[GRASS-SVN] r60533 - in grass/trunk/lib/python/pygrass: docs raster vector
svn_grass at osgeo.org
Wed May 28 04:09:47 PDT 2014
Author: lucadelu
Date: 2014-05-28 04:09:47 -0700 (Wed, 28 May 2014)
New Revision: 60533
grass/trunk/lib/python/pygrass/docs/raster.rst
grass/trunk/lib/python/pygrass/docs/vector.rst
grass/trunk/lib/python/pygrass/raster/history.py
grass/trunk/lib/python/pygrass/vector/__init__.py
grass/trunk/lib/python/pygrass/vector/abstract.py
grass/trunk/lib/python/pygrass/vector/basic.py
grass/trunk/lib/python/pygrass/vector/geometry.py
grass/trunk/lib/python/pygrass/vector/table.py
pygrass doc: improve documentation on vector and raster classes
Modified: grass/trunk/lib/python/pygrass/docs/raster.rst
--- grass/trunk/lib/python/pygrass/docs/raster.rst 2014-05-28 11:08:28 UTC (rev 60532)
+++ grass/trunk/lib/python/pygrass/docs/raster.rst 2014-05-28 11:09:47 UTC (rev 60533)
@@ -1,7 +1,7 @@
.. _raster-label:
-Raster
+Introduction on Raster
PyGRASS uses 4 different Raster classes, that respect the 4 different approaches
of GRASS-C API.
Modified: grass/trunk/lib/python/pygrass/docs/vector.rst
--- grass/trunk/lib/python/pygrass/docs/vector.rst 2014-05-28 11:08:28 UTC (rev 60532)
+++ grass/trunk/lib/python/pygrass/docs/vector.rst 2014-05-28 11:09:47 UTC (rev 60533)
@@ -1,6 +1,6 @@
-Vector
+Introduction on Vector
Instantiation and basic interaction. ::
@@ -114,16 +114,17 @@
Bbox(199947.296494, 199280.969494, 754920.623987, 754351.812986)
-VectorTopo
+Vector
-.. autoclass:: pygrass.vector.VectorTopo
+.. autoclass:: pygrass.vector.Vector
:members:
-Vector
+VectorTopo
+.. autoclass:: pygrass.vector.VectorTopo
:members:
@@ -165,7 +166,7 @@
Area
-.. autoclass:: pygrass.vector.geometry.Boundary
+.. autoclass:: pygrass.vector.geometry.Area
:members:
Utils
Modified: grass/trunk/lib/python/pygrass/raster/history.py
--- grass/trunk/lib/python/pygrass/raster/history.py 2014-05-28 11:08:28 UTC (rev 60532)
+++ grass/trunk/lib/python/pygrass/raster/history.py 2014-05-28 11:09:47 UTC (rev 60533)
@@ -10,31 +10,29 @@
class History(object):
- *Examples*
+ """History class help to manage all the metadata of a raster map
- >>> import grass.lib.gis as libgis
- >>> libgis.G_gisinit('')
- >>> hist = History('elevation')
- >>> hist.creator
- 'helena'
- >>> hist.src1
- >>> hist.src2
- >>> hist.keyword
- 'generated by r.proj'
- >>> hist.date
- datetime.datetime(2006, 11, 7, 1, 9, 51)
- >>> hist.mapset
- 'PERMANENT'
- >>> hist.maptype
- 'raster'
- >>> hist.title
- 'elev_ned10m'
+ >>> import grass.lib.gis as libgis
+ >>> libgis.G_gisinit('')
+ >>> hist = History('elevation')
+ >>> hist.read()
+ >>> hist.creator
+ 'helena'
+ >>> hist.src1
+ >>> hist.src2
+ >>> hist.keyword
+ 'generated by r.proj'
+ >>> hist.date
+ datetime.datetime(2006, 11, 7, 1, 9, 51)
+ >>> hist.mapset
+ 'PERMANENT'
+ >>> hist.maptype
+ 'raster'
+ >>> hist.title
+ 'elev_ned10m'
def __init__(self, name, mapset='', mtype='',
creator='', src1='', src2='', keyword='',
@@ -208,7 +206,7 @@
*args)
def clear(self):
- """Rast_clear_history"""
+ """Clear the history"""
libraster.Rast_clear_history(self.c_hist)
def command(self):
@@ -232,7 +230,8 @@
ctypes.c_int(line))
def read(self):
- """Rast_read_history. ::
+ """Read the history of map, users need to use this function to
+ obtain all the information of map. ::
Modified: grass/trunk/lib/python/pygrass/vector/__init__.py
--- grass/trunk/lib/python/pygrass/vector/__init__.py 2014-05-28 11:08:28 UTC (rev 60532)
+++ grass/trunk/lib/python/pygrass/vector/__init__.py 2014-05-28 11:09:47 UTC (rev 60533)
@@ -40,7 +40,7 @@
class Vector(Info):
+ """Vector class is the grass vector format without topology
>>> from grass.pygrass.vector import Vector
>>> cens = Vector('census')
@@ -55,7 +55,6 @@
>>> cens.overwrite
False
def __init__(self, name, mapset='', *args, **kwargs):
# Set map name and mapset
@@ -103,6 +102,7 @@
@must_be_open
def rewind(self):
+ """Rewind vector map to cause reads to start at beginning."""
if libvect.Vect_rewind(self.c_mapinfo) == -1:
raise GrassError("Vect_rewind raise an error.")
@@ -110,22 +110,18 @@
def write(self, geo_obj, attrs=None, set_cats=True):
"""Write geometry features and attributes.
- Parameters
+ :param geo_obj: a geometry grass object define in
+ grass.pygrass.vector.geometry
+ :type geo_obj: geometry GRASS object
+ :param attrs: a list with the values that will be insert in the
+ attribute table.
