[GRASS-SVN] r60514 - grass/trunk/lib/gis
svn_grass at osgeo.org
Tue May 27 08:13:40 PDT 2014
Author: hcho
Date: 2014-05-27 08:13:40 -0700 (Tue, 27 May 2014)
New Revision: 60514
grass/trunk/lib/gis/parser.c
libgis: Added G_open/close_option_file
Modified: grass/trunk/lib/gis/parser.c
--- grass/trunk/lib/gis/parser.c 2014-05-27 14:15:04 UTC (rev 60513)
+++ grass/trunk/lib/gis/parser.c 2014-05-27 15:13:40 UTC (rev 60514)
@@ -1457,12 +1457,79 @@
sep = G_store("\n");
else if (strcmp(option->answer, "comma") == 0)
sep = G_store(",");
- else {
+ else
sep = G_store(option->answer);
G_debug(1, "G_option_to_separator(): key = %s -> sep = '%s'",
option->key, sep);
return sep;
+ \brief Get an input/output file pointer from the option. If the file name is
+ omitted or '-', it returns either stdin or stdout based on the gisprompt.
+ Calls G_fatal_error() on error. File pointer can be later closed by
+ G_close_option_file().
+ \code
+ FILE *fp_input;
+ FILE *fp_output;
+ struct Option *opt_input;
+ struct Option *opt_output;
+ opt_input = G_define_standard_option(G_OPT_F_INPUT);
+ opt_output = G_define_standard_option(G_OPT_F_OUTPUT);
+ if (G_parser(argc, argv))
+ exit(EXIT_FAILURE);
+ fp_input = G_open_option_file(opt_input);
+ fp_output = G_open_option_file(opt_output);
+ G_close_option_file(fp_input);
+ G_close_option_file(fp_output);
+ \endcode
+ \param option pointer to a file option
+ \return file pointer
+FILE *G_open_option_file(const struct Option *option)
+ int stdinout;
+ FILE *fp;
+ stdinout = !option->answer || !*(option->answer) ||
+ strcmp(option->answer, "-") == 0;
+ if (option->gisprompt == NULL)
+ G_fatal_error(_("Not a file option"));
+ else if (strcmp(option->gisprompt, "old,file,file") == 0) {
+ if (stdinout)
+ fp = stdin;
+ else if ((fp = fopen(option->answer, "r")) == NULL)
+ G_fatal_error(_("Unable to read file [%s]"), option->answer);
+ } else if (strcmp(option->gisprompt, "new,file,file") == 0) {
+ if (stdinout)
+ fp = stdout;
+ else if ((fp = fopen(option->answer, "w")) == NULL)
+ G_fatal_error(_("Unable to create file [%s]"), option->answer);
+ } else
+ return fp;
+ \brief Close an input/output file returned by G_open_option_file(). If the
+ file pointer is stdin, stdout, or stderr, nothing happens.
+ \param file pointer
+void G_close_option_file(FILE *fp)
+ if (fp != stdin && fp != stdout && fp != stderr)
+ fclose(fp);
