[GRASS-SVN] r60511 - in grass/trunk/lib/python/pygrass: docs gis raster
Tue May 27 04:20:05 PDT 2014
Author: lucadelu
Date: 2014-05-27 04:20:05 -0700 (Tue, 27 May 2014)
New Revision: 60511
   grass/trunk/lib/python/pygrass/docs/gis.rst
   grass/trunk/lib/python/pygrass/docs/index.rst
   grass/trunk/lib/python/pygrass/docs/raster.rst
   grass/trunk/lib/python/pygrass/gis/__init__.py
   grass/trunk/lib/python/pygrass/gis/region.py
   grass/trunk/lib/python/pygrass/raster/__init__.py
   grass/trunk/lib/python/pygrass/raster/category.py
   grass/trunk/lib/python/pygrass/raster/history.py
pygrass: improve documentation about grass database managment, region and raster
Modified: grass/trunk/lib/python/pygrass/docs/gis.rst
--- grass/trunk/lib/python/pygrass/docs/gis.rst	2014-05-27 10:05:07 UTC (rev 60510)
+++ grass/trunk/lib/python/pygrass/docs/gis.rst	2014-05-27 11:20:05 UTC (rev 60511)
@@ -1,3 +1,4 @@
+.. _GRASSdatabase-label:
 GRASS database management
@@ -17,6 +18,8 @@
 .. autoclass:: pygrass.gis.VisibleMapset
     :members:
+.. _Region-label:
 Region management
Modified: grass/trunk/lib/python/pygrass/docs/index.rst
--- grass/trunk/lib/python/pygrass/docs/index.rst	2014-05-27 10:05:07 UTC (rev 60510)
+++ grass/trunk/lib/python/pygrass/docs/index.rst	2014-05-27 11:20:05 UTC (rev 60511)
@@ -22,6 +22,7 @@
    vector
    attributes
    modules
+   messages
 References
Modified: grass/trunk/lib/python/pygrass/docs/raster.rst
--- grass/trunk/lib/python/pygrass/docs/raster.rst	2014-05-27 10:05:07 UTC (rev 60510)
+++ grass/trunk/lib/python/pygrass/docs/raster.rst	2014-05-27 11:20:05 UTC (rev 60511)
@@ -153,6 +153,8 @@
     >>> land.write_cats_rules('land_rules.csv', ';')
     >>> land.read_cats_rules('land_rules.csv', ';')
+.. autoclass:: pygrass.raster.category.Category
+    :members:
 .. _RasterRow-label:
@@ -210,6 +212,8 @@
     >>> new.exist()
     False
+.. autoclass:: pygrass.raster.RasterRow
+    :members:
 .. _RasterRowIO-label:
@@ -233,8 +237,9 @@
     [ 144.99488831  145.22894287  145.57142639]
     >>> elev.close()
+.. autoclass:: pygrass.raster.RasterRowIO
+    :members:
 .. _RasterSegment-label:
 RastSegment
@@ -302,8 +307,9 @@
     >>> elev.close()
     >>> elev.remove()
+.. autoclass:: pygrass.raster.RasterSegment
+    :members:
 .. _RasterNumpy-label:
 RasterNumpy
@@ -342,8 +348,9 @@
     True
     >>> el.remove()
+.. autoclass:: pygrass.raster.RasterNumpy
+    :members:
 .. _Buffer-label:
 Buffer
@@ -384,14 +391,6 @@
     :members:
-.. _Category-label:
-Category
-.. autoclass:: pygrass.raster.category.Category
-    :members:
 .. _Raster library: http://grass.osgeo.org/programming7/rasterlib.html
 .. _RowIO library: http://grass.osgeo.org/programming7/rowiolib.html
 .. _Segmentation library: http://grass.osgeo.org/programming7/segmentlib.html
Modified: grass/trunk/lib/python/pygrass/gis/__init__.py
--- grass/trunk/lib/python/pygrass/gis/__init__.py	2014-05-27 10:05:07 UTC (rev 60510)
+++ grass/trunk/lib/python/pygrass/gis/__init__.py	2014-05-27 11:20:05 UTC (rev 60511)
@@ -60,6 +60,8 @@
 def set_current_mapset(mapset, location=None, gisdbase=None):
+    """Set the current mapset as working area
     libgis.G_setenv('MAPSET', mapset)
