[GRASS-SVN] r60379 - grass/branches/releasebranch_7_0/display/d.legend
svn_grass at osgeo.org
Tue May 20 19:24:08 PDT 2014
Author: hamish
Date: 2014-05-20 19:24:08 -0700 (Tue, 20 May 2014)
New Revision: 60379
Added:
grass/branches/releasebranch_7_0/display/d.legend/get_stats.c
grass/branches/releasebranch_7_0/display/d.legend/histogram.c
grass/branches/releasebranch_7_0/display/d.legend/Makefile
grass/branches/releasebranch_7_0/display/d.legend/d.legend.html
grass/branches/releasebranch_7_0/display/d.legend/local_proto.h
grass/branches/releasebranch_7_0/display/d.legend/main.c
add support for histogram sidebars (#1049); add support for 3D raster map legends (#2083, thanks Vaclav); display map data units, if known [merge from trunk]
Property changes on: grass/branches/releasebranch_7_0/display/d.legend
___________________________________________________________________
Modified: svn:ignore
- OBJ.*
+ OBJ.*
*.tmp.html
Modified: grass/branches/releasebranch_7_0/display/d.legend/Makefile
--- grass/branches/releasebranch_7_0/display/d.legend/Makefile 2014-05-20 16:04:53 UTC (rev 60378)
+++ grass/branches/releasebranch_7_0/display/d.legend/Makefile 2014-05-21 02:24:08 UTC (rev 60379)
@@ -2,8 +2,8 @@
PGM = d.legend
-LIBES = $(DISPLAYLIB) $(RASTERLIB) $(GISLIB) $(MATHLIB)
-DEPENDENCIES = $(DISPLAYDEP) $(RASTERDEP) $(GISDEP)
+LIBES = $(DISPLAYLIB) $(RASTERLIB) $(RASTER3DLIB) $(GISLIB) $(MATHLIB)
+DEPENDENCIES = $(DISPLAYDEP) $(RASTERDEP) $(RASTER3DDEP) $(GISDEP)
include $(MODULE_TOPDIR)/include/Make/Module.make
Modified: grass/branches/releasebranch_7_0/display/d.legend/d.legend.html
--- grass/branches/releasebranch_7_0/display/d.legend/d.legend.html 2014-05-20 16:04:53 UTC (rev 60378)
+++ grass/branches/releasebranch_7_0/display/d.legend/d.legend.html 2014-05-21 02:24:08 UTC (rev 60379)
@@ -1,7 +1,7 @@
<h2>DESCRIPTION</h2>
-<em>d.legend</em> displays a legend for a user-specified
-raster map layer in the active frame on the graphics monitor.
+<em>d.legend</em> displays a legend for a user-specified raster map or
+3D raster map layer in the active frame on the graphics monitor.
<p>
The legend's default size is based on the dimensions of the
active frame, specifically its height. <em>d.legend</em> will only
@@ -65,10 +65,14 @@
output with a meaningful number of significant digits. For very small values,
numbers will be expressed in scientific notation, e.g. "1.7e-9".
<p>
-Note that old scripts which relied on setting <b>lines</b> greater than the
-number of categories to scale the legend may no longer produce the desired
-output, although the auto-scaling should still produce something that looks
-good in this case.
+When the <b>-d</b> flag is used to display a histogram distribution along
+side the smoothed gradient legend, note that the statistics are calculated
+on the <i>current computational region</i> settings set by <em>g.region</em>.
+The default <b>range</b> however covers the entire natural bounds of the input map.
+If the histogram appears empty, check your region settings.
+<p>
+If the raster map's <i>units</i> metadata has been set with the
+<em>r.support</em> module then it will be displayed along side the legend.
