[GRASS-SVN] r60536 - in grass/branches/releasebranch_7_0: db/db.login include/defs lib/db/dbmi_base
Wed May 28 06:24:33 PDT 2014
Author: martinl
Date: 2014-05-28 06:24:33 -0700 (Wed, 28 May 2014)
New Revision: 60536
   grass/branches/releasebranch_7_0/db/db.login/main.c
   grass/branches/releasebranch_7_0/include/defs/dbmi.h
   grass/branches/releasebranch_7_0/lib/db/dbmi_base/login.c
libdbmi: db_get_login_dump() added
db.login: implement print flag
          (merge r60471-2 from trunk)
Modified: grass/branches/releasebranch_7_0/db/db.login/main.c
--- grass/branches/releasebranch_7_0/db/db.login/main.c	2014-05-28 13:17:02 UTC (rev 60535)
+++ grass/branches/releasebranch_7_0/db/db.login/main.c	2014-05-28 13:24:33 UTC (rev 60536)
@@ -30,6 +30,7 @@
 int main(int argc, char *argv[])
     struct Option *driver, *database, *user, *password;
+    struct Flag *print;
     struct GModule *module;
     /* Initialize the GIS calls */
@@ -65,9 +66,20 @@
     password->description = _("Password to set for DB connection");
     password->guisection = _("Settings");
+    print = G_define_flag();
+    print->key = 'p';
+    print->description = _("Print connection settings and exit");
+    print->guisection = _("Print");
     if (G_parser(argc, argv))
         exit(EXIT_FAILURE);
+    if (print->answer) {
+        /* print all settings to standard output and exit */
+        db_get_login_dump(stdout);
+        exit(EXIT_SUCCESS);
     if (db_set_login(driver->answer, database->answer, user->answer,
                      password->answer) == DB_FAILED) {
         G_fatal_error(_("Unable to set user/password"));
Modified: grass/branches/releasebranch_7_0/include/defs/dbmi.h
--- grass/branches/releasebranch_7_0/include/defs/dbmi.h	2014-05-28 13:17:02 UTC (rev 60535)
+++ grass/branches/releasebranch_7_0/include/defs/dbmi.h	2014-05-28 13:24:33 UTC (rev 60536)
@@ -411,5 +411,6 @@
 unsigned int db_sizeof_string(const dbString *);
 int db_set_login(const char *, const char *, const char *, const char *);
 int db_get_login(const char *, const char *, const char **, const char **);
+int db_get_login_dump(FILE *);
 #endif
Modified: grass/branches/releasebranch_7_0/lib/db/dbmi_base/login.c
--- grass/branches/releasebranch_7_0/lib/db/dbmi_base/login.c	2014-05-28 13:17:02 UTC (rev 60535)
+++ grass/branches/releasebranch_7_0/lib/db/dbmi_base/login.c	2014-05-28 13:24:33 UTC (rev 60536)
@@ -171,8 +171,8 @@
   \param user user name
   \param password password string
-  \return DB_OK
-  \return DB_FAILED
+  \return DB_OK on success
+  \return DB_FAILED on failure
 int db_set_login(const char *driver, const char *database, const char *user,
 		 const char *password)
@@ -225,8 +225,8 @@
   \param[out] user name
   \param[out] password string
-  \return DB_OK
-  \return DB_FAILED
 int db_get_login(const char *driver, const char *database, const char **user,
 		 const char **password)
@@ -263,3 +263,33 @@
     return DB_OK;
+  \brief Print all connection settings to file
+  \param fd file where to print settings
+int db_get_login_dump(FILE *fd)
+    int i;
+    LOGIN login;
+    G_debug(3, "db_get_login_dump()");
+    init_login(&login);
+    if (read_file(&login) == -1)
+	return DB_FAILED;
+    for (i = 0; i < login.n; i++) {
+        fprintf(fd, "%s|%s|%s|%s\n",
+                login.data[i].driver,
+                login.data[i].database,
+                login.data[i].user,
+                login.data[i].password);
+    return DB_OK;
