[GRASS-SVN] r60496 - grass-addons/grass7/raster/r.findtheriver
Mon May 26 12:19:21 PDT 2014
Author: hcho
Date: 2014-05-26 12:19:21 -0700 (Mon, 26 May 2014)
New Revision: 60496
   grass-addons/grass7/raster/r.findtheriver/main.c
   grass-addons/grass7/raster/r.findtheriver/point_list.c
   grass-addons/grass7/raster/r.findtheriver/point_list.h
r.findtheriver: the recommended indent rule seems to add too many empty lines between variable declarations
Modified: grass-addons/grass7/raster/r.findtheriver/main.c
--- grass-addons/grass7/raster/r.findtheriver/main.c	2014-05-26 19:13:42 UTC (rev 60495)
+++ grass-addons/grass7/raster/r.findtheriver/main.c	2014-05-26 19:19:21 UTC (rev 60496)
@@ -58,7 +58,6 @@
 int main(int argc, char *argv[])
     struct GModule *module;	/* GRASS module for parsing arguments */
     struct
 	struct Option *input;
@@ -67,31 +66,19 @@
 	struct Option *coords;
 	struct Option *separator;
     } opt;
     struct Cell_head cellhd;	/* it stores region information,
 				   and header information of rasters */
     char name[GNAME_MAX];	/* input raster name */
     const char *mapset;		/* mapset name */
     int nrows, ncols;
     int rowIdx, colIdx, nrows_less_one, ncols_less_one;
     int infd;			/* file descriptor */
     RASTER_MAP_TYPE data_type;	/* type of the map (CELL/DCELL/...) */
     double E, N;
     struct Cell_head window;
     int windowSize;
     double threshold;
     char sep;
     int debug;
     /* initialize GIS environment */
@@ -120,8 +107,7 @@
     opt.window->multiple = NO;
     opt.window->required = NO;
     opt.window->description =
-	_
-	("The size of the window in pixels to search in for stream pixels. Must be an odd integer. If not supplied, window will be inferred based on raster resolution.");
+	_("The size of the window in pixels to search in for stream pixels. Must be an odd integer. If not supplied, window will be inferred based on raster resolution.");
     opt.threshold = G_define_option();
     opt.threshold->key = "threshold";
@@ -130,8 +116,7 @@
     opt.threshold->multiple = NO;
     opt.threshold->required = NO;
     opt.threshold->description =
-	_
-	("The threshold for distinguishing log(UAA) values of stream and non-stream pixels. If not supplied, threshold will be inferred from minimum and maximum raster values.");
+	_("The threshold for distinguishing log(UAA) values of stream and non-stream pixels. If not supplied, threshold will be inferred from minimum and maximum raster values.");
     opt.coords = G_define_standard_option(G_OPT_M_COORDS);
     opt.coords->description = _("Coordinates of outlet point");
@@ -171,8 +156,7 @@
 	windowSize = atoi(opt.window->answer);
 	if (windowSize < 2 || !(windowSize & 1))
-	    G_fatal_error(_
-			  ("Invalid window size %s. Window size must be an odd integer >= 3"),
+	    G_fatal_error(_("Invalid window size %s. Window size must be an odd integer >= 3"),
     else {
@@ -246,11 +230,8 @@
     if (NULL != nearestStreamPixel) {
 	if (debug) {
 	    double nearestValue;
 	    void *tmpRow = Rast_allocate_buf(data_type);
 	    int currCol = nearestStreamPixel->col;
 	    int currRow = nearestStreamPixel->row;
 	    G_debug(1, "Nearest pixel col: %d, row: %d", currCol, currRow);
@@ -306,11 +287,8 @@
 					  int currCol)
     PointList_t *streamPixels = NULL;
     DCELL centralValue, tmpValue;
     double logCentralValue, logTmpValue;
     void *tmpRow = Rast_allocate_buf(dataType);
     /* Get value of central cell */
@@ -364,7 +342,6 @@
     /* Define window bounds */
     int windowOffset = (windowSize - 1) / 2;
     int minCol = currCol - windowOffset;
     if (minCol < 0)
Modified: grass-addons/grass7/raster/r.findtheriver/point_list.c
--- grass-addons/grass7/raster/r.findtheriver/point_list.c	2014-05-26 19:13:42 UTC (rev 60495)
+++ grass-addons/grass7/raster/r.findtheriver/point_list.c	2014-05-26 19:19:21 UTC (rev 60496)
@@ -47,7 +47,6 @@
     if (NULL != head) {
 	PointList_t *curr = head;
 	PointList_t *next = curr->next;
 	while (NULL != next) {
@@ -63,9 +62,7 @@
     PointList_t *nearest = NULL;
     double tmpDistance, minDistance = HUGE_VAL;
     while (NULL != curr) {
Modified: grass-addons/grass7/raster/r.findtheriver/point_list.h
--- grass-addons/grass7/raster/r.findtheriver/point_list.h	2014-05-26 19:13:42 UTC (rev 60495)
+++ grass-addons/grass7/raster/r.findtheriver/point_list.h	2014-05-26 19:19:21 UTC (rev 60496)
@@ -26,13 +26,9 @@
 } PointList_t;
 PointList_t *create_list(int col, int row);
 PointList_t *append_point(PointList_t * const head, int col, int row);
 void destroy_list(PointList_t * head);
 PointList_t *find_nearest_point(PointList_t * const head, int col, int row);
 void print_list(PointList_t * const head, const char *const sep);
 #endif
