[GRASS-SVN] r60519 - grass/trunk/vector/v.in.ascii
svn_grass at osgeo.org
Tue May 27 09:15:13 PDT 2014
Author: hcho
Date: 2014-05-27 09:15:13 -0700 (Tue, 27 May 2014)
New Revision: 60519
grass/trunk/vector/v.in.ascii/main.c
v.in.ascii: use G_open_option_file, G_option_to_separator
Modified: grass/trunk/vector/v.in.ascii/main.c
--- grass/trunk/vector/v.in.ascii/main.c 2014-05-27 16:14:18 UTC (rev 60518)
+++ grass/trunk/vector/v.in.ascii/main.c 2014-05-27 16:15:13 UTC (rev 60519)
@@ -203,24 +203,8 @@
if (xcol+1 < 1 || ycol+1 < 1 || zcol+1 < 0 || catcol+1 < 0)
G_fatal_error(_("Column numbers must not be negative"));
- if (strcmp(old->answer, "-")) {
- if ((ascii = fopen(old->answer, "r")) == NULL) {
- G_fatal_error(_("Unable to open ASCII file <%s>"), old->answer);
- else {
- ascii = stdin;
- fs = delim_opt->answer;
- if (strcmp(fs, "\\t") == 0)
- fs = "\t";
- if (strcmp(fs, "tab") == 0)
- fs = "\t";
- if (strcmp(fs, "space") == 0)
- fs = " ";
- if (strcmp(fs, "comma") == 0)
- fs = ",";
+ ascii = G_open_option_file(old);
+ fs = G_option_to_separator(delim_opt);
/* check dimension */
if (zcoorf->answer) {
@@ -539,8 +523,7 @@
G_fatal_error(_("Import failed"));
- if (ascii != stdin)
- fclose(ascii);
+ G_close_option_file(ascii);
if (notopol_flag->answer) {
Vect_close(&Map);