+ :type attrs: list
+ :param set_cats: if True, the category of the geometry feature is set
+ using the default layer of the vector map and a
+ progressive category value (default), otherwise the
+ c_cats attribute of the geometry object will be used.
+ :type set_cats: bool
- geo_obj : geometry GRASS object
- A geometry grass object define in grass.pygrass.vector.geometry.
- attrs: list, optional
- A list with the values that will be insert in the attribute table.
- set_cats, bool, optional
- If True, the category of the geometry feature is set using the
- default layer of the vector map and a progressive category value
- (default), otherwise the c_cats attribute of the geometry object
- will be used.
- Examples
Open a new vector map ::
>>> new = VectorTopo('newvect')
@@ -175,7 +171,6 @@
>>> new.close()
>>> new.remove()
self.n_lines += 1
if self.table is not None and attrs:
@@ -208,8 +203,6 @@
"""Return if vector has color table associated in file system;
Color table stored in the vector's attribute table well be not checked
- Examples
>>> cens.open()
>>> cens.has_color_table()
@@ -252,6 +245,7 @@
>>> schools.is_open()
False
super(VectorTopo, self).__init__(name, mapset, *args, **kwargs)
@@ -284,17 +278,21 @@
@must_be_open
def num_primitive_of(self, primitive):
- """Primitive are:
+ """Return the number of primitive
- * "boundary",
- * "centroid",
- * "face",
- * "kernel",
- * "line",
- * "point"
- * "area"
- * "volume"
+ :param primitive: the name of primitive to query; the supported values are:
+ * *boundary*,
+ * *centroid*,
+ * *face*,
+ * *kernel*,
+ * *line*,
+ * *point*
+ * *area*
+ * *volume*
+ :type primitive: str
>>> cens = VectorTopo('boundary_municp_sqlite')
@@ -316,11 +314,14 @@
@must_be_open
def number_of(self, vtype):
- vtype in ["areas", "dblinks", "faces", "holes", "islands", "kernels",
- "line_points", "lines", "nodes", "update_lines",
- "update_nodes", "volumes"]
+ """Return the number of the choosen element type
+ :param vtype: the name of type to query; the supported values are:
+ *areas*, *dblinks*, *faces*, *holes*, *islands*,
+ *kernels*, *line_points*, *lines*, *nodes*,
+ *update_lines*, *update_nodes*, *volumes*
+ :type vtype: str
>>> cens.open()
>>> cens.number_of("areas")
@@ -365,7 +366,15 @@
def viter(self, vtype, idonly=False):
"""Return an iterator of vector features
+ :type vtype: str
+ :param idonly: variable to return only the id of features instead of
+ full features
+ :type idonly: bool
>>> cens = VectorTopo('census')
>>> cens.open()
>>> big = [area for area in cens.viter('areas')
@@ -385,7 +394,6 @@
Area(2552) 298356117.948
>>> cens.close()
if vtype in _GEOOBJ.keys():
if _GEOOBJ[vtype] is not None:
@@ -425,16 +433,15 @@
def cat(self, cat_id, vtype, layer=None, generator=False, geo=None):
"""Return the geometry features with category == cat_id.
- Parameters
- cat_id : integer
- Integer with the category number.
- vtype : string
- String of the type of geometry feature that we are looking for.
- layer : integer, optional
- Integer of the layer that will be used.
- generator : bool, optional
- If True return a generator otherwise it return a list of features.
+ :param cat_id: the category number
+ :type cat_id: int
+ :param vtype: the type of geometry feature that we are looking for
+ :type vtype: str
+ :param layer: the layer number that will be used
+ :type layer: int
+ :param generator: if True return a generator otherwise it return a
+ list of features
+ :type generator: bool
if geo is None and vtype not in _GEOOBJ:
keys = "', '".join(sorted(_GEOOBJ.keys()))
@@ -455,8 +462,12 @@
@must_be_open
def read(self, feature_id):
- """Return a geometry object given the feature id. ::
+ """Return a geometry object given the feature id.
+ :param feature_id: the id of feature to obtain
+ :type feature_id: int
>>> mun = VectorTopo('boundary_municp_sqlite')
>>> mun.open()
>>> feature1 = mun.read(0) #doctest: +ELLIPSIS
@@ -480,7 +491,6 @@
IndexError: Index out of range
>>> mun.close()
return read_line(feature_id, self.c_mapinfo, self.table, self.writable)
@@ -504,7 +514,9 @@
attr = [line, ]
attr.extend(attrs)
self.table.update(key=line, values=attr)
+ elif self.table is None and attrs:
+ print "Table for vector {name} does not exist, attributes not" \
+ " loaded".format(name=self.name)
libvect.Vect_cat_set(geo_obj.c_cats, self.layer, line)
result = libvect.Vect_rewrite_line(self.c_mapinfo,
line, geo_obj.gtype,
@@ -518,6 +530,11 @@
@must_be_open
def delete(self, feature_id):
+ """Remove a feature by its id
+ :param feature_id: the id of the feature
if libvect.Vect_rewrite_line(self.c_mapinfo, feature_id) == -1:
raise GrassError("C funtion: Vect_rewrite_line.")
@@ -541,8 +558,9 @@
@must_be_open
def select_by_bbox(self, bbox):
- """Return the BBox of the vecor map
+ """Return the BBox of the vector map
+ # TODO replace with bbox if bbox else Bbox() ??
bbox = Bbox()
if libvect.Vect_get_map_box(self.c_mapinfo, bbox.c_bbox) == 0:
raise GrassError("I can not find the Bbox.")
