[GRASS-SVN] r60334 - grass-addons/grass6/raster/r.out.mbtiles_prep
svn_grass at osgeo.org
Mon May 19 01:59:14 PDT 2014
Author: hamish
Date: 2014-05-19 01:59:14 -0700 (Mon, 19 May 2014)
New Revision: 60334
grass-addons/grass6/raster/r.out.mbtiles_prep/r.out.mbtiles_prep
add fixme note about only storing unique tiles, add spec URLs, add some more metadata entries
Modified: grass-addons/grass6/raster/r.out.mbtiles_prep/r.out.mbtiles_prep
--- grass-addons/grass6/raster/r.out.mbtiles_prep/r.out.mbtiles_prep 2014-05-19 08:33:40 UTC (rev 60333)
+++ grass-addons/grass6/raster/r.out.mbtiles_prep/r.out.mbtiles_prep 2014-05-19 08:59:14 UTC (rev 60334)
@@ -23,6 +23,8 @@
# https://github.com/geopaparazzi/geopaparazzi/wiki/.mapurl-Converting-Tile-Set-to-.mbtiles
# https://github.com/geopaparazzi/geopaparazzi/wiki/.mapurl-parameters
+# https://github.com/mapbox/mbtiles-spec/blob/master/1.1/spec.md
+# https://github.com/geopaparazzi/geopaparazzi/wiki/mbtiles-Implementation
#%Module
#% description: Export GRASS raster as a TMS tree ready for converting to mbtiles format.
@@ -487,14 +489,23 @@
CREATE TABLE metadata (name text, value text);
INSERT INTO metadata VALUES ('name', '`basename "$OUTFILE"`');
INSERT INTO metadata VALUES ('type', 'baselayer');
-INSERT INTO metadata VALUES ('version', '1');
+INSERT INTO metadata VALUES ('version', '1.0');
INSERT INTO metadata VALUES ('description', '$TITLE_CLEAN');
INSERT INTO metadata VALUES ('format', '$ext');
INSERT INTO metadata VALUES ('bounds', '$ll_w,$ll_s,$ll_e,$ll_n');
+INSERT INTO metadata VALUES ('center', '$$ll_clon,$ll_clat');
+INSERT INTO metadata VALUES ('minzoom', '$minzoom');
+INSERT INTO metadata VALUES ('maxzoom', '$maxzoom');
CREATE TABLE tiles (zoom_level integer, tile_column integer, tile_row integer, tile_data blob);
BEGIN TRANSACTION;
EOF
+ # FIXME: keep DB small by checking for duplicate tile images (ocean, wasteland)
+ # Make the 'tiles' table a view, then replace 'blob' with (tile_id text),
+ # and in the 'images' table keep unique tiles in (tile_data blob, tile_id text).
+ # perhaps try 'md5sum | sort | uniq -d' to weed out duplicates?
+ # see https://github.com/geopaparazzi/geopaparazzi/wiki/mbtiles-Implementation
for file in `find "$OUTFILE" -name "*.$ext"` ; do
crop=`echo "$file" | sed -e "s|.*$OUTFILE/||" -e "s|\.$ext||"`
