[GRASS-SVN] r60427 - grass-addons/grass7/raster/r.northerness.easterness
Thu May 22 16:44:20 PDT 2014
Author: hellik
Date: 2014-05-22 16:44:20 -0700 (Thu, 22 May 2014)
New Revision: 60427
   grass-addons/grass7/raster/r.northerness.easterness/Makefile
   grass-addons/grass7/raster/r.northerness.easterness/r.northerness.easterness.html
   grass-addons/grass7/raster/r.northerness.easterness/r.northerness.easterness.py
add addon script grass7/raster/r.northerness.easterness: step 3 (svn propset)
Modified: grass-addons/grass7/raster/r.northerness.easterness/Makefile
--- grass-addons/grass7/raster/r.northerness.easterness/Makefile	2014-05-22 23:39:37 UTC (rev 60426)
+++ grass-addons/grass7/raster/r.northerness.easterness/Makefile	2014-05-22 23:44:20 UTC (rev 60427)
@@ -1,7 +1,7 @@
-MODULE_TOPDIR = ../..
-PGM = r.northerness.easterness
-include $(MODULE_TOPDIR)/include/Make/Script.make
-default: script
+MODULE_TOPDIR = ../..
+PGM = r.northerness.easterness
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Property changes on: grass-addons/grass7/raster/r.northerness.easterness/Makefile
___________________________________________________________________
Added: svn:mime-type
   + text/x-makefile
Added: svn:eol-style
   + native
Modified: grass-addons/grass7/raster/r.northerness.easterness/r.northerness.easterness.html
--- grass-addons/grass7/raster/r.northerness.easterness/r.northerness.easterness.html	2014-05-22 23:39:37 UTC (rev 60426)
+++ grass-addons/grass7/raster/r.northerness.easterness/r.northerness.easterness.html	2014-05-22 23:44:20 UTC (rev 60427)
@@ -1,61 +1,61 @@
-<h2>DESCRIPTION</h2>
-<p>
-<em>r.northerness.easterness</em> calculates northerness, easterness and
-the interaction between northerness and slope (northerness*slope). The
-user must specify the input <b>elevation raster</b> map.
-</p>
-<h2>NOTES</h2>
-<p>
-As aspect is a circular land-surface parameter, in ecology a sine or
-cosine transformation is often used to obtain a continuous gradient,
-stressing the north-south or east-west gradient (northness or eastness).
-</p>
-<p>
-The GRASS GIS default aspect angles (cartesian) are converted to compass
-angles.
-</p>
-<p>
-Calculated raster maps are:
-</p>
-<ul>
- <li>northerness: <em>cos(aspect)</em></li>
- <li>easterness: <em>sin(aspect)</em></li>
- <li>interaction between northerness and slope: <em>northerness*slope</em></li>
-</ul>
-<p>
-The color of these raster maps are set to <em>grey</em>.
-</p>
-<h2>EXAMPLE</h2>
-<div class="code">
- <pre>
-  # align region to DEM and habitat vector
-  g.region -a rast=DEM align=DEM
-  # run <em>r.northerness.easterness</em>
-  r.northerness.easterness elevation=DEM
- </pre>
-</div>
-<h2>SEE ALSO</h2>
-<em>
-<a href="r.mapcalc.html">r.mapcalc</a>,
-<a href="r.slope.aspect.html">r.slope.aspect</a>
-</em>
-<h2>AUTHOR</h2>
-Helmut Kudrnovsky
-<p>
-<i>Last changed: $Date: 2014-05-13 23:17:32 +0200 (Di, 13 Mai 2014) $</i>
+<h2>DESCRIPTION</h2>
+<p>
+<em>r.northerness.easterness</em> calculates northerness, easterness and
+the interaction between northerness and slope (northerness*slope). The
+user must specify the input <b>elevation raster</b> map.
+</p>
+<h2>NOTES</h2>
+<p>
+As aspect is a circular land-surface parameter, in ecology a sine or
+cosine transformation is often used to obtain a continuous gradient,
+stressing the north-south or east-west gradient (northness or eastness).
+</p>
+<p>
+The GRASS GIS default aspect angles (cartesian) are converted to compass
+angles.
+</p>
+<p>
+Calculated raster maps are:
+</p>
+<ul>
+ <li>northerness: <em>cos(aspect)</em></li>
+ <li>easterness: <em>sin(aspect)</em></li>
+ <li>interaction between northerness and slope: <em>northerness*slope</em></li>
+</ul>
+<p>
+The color of these raster maps are set to <em>grey</em>.