Modified: grass/trunk/lib/python/pygrass/vector/abstract.py
--- grass/trunk/lib/python/pygrass/vector/abstract.py 2014-05-28 11:08:28 UTC (rev 60532)
+++ grass/trunk/lib/python/pygrass/vector/abstract.py 2014-05-28 11:09:47 UTC (rev 60533)
@@ -111,18 +111,20 @@
self.rename(newname)
self._name = newname
- name = property(fget=_get_name, fset=_set_name)
+ name = property(fget=_get_name, fset=_set_name,
+ doc="Set or obtain the Vector name")
def _get_mapset(self):
- """Private method to obtain the Vector name"""
+ """Private method to obtain the Vector mapset"""
return self._mapset
def _set_mapset(self, mapset):
- """Private method to change the Vector name"""
+ """Private method to change the Vector mapset"""
if mapset:
self._mapset = mapset
- mapset = property(fget=_get_mapset, fset=_set_mapset)
+ mapset = property(fget=_get_mapset, fset=_set_mapset,
+ doc="Set or obtain the Vector mapset")
def _get_organization(self):
"""Private method to obtain the Vector organization"""
@@ -132,7 +134,8 @@
"""Private method to change the Vector organization"""
libvect.Vect_get_organization(self.c_mapinfo, ctypes.c_char_p(org))
- organization = property(fget=_get_organization, fset=_set_organization)
+ organization = property(fget=_get_organization, fset=_set_organization,
+ doc="Set or obtain the Vector organization")
def _get_date(self):
"""Private method to obtain the Vector date"""
@@ -142,7 +145,8 @@
"""Private method to change the Vector date"""
return libvect.Vect_set_date(self.c_mapinfo, ctypes.c_char_p(date))
- date = property(fget=_get_date, fset=_set_date)
+ date = property(fget=_get_date, fset=_set_date,
+ doc="Set or obtain the Vector date")
def _get_person(self):
"""Private method to obtain the Vector person"""
@@ -152,7 +156,8 @@
"""Private method to change the Vector person"""
libvect.Vect_set_person(self.c_mapinfo, ctypes.c_char_p(person))
- person = property(fget=_get_person, fset=_set_person)
+ person = property(fget=_get_person, fset=_set_person,
+ doc="Set or obtain the Vector author")
def _get_title(self):
"""Private method to obtain the Vector title"""
@@ -162,7 +167,8 @@
"""Private method to change the Vector title"""
libvect.Vect_set_map_name(self.c_mapinfo, ctypes.c_char_p(title))
- title = property(fget=_get_title, fset=_set_title)
+ title = property(fget=_get_title, fset=_set_title,
+ doc="Set or obtain the Vector title")
def _get_map_date(self):
"""Private method to obtain the Vector map date"""
@@ -174,7 +180,8 @@
date_str = datetimeobj.strftime(self.date_fmt)
libvect.Vect_set_map_date(self.c_mapinfo, ctypes.c_char_p(date_str))
- map_date = property(fget=_get_map_date, fset=_set_map_date)
+ map_date = property(fget=_get_map_date, fset=_set_map_date,
+ doc="Set or obtain the Vector map date")
def _get_scale(self):
"""Private method to obtain the Vector scale"""
@@ -184,7 +191,8 @@
"""Private method to set the Vector scale"""
return libvect.Vect_set_scale(self.c_mapinfo, ctypes.c_int(scale))
- scale = property(fget=_get_scale, fset=_set_scale)
+ scale = property(fget=_get_scale, fset=_set_scale,
+ doc="Set or obtain the Vector scale")
def _get_comment(self):
"""Private method to obtain the Vector comment"""
@@ -194,7 +202,8 @@
"""Private method to set the Vector comment"""
return libvect.Vect_set_comment(self.c_mapinfo, ctypes.c_char_p(comm))
- comment = property(fget=_get_comment, fset=_set_comment)
+ comment = property(fget=_get_comment, fset=_set_comment,
+ doc="Set or obtain the Vector comment")
def _get_zone(self):
"""Private method to obtain the Vector projection zone"""
@@ -204,7 +213,8 @@
"""Private method to set the Vector projection zone"""
return libvect.Vect_set_zone(self.c_mapinfo, ctypes.c_int(zone))
- zone = property(fget=_get_zone, fset=_set_zone)
+ zone = property(fget=_get_zone, fset=_set_zone,
+ doc="Set or obtain the Vector projection zone")
def _get_proj(self):
"""Private method to obtain the Vector projection code"""
@@ -214,7 +224,8 @@
"""Private method to set the Vector projection code"""
libvect.Vect_set_proj(self.c_mapinfo, ctypes.c_int(proj))
- proj = property(fget=_get_proj, fset=_set_proj)
+ proj = property(fget=_get_proj, fset=_set_proj,
+ doc="Set or obtain the Vector projection code")
def _get_thresh(self):
"""Private method to obtain the Vector threshold"""
@@ -224,7 +235,8 @@
"""Private method to set the Vector threshold"""
return libvect.Vect_set_thresh(self.c_mapinfo, ctypes.c_double(thresh))
- thresh = property(fget=_get_thresh, fset=_set_thresh)
+ thresh = property(fget=_get_thresh, fset=_set_thresh,
+ doc="Set or obtain the Vector threshold")
@property
@must_be_open
@@ -248,7 +260,11 @@
libvect.Vect_write_header(self.c_mapinfo)
def rename(self, newname):
- """Method to rename the Vector map"""
+ """Method to rename the Vector map
+ :param newname: the new name for the Vector map
+ :type newname: str
if self.exist():
if not self.is_open():
functions.rename(self.name, newname, 'vect')
@@ -282,34 +298,34 @@
link_driver='sqlite'):
"""Open a Vector map.
