[GRASS-SVN] r60463 - grass/branches/releasebranch_7_0/vector/v.vol.rst
svn_grass at osgeo.org
Sat May 24 13:48:12 PDT 2014
Author: annakrat
Date: 2014-05-24 13:48:12 -0700 (Sat, 24 May 2014)
New Revision: 60463
grass/branches/releasebranch_7_0/vector/v.vol.rst/user1.c
grass/branches/releasebranch_7_0/vector/v.vol.rst/v.vol.rst.html
v.vol.rst: 3D aspect maps should be in degrees to be consistent with 2D (merged from trunk, r60460)
Modified: grass/branches/releasebranch_7_0/vector/v.vol.rst/user1.c
--- grass/branches/releasebranch_7_0/vector/v.vol.rst/user1.c 2014-05-24 20:35:37 UTC (rev 60462)
+++ grass/branches/releasebranch_7_0/vector/v.vol.rst/user1.c 2014-05-24 20:48:12 UTC (rev 60463)
@@ -547,7 +547,7 @@
bmask = BM_get(bitmask, x, nsizr - y - 1);
else
bmask = 1;
- value = data[cnt];
+ value = data[cnt] * 180 / M_PI;
if (!bmask)
Rast3d_set_null_value(&value, 1, FCELL_TYPE);
if (Rast3d_put_float(cf3, x, y, iarc, value) == 0) {
@@ -597,7 +597,7 @@
else
bmask = 1;
if (!bmask)
if (Rast3d_put_float(cf4, x, y, iarc, value) == 0) {
Modified: grass/branches/releasebranch_7_0/vector/v.vol.rst/v.vol.rst.html
--- grass/branches/releasebranch_7_0/vector/v.vol.rst/v.vol.rst.html 2014-05-24 20:35:37 UTC (rev 60462)
+++ grass/branches/releasebranch_7_0/vector/v.vol.rst/v.vol.rst.html 2014-05-24 20:48:12 UTC (rev 60463)
@@ -18,7 +18,7 @@
Gauss-Kronecker curvature, or mean curvature). These geometric
parameteres are saved as
3d raster maps <b>gradient, aspect1, aspect2, ncurv, gcurv, mcurv</b>,
-respectively.
+respectively. Maps <b>aspect1</b> and <b>aspect2</b> are in degrees.
<p>At first, data points are checked for identical positions and points
that are closer to each other than given <b>dmin</b> are removed.
