[GRASS-SVN] r60583 - in grass/trunk/lib/python/pygrass: docs modules/interface vector
svn_grass at osgeo.org
Thu May 29 03:48:13 PDT 2014
Author: lucadelu
Date: 2014-05-29 03:48:13 -0700 (Thu, 29 May 2014)
New Revision: 60583
Added:
grass/trunk/lib/python/pygrass/docs/modules_grid.rst
grass/trunk/lib/python/pygrass/docs/raster_elements.rst
grass/trunk/lib/python/pygrass/docs/vector_attributes.rst
grass/trunk/lib/python/pygrass/docs/vector_features.rst
grass/trunk/lib/python/pygrass/docs/vector_utils.rst
Removed:
grass/trunk/lib/python/pygrass/docs/attributes.rst
grass/trunk/lib/python/pygrass/docs/gridmodules.rst
grass/trunk/lib/python/pygrass/docs/vector_database.rst
grass/trunk/lib/python/pygrass/docs/index.rst
grass/trunk/lib/python/pygrass/docs/modules.rst
grass/trunk/lib/python/pygrass/docs/raster.rst
grass/trunk/lib/python/pygrass/docs/vector.rst
grass/trunk/lib/python/pygrass/modules/interface/flag.py
grass/trunk/lib/python/pygrass/modules/interface/module.py
grass/trunk/lib/python/pygrass/modules/interface/parameter.py
grass/trunk/lib/python/pygrass/vector/basic.py
grass/trunk/lib/python/pygrass/vector/geometry.py
grass/trunk/lib/python/pygrass/vector/sql.py
pygrass doc: several improvements to sphinx documentation
Deleted: grass/trunk/lib/python/pygrass/docs/attributes.rst
--- grass/trunk/lib/python/pygrass/docs/attributes.rst 2014-05-29 10:33:59 UTC (rev 60582)
+++ grass/trunk/lib/python/pygrass/docs/attributes.rst 2014-05-29 10:48:13 UTC (rev 60583)
@@ -1,138 +0,0 @@
-Attributes
-It is possible to access the vector attributes with: ::
- >>> from pygrass.vector import Vector
- >>> municip = Vector('boundary_municp_sqlite')
- >>> municip.open()
- >>> municip.dblinks
- DBlinks([[Link(1, boundary_municp, sqlite)]])
-The vector map have a ``table`` attributes that contain a Table object, that
-have some useful attributes like: layer, name, driver, etc.
- >>> link = municip.dblinks[1]
- >>> link.number
- 1
- >>> link.name
- 'boundary_municp'
- >>> link.table_name
- 'boundary_municp_sqlite'
- >>> link.driver
- 'sqlite'
- >>> link.database # doctest: +ELLIPSIS
- '.../sqlite.db'
- >>> link.key
- 'cat'
-It is possible to change values, like: ::
- >>> link.name = 'boundary'
- >>> link.driver = 'pg'
- >>> link.database = 'host=localhost,dbname=grassdb'
- >>> link.key = 'gid'
-Now change again to old values: ::
- >>> link.name = 'boundary_municp_sqlite'
- >>> link.driver = 'sqlite'
- >>> link.database = '$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite.db'
- >>> link.key = 'cat'
-Link object have methods that return a
-:ref:`Connection object <python:library:sqlite3:connection-objects>`, and to
-return a Table object: ::
- >>> conn = link.connection()
- >>> cur = conn.cursor()
- >>> import sql
- >>> cur.execute(sql.SELECT.format(cols=', '.join(['cat', 'AREA']),
- ... tname=link.name)) # doctest: +ELLIPSIS
- <sqlite3.Cursor object at ...>
- >>> cur.fetchone()
- (1, 0.0)
- >>> cur.close()
- >>> conn.close()
-From the Link object we can instantiate a Table object that allow user to
-make simple query with the Filters object: ::
- >>> table = link.table()
- >>> table.filters.select('cat', 'COUNTY',
- ... 'AREA','PERIMETER').order_by('AREA').limit(3)
- Filters('SELECT cat, COUNTY, AREA, PERIMETER FROM boundary_municp_sqlite ORDER BY AREA LIMIT 3;')
- >>> cur = table.execute()
- >>> for row in cur.fetchall():
- ... print repr(row)
- (1, u'SURRY', 0.0, 1415.331)
- (2, u'SURRY', 0.0, 48286.011)
- (3, u'CASWELL', 0.0, 5750.087)
-Then we can get table information about table columns, from the columns
-attribute that is an instantiation of a Columns class.
