[GRASS-SVN] r60549 - grass/trunk/vector/v.out.ogr
svn_grass at osgeo.org
Wed May 28 08:55:59 PDT 2014
Author: martinl
Date: 2014-05-28 08:55:59 -0700 (Wed, 28 May 2014)
New Revision: 60549
grass/trunk/vector/v.out.ogr/main.c
v.out.ogr: do not ignore epsg code if defined
Modified: grass/trunk/vector/v.out.ogr/main.c
--- grass/trunk/vector/v.out.ogr/main.c 2014-05-28 15:37:32 UTC (rev 60548)
+++ grass/trunk/vector/v.out.ogr/main.c 2014-05-28 15:55:59 UTC (rev 60549)
@@ -27,6 +27,8 @@
#include "local_proto.h"
+#include "ogr_srs_api.h"
int main(int argc, char *argv[])
int i, otype, ftype, donocat;
@@ -40,7 +42,6 @@
char buf[SQL_BUFFER_SIZE];
char key1[SQL_BUFFER_SIZE], key2[SQL_BUFFER_SIZE];
- struct Key_Value *projinfo, *projunits;
struct Cell_head cellhd;
char **tokens;
@@ -251,12 +252,25 @@
/* fetch PROJ info */
G_get_default_window(&cellhd);
- if (cellhd.proj == PROJECTION_XY)
- Ogr_projection = NULL;
- else {
- projinfo = G_get_projinfo();
- projunits = G_get_projunits();
- Ogr_projection = GPJ_grass_to_osr(projinfo, projunits);
+ Ogr_projection = NULL;
+ if (cellhd.proj != PROJECTION_XY) {
+ const char *epsg;
+ /* try EPSG code first */
+ epsg = G_database_epsg_code();
+ if (!epsg) {
+ struct Key_Value *projinfo, *projunits;
+ projinfo = G_get_projinfo();
+ projunits = G_get_projunits();
+ Ogr_projection = GPJ_grass_to_osr(projinfo, projunits);
+ else {
+ Ogr_projection = OSRNewSpatialReference(NULL);
+ if (OSRImportFromEPSG(Ogr_projection, atoi(epsg)) != OGRERR_NONE)
+ G_fatal_error(_("Unknown EPSG code %s"), epsg);
if (flags.esristyle->answer &&
(strcmp(options.format->answer, "ESRI_Shapefile") == 0))
OSRMorphToESRI(Ogr_projection);