- Parameters
- mode : string
- Open a vector map in ``r`` in reading, ``w`` in writing and
- in ``rw`` read and write mode
- layer: int, optional
- Specify the layer that you want to use
+ :param mode: open a vector map in ``r`` in reading, ``w`` in writing
+ and in ``rw`` read and write mode
+ :type mode: str
+ :param layer: specify the layer that you want to use
+ :type layer: int
+ :param overwrite: valid only for ``w`` mode
+ :type overwrite: bool
+ :param tab_name: define the name of the table that will be generate
+ :type tab_name: str
+ :param tab_cols: define the name and type of the columns of the
+ attribute table of the vecto map
+ :type tab_cols: list of pairs
+ :param link_name: define the name of the link connecttion with the
+ database
+ :type link_name: str
+ :param link_key: define the nema of the column that will be use as
+ vector category
+ :type link_key: str
+ :param link_db: define the database connection parameters
+ :type link_db: str
+ :param link_driver: define witch database driver will be used
+ :param link_driver: str
- Some parameters are valid only if we open use the writing mode (``w``)
+ Some of the parameters are valid only with mode ``w`` or ``rw``
- overwrite: bool, optional
- valid only for ``w`` mode
- tab_name: string, optional
- Define the name of the table that will be generate
- tab_cols: list of pairs, optional
- Define the name and type of the columns of the attribute table
- of the vecto map
- link_name: string, optional
- Define the name of the link connecttion with the database
- link_key: string, optional
- Define the nema of the column that will be use as vector category
- link_db: string, optional
- Define the database connection parameters
- link_driver: string, optional
- Define witch database driver will be used
See more examples in the documentation of the ``read`` and ``write``
- methods.
+ methods
self.mode = mode if mode else self.mode
# check if map exists or not
@@ -377,7 +393,11 @@
self.writable), }
def close(self, build=False):
- """Method to close the Vector"""
+ """Method to close the Vector
+ :param build: True if the vector map should be build before close it
+ :type build: bool
if hasattr(self, 'table') and self.table is not None:
self.table.conn.close()
if self.is_open():
Modified: grass/trunk/lib/python/pygrass/vector/basic.py
--- grass/trunk/lib/python/pygrass/vector/basic.py 2014-05-28 11:08:28 UTC (rev 60532)
+++ grass/trunk/lib/python/pygrass/vector/basic.py 2014-05-28 11:09:47 UTC (rev 60533)
@@ -55,7 +55,8 @@
"""Private method to set the north value"""
self.c_bbox.contents.N = value
- north = property(fget=_get_n, fset=_set_n)
+ north = property(fget=_get_n, fset=_set_n,
+ doc="Set and obtain north value")
def _get_s(self):
"""Private method to obtain the south value"""
@@ -65,7 +66,8 @@
"""Private method to set the south value"""
self.c_bbox.contents.S = value
- south = property(fget=_get_s, fset=_set_s)
+ south = property(fget=_get_s, fset=_set_s,
+ doc="Set and obtain south value")
def _get_e(self):
"""Private method to obtain the east value"""
@@ -75,7 +77,8 @@
"""Private method to set the east value"""
self.c_bbox.contents.E = value
- east = property(fget=_get_e, fset=_set_e)
+ east = property(fget=_get_e, fset=_set_e,
+ doc="Set and obtain east value")
def _get_w(self):
"""Private method to obtain the west value"""
@@ -85,7 +88,8 @@
"""Private method to set the west value"""
self.c_bbox.contents.W = value
- west = property(fget=_get_w, fset=_set_w)
+ west = property(fget=_get_w, fset=_set_w,
+ doc="Set and obtain west value")
def _get_t(self):
"""Private method to obtain the top value"""
@@ -95,7 +99,8 @@
"""Private method to set the top value"""
self.c_bbox.contents.T = value
- top = property(fget=_get_t, fset=_set_t)
+ top = property(fget=_get_t, fset=_set_t,
+ doc="Set and obtain top value")
def _get_b(self):
"""Private method to obtain the bottom value"""
@@ -105,7 +110,8 @@
"""Private method to set the bottom value"""
self.c_bbox.contents.B = value
- bottom = property(fget=_get_b, fset=_set_b)
+ bottom = property(fget=_get_b, fset=_set_b,
+ doc="Set and obtain bottom value")
def __repr__(self):
return "Bbox({n}, {s}, {e}, {w})".format(n=self.north, s=self.south,
@@ -119,15 +125,16 @@
return ['north', 'south', 'west', 'east', 'top', 'bottom']
def contains(self, point):
- """Return True if the object is contained by the BoundingBox. ::
+ """Return True if the object is contained by the BoundingBox.
+ :param point:the point to analyze
+ :type point: a Point object or a tuple with the coordinates
>>> from grass.pygrass.vector.geometry import Point
>>> poi = Point(5,5)
>>> bbox = Bbox(north=10, south=0, west=0, east=10)
>>> bbox.contains(poi)
True
return bool(libvect.Vect_point_in_box(point.x, point.y,
point.z if point.z else 0,
@@ -137,10 +144,11 @@
return [(k, self.__getattribute__(k)) for k in self.keys()]
def nsewtb(self, tb=True):
- """Return a list
+ """Return a list of values from bounding box
- If tb parameter is False return only:
- north, south, east, west
+ :param tb: if tb parameter is False return only: north, south, east,
+ west and not top and bottom
+ :type tb: bool
if tb:
return (self.north, self.south, self.east, self.west,
@@ -193,8 +201,11 @@
def append(self, box):
"""Append a Bbox object to a Boxlist object, using the
- ``Vect_boxlist_append`` C fuction. ::
+ ``Vect_boxlist_append`` C fuction.
+ :param bbox: the bounding box to add to the list
+ :param bbox: a Bbox object
>>> box0 = Bbox()
>>> box1 = Bbox(1,2,3,4)
>>> box2 = Bbox(5,6,7,8)
@@ -207,7 +218,6 @@
>>> len(boxlist)
3
indx = self.__len__()
libvect.Vect_boxlist_append(self.c_boxlist, indx, box.c_bbox)
@@ -247,8 +257,10 @@
def remove(self, indx):
"""Remove Bbox from the boxlist, given an integer or a list of integer
or a boxlist, using ``Vect_boxlist_delete`` C function or the
- ``Vect_boxlist_delete_boxlist``. ::
+ ``Vect_boxlist_delete_boxlist``.