- >>> table.columns # doctest: +ELLIPSIS
- Columns([(u'cat', u'integer'), ..., (u'ACRES', u'double precision')])
- >>> table.columns.names() # doctest: +ELLIPSIS
- [u'cat', u'OBJECTID', u'AREA', u'PERIMETER', ..., u'ACRES']
- >>> table.columns.types() # doctest: +ELLIPSIS
- [u'integer', u'integer', u'double precision', ..., u'double precision']
-.. note ::
- If the map use postgresql it is possible to: add/rename/cast/remove columns
- the sqlite does not support these operations.
-For people that are used to the standardized Python SQL 2.0 interface:
- * http://docs.python.org/library/sqlite3.html
- * http://www.python.org/dev/peps/pep-0249/
-Therefore advanced user can just use, the connect attribute to build
-a new cursor object and interact with the database. ::
- >>> cur = table.conn.cursor()
- >>> cur.execute("SELECT * FROM %s" % table.name) # doctest: +ELLIPSIS
- >>> cur.fetchone()[:5] # doctest: +ELLIPSIS
- (1, 1, 0.0, 1415.331, 2.0)
- >>> # Close communication with the database
- >>> cur.close()
- >>> conn.close()
-Link
-.. autoclass:: pygrass.vector.table.Link
- :members:
-DBlinks
-.. autoclass:: pygrass.vector.table.DBlinks
- :members:
-Filters
-.. autoclass:: pygrass.vector.table.Filters
- :members:
-Columns
-.. autoclass:: pygrass.vector.table.Columns
- :members:
-Table
-.. autoclass:: pygrass.vector.table.Table
- :members:
Deleted: grass/trunk/lib/python/pygrass/docs/gridmodules.rst
--- grass/trunk/lib/python/pygrass/docs/gridmodules.rst 2014-05-29 10:33:59 UTC (rev 60582)
+++ grass/trunk/lib/python/pygrass/docs/gridmodules.rst 2014-05-29 10:48:13 UTC (rev 60583)
@@ -1,24 +0,0 @@
-GridModule
-GridModule class permit to work with raster data and all the processors
-of your computer. It divides the input data into the number of choosen rows and
-columns and after it patches the results together to obtain only one output map.
-.. automodule:: pygrass.modules.grid.grid
- :members:
-Functions
-Split
-.. automodule:: pygrass.modules.grid.split
- :members:
-Patch
-.. automodule:: pygrass.modules.grid.patch
- :members:
Modified: grass/trunk/lib/python/pygrass/docs/index.rst
--- grass/trunk/lib/python/pygrass/docs/index.rst 2014-05-29 10:33:59 UTC (rev 60582)
+++ grass/trunk/lib/python/pygrass/docs/index.rst 2014-05-29 10:48:13 UTC (rev 60583)
@@ -19,11 +19,13 @@
gis
raster
+ raster_elements
vector
- attributes
- vector_database
+ vector_attributes
+ vector_features
+ vector_utils
modules
- gridmodules
+ modules_grid
messages
Modified: grass/trunk/lib/python/pygrass/docs/modules.rst
--- grass/trunk/lib/python/pygrass/docs/modules.rst 2014-05-29 10:33:59 UTC (rev 60582)
+++ grass/trunk/lib/python/pygrass/docs/modules.rst 2014-05-29 10:48:13 UTC (rev 60583)
@@ -1,5 +1,5 @@
-Modules
+Introduction on Modules
Grass modules are represented as objects. These objects are generated based
on the XML module description that is used for GUI generation already. ::
Copied: grass/trunk/lib/python/pygrass/docs/modules_grid.rst (from rev 60581, grass/trunk/lib/python/pygrass/docs/gridmodules.rst)
--- grass/trunk/lib/python/pygrass/docs/modules_grid.rst (rev 0)
+++ grass/trunk/lib/python/pygrass/docs/modules_grid.rst 2014-05-29 10:48:13 UTC (rev 60583)
@@ -0,0 +1,24 @@
+GridModule
+GridModule class permit to work with raster data and all the processors
+of your computer. It divides the input data into the number of choosen rows and
+columns and after it patches the results together to obtain only one output map.
