster/r.bioclim/r.bioclim.py (rev 0)
+++ grass-addons/grass7/raster/r.bioclim/r.bioclim.py 2014-05-19 08:14:15 UTC (rev 60331)
@@ -0,0 +1,433 @@
+#!/usr/bin/env python
+# MODULE: r.bioclim
+# AUTHOR(S): Markus Metz
+# PURPOSE: Calculates bioclimatic indices from time series
+# COPYRIGHT: (C) 2014 by the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+#%module
+#% description: Calcuates bioclimatic indices.
+#% keywords: raster
+#% keywords: time series
+#% overwrite: yes
+#%end
+#%option G_OPT_R_INPUTS
+#% key: tmin
+#% label: Monthly minimum temperatures
+#% description: Monthly minimum temperatures for 12 months
+#% required: YES
+#%end
+#% key: tmax
+#% label: Monthly maximum temperatures
+#% description: Monthly maximum temperatures for 12 months
+#% required: YES
+#%end
+#% key: tavg
+#% label: Monthly average temperatures
+#% description: Monthly average temperatures for 12 months
+#% required: NO
+#%end
+#% key: precipitation
+#% label: Monthly precipitation
+#% required: NO
+#%end
+#%option
+#% key: output
+#% type: string
+#% description: Prefix for output maps
+#% required: YES
+#%end
+#%option
+#% key: tinscale
+#% type: integer
+#% description: Scale factor for input temperature
+#% answer: 1
+#%end
+#%option
+#% key: toutscale
+#% type: integer
+#% description: Scale factor for output temperature
+#% answer: 10
+#%end
+#%Option
+#% key: workers
+#% type: integer
+#% required: no
+#% multiple: no
+#% options: 1-12
+#% answer: 1
+#% description: Number of parallel processes to launch
+#%End
+import sys
+import os
+import string
+import grass.script as grass
+import atexit
+def cleanup():
+ if tmp:
+ grass.run_command('g.mremove', rast = tmp, flags = 'f', quiet = True)
+def main():
+ tavg = options['tavg']
+ tmin = options['tmin']
+ tmax = options['tmax']
+ prec = options['precipitation']
+ outpre = options['output']
+ tinscale = options['tinscale']
+ toutscale = options['toutscale']
+ workers = int(options['workers'])
+ mapset = grass.gisenv()['MAPSET']
+ # count input maps
+ if len(tmin.split(',')) != 12:
+ grass.fatal(_("12 maps with minimum temperatures are required"))
+ if len(tmax.split(',')) != 12:
+ grass.fatal(_("12 maps with maximum temperatures are required"))
+ if tavg and len(tavg.split(',')) != 12:
+ grass.fatal(_("12 maps with average temperatures are required"))
+ if prec:
+ if len(prec.split(',')) != 12:
+ grass.fatal(_("12 maps with precipitation are required"))
+ tinscale = int(tinscale)
+ if tinscale <= 0:
+ grass.fatal(_("Input temperature scale must be positive"))
+ toutscale = int(toutscale)
+ if toutscale <= 0:
+ grass.fatal(_("Output temperature scale must be positive"))
+ pid = os.getpid()
+ # all temporary raster maps must follow this naming pattern
+ tmp = "%s.*.%d" % (outpre, pid)
+ tminl = tmin.split(',')
+ tmaxl = tmax.split(',')
+ ps = {}
+ if not tavg:
+ # calculate monthly averages from min and max
+ grass.message(_("Calculating monthly averages from min and max"))
+ e = "$ta = ($tmax - $tmin) / 2.0"
+ if workers > 1:
+ for i in range(0, 12, workers):
+ jend = 12 - i
+ if jend > workers:
+ jend = workers
+ for j in range(jend):
+ ta = "%s.tavg%02d.%d" % (outpre, (i + j + 1), pid)
+ ps[j] = grass.mapcalc_start(e, ta = ta, tmax = tmaxl[i + j], tmin = tminl[i + j])
+ ps[j].wait()
+ else:
+ for i in range(12):
+ ta = "%s.tavg%02d.%d" % (outpre, (i + 1), pid)
+ grass.mapcalc(e, ta = ta, tmax = tmaxl[i], tmin = tminl[i])
+ tavg = grass.read_command("g.mlist",
+ quiet = True,
+ type = 'rast',
+ pattern = '%s.tavg??.%d' % (outpre, pid),
+ separator = ',',
+ mapset= '.')
+ tavg = tavg.strip('\n')
+ tavgl = tavg.split(',')
+ # BIO1 = Annual Mean Temperature
+ grass.message(_("BIO1 = Annual Mean Temperature ..."))
+ output = outpre + '.bio01.' + str(pid)
+ grass.run_command('r.series', input = tavg, output = output, method = 'average')
+ grass.mapcalc("$bio = round(double($oscale) * $input / $iscale)",
+ bio = outpre + '.bio01',
+ oscale = toutscale, input = output, iscale = tinscale)
+ grass.run_command('g.remove', rast = output, quiet = True);
+ # BIO2 = Mean Diurnal Range (Mean of monthly (max temp - min temp))
+ grass.message(_("BIO2 = Mean Diurnal Range ..."))