+</p>
+<h2>EXAMPLE</h2>
+<div class="code">
+ <pre>
+  # align region to DEM and habitat vector
+  g.region -a rast=DEM align=DEM
+  # run <em>r.northerness.easterness</em>
+  r.northerness.easterness elevation=DEM
+ </pre>
+</div>
+<h2>SEE ALSO</h2>
+<em>
+<a href="r.mapcalc.html">r.mapcalc</a>,
+<a href="r.slope.aspect.html">r.slope.aspect</a>
+</em>
+<h2>AUTHOR</h2>
+Helmut Kudrnovsky
+<p>
+<i>Last changed: $Date$</i>
 </p>
\ No newline at end of file
Property changes on: grass-addons/grass7/raster/r.northerness.easterness/r.northerness.easterness.html
   + text/html
Added: svn:keywords
   + Author Date Id
   + native
Modified: grass-addons/grass7/raster/r.northerness.easterness/r.northerness.easterness.py
--- grass-addons/grass7/raster/r.northerness.easterness/r.northerness.easterness.py	2014-05-22 23:39:37 UTC (rev 60426)
+++ grass-addons/grass7/raster/r.northerness.easterness/r.northerness.easterness.py	2014-05-22 23:44:20 UTC (rev 60427)
@@ -1,131 +1,131 @@
-#!/usr/bin/env python
-MODULE:    r.northerness.easterness
-AUTHOR(S): Helmut Kudrnovsky <alectoria AT gmx at>
-PURPOSE:   Calculates northerness and easterness of a DEM
-COPYRIGHT: (C) 2014 by the GRASS Development Team
-           This program is free software under the GNU General Public
-           License (>=v2). Read the file COPYING that comes with GRASS
-           for details.
-#%module
-#% description: DEM derived characteristics of habitats
-#% keywords: raster
-#% keywords: terrain
-#% keywords: aspect
-#% keywords: slope
-#% keywords: sun
-#%end
-#%option G_OPT_R_ELEV
-#% key: elevation
-#% description: Name of elevation raster map
-#% required: yes
-#%end
-import sys
-import os
-import grass.script as grass
-import math
-if not os.environ.has_key("GISBASE"):
-    grass.message( "You must be in GRASS GIS to run this program." )
-    sys.exit(1)
-def main():
-    r_elevation = options['elevation'].split('@')[0]
-    r_aspect = r_elevation+'_aspect'
-    r_slope = r_elevation+'_slope'
-    r_aspect_compass = r_elevation+'_aspect_compass'
-    r_northerness = r_elevation+'_northerness'
-    r_easterness = r_elevation+'_easterness'
-    r_northerness_slope = r_elevation+'_northerness_slope'
-    # Calculation of slope and aspect maps
-    grass.message( "----" )
-    grass.message( "Calculation of slope and aspect by r.slope.aspect ..." )
-    grass.run_command('r.slope.aspect', elevation = r_elevation,
-                                     slope = r_slope,
-                                     aspect = r_aspect,
-                                     overwrite = True)
-    grass.message( "Calculation of slope and aspect done." )
-    # Correction aspect angles from cartesian (GRASS default) to compass angles
-    #   if((A < 90, 90-A, 360+90-A))
-    grass.message( "Convert aspect angles from cartesian (GRASS GIS default) to compass angles ..." )
-    grass.mapcalc("$outmap = if( $cartesian == 0, 0, if( $cartesian < 90, 90 - $cartesian, 360 + 90 - $cartesian) )",
-                                     outmap = r_aspect_compass,
-                                     cartesian = r_aspect)
-    grass.message( "..." )
-    grass.run_command('r.info', map = r_aspect_compass)
-    grass.message( "Aspect conversion done." )
-    # Calculation of northerness
-    grass.message( "Calculate northerness ..." )
-    grass.mapcalc("$outmap = cos( $compass )",
-                                     outmap = r_northerness,
-                                     compass = r_aspect_compass)
-    grass.run_command('r.info', map = r_northerness)
-    grass.message( "Northerness calculation done." )
-    # Calculation of easterness
-    grass.message( "Calculate easterness ..." )
-    grass.mapcalc("$outmap = sin( $compass )",
-                                     outmap = r_easterness,
-    grass.run_command('r.info', map = r_easterness)
-    grass.message( "Easterness calculation done." )
-    # Calculation of northerness*slope
-    grass.message( "Calculate northerness*slope ..." )
-    grass.mapcalc("$outmap = $northerness * $slope",
-                                     outmap = r_northerness_slope,
-                                     northerness = r_northerness,
-                                     slope = r_slope)
-    grass.run_command('r.info', map = r_northerness_slope)
-    grass.message( "Northerness*slope calculation done." )
-    # adjust color
-    grass.message( "Adjust color ..." )
-    grass.run_command('r.colors', map = r_northerness,
-                                     color = 'grey')
-    grass.run_command('r.colors', map = r_easterness,
-                                     color = 'grey')
-    grass.run_command('r.colors', map = r_northerness_slope,
-                                     color = 'grey')
-    grass.message( "Color adjustment done." )
-    # clean up some temporay files and maps
-    grass.message( "Some clean up ..." )
-    grass.run_command("g.remove", rast = r_slope,
-                                     quiet = True)
-    grass.run_command("g.remove", rast = r_aspect,
-                                     quiet = True)
-    grass.run_command("g.remove", rast = r_aspect_compass,
-                                     quiet = True)
-    grass.message( "Clean up done." )
-    # r.northerness.easterness done!