<h2>SEE ALSO</h2>
@@ -76,14 +80,15 @@
<em>
<a href="d.barscale.html">d.barscale</a>,
<a href="d.colortable.html">d.colortable</a>,
-<a href="d.erase.html">d.erase</a>,
<a href="d.font.html">d.font</a>,
<a href="d.grid.html">d.grid</a>,
<a href="d.rast.html">d.rast</a>,
<a href="d.rast.leg.html">d.rast.leg</a>,
<a href="d.text.html">d.text</a>,
<a href="d.vect.thematic.html">d.vect.thematic</a>,
-<a href="r.reclass.html">r.reclass</a>
+<a href="r.reclass.html">r.reclass</a>,
+<a href="r.stats.html">r.stats</a>,
+<a href="r3.stats.html">r3.stats</a>
</em>
Copied: grass/branches/releasebranch_7_0/display/d.legend/get_stats.c (from rev 60093, grass/trunk/display/d.legend/get_stats.c)
--- grass/branches/releasebranch_7_0/display/d.legend/get_stats.c (rev 0)
+++ grass/branches/releasebranch_7_0/display/d.legend/get_stats.c 2014-05-21 02:24:08 UTC (rev 60379)
@@ -0,0 +1,149 @@
+#include <stdio.h>
+#include <unistd.h>
+#include <grass/gis.h>
+#include <grass/raster.h>
+#include <grass/spawn.h>
+#include "local_proto.h"
+void run_stats(const char *mapname, int nsteps, const char *tempfile,
+ int map_type)
+ char buf[32];
+ const char *argv[12];
+ int argc = 0;
+ if (map_type == MAP_TYPE_RASTER2D) {
+ argv[argc++] = "r.stats";
+ argv[argc++] = "-r";
+ else
+ argv[argc++] = "r3.stats";
+ argv[argc++] = "-c";
+ argv[argc++] = mapname;
+ sprintf(buf, "nsteps=%d", nsteps);
+ argv[argc++] = buf;
+ argv[argc++] = SF_REDIRECT_FILE;
+ argv[argc++] = SF_STDOUT;
+ argv[argc++] = SF_MODE_OUT;
+ argv[argc++] = tempfile;
+ argv[argc++] = NULL;
+ if (G_vspawn_ex(argv[0], argv) != 0)
+ G_fatal_error("error running r.stats");
+/* linked list of stats */
+void get_stats(const char *mapname, struct stat_list *dist_stats, int nsteps,
+ int map_type)
+ char buf[1024]; /* input buffer for reading stats */
+ int done = FALSE;
+ char *tempfile; /* temp file name */
+ FILE *fd; /* temp file pointer */
+ int is_fp;
+ struct FPRange fp_range;
+ long int cat; /* a category value */
+ long int stat; /* a category stat value */
+ struct stat_node *ptr = NULL;
+ int first;
+ /* write stats to a temp file */
+ tempfile = G_tempfile();
+ is_fp = Rast_map_is_fp(mapname, "");
+ if (is_fp) {
+ if (Rast_read_fp_range(mapname, "", &fp_range) <= 0)
+ G_fatal_error("Can't read frange file");
+ run_stats(mapname, nsteps, tempfile, map_type);
+ /* open temp file and read the stats into a linked list */
+ fd = fopen(tempfile, "r");
+ if (fd == NULL) {
+ perror("opening r.stats output file");
+ G_fatal_error("unable to continue.");
+ dist_stats->ptr = NULL;
+ dist_stats->count = 0;
+ dist_stats->sumstat = 0;
+ first = TRUE;
+ while (!done) {
+ if (fgets(buf, sizeof(buf), fd) != NULL) {
+ /* WARNING!!!!!!