     if location:
         libgis.G_setenv('LOCATION_NAME', location)
@@ -68,6 +70,7 @@
 def make_mapset(mapset, location=None, gisdbase=None):
+    """Create a new mapset"""
     res = libgis.G_make_mapset(gisdbase, location, mapset)
     if res == -1:
         raise GrassError("Cannot create new mapset")
@@ -83,6 +86,7 @@
         >>> gisdbase.name == gisenv()['GISDBASE']
         True
     def __init__(self, gisdbase=''):
         self.name = gisdbase
@@ -93,7 +97,8 @@
     def _set_name(self, name):
         self._name = _check(name, '', "GISDBASE")
-    name = property(fget=_get_name, fset=_set_name)
+    name = property(fget=_get_name, fset=_set_name,
+                    doc="Set or obtain the name of GISDBASE")
     def __str__(self):
         return self.name
@@ -122,6 +127,7 @@
         for loc in self.locations():
             yield Location(loc, self.name)
+    # TODO remove or complete this function
     def new_location(self):
         if libgis.G__make_location() != 0:
             raise GrassError("Cannot create new location")
@@ -167,7 +173,8 @@
     def _set_gisdb(self, gisdb):
         self._gisdb = _check(gisdb, '', "GISDBASE")
-    gisdbase = property(fget=_get_gisdb, fset=_set_gisdb)
+    gisdbase = property(fget=_get_gisdb, fset=_set_gisdb,
     def _get_name(self):
         return self._name
@@ -175,7 +182,8 @@
         self._name = _check(name, self._gisdb, "LOCATION_NAME")
+                    doc="Set or obtain the name of LOCATION")
     def __getitem__(self, mapset):
         if mapset in self.mapsets():
@@ -198,11 +206,20 @@
         return 'Location(%r)' % self.name
     def mapsets(self, pattern=None, permissions=True):
-        """Return a list of the available mapsets. ::
+        """Return a list of the available mapsets.
+        :param pattern: the pattern to filter the result
+        :type pattern: str
+        :param permissions: check the permission of mapset
+        :type permissions: bool
+        :returns:  a list of mapset's names
             >>> location = Location()
             >>> location.mapsets()
             ['PERMANENT', 'user1']
         mapsets = [mapset for mapset in self]
         if permissions:
@@ -228,6 +245,8 @@
         'nc_basic_spm_grass7'
         >>> mapset.name
         'user1'
     def __init__(self, mapset='', location='', gisdbase=''):
         self.gisdbase = gisdbase
@@ -241,7 +260,8 @@
     def _get_loc(self):
         return self._loc
@@ -249,7 +269,8 @@
     def _set_loc(self, loc):
         self._loc = _check(loc, self._gisdb, "LOCATION_NAME")
-    location = property(fget=_get_loc, fset=_set_loc)
+    location = property(fget=_get_loc, fset=_set_loc,
         return self._name
@@ -257,7 +278,8 @@
         self._name = _check(name, join(self._gisdb, self._loc), "MAPSET")
+                    doc="Set or obtain the name of MAPSET")
     def __str__(self):
         return self.name
@@ -281,6 +303,11 @@
             * 'vect',
             * 'view3d'
+        :param type: the type of element to query
+        :type type: str
             >>> mapset = Mapset('PERMANENT')
@@ -290,6 +317,8 @@
             ['basins', 'elevation', ...]
