[GRASS-SVN] r60457 - grass-addons/grass6/display/d.barb
Fri May 23 23:49:33 PDT 2014
Author: hamish
Date: 2014-05-23 23:49:33 -0700 (Fri, 23 May 2014)
New Revision: 60457
   grass-addons/grass6/display/d.barb/description.html
   grass-addons/grass6/display/d.barb/grid.c
   grass-addons/grass6/display/d.barb/legend.c
   grass-addons/grass6/display/d.barb/local_proto.h
   grass-addons/grass6/display/d.barb/main.c
   grass-addons/grass6/display/d.barb/points.c
enable the peak= option
Modified: grass-addons/grass6/display/d.barb/description.html
--- grass-addons/grass6/display/d.barb/description.html	2014-05-23 22:15:55 UTC (rev 60456)
+++ grass-addons/grass6/display/d.barb/description.html	2014-05-24 06:49:33 UTC (rev 60457)
@@ -109,7 +109,6 @@
 <ul>
 <li>Scaling of legend does not yet match normal operation.
-<li>The peak option is not yet fully implemented.
 </ul>
 <h2>SEE ALSO</h2>
Modified: grass-addons/grass6/display/d.barb/grid.c
--- grass-addons/grass6/display/d.barb/grid.c	2014-05-23 22:15:55 UTC (rev 60456)
+++ grass-addons/grass6/display/d.barb/grid.c	2014-05-24 06:49:33 UTC (rev 60457)
@@ -8,8 +8,8 @@
 /* load and plot barbs from data stored in two raster maps */
 void do_barb_grid(char *dir_u_map, char *mag_v_map, int is_component,
-		  int color, int aspect_type, double scale, int skip,
-		  int style, int reverse)
+		  int color, int aspect_type, double scale, double setpeak,
+		  int skip, int style, int reverse)
     /* from d.rast.arrow */
     struct FPRange range;
@@ -32,6 +32,9 @@
 	G_fatal_error(_("Problem reading range file"));
     G_get_fp_range_min_max(&range, &mag_min, &mag_max);
+    if (!isnan(setpeak))
+	mag_max = setpeak;
     if (style == TYPE_ARROW || style == TYPE_STRAW) {
 	scale *= 1.5 / fabs(mag_max);
Modified: grass-addons/grass6/display/d.barb/legend.c
--- grass-addons/grass6/display/d.barb/legend.c	2014-05-23 22:15:55 UTC (rev 60456)
+++ grass-addons/grass6/display/d.barb/legend.c	2014-05-24 06:49:33 UTC (rev 60457)
@@ -6,7 +6,7 @@
 #include "local_proto.h"
 void do_legend(char **at_list, char **velo_list, int num_velos,
-	       double key_fontsize, int style, double scale, double peak,
+	       double key_fontsize, int style, double scale, double setpeak,
 	       int color)
     double easting, northing, px, py, velo, angle;
Modified: grass-addons/grass6/display/d.barb/local_proto.h
--- grass-addons/grass6/display/d.barb/local_proto.h	2014-05-23 22:15:55 UTC (rev 60456)
+++ grass-addons/grass6/display/d.barb/local_proto.h	2014-05-24 06:49:33 UTC (rev 60457)
@@ -16,11 +16,11 @@
 #define R2D(d) (double)(d / RpD)	/* radians->degrees */
 /* grid.c */
-void do_barb_grid(char *, char *, int, int, int, double, int, int, int);
+void do_barb_grid(char *, char *, int, int, int, double, double, int, int, int);
 /* points.c */
-void do_barb_points(char *, int, char *, char *, int, int, int, double, int,
-		    int);
+void do_barb_points(char *, int, char *, char *, int, int, int, double, double,
+		    int, int);
 int count_pts_in_region(struct Map_info *);
 void fill_arrays(struct Map_info *, int, char *, char *, int, double *,
 		 double *, double *, double *);
Modified: grass-addons/grass6/display/d.barb/main.c
--- grass-addons/grass6/display/d.barb/main.c	2014-05-23 22:15:55 UTC (rev 60456)
+++ grass-addons/grass6/display/d.barb/main.c	2014-05-24 06:49:33 UTC (rev 60457)
@@ -7,7 +7,7 @@
  * AUTHORS:     Hamish Bowman, Dunedin, New Zealand
  *              Grid code derived from d.rast.arrow
- * COPYRIGHT:   (c) 2008-2012 by Hamish Bowman, and The GRASS Development Team
+ * COPYRIGHT:   (c) 2008-2014 by Hamish Bowman, and The GRASS Development Team
  *              This program is free software under the GNU General Public
  *              License (>=v2). Read the file COPYING that comes with GRASS
  *              for details.
@@ -196,6 +196,8 @@
     vlayer = atoi(vlayer_opt->answer);
     if (peak_opt->answer)
 	peak = atof(peak_opt->answer);
+    else
+	peak = 0./0.; /* NaN */
     if (strcmp(type_opt->answer, "compass") == 0)
 	aspect_type = TYPE_COMPASS;
@@ -224,7 +226,8 @@
 	    num_leg_velo++;
 	if (num_leg_at != num_leg_velo * 2)
-	    G_fatal_error(_("Unequal number of legend placement and velocity requests (%d vs. %d)"),
+	    G_fatal_error(
+	       _("Unequal number of legend placement and velocity requests (%d vs. %d)"),
 			  num_leg_at, num_leg_velo);
 	key_fontsize = atof(keyfont_opt->answer);
@@ -253,10 +256,10 @@
     if (is_vector)
 	do_barb_points(vinput_opt->answer, vlayer,
 		       dir_u_map, mag_v_map, is_component, color,
-		       aspect_type, scale, style, from_to->answer);
+		       aspect_type, scale, peak, style, from_to->answer);
     else
 	do_barb_grid(dir_u_map, mag_v_map, is_component, color,
-		     aspect_type, scale, skip, style, from_to->answer);
+		     aspect_type, scale, peak, skip, style, from_to->answer);
     D_add_to_list(G_recreate_command());
Modified: grass-addons/grass6/display/d.barb/points.c
--- grass-addons/grass6/display/d.barb/points.c	2014-05-23 22:15:55 UTC (rev 60456)
+++ grass-addons/grass6/display/d.barb/points.c	2014-05-24 06:49:33 UTC (rev 60457)
@@ -9,7 +9,8 @@
 /* load and plot barbs from data stored in a vector map's attribute table */
 void do_barb_points(char *vinput_name, int vlayer, char *dir_u_col,
 		    char *mag_v_col, int is_component, int color,
-		    int aspect_type, double scale, int style, int reverse)
+		    int aspect_type, double scale, double setpeak,
+		    int style, int reverse)
     struct Map_info vMap;
@@ -76,14 +77,18 @@
-    peak = max_magnitude(magn, num_pts);
+    if(!isnan(setpeak))
+	peak = setpeak;
+    else
+	peak = max_magnitude(magn, num_pts);
     G_debug(2, "  peak = %.2f", peak);
     if (style == TYPE_BARB || style == TYPE_SMLBARB) {
 	if(peak > 150)
 	    G_warning(_("Maximum wind barb displayed is 150 knots"));
-    peak = 1.;			// TODO: window width * 0.20
+    peak = 1.;			// TODO: window width * 0.20
     scale_fact = (peak) * scale;
     for (i = 0; i < num_pts; i++) {