+ e = "$tr = $tmax - $tmin"
+ if workers > 1:
+ jend = 12 - i
+ jend = workers
+ tr = "%s.tr%02d.%d" % (outpre, (i + j + 1), pid)
+ ps[j] = grass.mapcalc_start(e, tr = tr, tmax = tmaxl[i + j], tmin = tminl[i + j])
+ ps[j].wait()
+ else:
+ tr = "%s.tr%02d.%d" % (outpre, (i + 1), pid)
+ grass.mapcalc(e, tr = tr, tmax = tmaxl[i], tmin = tminl[i])
+ tr = grass.read_command("g.mlist",
+ quiet = True,
+ type = 'rast',
+ pattern = '%s.tr??.%d' % (outpre, pid),
+ separator = ',',
+ mapset= '.')
+ tr = tr.strip('\n')
+ output = outpre + '.bio02.' + str(pid)
+ grass.run_command('r.series', input = tr, output = output, method = 'average')
+ bio = outpre + '.bio02',
+ grass.run_command('g.mremove', rast = '%s.tr??.%d' % (outpre, pid), flags = 'f', quiet = True)
+ # BIO4 = Temperature Seasonality (standard deviation * 100)
+ grass.message(_("BIO4 = Temperature Seasonality ..."))
+ output = outpre + '.bio04.' + str(pid)
+ grass.run_command('r.series', input = tavg, output = output, method = 'stddev')
+ grass.mapcalc("$bio = round(100 * $biotmp / $iscale)",
+ bio = outpre + '.bio04',
+ biotmp = output,
+ iscale = tinscale)
+ # BIO5 = Max Temperature of Warmest Month
+ grass.message(_("BIO5 = Max Temperature of Warmest Month ..."))
+ output = outpre + '.bio05.' + str(pid)
+ grass.run_command('r.series', input = tmax, output = output, method = 'maximum')
+ grass.mapcalc("$bio = round(double($oscale) * $biotmp / $iscale)",
+ bio = outpre + '.bio05',
+ iscale = tinscale,
+ biotmp = output)
+ # BIO6 = Min Temperature of Coldest Month
+ grass.message(_("BIO6 = Min Temperature of Coldest Month ..."))
+ output = outpre + '.bio06.' + str(pid)
+ grass.run_command('r.series', input = tmin, output = output, method = 'minimum')
+ bio = outpre + '.bio06',
+ biotmp = output,
+ # BIO7 = Temperature Annual Range (BIO5-BIO6)
+ grass.message(_("BIO7 = Temperature Annual Range ..."))
+ grass.mapcalc("$bio = $bio5 - $bio6",
+ bio = outpre + '.bio07',
+ bio5 = outpre + '.bio05',
+ bio6 = outpre + '.bio06')
+ # BIO3 = Isothermality (BIO2/BIO7) (* 100)
+ grass.message(_("BIO3 = Isothermality (BIO2/BIO7) ..."))
+ grass.mapcalc("$bio = round(double($bio2) / $bio7 * 100)",
+ bio = outpre + '.bio03',
+ bio2 = outpre + '.bio02',
+ bio7 = outpre + '.bio07')
+ # mean of mean for each quarter year
+ grass.message(_("Mean temperature for each quarter year ..."))
+ for i in range(0, 12, 3):
+ tavgq = "%s.tavgq.%d.%d" % (outpre, i / 3, pid)
+ input = "%s,%s,%s" % (tavgl[i], tavgl[i + 1], tavgl[i + 2]),
+ output = tavgq, method = 'average')
+ # BIO10 = Mean Temperature of Warmest Quarter
+ # BIO11 = Mean Temperature of Coldest Quarter
+ grass.message(_("BIO10 = Mean Temperature of Warmest Quarter,"))
+ grass.message(_("BIO11 = Mean Temperature of Coldest Quarter ..."))
+ tavgq = grass.read_command("g.mlist",
+ quiet = True,
+ type = 'rast',
+ pattern = '%s.tavgq.?.%d' % (outpre, pid),
+ separator = ',',
+ mapset= '.')
+ tavgq = tavgq.strip("\n")
+ bio10 = outpre + '.bio10.' + str(pid)
+ bio11 = outpre + '.bio11.' + str(pid)
+ grass.run_command('r.series', input = tavgq,
+ output = "%s,%s" % (bio10, bio11),
+ method = 'maximum,minimum')
+ bio = outpre + '.bio10',
+ biotmp = bio10,
+ bio = outpre + '.bio11',
+ biotmp = bio11,
+ grass.run_command('g.remove', rast = "%s,%s" % (bio10, bio11), quiet = True);
+ if not prec:
+ sys.exit(1)
+ precl = prec.split(',')
+ # sum for each quarter year
+ grass.message(_("Precipitation for each quarter year ..."))