             >>> mapset.glist('rast', pattern='el*')
             ['elevation_shade', 'elevation']
         if type not in ETYPE:
             str_err = "Type %s is not valid, valid types are: %s."
@@ -307,6 +336,7 @@
                 return elist
     def is_current(self):
+        """Check if the MAPSET is the working MAPSET"""
         return (self.name == libgis.G_getenv('MAPSET') and
                 self.location == libgis.G_getenv('LOCATION_NAME') and
                 self.gisdbase == libgis.G_getenv('GISDBASE'))
@@ -331,6 +361,8 @@
         >>> mapset = VisibleMapset('user1')
         >>> mapset
         ['user1', 'PERMANENT']
     def __init__(self, mapset, location='', gisdbase=''):
         self.mapset = mapset
@@ -357,13 +389,21 @@
         return lns
     def _write(self, mapsets):
-        """Write to SEARCH_PATH file the changes in the search path"""
+        """Write to SEARCH_PATH file the changes in the search path
+        :param mapsets: a list of mapset's names
+        :type mapsets: list
         with open(self.spath, "w+") as f:
             ms = self.location.mapsets()
             f.write('%s' % '\n'.join([m for m in mapsets if m in ms]))
     def add(self, mapset):
-        """Add a mapset to the search path"""
+        """Add a mapset to the search path
+        :param mapset: a mapset's name
+        :type mapset: str
         if mapset not in self.read() and mapset in self.location:
             with open(self.spath, "a+") as f:
                 f.write('\n%s' % mapset)
@@ -371,13 +411,21 @@
             raise TypeError('Mapset not found')
     def remove(self, mapset):
-        """Remove mapset to the search path"""
+        """Remove mapset to the search path
+        :type mapset: str
         mapsets = self.read()
         mapsets.remove(mapset)
         self._write(mapsets)
     def extend(self, mapsets):
-        """Add more mapsets to the search path"""
+        """Add more mapsets to the search path
         final = self.read()
         final.extend([m for m in mapsets if m in ms and m not in final])
Modified: grass/trunk/lib/python/pygrass/gis/region.py
--- grass/trunk/lib/python/pygrass/gis/region.py	2014-05-27 10:05:07 UTC (rev 60510)
+++ grass/trunk/lib/python/pygrass/gis/region.py	2014-05-27 11:20:05 UTC (rev 60511)
@@ -15,34 +15,37 @@
 class Region(object):
+        >>> default = Region(default=True)
+        >>> current_good = Region()
+        >>> current = Region()
+        >>> current.align('elevation')
+        >>> default == current
+        True
+        >>> current.cols
+        1500
+        >>> current.ewres
+        10.0
+        >>> current.cols = 3000
+        >>> current.ewres
+        5.0
+        >>> current.ewres = 20.0
+        >>> current.cols
+        750
+        >>> current.set_current()
+        False
+        >>> current.get_default()
+        True
+        >>> current_good.set_current()
     def __init__(self, default=False):
-            >>> default = Region(default=True)
-            >>> current_good = Region()
-            >>> current = Region()
-            >>> current.align('elevation')
-            >>> default == current
-            True
-            >>> current.cols
-            1500
-            >>> current.ewres
-            10.0
-            >>> current.cols = 3000
-            >>> current.ewres
-            5.0
-            >>> current.ewres = 20.0
-            >>> current.cols
-            750
-            >>> current.set_current()
-            False
-            >>> current.get_default()
-            True
-            >>> current_good.set_current()
         self.c_region = ctypes.pointer(libgis.Cell_head())
         if default:
             self.get_default()
@@ -61,7 +64,8 @@
         """Private function to set north value"""
         self.c_region.contents.north = value
-    north = property(fget=_get_n, fset=_set_n)
+    north = property(fget=_get_n, fset=_set_n,
+                     doc="Set and obtain north coordinate")
     def _get_s(self):
         """Private function to obtain south value"""
