[GRASS-SVN] r60526 - grass-addons/grass6/display/d.barb
svn_grass at osgeo.org
Tue May 27 23:16:39 PDT 2014
Author: hamish
Date: 2014-05-27 23:16:39 -0700 (Tue, 27 May 2014)
New Revision: 60526
grass-addons/grass6/display/d.barb/points.c
respect peak= setting with vector input
Modified: grass-addons/grass6/display/d.barb/points.c
--- grass-addons/grass6/display/d.barb/points.c 2014-05-28 05:57:39 UTC (rev 60525)
+++ grass-addons/grass6/display/d.barb/points.c 2014-05-28 06:16:39 UTC (rev 60526)
@@ -59,6 +59,8 @@
fill_arrays(&vMap, vlayer, dir_u_col, mag_v_col, is_component,
coord_x, coord_y, dirn, magn);
+ G_debug(3, "Arrays are filled.");
if (aspect_type == TYPE_GRASS) {
for (i = 0; i < num_pts; i++) {
//G_debug(5, "in=%.1f out=%.1f", dirn[i], 90-dirn[i] < 0 ? 360+90-dirn[i] : 90-dirn[i]);
@@ -88,9 +90,10 @@
G_warning(_("Maximum wind barb displayed is 150 knots"));
- peak = 1.; // TODO: window width * 0.20
- scale_fact = (peak) * scale;
+ scale_fact = 20. * scale / peak;
+ G_debug(3, "Ready to draw");
draw_barb(coord_x[i], coord_y[i], magn[i] * scale_fact, dirn[i],
color, scale, style);
@@ -218,6 +221,8 @@
Vect_rewind(Map);
i = 0;
+ G_debug(3, "Select is done.");
while (1) {
ltype = Vect_read_next_line(Map, Points, Cats);
switch (ltype) {