+ * this will be very wrong if type!=COUNT
+ * since the stat prodcued by r.stats will be a floating point value
+ * possibly less than 1 (shapiro)
+ if (sscanf(buf, "* %ld", &stat) == 1) {
+ dist_stats->null_stat = stat;
+ if (stat > dist_stats->maxstat && nodata)
+ dist_stats->maxstat = stat;
+ if (stat < dist_stats->minstat && nodata)
+ dist_stats->minstat = stat;
+ if (nodata)
+ dist_stats->sumstat += stat;
+ else if (sscanf(buf, "%ld %ld", &cat, &stat) == 2) {
+ /* count stats */
+ dist_stats->count++;
+ /* sum stats */
+ /* a max or a min stat? */
+ if (first) {
+ dist_stats->maxcat = cat;
+ dist_stats->mincat = cat;
+ first = FALSE;
+ if (stat > dist_stats->maxstat)
+ if (stat < dist_stats->minstat)
+ /* a max or a min cat? */
+ if (cat > dist_stats->maxcat)
+ if (cat < dist_stats->mincat)
+ /* put it in the list */
+ if (dist_stats->ptr == NULL) {
+ /* first in list */
+ dist_stats->ptr = (struct stat_node *)
+ G_malloc(sizeof(struct stat_node));
+ dist_stats->ptr->cat = cat;
+ dist_stats->ptr->stat = stat;
+ dist_stats->ptr->next = NULL;
+ ptr = dist_stats->ptr;
+ else {
+ ptr->next = (struct stat_node *)
+ ptr->next->cat = cat;
+ ptr->next->stat = stat;
+ ptr->next->next = NULL; /* mod: shapiro */
+ ptr = ptr->next;
+ else
+ done = TRUE;
+ fclose(fd);
+ unlink(tempfile);
Copied: grass/branches/releasebranch_7_0/display/d.legend/histogram.c (from rev 60093, grass/trunk/display/d.legend/histogram.c)
--- grass/branches/releasebranch_7_0/display/d.legend/histogram.c (rev 0)
+++ grass/branches/releasebranch_7_0/display/d.legend/histogram.c 2014-05-21 02:24:08 UTC (rev 60379)
@@ -0,0 +1,94 @@
+/* histogram.c:
+ * Draws a histogram along the left side of a smooth gradient legend
+ * (stats fetching code adapted from d.histogram)
+ * Copyright (C) 2014 by Hamish Bowman, and the GRASS Development Team*
+ * This program is free software under the GPL (>=v2)
+ * Read the COPYING file that comes with GRASS for details.
+#include <grass/display.h>
+void draw_histogram(const char *map_name, int x0, int y0, int width,
+ int height, int color, int flip, int horiz,
+ int map_type)
+ int i, nsteps;
+ long cell_count;
+ double max_width, width_mult, dx;
+ struct stat_list dist_stats;
+ struct stat_node *ptr;
+ if (horiz) {
+ max_width = height * 1.75;
+ nsteps = width - 3;
+ else {
+ max_width = width * 1.75;
+ nsteps = height - 3;
+ /* get the distribution statistics */
+ get_stats(map_name, &dist_stats, nsteps, map_type);
+ width_mult = max_width / dist_stats.maxstat;
+ D_use_color(color);
+ D_begin();
+ ptr = dist_stats.ptr;
+ for (i = dist_stats.mincat; i <= dist_stats.maxcat; i++) {
+ if (!ptr)
+ break;
+ if (ptr->cat == i) { /* AH-HA!! found the stat */
+ cell_count = ptr->stat;
+ if (ptr->next != NULL)
+ ptr = ptr->next;
+ else { /* we have to look for the stat */
+ /* loop until we find it, or pass where it should be */
+ while (ptr->cat < i && ptr->next != NULL)
+ ptr = ptr->next;
+ ptr = ptr->next;
+ else /* stat cannot be found */
+ G_debug(4, "No matching stat found, i=%d", i);
+ if (!cell_count)
+ continue;
+ dx = cell_count * width_mult;
+ if (horiz) {
+ if (flip)
+ D_move_abs(x0 + width - i - 1, y0 - 1);