+ :param indx: the index value of the Bbox to remove
+ :param indx: int
>>> boxlist = BoxList([Bbox(),
... Bbox(1, 0, 0, 1),
... Bbox(1, -1, -1, 1)])
@@ -256,7 +268,6 @@
>>> boxlist
Boxlist([Bbox(1.0, 0.0, 0.0, 1.0), Bbox(1.0, -1.0, -1.0, 1.0)])
if hasattr(indx, 'c_boxlist'):
libvect.Vect_boxlist_delete_boxlist(self.c_boxlist, indx.c_boxlist)
@@ -335,7 +346,11 @@
def extend(self, ilist):
"""Extend the list with another Ilist object or
- with a list of integers"""
+ with a list of integers
+ :param ilist: the ilist to append
+ :type ilist: a Ilist object
if isinstance(ilist, Ilist):
libvect.Vect_list_append_list(self.c_ilist, ilist.ilist)
else:
@@ -416,19 +431,34 @@
def get(self, layer=1):
"""Return the first found category of given layer
- and the number of category found. """
+ and the number of category found.
+ :param layer: the number of layer
+ :type layer: int
cat = ctypes.c_int()
n_cats = libvect.Vect_cat_get(self.c_cats, layer, ctypes.byref(cat))
return cat.value, n_cats
def set(self, cat, layer=1):
- """Add new field/cat to category structure if doesn't exist yet."""
+ """Add new field/cat to category structure if doesn't exist yet.
+ :param cat: the cat to add
+ :type cat: int
+ :type layer: int
libvect.Vect_cat_set(self.c_cats, layer, cat)
def delete(self, cat=None, layer=1):
"""If cat is given delete cat from line_cats structure
(using Vect_field_cat_del) else delete all categories of given layer
(using Vect_cat_del).
+ :type cat: int
+ :type layer: int
if cat:
self.n_del = libvect.Vect_field_cat_del(self.c_cats, layer, cat)
@@ -441,12 +471,22 @@
raise ValueError(err_msg)
def check_cats_constraints(self, cats_list, layer=1):
- """Check if categories match with category constraints"""
+ """Check if categories match with category constraints
+ :param cats_list: a list of categories
+ :type cats_list: list
+ :type layer: int
return bool(libvect.Vect_cats_in_constraint(self.c_cats, layer,
cats_list.c_cat_list))
def get_list(self, layer=1):
- """Get list of categories of given field."""
+ """Get list of categories of given field.
+ :type layer: int
ilist = Ilist()
if libvect.Vect_field_cat_get(self.c_cats, layer,
ilist.c_ilist) < 0:
@@ -504,19 +544,30 @@
def from_string(self, string):
"""Converts string of categories and cat ranges separated by commas
- to cat_list."""
+ to cat_list.
+ :param string: a string containing the cats separated by commas
+ :type string: str
num_errors = libvect.Vect_str_to_cat_list(string, self.c_cat_list)
if num_errors:
from grass.pygrass.errors import GrassError
raise GrassError("%d number of errors in ranges" % num_errors)
def from_array(self, array):
- """Convert ordered array of integers to cat_list structure."""
+ """Convert ordered array of integers to cat_list structure.
+ :param array: the input array containing the cats
+ :type array: array
# Vect_array_to_cat_list(const int *vals, int nvals, ***)
# TODO: it's not working
libvect.Vect_array_to_cat_list(array, len(array), self.c_cat_list)
def __contains__(self, cat):
"""Check if category number is in list.
- int Vect_cat_in_cat_list (int cat, const struct cat_list *list)"""
+ :param cat: the category number
+ :type cat: int
return bool(libvect.Vect_cat_in_cat_list(cat, self.c_cat_list))
Modified: grass/trunk/lib/python/pygrass/vector/geometry.py
--- grass/trunk/lib/python/pygrass/vector/geometry.py 2014-05-28 11:08:28 UTC (rev 60532)
+++ grass/trunk/lib/python/pygrass/vector/geometry.py 2014-05-28 11:09:47 UTC (rev 60533)
@@ -143,7 +143,8 @@
# update condition
self.cond = "%s=%d" % (self.table.key, value)
- cat = property(fget=_get_cat, fset=_set_cat)
+ cat = property(fget=_get_cat, fset=_set_cat,
+ doc="Set and obtain cat value")
def __getitem__(self, key):
"""Return the value stored in the attribute table. ::
@@ -342,7 +343,8 @@
def _set_x(self, value):
self.c_points.contents.x[0] = value
- x = property(fget=_get_x, fset=_set_x)
+ x = property(fget=_get_x, fset=_set_x,
+ doc="Set and obtain x coordinate")
def _get_y(self):
return self.c_points.contents.y[0]
@@ -350,7 +352,8 @@
def _set_y(self, value):
self.c_points.contents.y[0] = value
- y = property(fget=_get_y, fset=_set_y)
+ y = property(fget=_get_y, fset=_set_y,
+ doc="Set and obtain y coordinate")
def _get_z(self):
if self.is2D:
@@ -365,7 +368,8 @@
self.c_points.contents.z[0] = value
self.is2D = False
- z = property(fget=_get_z, fset=_set_z)
+ z = property(fget=_get_z, fset=_set_z,
+ doc="Set and obtain z coordinate")
def __str__(self):
return self.get_wkt()
@@ -429,8 +433,11 @@
def distance(self, pnt):
"""Calculate distance of 2 points, using the Vect_points_distance
C function, If one of the point have z == None, return the 2D distance.
+ :param pnt: the point for calculate the distance
+ :type pnt: a Point object or a tuple with the coordinates
>>> pnt0 = Point(0, 0, 0)
>>> pnt1 = Point(1, 0)
>>> pnt0.distance(pnt1)
@@ -441,8 +448,6 @@
>>> pnt0.distance(pnt1)
1.4142135623730951
- The distance method require a :class:Point or a tuple with
- the coordinates.
if self.is2D or pnt.is2D:
return libvect.Vect_points_distance(self.x, self.y, 0,
@@ -456,31 +461,21 @@
"""Return the buffer area around the point, using the
``Vect_point_buffer2`` C function.
