[GRASS-SVN] r60562 - grass/trunk/lib/vector/Vlib
Wed May 28 14:00:04 PDT 2014
Author: martinl
Date: 2014-05-28 14:00:04 -0700 (Wed, 28 May 2014)
New Revision: 60562
   grass/trunk/lib/vector/Vlib/write_pg.c
vlib/pg: column check must be case-insensitive
Modified: grass/trunk/lib/vector/Vlib/write_pg.c
--- grass/trunk/lib/vector/Vlib/write_pg.c	2014-05-28 20:56:44 UTC (rev 60561)
+++ grass/trunk/lib/vector/Vlib/write_pg.c	2014-05-28 21:00:04 UTC (rev 60562)
@@ -674,8 +674,8 @@
             G_debug(3, "\tcolumn = %d name = %s type = %d length = %d",
                     col, colname, sqltype, length);
-            if (strcmp(pg_info->fid_column, colname) == 0 ||
-                strcmp(GV_KEY_COLUMN, colname) == 0) {
+            if (G_strcasecmp(pg_info->fid_column, colname) == 0 ||
+                G_strcasecmp(GV_KEY_COLUMN, colname) == 0) {
                 /* skip fid column if exists */
                 G_debug(3, "\t%s skipped", colname);
                 continue;