-    grass.message( "r.northerness.easterness done!" )
-if __name__ == "__main__":
-    options, flags = grass.parser()
-    sys.exit(main())
+#!/usr/bin/env python
+MODULE:    r.northerness.easterness
+AUTHOR(S): Helmut Kudrnovsky <alectoria AT gmx at>
+PURPOSE:   Calculates northerness and easterness of a DEM
+COPYRIGHT: (C) 2014 by the GRASS Development Team
+           This program is free software under the GNU General Public
+           License (>=v2). Read the file COPYING that comes with GRASS
+           for details.
+#%module
+#% description: DEM derived characteristics of habitats
+#% keywords: raster
+#% keywords: terrain
+#% keywords: aspect
+#% keywords: slope
+#% keywords: sun
+#%end
+#%option G_OPT_R_ELEV
+#% key: elevation
+#% description: Name of elevation raster map
+#% required: yes
+#%end
+import sys
+import os
+import grass.script as grass
+import math
+if not os.environ.has_key("GISBASE"):
+    grass.message( "You must be in GRASS GIS to run this program." )
+    sys.exit(1)
+def main():
+    r_elevation = options['elevation'].split('@')[0]
+    r_aspect = r_elevation+'_aspect'
+    r_slope = r_elevation+'_slope'
+    r_aspect_compass = r_elevation+'_aspect_compass'
+    r_northerness = r_elevation+'_northerness'
+    r_easterness = r_elevation+'_easterness'
+    r_northerness_slope = r_elevation+'_northerness_slope'
+    # Calculation of slope and aspect maps
+    grass.message( "----" )
+    grass.message( "Calculation of slope and aspect by r.slope.aspect ..." )
+    grass.run_command('r.slope.aspect', elevation = r_elevation,
+                                     slope = r_slope,
+                                     aspect = r_aspect,
+                                     overwrite = True)
+    grass.message( "Calculation of slope and aspect done." )
+    # Correction aspect angles from cartesian (GRASS default) to compass angles
+    #   if((A < 90, 90-A, 360+90-A))
+    grass.message( "Convert aspect angles from cartesian (GRASS GIS default) to compass angles ..." )
+    grass.mapcalc("$outmap = if( $cartesian == 0, 0, if( $cartesian < 90, 90 - $cartesian, 360 + 90 - $cartesian) )",
+                                     outmap = r_aspect_compass,
+                                     cartesian = r_aspect)
+    grass.message( "..." )
+    grass.run_command('r.info', map = r_aspect_compass)
+    grass.message( "Aspect conversion done." )
+    # Calculation of northerness
+    grass.message( "Calculate northerness ..." )
+    grass.mapcalc("$outmap = cos( $compass )",
+                                     outmap = r_northerness,
+                                     compass = r_aspect_compass)
+    grass.run_command('r.info', map = r_northerness)
+    grass.message( "Northerness calculation done." )
+    # Calculation of easterness
+    grass.message( "Calculate easterness ..." )
+    grass.mapcalc("$outmap = sin( $compass )",
+                                     outmap = r_easterness,
+    grass.run_command('r.info', map = r_easterness)
+    grass.message( "Easterness calculation done." )
+    # Calculation of northerness*slope
+    grass.message( "Calculate northerness*slope ..." )
+    grass.mapcalc("$outmap = $northerness * $slope",
+                                     outmap = r_northerness_slope,
+                                     northerness = r_northerness,
+                                     slope = r_slope)
+    grass.run_command('r.info', map = r_northerness_slope)
+    grass.message( "Northerness*slope calculation done." )
+    # adjust color
+    grass.message( "Adjust color ..." )
+    grass.run_command('r.colors', map = r_northerness,
+                                     color = 'grey')
+    grass.run_command('r.colors', map = r_easterness,
+                                     color = 'grey')
+    grass.run_command('r.colors', map = r_northerness_slope,
+                                     color = 'grey')
+    grass.message( "Color adjustment done." )
+    # clean up some temporay files and maps
+    grass.message( "Some clean up ..." )
+    grass.run_command("g.remove", rast = r_slope,
+                                     quiet = True)
+    grass.run_command("g.remove", rast = r_aspect,
+                                     quiet = True)
+    grass.run_command("g.remove", rast = r_aspect_compass,
+                                     quiet = True)
+    grass.message( "Clean up done." )
+    # r.northerness.easterness done!
+    grass.message( "r.northerness.easterness done!" )
+if __name__ == "__main__":
+    options, flags = grass.parser()
+    sys.exit(main())
Property changes on: grass-addons/grass7/raster/r.northerness.easterness/r.northerness.easterness.py
   + text/x-python
   + native