- Parameters
- dist : numeric
- The distance around the line.
- dist_x: numeric, optional
- The distance along x
- dist_y: numeric, optional
- The distance along y
- angle: numeric, optional
- The angle between 0x and major axis
- round_: bool, optional
- To make corners round
- tol: float, optional
- Fix the maximum distance between theoretical arc
- and output segments
+ :param dist: the distance around the point
+ :type dist: num
+ :param dist_x: the distance along x
+ :type dist_x: num
+ :param dist_y: the distance along y
+ :type dist_y: num
+ :param angle: the angle between 0x and major axis
+ :type angle: num
+ :param round_: to make corners round
+ :type round_: bool
+ :param tol: fix the maximum distance between theoretical arc and
+ output segments
+ :type tol: float
+ :returns: the buffer as Area object
- Returns
- buffer : Area
- The buffer area around the line.
- Example
>>> pnt = Point(0, 0)
>>> area = pnt.buffer(10)
>>> area.boundary #doctest: +ELLIPSIS
@@ -623,7 +618,10 @@
def append(self, pnt):
"""Appends one point to the end of a line, using the
- ``Vect_append_point`` C function. ::
+ ``Vect_append_point`` C function.
+ :param pnt: the point to add to line
>>> line = Line()
>>> line.append((10, 100))
@@ -656,12 +654,14 @@
def extend(self, line, forward=True):
"""Appends points to the end of a line.
- It is possible to extend a line, give a list of points, or directly
- with a line_pnts struct.
+ :param line: it is possible to extend a line, give a list of points,
+ or directly with a line_pnts struct.
+ :type line: Line object ot list of points
+ :param forward: if forward is True the line is extend forward otherwise
+ is extend backward. The method use the
+ `Vect_append_points` C function.
+ :type forward: bool
- If forward is True the line is extend forward otherwise is extend
- backward. The method use the `Vect_append_points` C function. ::
>>> line = Line([(0, 0), (1, 1)])
>>> line.extend( Line([(2, 2), (3, 3)]) )
>>> line #doctest: +NORMALIZE_WHITESPACE
@@ -670,8 +670,6 @@
Point(2.000000, 2.000000),
Point(3.000000, 3.000000)])
- Like python list, it is possible to extend a line, with another line
- or with a list of points.
# set direction
if forward:
@@ -694,8 +692,13 @@
def insert(self, indx, pnt):
"""Insert new point at index position and move all old points at
that position and above up, using ``Vect_line_insert_point``
- C function. ::
+ C function.
+ :param indx: the index where add new point
+ :type indx: int
>>> line.insert(0, Point(1.000000, -1.000000) )
@@ -703,7 +706,6 @@
Point(0.000000, 0.000000),
Point(1.000000, 1.000000)])
if indx < 0: # Handle negative indices
indx += self.c_points.contents.n_points
@@ -737,7 +739,12 @@
return libvect.Vect_line_geodesic_length(self.c_points)
- """Return a tuple with:
+ """Calculate the distance between line and a point.
+ :param pnt: the point to calculate distance
+ Return a tuple with:
* the closest point on the line,
* the distance between these two points,
@@ -746,15 +753,10 @@
The distance is compute using the ``Vect_line_distance`` C function.
- Example
>>> line = Line([(0, 0), (0, 2)])
>>> line.distance(Point(1, 1))
(Point(0.000000, 1.000000), 1.0, 1.0, 1.0)
# instantite outputs
cx = ctypes.c_double(0)
@@ -789,8 +791,11 @@
pass
def pop(self, indx):
- """Return the point in the index position and remove from the Line. ::
+ """Return the point in the index position and remove from the Line.
+ :type indx: int
>>> line = Line([(0, 0), (1, 1), (2, 2)])
>>> midle_pnt = line.pop(1)
>>> midle_pnt
@@ -798,7 +803,6 @@
>>> line
Line([Point(0.000000, 0.000000), Point(2.000000, 2.000000)])
@@ -809,14 +813,15 @@
return pnt
def delete(self, indx):
- """Remove the point in the index position. ::
+ """Remove the point in the index position.
+ :type indx: int
>>> line.delete(-1)
>>> line
Line([Point(0.000000, 0.000000), Point(1.000000, 1.000000)])
@@ -841,7 +846,10 @@
def prune_thresh(self, threshold):
"""Remove points in threshold, using the ``Vect_line_prune_thresh``
- C funtion. ::
+ C funtion.
+ :param threshold: the threshold value where prune points
+ :type threshold: num
>>> line = Line([(0, 0), (1.0, 1.0), (1.2, 0.9), (2, 2)])
>>> line.prune_thresh(0.5)
@@ -858,7 +866,10 @@
def remove(self, pnt):
"""Delete point at given index and move all points above down, using
- `Vect_line_delete_point` C function. ::
+ `Vect_line_delete_point` C function.
+ :param pnt: the point to remove
>>> line.remove((2, 2))
@@ -889,7 +900,9 @@
libvect.Vect_line_reverse(self.c_points)
def segment(self, start, end):
- """Create line segment. using the ``Vect_line_segment`` C function."""
+ # TODO improve documentation
+ """Create line segment. using the ``Vect_line_segment`` C function.
line = Line()
libvect.Vect_line_segment(self.c_points, start, end, line.c_points)
return line
@@ -933,8 +946,11 @@
for pnt in self.__iter__()])
def from_wkt(self, wkt):
- """Read a WKT string. ::
+ """Create a line reading a WKT string.
+ :param wkt: the WKT string containing the LINESTRING
+ :type wkt: str
>>> line = Line()
>>> line.from_wkt("LINESTRING(0 0,1 1,1 2)")
@@ -966,33 +982,21 @@
"""Return the buffer area around the line, using the
``Vect_line_buffer2`` C function.
