[GRASS-SVN] r60431 - grass/branches/releasebranch_7_0/tools
svn_grass at osgeo.org
Fri May 23 00:04:20 PDT 2014
Author: neteler
Date: 2014-05-23 00:04:20 -0700 (Fri, 23 May 2014)
New Revision: 60431
Removed:
grass/branches/releasebranch_7_0/tools/reindent.py
tools: removed unused 3rd party Python reindent script
Deleted: grass/branches/releasebranch_7_0/tools/reindent.py
--- grass/branches/releasebranch_7_0/tools/reindent.py 2014-05-23 07:04:12 UTC (rev 60430)
+++ grass/branches/releasebranch_7_0/tools/reindent.py 2014-05-23 07:04:20 UTC (rev 60431)
@@ -1,306 +0,0 @@
-#! /usr/bin/env python
-# FROM http://svn.python.org/view/python/trunk/Tools/scripts/reindent.py
-# Released to the public domain, by Tim Peters, 03 October 2000.
-"""reindent [-d][-r][-v] [ path ... ]
--d (--dryrun) Dry run. Analyze, but don't make any changes to, files.
--r (--recurse) Recurse. Search for all .py files in subdirectories too.
--n (--nobackup) No backup. Does not make a ".bak" file before reindenting.
--v (--verbose) Verbose. Print informative msgs; else no output.
--h (--help) Help. Print this usage information and exit.
-Change Python (.py) files to use 4-space indents and no hard tab characters.
-Also trim excess spaces and tabs from ends of lines, and remove empty lines
-at the end of files. Also ensure the last line ends with a newline.
-If no paths are given on the command line, reindent operates as a filter,
-reading a single source file from standard input and writing the transformed
-source to standard output. In this case, the -d, -r and -v flags are
-ignored.
-You can pass one or more file and/or directory paths. When a directory
-path, all .py files within the directory will be examined, and, if the -r
-option is given, likewise recursively for subdirectories.
-If output is not to standard output, reindent overwrites files in place,
-renaming the originals with a .bak extension. If it finds nothing to
-change, the file is left alone. If reindent does change a file, the changed
-file is a fixed-point for future runs (i.e., running reindent on the
-resulting .py file won't change it again).
-The hard part of reindenting is figuring out what to do with comment
-lines. So long as the input files get a clean bill of health from
-tabnanny.py, reindent should do a good job.
-The backup file is a copy of the one that is being reindented. The ".bak"
-file is generated with shutil.copy(), but some corner cases regarding
-user/group and permissions could leave the backup file more readable that
-you'd prefer. You can always use the --nobackup option to prevent this.
-__version__ = "1"
-import tokenize
-import os, shutil
-import sys
-verbose = 0
-recurse = 0
-dryrun = 0
-makebackup = True
-def usage(msg=None):
- if msg is not None:
- print >> sys.stderr, msg
- print >> sys.stderr, __doc__
-def errprint(*args):
- sep = ""
- for arg in args:
- sys.stderr.write(sep + str(arg))
- sep = " "
- sys.stderr.write("\n")
-def main():
- import getopt
- global verbose, recurse, dryrun, makebackup
- try:
- opts, args = getopt.getopt(sys.argv[1:], "drnvh",
- ["dryrun", "recurse", "nobackup", "verbose", "help"])
- except getopt.error as msg:
- usage(msg)
- return
- for o, a in opts:
- if o in ('-d', '--dryrun'):
- dryrun += 1
- elif o in ('-r', '--recurse'):
- recurse += 1
- elif o in ('-n', '--nobackup'):
- makebackup = False
- elif o in ('-v', '--verbose'):
- verbose += 1
- elif o in ('-h', '--help'):
- usage()
- return
- if not args:
- r = Reindenter(sys.stdin)
- r.run()
- r.write(sys.stdout)
- return
- for arg in args:
- check(arg)
-def check(file):
- if os.path.isdir(file) and not os.path.islink(file):
- if verbose:
- print "listing directory", file
- names = os.listdir(file)
- for name in names:
- fullname = os.path.join(file, name)
- if ((recurse and os.path.isdir(fullname) and
- not os.path.islink(fullname) and
- not os.path.split(fullname)[1].startswith("."))
- or name.lower().endswith(".py")):
- check(fullname)
- return
- if verbose:
- print "checking", file, "...",
- try:
- f = open(file)
- except IOError as msg:
- errprint("%s: I/O Error: %s" % (file, str(msg)))
- return
- r = Reindenter(f)
- f.close()
- if r.run():
- if verbose:
- print "changed."
- if dryrun:
- print "But this is a dry run, so leaving it alone."
- if not dryrun:
- bak = file + ".bak"
- if makebackup:
- shutil.copyfile(file, bak)
- if verbose:
- print "backed up", file, "to", bak
- f = open(file, "w")
- r.write(f)
- f.close()
- if verbose:
- print "wrote new", file
- return True
- else:
- if verbose:
- print "unchanged."