+ else
+ D_move_abs(x0 + i + 1, y0 - 1);
+ D_cont_rel(0, -dx);
+ else { /* vertical */
+ if (flip)
+ D_move_abs(x0 - 1, y0 - 1 + height - i);
+ else
+ D_move_abs(x0 - 1, y0 + 1 + i);
+ D_cont_rel(-dx, 0);
+ D_close();
+ D_end();
+ D_stroke();
Modified: grass/branches/releasebranch_7_0/display/d.legend/local_proto.h
--- grass/branches/releasebranch_7_0/display/d.legend/local_proto.h 2014-05-20 16:04:53 UTC (rev 60378)
+++ grass/branches/releasebranch_7_0/display/d.legend/local_proto.h 2014-05-21 02:24:08 UTC (rev 60379)
@@ -1,5 +1,34 @@
-/* main.c */
-char *G_chop(char *s);
+#define MAP_TYPE_RASTER2D 1
+#define MAP_TYPE_RASTER3D 2
+/* possibles for the future:
+#define MAP_TYPE_VECTOR 3
+#define MAP_TYPE_RULES 4
-/* box.c */
-int get_legend_box(int *, int *, int *, int *);
+struct stat_node
+ long int cat; /* cell-file category value */
+ long int stat; /* statistic: number of cells with that cat */
+ struct stat_node *next; /* pointer to next stat_node in list */
+struct stat_list
+ struct stat_node *ptr; /* pointer to first stat_node in list */
+ long int count, /* number of stat_nodes in list
+ (not counting null cells) */
+ null_stat, /* stats for null cell */
+ maxstat, /* max. statistic in list */
+ minstat, /* min. statistic in list */
+ sumstat, /* sum of all statistics in list */
+ maxcat, /* max. cell-file category value in list */
+ mincat; /* min. cell-file category value in list */
+/* histogram.c */
+void draw_histogram(const char *, int, int, int, int, int, int, int, int);
+/* get_stats.c */
+void get_stats(const char *, struct stat_list *, int, int);
+void run_stats(const char *, int, const char *, int);
Modified: grass/branches/releasebranch_7_0/display/d.legend/main.c
--- grass/branches/releasebranch_7_0/display/d.legend/main.c 2014-05-20 16:04:53 UTC (rev 60378)
+++ grass/branches/releasebranch_7_0/display/d.legend/main.c 2014-05-21 02:24:08 UTC (rev 60379)
@@ -29,6 +29,7 @@
#include <math.h>
+#include <grass/raster3d.h>
#include <grass/glocale.h>
@@ -38,32 +39,29 @@
char buff[512];
char *map_name;
- int black;
+ int maptype;
+ int black, white, color;
int cats_num;
- int color;
int cur_dot_row;
int do_cats;
int dots_per_line;
- int thin;
int i, j, k;
- int lines, steps;
+ int thin, lines, steps;
int fp;
double t, b, l, r;
int hide_catnum, hide_catstr, hide_nodata, do_smooth;
char *cstr;
- int white;
- double x_box[5];
- double y_box[5];
+ double x_box[5], y_box[5];
struct Categories cats;
struct Colors colors;
struct GModule *module;
- struct Option *opt_input, *opt_color, *opt_lines, *opt_thin,
- *opt_labelnum, *opt_at, *opt_use, *opt_range,
+ struct Option *opt_rast2d, *opt_rast3d, *opt_color, *opt_lines,
+ *opt_thin, *opt_labelnum, *opt_at, *opt_use, *opt_range,
*opt_font, *opt_path, *opt_charset, *opt_fontsize;
- struct Flag *hidestr, *hidenum, *hidenodata, *smooth, *flipit, *size;
+ struct Flag *hidestr, *hidenum, *hidenodata, *smooth, *flipit, *histo;
struct Range range;
struct FPRange fprange;
- CELL min_ind, max_ind, null_cell;
+ CELL min_ind, max_ind;
DCELL dmin, dmax, val;
CELL min_colr, max_colr;
DCELL min_dcolr, max_dcolr;
@@ -77,6 +75,7 @@
double *catlist, maxCat;