@@ -71,7 +75,8 @@
         """Private function to set south value"""
         self.c_region.contents.south = value
-    south = property(fget=_get_s, fset=_set_s)
+    south = property(fget=_get_s, fset=_set_s,
+                     doc="Set and obtain south coordinate")
     def _get_e(self):
         """Private function to obtain east value"""
@@ -81,7 +86,8 @@
         """Private function to set east value"""
         self.c_region.contents.east = value
-    east = property(fget=_get_e, fset=_set_e)
+    east = property(fget=_get_e, fset=_set_e,
+                    doc="Set and obtain east coordinate")
     def _get_w(self):
         """Private function to obtain west value"""
@@ -91,7 +97,8 @@
         """Private function to set west value"""
         self.c_region.contents.west = value
-    west = property(fget=_get_w, fset=_set_w)
+    west = property(fget=_get_w, fset=_set_w,
+                    doc="Set and obtain west coordinate")
     def _get_t(self):
         """Private function to obtain top value"""
@@ -101,7 +108,8 @@
         """Private function to set top value"""
         self.c_region.contents.top = value
-    top = property(fget=_get_t, fset=_set_t)
+    top = property(fget=_get_t, fset=_set_t,
+                   doc="Set and obtain top value")
     def _get_b(self):
         """Private function to obtain bottom value"""
@@ -111,7 +119,8 @@
         """Private function to set bottom value"""
         self.c_region.contents.bottom = value
-    bottom = property(fget=_get_b, fset=_set_b)
+    bottom = property(fget=_get_b, fset=_set_b,
+                      doc="Set and obtain bottom value")
     #----------RESOLUTION----------
     def _get_rows(self):
@@ -123,7 +132,8 @@
         self.c_region.contents.rows = value
         self.adjust(rows=True)
-    rows = property(fget=_get_rows, fset=_set_rows)
+    rows = property(fget=_get_rows, fset=_set_rows,
+                    doc="Set and obtain number of rows")
     def _get_cols(self):
         """Private function to obtain columns value"""
@@ -134,7 +144,8 @@
         self.c_region.contents.cols = value
         self.adjust(cols=True)
-    cols = property(fget=_get_cols, fset=_set_cols)
+    cols = property(fget=_get_cols, fset=_set_cols,
+                    doc="Set and obtain number of columns")
     def _get_nsres(self):
         """Private function to obtain north-south value"""
@@ -145,7 +156,8 @@
         self.c_region.contents.ns_res = value
         self.adjust()
-    nsres = property(fget=_get_nsres, fset=_set_nsres)
+    nsres = property(fget=_get_nsres, fset=_set_nsres,
+                     doc="Set and obtain north-south resolution value")
     def _get_ewres(self):
         """Private function to obtain east-west value"""
@@ -156,7 +168,8 @@
         self.c_region.contents.ew_res = value
         self.adjust()
-    ewres = property(fget=_get_ewres, fset=_set_ewres)
+    ewres = property(fget=_get_ewres, fset=_set_ewres,
+                     doc="Set and obtain east-west resolution value")
     def _get_tbres(self):
         """Private function to obtain top-botton 3D value"""
@@ -167,7 +180,8 @@
         self.c_region.contents.tb_res = value
         self.adjust()
-    tbres = property(fget=_get_tbres, fset=_set_tbres)
+    tbres = property(fget=_get_tbres, fset=_set_tbres,
+                     doc="Set and obtain top-bottom 3D value")
     @property
     def zone(self):
@@ -228,12 +242,20 @@
     #----------METHODS----------
     def zoom(self, raster_name):
-        """Shrink region until it meets non-NULL data from this raster map:"""
+        """Shrink region until it meets non-NULL data from this raster map
+        :param raster_name: the name of raster
+        :type raster_name: str
         self._set_param('zoom', str(raster_name))
         self.get_current()
     def align(self, raster_name):
-        """Adjust region cells to cleanly align with this raster map"""
+        """Adjust region cells to cleanly align with this raster map
         self._set_param('align', str(raster_name))
