[GRASS-SVN] r60411 - grass/trunk/lib/python/pygrass/docs
svn_grass at osgeo.org
Thu May 22 06:44:29 PDT 2014
Author: lucadelu
Date: 2014-05-22 06:44:29 -0700 (Thu, 22 May 2014)
New Revision: 60411
grass/trunk/lib/python/pygrass/docs/Makefile
pygrass: set html documentation output to main html grass documentation; remove superfluous output formats
Modified: grass/trunk/lib/python/pygrass/docs/Makefile
--- grass/trunk/lib/python/pygrass/docs/Makefile 2014-05-22 13:43:43 UTC (rev 60410)
+++ grass/trunk/lib/python/pygrass/docs/Makefile 2014-05-22 13:44:29 UTC (rev 60411)
@@ -14,6 +14,7 @@
endif
PAPER =
BUILDDIR = _build
+BUILDDIR_HTML = $(HTMLDIR)/pygrass
MYGISBASE = $(GISBASE)
@@ -33,75 +34,30 @@
@echo " html to make standalone HTML files"
@echo " dirhtml to make HTML files named index.html in directories"
@echo " singlehtml to make a single large HTML file"
- @echo " pickle to make pickle files"
- @echo " json to make JSON files"
- @echo " htmlhelp to make HTML files and a HTML help project"
- @echo " qthelp to make HTML files and a qthelp project"
- @echo " devhelp to make HTML files and a Devhelp project"
@echo " epub to make an epub"
@echo " latex to make LaTeX files, you can set PAPER=a4 or PAPER=letter"
@echo " latexpdf to make LaTeX files and run them through pdflatex"
- @echo " text to make text files"
@echo " man to make manual pages"
- @echo " texinfo to make Texinfo files"
- @echo " info to make Texinfo files and run them through makeinfo"
- @echo " gettext to make PO message catalogs"
- @echo " changes to make an overview of all changed/added/deprecated items"
- @echo " linkcheck to check all external links for integrity"
@echo " doctest to run all doctests embedded in the documentation (if enabled)"
clean:
-rm -rf $(BUILDDIR)/*
html:
- $(call run_grass,$(SPHINXBUILD) -b html $(ALLSPHINXOPTS) $(BUILDDIR)/html)
+ $(call run_grass,$(SPHINXBUILD) -b html $(ALLSPHINXOPTS) $(BUILDDIR_HTML))
@echo
- @echo "Build finished. The HTML pages are in $(BUILDDIR)/html/"
+ @echo "Build finished. The HTML pages are in $(BUILDDIR_HTML)"
dirhtml:
- $(call run_grass,$(SPHINXBUILD) -b dirhtml $(ALLSPHINXOPTS) $(BUILDDIR)/dirhtml)
+ $(call run_grass,$(SPHINXBUILD) -b dirhtml $(ALLSPHINXOPTS) $(BUILDDIR_HTML))
@echo
- @echo "Build finished. The HTML pages are in $(BUILDDIR)/dirhtml/"
singlehtml:
- $(call run_grass,$(SPHINXBUILD) -b singlehtml $(ALLSPHINXOPTS) $(BUILDDIR)/singlehtml)
+ $(call run_grass,$(SPHINXBUILD) -b singlehtml $(ALLSPHINXOPTS) $(BUILDDIR_HTML))
@echo
- @echo "Build finished. The HTML page is in $(BUILDDIR)/singlehtml/"
+ @echo "Build finished. The HTML page is in $(BUILDDIR_HTML)"
-pickle:
- $(call run_grass,$(SPHINXBUILD) -b pickle $(ALLSPHINXOPTS) $(BUILDDIR)/pickle)
- @echo
- @echo "Build finished; now you can process the pickle files in $(BUILDDIR)/pickle/."