- return False
-def _rstrip(line, JUNK='\n \t'):
- """Return line stripped of trailing spaces, tabs, newlines.
- Note that line.rstrip() instead also strips sundry control characters,
- but at least one known Emacs user expects to keep junk like that, not
- mentioning Barry by name or anything <wink>.
- i = len(line)
- while i > 0 and line[i-1] in JUNK:
- i -= 1
- return line[:i]
-class Reindenter:
- def __init__(self, f):
- self.find_stmt = 1 # next token begins a fresh stmt?
- self.level = 0 # current indent level
- # Raw file lines.
- self.raw = f.readlines()
- # File lines, rstripped & tab-expanded. Dummy at start is so
- # that we can use tokenize's 1-based line numbering easily.
- # Note that a line is all-blank iff it's "\n".
- self.lines = [_rstrip(line).expandtabs() + "\n"
- for line in self.raw]
- self.lines.insert(0, None)
- self.index = 1 # index into self.lines of next line
- # List of (lineno, indentlevel) pairs, one for each stmt and
- # comment line. indentlevel is -1 for comment lines, as a
- # signal that tokenize doesn't know what to do about them;
- # indeed, they're our headache!
- self.stats = []
- def run(self):
- tokenize.tokenize(self.getline, self.tokeneater)
- # Remove trailing empty lines.
- lines = self.lines
- while lines and lines[-1] == "\n":
- lines.pop()
- # Sentinel.
- stats = self.stats
- stats.append((len(lines), 0))
- # Map count of leading spaces to # we want.
- have2want = {}
- # Program after transformation.
- after = self.after = []
- # Copy over initial empty lines -- there's nothing to do until
- # we see a line with *something* on it.
- i = stats[0][0]
- after.extend(lines[1:i])
- for i in range(len(stats)-1):
- thisstmt, thislevel = stats[i]
- nextstmt = stats[i+1][0]
- have = getlspace(lines[thisstmt])
- want = thislevel * 4
- if want < 0:
- # A comment line.
- if have:
- # An indented comment line. If we saw the same
- # indentation before, reuse what it most recently
- # mapped to.
- want = have2want.get(have, -1)
- if want < 0:
- # Then it probably belongs to the next real stmt.
- for j in xrange(i+1, len(stats)-1):
- jline, jlevel = stats[j]
- if jlevel >= 0:
- if have == getlspace(lines[jline]):
- want = jlevel * 4
- break
- if want < 0: # Maybe it's a hanging
- # comment like this one,
- # in which case we should shift it like its base
- # line got shifted.
- for j in xrange(i-1, -1, -1):
- if jlevel >= 0:
- want = have + getlspace(after[jline-1]) - \
- getlspace(lines[jline])
- break
- if want < 0:
- # Still no luck -- leave it alone.
- want = have
- else:
- want = 0
- assert want >= 0
- have2want[have] = want
- diff = want - have
- if diff == 0 or have == 0:
- after.extend(lines[thisstmt:nextstmt])
- else:
- for line in lines[thisstmt:nextstmt]:
- if diff > 0:
- if line == "\n":
- after.append(line)
- else:
- after.append(" " * diff + line)
- else:
- remove = min(getlspace(line), -diff)
- after.append(line[remove:])
- return self.raw != self.after
- def write(self, f):
- f.writelines(self.after)
- # Line-getter for tokenize.
- def getline(self):
- if self.index >= len(self.lines):
- line = ""
- else:
- line = self.lines[self.index]
- self.index += 1
- return line
- # Line-eater for tokenize.
- def tokeneater(self, type, token, (sline, scol), end, line,
- INDENT=tokenize.INDENT,
- DEDENT=tokenize.DEDENT,
- NEWLINE=tokenize.NEWLINE,
- COMMENT=tokenize.COMMENT,
- NL=tokenize.NL):
- if type == NEWLINE:
- # A program statement, or ENDMARKER, will eventually follow,
- # after some (possibly empty) run of tokens of the form
- # (NL | COMMENT)* (INDENT | DEDENT+)?
- elif type == INDENT:
- self.level += 1
- elif type == DEDENT:
- self.level -= 1
- elif type == COMMENT:
- if self.find_stmt:
- self.stats.append((sline, -1))
- # but we're still looking for a new stmt, so leave
- # find_stmt alone
- elif type == NL:
- pass
- elif self.find_stmt:
- # This is the first "real token" following a NEWLINE, so it
- # must be the first token of the next program statement, or an
- # ENDMARKER.
- self.find_stmt = 0
- if line: # not endmarker
- self.stats.append((sline, self.level))
-# Count number of leading blanks.
-def getlspace(line):
- i, n = 0, len(line)
- while i < n and line[i] == " ":
- i += 1
- return i
-if __name__ == '__main__':
- main()