+ for i in range(4):
+ precq = "%s.precq.%d.%d" % (outpre, i + 1, pid)
+ j = i * 3
+ input = "%s,%s,%s" % (precl[j], precl[j + 1], precl[j + 2]),
+ output = precq, method = 'sum')
+ precq = grass.read_command("g.mlist",
+ quiet = True,
+ type = 'rast',
+ pattern = '%s.precq.?.%d' % (outpre, pid),
+ separator = ',',
+ mapset= '.')
+ precq = precq.strip("\n")
+ # warmest and coldest quarter
+ warmestq = "%s.warmestq.%d" % (outpre, pid)
+ coldestq = "%s.coldestq.%d" % (outpre, pid)
+ output = "%s,%s" % (warmestq, coldestq),
+ method = 'max_raster,min_raster')
+ tavgql = tavgq.split(',')
+ # wettest and driest quarter
+ wettestq = "%s.wettestq.%d" % (outpre, pid)
+ driestq = "%s.driestq.%d" % (outpre, pid)
+ grass.run_command('r.series', input = precq,
+ output = "%s,%s" % (wettestq, driestq),
+ # BIO8 = Mean Temperature of Wettest Quarter
+ grass.message(_("BIO8 = Mean Temperature of Wettest Quarter ..."))
+ grass.mapcalc("$bio = round(graph($wettestq, \
+ 0, $tavgq0, \
+ 1, $tavgq1, \
+ 2, $tavgq2, \
+ 3, $tavgq3) * $oscale / $iscale)",
+ bio = outpre + '.bio08',
+ wettestq = wettestq,
+ tavgq0 = tavgql[0], tavgq1 = tavgql[1],
+ tavgq2 = tavgql[2], tavgq3 = tavgql[3],
+ oscale = toutscale, iscale = tinscale)
+ # BIO9 = Mean Temperature of Driest Quarter
+ grass.message(_("BIO9 = Mean Temperature of Driest Quarter ..."))
+ grass.mapcalc("$bio = round(graph($driestq, \
+ 0, $tavgq0, \
+ 1, $tavgq1, \
+ 2, $tavgq2, \
+ bio = outpre + '.bio09',
+ driestq = driestq,
+ # BIO12 = Annual Precipitation
+ grass.message(_("BIO12 = Annual Precipitation ..."))
+ output = outpre + '.bio12'
+ grass.run_command('r.series', input = prec, output = output, method = 'sum')
+ # BIO13 = Precipitation of Wettest Month
+ # BIO14 = Precipitation of Driest Month
+ grass.message(_("BIO13 = Precipitation of Wettest Month,"))
+ grass.message(_("BIO14 = Precipitation of Driest Month ..."))
+ bio13 = outpre + '.bio13'
+ bio14 = outpre + '.bio14'
+ output = "%s,%s" % (bio13, bio14),
+ # BIO15 = Precipitation Seasonality (Coefficient of Variation)
+ grass.message(_("BIO15 = Precipitation Seasonality ..."))
+ precavg = "%s.precavg.%d" % (outpre, pid)
+ precstddev = "%s.precstddev.%d" % (outpre, pid)
+ output = "%s,%s" % (precavg, precstddev),
+ method = 'average,stddev')
+ grass.mapcalc("$bio = round(100.0 * $precstddev / $precavg)",
+ bio = outpre + '.bio15',
+ precstddev = precstddev,
+ precavg = precavg)
+ # BIO16 = Precipitation of Wettest Quarter
+ # BIO17 = Precipitation of Driest Quarter
+ grass.message(_("BIO16 = Precipitation of Wettest Quarter,"))
+ grass.message(_("BIO17 = Precipitation of Driest Quarter ..."))
+ bio16 = outpre + '.bio16'
+ bio17 = outpre + '.bio17'
+ output = "%s,%s" % (bio16, bio17),
+ precql = precq.split(',')
+ # BIO18 = Precipitation of Warmest Quarter
+ grass.message(_("BIO18 = Precipitation of Warmest Quarter ..."))
+ grass.mapcalc("$bio = round(graph($warmestq, \
+ 0, $precq0, \
+ 1, $precq1, \
+ 2, $precq2, \
+ 3, $precq3))",
+ bio = outpre + '.bio18',
+ warmestq = warmestq,
+ precq0 = precql[0], precq1 = precql[1],
+ precq2 = precql[2], precq3 = precql[3])
+ # BIO19 = Precipitation of Coldest Quarter
+ grass.message(_("BIO19 = Precipitation of Coldest Quarter ..."))
+ grass.mapcalc("$bio = round(graph($coldestq, \
+ 0, $precq0, \
+ 1, $precq1, \
+ 2, $precq2, \
+ 3, $precq3))",
+ coldestq = coldestq,
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ tmp = None
+ atexit.register(cleanup)
+ main()
Property changes on: grass-addons/grass7/raster/r.bioclim/r.bioclim.py
Added: svn:executable
+ text/x-python
+ native