         self.get_current()
@@ -245,13 +267,20 @@
         libgis.G_adjust_Cell_head(self.c_region, bool(rows), bool(cols))
     def vect(self, vector_name):
-        """Adjust bounding box of region using a vector ::
+        """Adjust bounding box of region using a vector
+        :param vector_name: the name of vector
+        :type vector_name: str
         >>> reg = Region()
         >>> reg.vect('census')
         >>> reg.get_bbox()
         Bbox(230963.640878, 212125.562878, 645837.437393, 628769.374393)
         >>> reg.get_default()
         from grass.pygrass.vector import VectorTopo
         vect = VectorTopo(vector_name)
@@ -289,6 +318,8 @@
         >>> reg = Region()
         >>> reg.get_bbox()
         Bbox(228500.0, 215000.0, 645000.0, 630000.0)
         from grass.pygrass.vector.basic import Bbox
         return Bbox(north=self.north, south=self.south,
@@ -296,16 +327,22 @@
                     top=self.top, bottom=self.bottom)
     def set_bbox(self, bbox):
-        """Set region from Bbox ::
+        """Set region extent from Bbox
+        :param bbox: a Bbox object to set the extent
+        :type bbox: Bbox object
-        >>> b = Bbox(230963.640878, 212125.562878,
-        ...          645837.437393, 628769.374393)
+        >>> b = Bbox(230963.640878, 212125.562878, 645837.437393, 628769.374393)
         >>> reg = Region()
         >>> reg.set_bbox(b)
         >>> reg.get_bbox()
         >>> reg.get_current()
         self.north = bbox.north
         self.south = bbox.south
Modified: grass/trunk/lib/python/pygrass/raster/__init__.py
--- grass/trunk/lib/python/pygrass/raster/__init__.py	2014-05-27 10:05:07 UTC (rev 60510)
+++ grass/trunk/lib/python/pygrass/raster/__init__.py	2014-05-27 11:20:05 UTC (rev 60511)
@@ -56,7 +56,6 @@
     Examples
         >>> elev = RasterRow('elevation')
         >>> elev.exist()
         True
@@ -91,7 +90,7 @@
     Open a raster map using the *with statement*: ::
-        >>> with RasterRow('elevation') as elev:
+        >>> with RasterRow('elevation') as elev:
         ...     for row in elev[:3]:
         ...         row[:4]
@@ -111,6 +110,11 @@
         """Private method that return the row using the read mode
         call the `Rast_get_row` C function.
+        :param row: the number of row to obtain
+        :type row: int
+        :param row_buffer: specify the Buffer object that will be instantiate
+        :type row_buffer: bool
         >>> elev.open()
         >>> elev[0]                 # doctest: +ELLIPSIS +NORMALIZE_WHITESPACE
@@ -129,24 +133,26 @@
     @must_be_open
     def put_row(self, row):
         """Private method to write the row sequentially.
+        :param row: a Row object to insert into raster
+        :type row: Buffer object
         libraster.Rast_put_row(self._fd, row.p, self._gtype)
     def open(self, mode=None, mtype=None, overwrite=None):
         """Open the raster if exist or created a new one.
-        Parameters
+        :param mode: Specify if the map will be open with read or write mode
+                     ('r', 'w')
+        :type mode: str
+        :param type: If a new map is open, specify the type of the map(`CELL`,
+                     `FCELL`, `DCELL`)
+        :type type: str
+        :param overwrite: Use this flag to set the overwrite mode of existing
+                          raster maps
+        :type overwrite: bool
-        mode: string
-            Specify if the map will be open with read or write mode ('r', 'w')
-        type: string
-            If a new map is open, specify the type of the map(`CELL`, `FCELL`,
-            `DCELL`)
-        overwrite: Boolean
-            Use this flag to set the overwrite mode of existing raster maps
         if the map already exist, automatically check the type and set:
             * self.mtype
@@ -203,11 +209,24 @@
         super(RasterRowIO, self).__init__(name, *args, **kargs)
     def open(self, mode=None, mtype=None, overwrite=False):
+        """Open the raster if exist or created a new one.
