[GRASS-SVN] r60572 - grass/trunk/general/g.mlist
svn_grass at osgeo.org
Wed May 28 20:38:49 PDT 2014
Author: hcho
Date: 2014-05-28 20:38:49 -0700 (Wed, 28 May 2014)
New Revision: 60572
grass/trunk/general/g.mlist/main.c
g.mlist: Allow comma-separated map names for wildcard patterns
Modified: grass/trunk/general/g.mlist/main.c
--- grass/trunk/general/g.mlist/main.c 2014-05-29 03:19:56 UTC (rev 60571)
+++ grass/trunk/general/g.mlist/main.c 2014-05-29 03:38:49 UTC (rev 60572)
@@ -157,8 +157,19 @@
if (flag.regex->answer || flag.extended->answer)
filter = G_ls_regex_filter(opt.pattern->answer, 0,
(int)flag.extended->answer);
- else
- filter = G_ls_glob_filter(opt.pattern->answer, 0);
+ else {
+ /* handle individual map names */
+ if (strchr(opt.pattern->answer, ',')) {
+ char *pattern;
+ pattern = (char *)G_malloc(strlen(opt.pattern->answer) + 3);
+ sprintf(pattern, "{%s}", opt.pattern->answer);
+ filter = G_ls_glob_filter(pattern, 0);
+ else
+ filter = G_ls_glob_filter(opt.pattern->answer, 0);
if (!filter)
G_fatal_error(_("Unable to compile pattern <%s>"),
@@ -170,8 +181,19 @@
exclude = G_ls_regex_filter(opt.exclude->answer, 1,
- else
- exclude = G_ls_glob_filter(opt.exclude->answer, 1);
+ else {
+ if (strchr(opt.exclude->answer, ',')) {
+ char *pattern;
+ pattern = (char *)G_malloc(strlen(opt.exclude->answer) + 3);
+ sprintf(pattern, "{%s}", opt.exclude->answer);
+ exclude = G_ls_glob_filter(pattern, 1);
+ else
+ exclude = G_ls_glob_filter(opt.exclude->answer, 1);
if (!exclude)