-json:
- $(call run_grass,$(SPHINXBUILD) -b json $(ALLSPHINXOPTS) $(BUILDDIR)/json)
- @echo
- @echo "Build finished; now you can process the JSON files in $(BUILDDIR)/json/"
-htmlhelp:
- $(call run_grass,$(SPHINXBUILD) -b htmlhelp $(ALLSPHINXOPTS) $(BUILDDIR)/htmlhelp)
- @echo
- @echo "Build finished; now you can run HTML Help Workshop with the" \
- ".hhp project file in $(BUILDDIR)/htmlhelp/"
-qthelp:
- $(call run_grass,$(SPHINXBUILD) -b qthelp $(ALLSPHINXOPTS) $(BUILDDIR)/qthelp)
- @echo
- @echo "Build finished; now you can run "qcollectiongenerator" with the" \
- ".qhcp project file in $(BUILDDIR)/qthelp, like this:"
- @echo "# qcollectiongenerator $(BUILDDIR)/qthelp/PyGrass.qhcp"
- @echo "To view the help file:"
- @echo "# assistant -collectionFile $(BUILDDIR)/qthelp/PyGrass.qhc"
-devhelp:
- $(call run_grass,$(SPHINXBUILD) -b devhelp $(ALLSPHINXOPTS) $(BUILDDIR)/devhelp)
- @echo
- @echo "Build finished."
- @echo "# mkdir -p $$HOME/.local/share/devhelp/PyGrass"
- @echo "# ln -s $(BUILDDIR)/devhelp $$HOME/.local/share/devhelp/PyGrass"
- @echo "# devhelp"
epub:
$(call run_grass,$(SPHINXBUILD) -b epub $(ALLSPHINXOPTS) $(BUILDDIR)/epub)
@echo
@@ -120,45 +76,11 @@
$(MAKE) -C $(BUILDDIR)/latex all-pdf
@echo "pdflatex finished; the PDF files are in $(BUILDDIR)/latex/"
-text:
- $(call run_grass,$(SPHINXBUILD) -b text $(ALLSPHINXOPTS) $(BUILDDIR)/text)
- @echo
- @echo "Build finished. The text files are in $(BUILDDIR)/text/"
man:
$(call run_grass,$(SPHINXBUILD) -b man $(ALLSPHINXOPTS) $(BUILDDIR)/man)
@echo
@echo "Build finished. The manual pages are in $(BUILDDIR)/man/"
-texinfo:
- $(call run_grass,$(SPHINXBUILD) -b texinfo $(ALLSPHINXOPTS) $(BUILDDIR)/texinfo)
- @echo
- @echo "Build finished. The Texinfo files are in $(BUILDDIR)/texinfo."
- @echo "Run \`make' in that directory to run these through makeinfo" \
- "(use \`make info' here to do that automatically)."
-info:
- @echo "Running Texinfo files through makeinfo..."
- make -C $(BUILDDIR)/texinfo info
- @echo "makeinfo finished; the Info files are in $(BUILDDIR)/texinfo/"
-gettext:
- $(call run_grass,$(SPHINXBUILD) -b gettext $(I18NSPHINXOPTS) $(BUILDDIR)/locale)
- @echo
- @echo "Build finished. The message catalogs are in $(BUILDDIR)/locale/"
-changes:
- $(call run_grass,$(SPHINXBUILD) -b changes $(ALLSPHINXOPTS) $(BUILDDIR)/changes)
- @echo
- @echo "The overview file is in $(BUILDDIR)/changes/"
-linkcheck:
- $(call run_grass,$(SPHINXBUILD) -b linkcheck $(ALLSPHINXOPTS) $(BUILDDIR)/linkcheck)
- @echo
- @echo "Link check complete; look for any errors in the above output " \
- "or in $(BUILDDIR)/linkcheck/output.txt."
doctest:
$(call run_grass,$(SPHINXBUILD) -b doctest $(ALLSPHINXOPTS) $(BUILDDIR)/doctest)
@echo "Testing of doctests in the sources finished, look at the " \