+        :param mode: specify if the map will be open with read or write mode
+                     ('r', 'w')
+        :type mode: str
+        :param type: if a new map is open, specify the type of the map(`CELL`,
+                     `FCELL`, `DCELL`)
+        :type type: str
+        :param overwrite: use this flag to set the overwrite mode of existing
+                          raster maps
         super(RasterRowIO, self).open(mode, mtype, overwrite)
         self.rowio.open(self._fd, self._rows, self._cols, self.mtype)
     @must_be_open
     def close(self):
+        """Function to close the raster"""
         self.rowio.release()
         libraster.Rast_close(self._fd)
         # update rows and cols attributes
@@ -222,6 +241,10 @@
             * the read mode and
             * `rowcache` method
+        :type row: int
+        :param row_buffer: Specify the Buffer object that will be instantiate
+        :type row_buffer: Buffer object
         if row_buffer is None:
             row_buffer = Buffer((self._cols,), self.mtype)
@@ -260,7 +283,8 @@
             raise ValueError(str_err.format(mode))
         self._mode = mode
-    mode = property(fget=_get_mode, fset=_set_mode)
+    mode = property(fget=_get_mode, fset=_set_mode,
+                    doc="Set or obtain the opening mode of raster")
     def __setitem__(self, key, row):
         """Return the row of Raster object, slice allowed."""
@@ -303,13 +327,10 @@
     def get_row(self, row, row_buffer=None):
         """Return the row using the `segment.get_row` method
-        Parameters
-        row: integer
-            Specify the row number;
-        row_buffer: Buffer object, optional
-            Specify the Buffer object that will be instantiate.
+        :param row: specify the row number
+        :type row: int
             row_buffer = Buffer((self._cols), self.mtype)
@@ -319,13 +340,8 @@
     def put_row(self, row, row_buffer):
         """Write the row using the `segment.put_row` method
-        Parameters
-        row: integer
-            Specify the Buffer object that will be write to the map.
         self.segment.put_row(row, row_buffer)
@@ -333,13 +349,10 @@
     def get(self, row, col):
         """Return the map value using the `segment.get` method
-        Parameters
-        row: integer
-        col: integer
-            Specify the column number.
+        :param row: Specify the row number
+        :type row: int
+        :param col: Specify the column number
+        :type col: int
         return self.segment.get(row, col)
@@ -347,15 +360,12 @@
     def put(self, row, col, val):
         """Write the value to the map using the `segment.put` method
-        Parameters
-        row: integer
-        col: integer
-        val: value
-            Specify the value that will be write to the map cell.
+        :type row: int
+        :type col: int
+        :param val: Specify the value that will be write to the map cell
+        :type val: value
         self.segment.val.value = val
         self.segment.put(row, col)
@@ -365,16 +375,15 @@
         and copy the map to the segment files;
         else, open a new segment map.
-        Parameters
-        mode: string, optional
-            Specify if the map will be open with read, write or read/write
-            mode ('r', 'w', 'rw')
-        mtype: string, optional
-            Specify the map type, valid only for new maps: CELL, FCELL, DCELL;
-        overwrite: Boolean, optional
+        :param mode: specify if the map will be open with read, write or
+                     read/write mode ('r', 'w', 'rw')
+        :type mode: str
+        :param mtype: specify the map type, valid only for new maps: CELL,
+                      FCELL, DCELL
+        :type mtype: str
+                          raster maps
         # read rows and cols from the active region
         self._rows = libraster.Rast_window_rows()
@@ -433,11 +442,8 @@
     def close(self, rm_temp_files=True):
         """Close the map, copy the segment files to the map.