int catlistCount, use_catlist;
double fontsize;
+ char *units;
/* Initialize the GIS calls */
@@ -86,15 +85,18 @@
G_add_keyword(_("display"));
G_add_keyword(_("cartography"));
module->description =
- _("Displays a legend for a raster map in the active frame "
+ _("Displays a legend for a raster map (2 or 3D) in the active frame "
"of the graphics monitor.");
- opt_input = G_define_standard_option(G_OPT_R_MAP);
- opt_input->description = _("Name of raster map");
+ opt_rast2d = G_define_standard_option(G_OPT_R_MAP);
+ opt_rast2d->key = "rast";
+ opt_rast2d->required = NO;
+ opt_rast2d->guisection = _("Input");
- opt_color = G_define_standard_option(G_OPT_C_FG);
- opt_color->label = _("Text color");
- opt_color->guisection = _("Font settings");
+ opt_rast3d = G_define_standard_option(G_OPT_R3_MAP);
+ opt_rast3d->key = "rast3d";
+ opt_rast3d->required = NO;
+ opt_rast3d->guisection = _("Input");
opt_lines = G_define_option();
opt_lines->key = "lines";
@@ -111,7 +113,8 @@
opt_thin->required = NO;
opt_thin->answer = "1";
opt_thin->options = "1-1000";
- opt_thin->description = _("Thinning factor (thin=10 gives cats 0,10,20...)");
+ opt_thin->description =
+ _("Thinning factor (thin=10 gives cats 0,10,20...)");
opt_thin->guisection = _("Advanced");
opt_labelnum = G_define_option();
@@ -119,23 +122,25 @@
opt_labelnum->type = TYPE_INTEGER;
opt_labelnum->answer = "5";
opt_labelnum->options = "2-100";
- opt_labelnum->description = _("Number of text labels for smooth gradient legend");
+ opt_labelnum->description =
+ _("Number of text labels for smooth gradient legend");
opt_labelnum->guisection = _("Gradient");
opt_at = G_define_option();
opt_at->key = "at";
opt_at->key_desc = "bottom,top,left,right";
- opt_at->type = TYPE_DOUBLE; /* needs to be TYPE_DOUBLE to get past options check */
+ opt_at->type = TYPE_DOUBLE; /* needs to be TYPE_DOUBLE to get past options check */
opt_at->required = NO;
opt_at->options = "0-100";
opt_at->label =
- _("Size and placement as percentage of screen coordinates (0,0 is lower left)");
+ _("Size and placement as percentage of screen coordinates "
+ "(0,0 is lower left)");
opt_at->description = opt_at->key_desc;
opt_at->answer = NULL;
opt_use = G_define_option();
opt_use->key = "use";
- opt_use->type = TYPE_DOUBLE; /* string as it is fed through the parser? */
+ opt_use->type = TYPE_DOUBLE; /* string as it is fed through the parser? */
opt_use->required = NO;
opt_use->description =
_("List of discrete category numbers/values for legend");
@@ -145,12 +150,16 @@
opt_range = G_define_option();
opt_range->key = "range";
opt_range->key_desc = "min,max";
- opt_range->type = TYPE_DOUBLE; /* should it be type_double or _string ?? */
+ opt_range->type = TYPE_DOUBLE; /* should it be type_double or _string ?? */
opt_range->required = NO;
opt_range->description =
_("Use a subset of the map range for the legend (min,max)");
opt_range->guisection = _("Subset");
+ opt_color = G_define_standard_option(G_OPT_C_FG);
+ opt_color->label = _("Text color");
+ opt_color->guisection = _("Font settings");
opt_font = G_define_option();
opt_font->key = "font";
opt_font->type = TYPE_STRING;
@@ -207,17 +216,29 @@
flipit->description = _("Flip legend");
