[GRASS-SVN] r60569 - grass/trunk/scripts/r.out.xyz
Wed May 28 17:26:42 PDT 2014
Author: hcho
Date: 2014-05-28 17:26:42 -0700 (Wed, 28 May 2014)
New Revision: 60569
   grass/trunk/scripts/r.out.xyz/r.out.xyz.py
r.out.xyz: separator default to space because | is not allowed (but why?)
Modified: grass/trunk/scripts/r.out.xyz/r.out.xyz.py
--- grass/trunk/scripts/r.out.xyz/r.out.xyz.py	2014-05-28 21:52:12 UTC (rev 60568)
+++ grass/trunk/scripts/r.out.xyz/r.out.xyz.py	2014-05-29 00:26:42 UTC (rev 60569)
@@ -4,12 +4,12 @@
 # MODULE:       r.out.xyz
 # AUTHOR:       M. Hamish Bowman, Dept. Marine Science, Otago Univeristy,
 #                 New Zealand
-#		Converted to Python by Glynn Clements
+#               Converted to Python by Glynn Clements
 # PURPOSE:      Export a raster map as x,y,z values based on cell centers
 #               This is a simple wrapper script for "r.stats -1ng"
 # COPYRIGHT:    (c) 2006 Hamish Bowman, and the GRASS Development Team
-#		(c) 2008 Glynn Clements, and the GRASS Development Team
+#               (c) 2008 Glynn Clements, and the GRASS Development Team
 #               This program is free software under the GNU General Public
 #               License (>=v2). Read the file COPYING that comes with GRASS
 #               for details.
@@ -31,6 +31,7 @@
 #% required: no
 #%end
 #%option G_OPT_F_SEP
+#% answer: space
 #%end
 import sys
@@ -47,7 +48,10 @@
     if output:
         parameters.update(output=output)
     # windows don't like pipe so we don't include it in the command explicitly
-    if sep != '|':
+    if sep == '|':
+        grass.warning(_("Separator '|' is not allowed. Using a space."))
+        # but why?
+    else:
         parameters.update(separator=sep)
     ret = grass.run_command("r.stats", **parameters)