-        Parameters
-        rm_temp_files: bool
-            If True all the segments file will be removed.
+        :param rm_temp_files: if True all the segments file will be removed
+        :type rm_temp_files: bool
         if self.mode == "w" or self.mode == "rw":
             self.segment.flush()
@@ -537,7 +543,8 @@
             raise ValueError(_("Mode type: {0} not supported.").format(mode))
         self._mode = mode
     def __array_wrap__(self, out_arr, context=None):
         """See:
@@ -584,10 +591,9 @@
                 self[i] = rst.get_row(i, buff)
     def _write(self):
+        """Write the numpy array into map
-        r.in.bin input=/home/pietro/docdat/phd/thesis/gis/north_carolina/user1/.tmp/eraclito/14325.0 output=new title='' bytes=1,anull='' --verbose --overwrite north=228500.0 south=215000.0 east=645000.0 west=630000.0 rows=1350 cols=1500
+        #r.in.bin input=/home/pietro/docdat/phd/thesis/gis/north_carolina/user1/.tmp/eraclito/14325.0 output=new title='' bytes=1,anull='' --verbose --overwrite north=228500.0 south=215000.0 east=645000.0 west=630000.0 rows=1350 cols=1500
         if not self.exist() or self.mode != 'r':
             self.flush()
             buff = Buffer(self[0].shape, mtype=self.mtype)
@@ -602,11 +608,14 @@
-        Parameters
+                      FCELL, DCELL;
+        :type mtype: str
+        :param null:
+        :type null:
+                          raster maps
         if overwrite is not None:
             self.overwrite = overwrite
@@ -627,6 +636,11 @@
         self._fd = 1
     def close(self, name=''):
+        """Function to close the map
+        :param name: the name of raster
+        :type name: str
         if self.is_open():
             name = name if name else self.name
             if not name:
@@ -639,10 +653,10 @@
     def get_value(self, point, region=None):
         """This method returns the pixel value of a given pair of coordinates:
-        Parameters
-        point = pair of coordinates in tuple object
+        :param point: pair of coordinates in tuple object
+        :type point: tuple
+        :param region: the region to crop the request
+        :type region: Region object
         if not region:
             region = Region()
Modified: grass/trunk/lib/python/pygrass/raster/category.py
--- grass/trunk/lib/python/pygrass/raster/category.py	2014-05-27 10:05:07 UTC (rev 60510)
+++ grass/trunk/lib/python/pygrass/raster/category.py	2014-05-27 11:20:05 UTC (rev 60511)
@@ -80,11 +80,12 @@
     def _set_mtype(self, mtype):
         if mtype.upper() not in ('CELL', 'FCELL', 'DCELL'):
             #fatal(_("Raser type: {0} not supported".format(mtype) ) )
-            raise ValueError(_("Raser type: {0} not supported".format(mtype)))
+            raise ValueError(_("Raster type: {0} not supported".format(mtype)))
         self._mtype = mtype
         self._gtype = RTYPE[self.mtype]['grass type']
-    mtype = property(fget=_get_mtype, fset=_set_mtype)
+    mtype = property(fget=_get_mtype, fset=_set_mtype,
+                     doc="Set or obtain raster data type")
     def _get_title(self):
         return libraster.Rast_get_cats_title(ctypes.byref(self.c_cats))
@@ -93,7 +94,8 @@
         return libraster.Rast_set_cats_title(newtitle,
-    title = property(fget=_get_title, fset=_set_title)
+    title = property(fget=_get_title, fset=_set_title,
+                     doc="Set or obtain raster title")
     def __str__(self):
         return self.__repr__()
@@ -266,7 +268,11 @@
         libraster.Rast_write_cats(self.name, ctypes.byref(self.c_cats))
     def copy(self, category):
-        """Copy from another Category class"""
+        """Copy from another Category class
+        :param category: Category class to be copied
+        :type category: Category object