flipit->guisection = _("Advanced");
- size = G_define_flag();
- size->key = 's';
- size->description = _("Font size is height in pixels");
- size->guisection = _("Font settings");
+ histo = G_define_flag();
+ histo->key = 'd';
+ histo->description = _("Add histogram to smoothed legend");
+ histo->guisection = _("Gradient");
/* Check command line */
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
+ /* FIXME: add GUI launching logic to G_parser() call */
+ if ((opt_rast2d->answer && opt_rast3d->answer) ||
+ !(opt_rast2d->answer || opt_rast3d->answer))
+ G_fatal_error(_("Please specify a single map name. To launch GUI use d.legend --ui."));
- map_name = opt_input->answer;
+ if (opt_rast2d->answer) {
+ map_name = opt_rast2d->answer;
+ maptype = MAP_TYPE_RASTER2D;
+ else {
+ map_name = opt_rast3d->answer;
+ maptype = MAP_TYPE_RASTER3D;
hide_catstr = hidestr->answer; /* note hide_catstr gets changed and re-read below */
hide_catnum = hidenum->answer;
@@ -225,11 +246,6 @@
do_smooth = smooth->answer;
flip = flipit->answer;
- if (opt_fontsize->answer != NULL)
- fontsize = atof(opt_fontsize->answer);
- else
- fontsize = 12; /* dummy placeholder, should never be called */
color = D_parse_color(opt_color->answer, TRUE);
if (opt_lines->answer != NULL)
@@ -275,34 +291,46 @@
+ if (maptype == MAP_TYPE_RASTER2D) {
+ if (Rast_read_colors(map_name, "", &colors) == -1)
+ G_fatal_error(_("Color file for <%s> not available"), map_name);
- if (Rast_read_colors(map_name, "", &colors) == -1)
- G_fatal_error(_("Color file for <%s> not available"), map_name);
+ fp = Rast_map_is_fp(map_name, "");
+ Rast_read_cats(map_name, "", &cats);
+ else {
+ if (Rast3d_read_colors(map_name, "", &colors) == -1)
- fp = Rast_map_is_fp(map_name, "");
+ fp = TRUE; /* currently raster 3D is always floating point */
+ Rast3d_read_cats(map_name, "", &cats);
if (fp && !use_catlist) {
do_smooth = TRUE;
/* fprintf(stderr, "FP map found - switching gradient legend on\n"); */
flip = !flip;
- if (Rast_read_cats(map_name, "", &cats) == -1)
- G_warning(_("Category file for <%s> not available"), map_name);
- Rast_set_c_null_value(&null_cell, 1);
if (D_open_driver() != 0)
- G_fatal_error(_("No graphics device selected. "
+ G_fatal_error(_("No graphics device selected. "
"Use d.mon to select graphics device."));
white = D_translate_color(DEFAULT_FG_COLOR);
black = D_translate_color(DEFAULT_BG_COLOR);
if (opt_font->answer)
D_font(opt_font->answer);
else if (opt_path->answer)
D_font(opt_path->answer);
+ if (opt_fontsize->answer != NULL)
+ fontsize = atof(opt_fontsize->answer);
+ else
+ fontsize = 12; /* dummy placeholder, should never be called */
if (opt_charset->answer)
D_encoding(opt_charset->answer);
@@ -321,11 +349,16 @@
Y0 = 88;
X0 = 3;
X1 = 7;
+ if (histo->answer) {
+ X0 += 5;
+ X1 += 5;
x0 = l + (int)((r - l) * X0 / 100.);
x1 = l + (int)((r - l) * X1 / 100.);
- y0 = t + (int)((b - t) * (100. - Y0) / 100.); /* make lower left the origin */
+ y0 = t + (int)((b - t) * (100. - Y0) / 100.); /* make lower left the origin */
y1 = t + (int)((b - t) * (100. - Y1) / 100.);
if (y0 > y1) { /* allow for variety in order of corner */
@@ -523,13 +556,19 @@
