[GRASS-SVN] r60439 - grass/branches/releasebranch_7_0/display/d.vect
Fri May 23 00:39:08 PDT 2014
Author: mlennert
Date: 2014-05-23 00:39:08 -0700 (Fri, 23 May 2014)
New Revision: 60439
   grass/branches/releasebranch_7_0/display/d.vect/lines.c
Correcting wrong variable declaration (fixing #2308 - merge from trunk r60438)
Modified: grass/branches/releasebranch_7_0/display/d.vect/lines.c
--- grass/branches/releasebranch_7_0/display/d.vect/lines.c	2014-05-23 07:37:16 UTC (rev 60438)
+++ grass/branches/releasebranch_7_0/display/d.vect/lines.c	2014-05-23 07:39:08 UTC (rev 60439)
@@ -37,7 +37,7 @@
 static int draw_line(int, int, int,
 		     const struct line_pnts *, const struct line_cats *,
 		     const struct color_rgb *, const struct color_rgb *, int,
-		     const char *, int, int,
+		     const char *, double, int,
 		     int, int,
 		     int, double,
 		     struct Colors *,
@@ -194,7 +194,7 @@
 int draw_line(int type, int ltype, int line,
 	      const struct line_pnts *Points, const struct line_cats *Cats,
 	      const struct color_rgb *color, const struct color_rgb *fcolor, int chcat,
-	      const char *symbol_name, int size, int sqrt_flag,
+	      const char *symbol_name, double size, int sqrt_flag,
 	      int id_flag, int cats_color_flag,
 	      int default_width, double width_scale,
 	      struct Colors *zcolors,