         libraster.Rast_copy_cats(ctypes.byref(self.c_cats),     # to
                                  ctypes.byref(category._cats))  # from
         self._read_cats()
@@ -293,7 +299,12 @@
             0.5:1.0:road
             1.0:1.5:urban
+        :param filename: the name of file with categories rules
+        :type filename: str
+        :param sep: the separator used to divide values and category
+        :type sep: str
         self.reset()
         with open(filename, 'r') as f:
             for row in f.readlines():
@@ -320,7 +331,12 @@
             0.5:1.0:road
             1.0:1.5:urban
+        :type sep: str
         with open(filename, 'w') as f:
             cats = []
             for cat in self.__iter__():
Modified: grass/trunk/lib/python/pygrass/raster/history.py
--- grass/trunk/lib/python/pygrass/raster/history.py	2014-05-27 10:05:07 UTC (rev 60510)
+++ grass/trunk/lib/python/pygrass/raster/history.py	2014-05-27 11:20:05 UTC (rev 60511)
@@ -76,7 +76,8 @@
                                           libraster.HIST_CREATOR,
                                           ctypes.c_char_p(creator))
-    creator = property(fget=_get_creator, fset=_set_creator)
+    creator = property(fget=_get_creator, fset=_set_creator,
+                       doc="Set or obtain the creator of map")
     #libraster.HIST_DATSRC_1
@@ -89,7 +90,8 @@
                                           libraster.HIST_DATSRC_1,
                                           ctypes.c_char_p(src1))
-    src1 = property(fget=_get_src1, fset=_set_src1)
+    src1 = property(fget=_get_src1, fset=_set_src1,
+                    doc="Set or obtain the first source of map")
     #libraster.HIST_DATSRC_2
@@ -102,7 +104,8 @@
                                           libraster.HIST_DATSRC_2,
                                           ctypes.c_char_p(src2))
-    src2 = property(fget=_get_src2, fset=_set_src2)
+    src2 = property(fget=_get_src2, fset=_set_src2,
+                    doc="Set or obtain the second source of map")
     #libraster.HIST_KEYWORD
@@ -115,7 +118,8 @@
                                           libraster.HIST_KEYWRD,
                                           ctypes.c_char_p(keyword))
-    keyword = property(fget=_get_keyword, fset=_set_keyword)
+    keyword = property(fget=_get_keyword, fset=_set_keyword,
+                       doc="Set or obtain the keywords of map")
     #libraster.HIST_MAPID
@@ -132,7 +136,8 @@
                                               libraster.HIST_MAPID,
                                               ctypes.c_char_p(date_str))
-    date = property(fget=_get_date, fset=_set_date)
+    date = property(fget=_get_date, fset=_set_date,
+                    doc="Set or obtain the date of map")
     #libraster.HIST_MAPSET
@@ -145,7 +150,8 @@
                                           libraster.HIST_MAPSET,
                                           ctypes.c_char_p(mapset))
-    mapset = property(fget=_get_mapset, fset=_set_mapset)
+    mapset = property(fget=_get_mapset, fset=_set_mapset,
+                      doc="Set or obtain the mapset of map")
     #libraster.HIST_MAPTYPE
@@ -158,7 +164,8 @@
                                           libraster.HIST_MAPTYPE,
                                           ctypes.c_char_p(maptype))
-    maptype = property(fget=_get_maptype, fset=_set_maptype)
+    maptype = property(fget=_get_maptype, fset=_set_maptype,
+                       doc="Set or obtain the type of map")
     #libraster.HIST_NUM_FIELDS
@@ -186,7 +193,8 @@
                                           libraster.HIST_TITLE,
                                           ctypes.c_char_p(title))
+                     doc="Set or obtain the title of map")
     def append(self, obj):
         """Rast_append_history"""