sprintf(DispFormat, "%%2d");
- else { /* is fp */
- if (Rast_read_fp_range(map_name, "", &fprange) == -1)
- G_fatal_error(_("Range information for <%s> not available"),
- map_name);
+ else { /* is fp */
+ if (Rast_read_fp_range(map_name, "", &fprange) == -1)
+ G_fatal_error(_("Range information for <%s> not available"),
+ map_name);
+ else {
+ if (Rast3d_read_range(map_name, "", &fprange) == -1)
+ map_name);
Rast_get_fp_range_min_max(&fprange, &dmin, &dmax);
Rast_get_d_color_range(&min_dcolr, &max_dcolr, &colors);
if (UserRange) {
@@ -648,6 +687,7 @@
1);
cstr = Rast_get_c_cat(&tcell, &cats);
if (!cstr[0]) /* no cats found, disable str output */
hide_catstr = 1;
else
@@ -676,7 +716,7 @@
- /* this probably shouldn't happen mid-loop as text sizes
+ /* this probably shouldn't happen mid-loop as text sizes
might not end up being uniform, but it's a start */
if (strlen(buff) > MaxLabelLen)
MaxLabelLen = strlen(buff);
@@ -716,24 +756,24 @@
D_pos_abs(x1 + 4, y0 + ppl * k + txsiz / 2);
else {
- /* text width is 0.81 of text height? so even though we set width
+ /* text width is 0.81 of text height? so even though we set width
to txsiz with D_text_size(), we still have to reduce.. hmmm */
if (!k) /* first */
D_pos_abs(x0 - (strlen(buff) * txsiz * .81 / 2),
- y1 + 4 + txsiz);
+ y1 + 4 + txsiz);
else if (k == steps - 1) /* last */
D_pos_abs(x1 - (strlen(buff) * txsiz * .81 / 2),
- y1 + 4 + txsiz);
+ y1 + 4 + txsiz);
else
D_pos_abs(x0 + ppl * k -
- y1 + 4 + txsiz);
+ (strlen(buff) * txsiz * .81 / 2),
+ y1 + 4 + txsiz);
- if(color)
+ if (color)
D_text(buff);
- } /*for */
+ } /* for */
lleg = y1 - y0;
wleg = x1 - x0;
@@ -760,8 +800,42 @@
D_end();
D_stroke();
+ /* print units label, if present */
+ units = Rast_read_units(map_name, "");
+ else
+ units = "";
+/* FIXME: does the raster3d really need to be opened to read the units?
+ units = Rast3d_get_unit(map_fid); */
+ if (!units)
+ units = "";
+ if(strlen(units)) {
+ /* D_text_size() should be already set */
+ if (horiz)
+ D_pos_abs((x0 + x1)/2. - (strlen(units) * txsiz * 0.81)/2,
+ y1 + (txsiz * 3));
+ else
+ D_pos_abs(x1 - 4, y0 - (txsiz * 1.75));
+ D_text(units);
+ /* display sidebar histogram, if requested */
+ if (opt_range->answer != NULL)
+ G_warning(_("Histogram constrained by range not yet implemented"));
+ else
+ draw_histogram(map_name, x0, y0, wleg, lleg, color, flip,
+ horiz, maptype);
- else { /* non FP, no smoothing */
+ else { /* non FP, no smoothing */
int true_l, true_r;
double txsiz;
@@ -908,11 +982,11 @@
else { /* is fp */
if (!flip) {
- if(use_catlist)
+ if (use_catlist)
/* pass through format exactly as given by the user in
the use= command line parameter (helps with log scale) */
sprintf(buff, "%s", opt_use->answers[i]);
- else
+ else
/* automatically generated/tuned decimal precision format */
sprintf(buff, DispFormat, catlist[i]);
@@ -926,7 +1000,7 @@
D_pos_abs((l + 3 + dots_per_line), (cur_dot_row) - 3);
- if(color)
+ if (color)
D_text(buff);
@@ -953,13 +1027,13 @@
D_use_color(white);
D_pos_abs((l + 3 + dots_per_line), (cur_dot_row));
- if(color)
+ if (color)
D_text(buff);
D_save_command(G_recreate_command());
D_close_driver();
exit(EXIT_SUCCESS);
