[GRASS-SVN] r60388 - grass-addons/grass7/raster/r.area
svn_grass at osgeo.org
Wed May 21 02:51:19 PDT 2014
Author: zarch
Date: 2014-05-21 02:51:19 -0700 (Wed, 21 May 2014)
New Revision: 60388
grass-addons/grass7/raster/r.area/main.c
Fix typo: treshold => threshold
Modified: grass-addons/grass7/raster/r.area/main.c
--- grass-addons/grass7/raster/r.area/main.c 2014-05-21 08:24:32 UTC (rev 60387)
+++ grass-addons/grass7/raster/r.area/main.c 2014-05-21 09:51:19 UTC (rev 60388)
@@ -3,7 +3,7 @@
* MODULE: r.area
* AUTHOR(S): Jarek Jasiewicz <jarekj amu.edu.pl>
* PURPOSE: Calculate area of clumped areas. Remove areas smaller than
- * given threshold.
+ * given threshold.
* COPYRIGHT: (C) 1999-2010 by the GRASS Development Team
@@ -25,7 +25,7 @@
struct GModule *module;
- struct Option *input, *output, *par_treshold;
+ struct Option *input, *output, *par_threshold;
struct Flag *flag_binary;
struct Cell_head cellhd;
@@ -34,7 +34,7 @@
char *mapset;
int nrows, ncols;
- int binary, treshold;
+ int binary, threshold;
int row, col;
int infd, outfd;
CELL *in_buf;
@@ -58,11 +58,11 @@
output = G_define_standard_option(G_OPT_R_OUTPUT);
output->description = _("Map with area size (in cells)");
- par_treshold = G_define_option(); /* input stream mask file - optional */
- par_treshold->key = "treshold";
- par_treshold->type = TYPE_INTEGER;
- par_treshold->answer = "0";
- par_treshold->description = _("Remove areas lower than (0 for none):");
+ par_threshold = G_define_option(); /* input stream mask file - optional */
+ par_threshold->key = "threshold";
+ par_threshold->type = TYPE_INTEGER;
+ par_threshold->answer = "0";
+ par_threshold->description = _("Remove areas lower than (0 for none):");
flag_binary = G_define_flag();
flag_binary->key = 'b';
@@ -73,7 +73,7 @@
exit(EXIT_FAILURE);
- treshold = atof(par_treshold->answer);
+ threshold = atof(par_threshold->answer);
binary = (flag_binary->answer != 0);
mapset = (char *)G_find_raster2(input->answer, "");
@@ -114,15 +114,15 @@
} /* end for row */
- if (treshold) {
+ if (threshold) {
for (i = 1; i < c_max; ++i)
- if (ncells[i] < treshold)
+ if (ncells[i] < threshold)
ncells[i] = -1;
if (binary) {
- ncells[i] = ncells[i] < treshold ? -1 : 1;
+ ncells[i] = ncells[i] < threshold ? -1 : 1;
outfd = Rast_open_new(output->answer, CELL_TYPE);