- Parameters
- dist : numeric
- caps: bool, optional
- To add caps at line ends
+ :param dist: the distance around the line
+ :type dist: num
+ :type dist_x: num
+ :type dist_y: num
+ :type angle: num
+ output segments
+ :type tol: float
- Returns
- buffer : Area
- Example
>>> area = line.buffer(10)
@@ -1080,9 +1084,19 @@
return cntr
def get_left_centroid(self, idonly=False):
+ """Return left value
+ :param idonly: True to return only the cat of feature
return self._get_centroid(self.left_id, idonly)
def get_right_centroid(self, idonly=False):
+ """Return right value
def get_left_right(self):
@@ -1094,13 +1108,13 @@
def area(self):
"""Return the area of the polygon.
>>> bound = Boundary(points=[(0, 0), (0, 2), (2, 2), (2, 0),
... (0, 0)])
>>> bound.area()
4.0
libgis.G_begin_polygon_area_calculations()
return libgis.G_area_of_polygon(self.c_points.contents.x,
self.c_points.contents.y,
@@ -1170,12 +1184,14 @@
return "Isle(%d)" % (self.id)
def boundaries(self):
+ """Return a list of boundaries"""
ilist = Ilist()
libvect.Vect_get_isle_boundaries(self.c_mapinfo, self.id,
ilist.c_ilist)
return ilist
def bbox(self, bbox=None):
+ """Return bounding box of Isle"""
bbox = bbox if bbox else Bbox()
libvect.Vect_get_isle_box(self.c_mapinfo, self.id, bbox.c_bbox)
return bbox
@@ -1200,7 +1216,11 @@
return bool(libvect.Vect_isle_alive(self.c_mapinfo, self.id))
def contain_pnt(self, pnt):
- """Check if point is in area."""
+ """Check if point is in area.
bbox = self.bbox()
return bool(libvect.Vect_point_in_island(pnt.x, pnt.y,
@@ -1245,15 +1265,22 @@
return self._isles[key]
def get_isles_id(self):
+ """Return the id of isles"""
return [libvect.Vect_get_area_isle(self.c_mapinfo, self.area_id, i)
for i in range(self.__len__())]
def get_isles(self):
+ """Return isles"""
return [Isle(v_id=isle_id, c_mapinfo=self.c_mapinfo)
for isle_id in self._isles_id]
- """Vect_select_isles_by_box"""
+ """Vect_select_isles_by_box
+ .. warning::
+ Not implemented yet.
pass
@@ -1309,12 +1336,21 @@
self.get_isles()
def get_points(self, line=None):
- """Return a Line object with the outer ring"""
+ """Return a Line object with the outer ring
+ :param line: a Line object to fill with info from points of area
+ :type line: a Line object
line = Line() if line is None else line
libvect.Vect_get_area_points(self.c_mapinfo, self.id, line.c_points)
return line
def get_centroid(self, centroid=None):
+ """Return the centroid
+ :param centroid: a Centroid object to fill with info from centroid of area
+ :type centroid: a Centroid object
centroid_id = libvect.Vect_get_area_centroid(self.c_mapinfo, self.id)
if centroid:
centroid.id = centroid_id
@@ -1346,9 +1382,11 @@
return bool(libvect.Vect_area_alive(self.c_mapinfo, self.id))
+ """Return the Bbox of area
+ :param bbox: a Bbox object to fill with info from bounding box of area
+ :type bbox: a Bbox object
- Vect_get_area_box
libvect.Vect_get_area_box(self.c_mapinfo, self.id, bbox.c_bbox)
return bbox
@@ -1358,29 +1396,21 @@
"""Return the buffer area around the area, using the
``Vect_area_buffer2`` C function.
- Parameters
- dist : numeric
+ :param dist: the distance around the area
+ :type dist: num
+ :type dist_x: num
+ :type dist_y: num
+ :type angle: num
+ output segments
+ :type tol: float
- Returns
- buffer : Area
if dist is not None:
dist_x = dist
@@ -1415,8 +1445,9 @@
def cats(self, cats=None):
"""Get area categories.
- int Vect_get_area_cats (const struct Map_info *Map,
- int area, struct line_cats *Cats)
+ :param cats: a Cats object to fill with info with area categories
+ :type cats: a Cats object
cats = cats if cats else Cats()
libvect.Vect_get_area_cats(self.c_mapinfo, self.id, cats.c_cats)
@@ -1431,9 +1462,11 @@
def contain_pnt(self, pnt, bbox=None):
- int Vect_point_in_area(double x, double y,
- const struct Map_info *Map,
- int area, struct bound_box box)
+ :param pnt: the point to analyze
+ :param bbox: the bounding box where run the analysis
bbox = bbox if bbox else self.bbox()
return bool(libvect.Vect_point_in_area(pnt.x, pnt.y,
Modified: grass/trunk/lib/python/pygrass/vector/table.py
--- grass/trunk/lib/python/pygrass/vector/table.py 2014-05-28 11:08:28 UTC (rev 60532)
+++ grass/trunk/lib/python/pygrass/vector/table.py 2014-05-28 11:09:47 UTC (rev 60533)
@@ -93,19 +93,32 @@
return self
def where(self, condition):
- """Create the where condition"""
+ """Create the where condition
+ :param condition: the condition of where statement, for example
+ `cat = 1`
+ :type condition: str
self._where = 'WHERE {condition}'.format(condition=condition)
return self
def order_by(self, orderby):
- """Create the order by condition"""
+ """Create the order by condition
+ :param orderby: the name of column/s to order the result
+ :type orderby: str
if not isinstance(orderby, unicode):
orderby = ', '.join(orderby)
self._orderby = 'ORDER BY {orderby}'.format(orderby=orderby)
return self
def limit(self, number):
- """Create the limit condition"""
+ """Create the limit condition
+ :param number: the number to limit the result
+ :type number: int
if not isinstance(number, int):
raise ValueError("Must be an integer.")
else:
@@ -113,7 +126,11 @@
return self
def group_by(self, groupby):
- """Create the group by condition"""
+ """Create the group by condition
+ :param groupby: the name of column/s to group the result
+ :type groupby: str, list
if not isinstance(groupby, unicode):
groupby = ', '.join(groupby)
self._groupby = 'GROUP BY {groupby}'.format(groupby=groupby)
@@ -347,8 +364,14 @@
return self.odict.items()
def add(self, col_name, col_type):
- """Add a new column to the table. ::
+ """Add a new column to the table.
+ :param col_name: the name of column to add
+ :type col_name: str
+ :param col_type: the tipe of column to add
+ :type col_type: str
>>> import sqlite3
>>> path = '$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db'
>>> from grass.pygrass.functions import copy, remove
@@ -369,6 +392,11 @@
def check_col(col_type):
+ """Check the column type if it is supported by GRASS
+ :param col_type: the type of column
valid_type = ('DOUBLE PRECISION', 'DOUBLE', 'INT', 'INTEGER',
'DATE')
if 'VARCHAR' in col_type or col_type.upper() not in valid_type:
@@ -397,8 +425,14 @@
self.update_odict()
def rename(self, old_name, new_name):
- """Rename a column of the table. ::
+ """Rename a column of the table.
+ :param old_name: the name of existing column
+ :type old_name: str
+ :param new_name: the name of new column
+ :type new_name: str
>>> import sqlite3
@@ -447,8 +481,14 @@
self.drop(old_name)
def cast(self, col_name, new_type):
- """Change the column type. ::
+ """Change the column type.
+ :param new_type: the new type of column
+ :type new_type: str
>>> import sqlite3
@@ -485,8 +525,12 @@
raise DBError('SQLite does not support to cast columns.')
def drop(self, col_name):
- """Drop a column from the table. ::
+ """Drop a column from the table.
+ :param col_name: the name of column to remove
>>> import sqlite3
@@ -582,7 +626,8 @@
raise TypeError("Number must be positive and greater than 0.")
self.c_fieldinfo.contents.number = number
- layer = property(fget=_get_layer, fset=_set_layer)
+ layer = property(fget=_get_layer, fset=_set_layer,
+ doc="Set and obtain layer number")
def _get_name(self):
return self.c_fieldinfo.contents.name
@@ -590,7 +635,8 @@
def _set_name(self, name):
self.c_fieldinfo.contents.name = name
+ doc="Set and obtain name vale")
def _get_table(self):
return self.c_fieldinfo.contents.table
@@ -598,7 +644,8 @@
def _set_table(self, new_name):
self.c_fieldinfo.contents.table = new_name
- table_name = property(fget=_get_table, fset=_set_table)
+ table_name = property(fget=_get_table, fset=_set_table,
+ doc="Set and obtain table name value")
def _get_key(self):
return self.c_fieldinfo.contents.key
@@ -606,7 +653,8 @@
def _set_key(self, key):
self.c_fieldinfo.contents.key = key
- key = property(fget=_get_key, fset=_set_key)
+ key = property(fget=_get_key, fset=_set_key,
def _get_database(self):
return self.c_fieldinfo.contents.database
@@ -614,7 +662,8 @@
def _set_database(self, database):
self.c_fieldinfo.contents.database = database
- database = property(fget=_get_database, fset=_set_database)
+ database = property(fget=_get_database, fset=_set_database,
+ doc="Set and obtain database value")
def _get_driver(self):
return self.c_fieldinfo.contents.driver
@@ -625,7 +674,9 @@
raise TypeError(str_err)
self.c_fieldinfo.contents.driver = driver
- driver = property(fget=_get_driver, fset=_set_driver)
+ driver = property(fget=_get_driver, fset=_set_driver,
+ doc="Set and obtain driver value. The drivers supported \
+ by PyGRASS are: SQLite and PostgreSQL")
def __init__(self, layer=1, name=None, table=None, key='cat',
database='$GISDBASE/$LOCATION_NAME/'
@@ -777,7 +828,11 @@
return "DBlinks(%r)" % [link for link in self.__iter__()]
def by_index(self, indx):
- """Return a Link object by index"""
+ """Return a Link object by index
+ :type indx: int
nlinks = self.num_dblinks()
if nlinks == 0:
raise IndexError
@@ -789,20 +844,34 @@
return Link(c_fieldinfo=c_fieldinfo) if c_fieldinfo else None
def by_layer(self, layer):
+ """Return the choosen Link using the layer
+ :type layer: int
c_fieldinfo = libvect.Vect_get_field(self.c_mapinfo, layer)
def by_name(self, name):
+ """Return the choosen Link using the name
+ :param name: the name of Link
+ :type name: str
c_fieldinfo = libvect.Vect_get_field_by_name(self.c_mapinfo, name)
def num_dblinks(self):
+ """Return the number of DBlinks"""
return libvect.Vect_get_num_dblinks(self.c_mapinfo)
def add(self, link):
- """Add a new link.
- Need to open vector map in write mode::
+ """Add a new link. Need to open vector map in write mode
+ :param link: the Link to add to the DBlinks
+ :type link: a Link object
>>> from grass.pygrass.vector import VectorTopo
>>> municip = VectorTopo('census')
>>> municip.open()
@@ -883,7 +952,8 @@
self.conn.commit()
cur.close()
+ doc="Set and obtain table name")
def __init__(self, name, connection, key='cat'):
self._name = name
@@ -917,7 +987,7 @@
return self.n_rows()
def drop(self, cursor=None, force=False):
- """Private method to drop table from database"""
+ """Method to drop table from database"""
cur = cursor if cursor else self.conn.cursor()
if self.exist(cursor=cur):