+.. automodule:: pygrass.modules.grid.grid
+ :members:
+Functions
+Split
+.. automodule:: pygrass.modules.grid.split
+ :members:
+Patch
+.. automodule:: pygrass.modules.grid.patch
+ :members:
Modified: grass/trunk/lib/python/pygrass/docs/raster.rst
--- grass/trunk/lib/python/pygrass/docs/raster.rst 2014-05-29 10:33:59 UTC (rev 60582)
+++ grass/trunk/lib/python/pygrass/docs/raster.rst 2014-05-29 10:48:13 UTC (rev 60583)
@@ -58,104 +58,6 @@
>>> print(new)
new
-.. _RasterCategory-label:
-Categories
-All the raster classes support raster categories and share commons methods
-to modify the raster category.
-It is possible to check if the map has or not the categories with the
-``has_cats`` method. ::
- >>> elev.has_cats()
- False
-Opening a map that has category, for example the "landcove_1m" raster map
-from the North Carolina mapset. The ``has_cats`` method return True. ::
- >>> land = raster.RasterRow('landcover_1m')
- >>> land.has_cats()
- True
-Get and set the categories title, with: ::
- >>> land.cats_title
- 'Rural area: Landcover'
- >>> land.cats_title = 'Rural area: Landcover2'
- 'Rural area: Landcover2'
- >>> land.cats_title = 'Rural area: Landcover'
-Get the number of categories of the map with: ::
- >>> land.num_cats()
- 11
-See all the categories with: ::
- >>> land.cats
- [('pond', 1, None),
- ('forest', 2, None),
- ('developed', 3, None),
- ('bare', 4, None),
- ('paved road', 5, None),
- ('dirt road', 6, None),
- ('vineyard', 7, None),
- ('agriculture', 8, None),
- ('wetland', 9, None),
- ('bare ground path', 10, None),
- ('grass', 11, None)]
-Access a single category, using Rast_get_ith_cat(), with: ::
- >>> land.cats[0]
- ('pond', 1, None)
- >>> land.cats['pond']
- ('pond', 1, None)
- >>> land.get_cat(0)
- ('pond', 1, None)
- >>> land.get_cat('pond')
- ('pond', 1, None)
-Add new or change existing categories: ::
- >>> land.set_cat('label', 1)
- >>> land.get_cat('label')
- ('label', 1, None)
- >>> land.set_cat('pond', 1, 1)
-Sort categories, with: ::
- >>> land.sort_cats()
-Copy categories from another raster map with: ::
- >>> land.copy_cats(elev)
-Read and Write: ::
- >>> land.read_cats()
- >>> #land.write_cats()
-Get a Category object or set from a Category object: ::
- >>> cats = land.get_cats()
- >>> land.set_cats(cats)
-Export and import from a file: ::
- >>> land.write_cats_rules('land_rules.csv', ';')
- >>> land.read_cats_rules('land_rules.csv', ';')
-.. autoclass:: pygrass.raster.category.Category
- :members:
.. _RasterRow-label:
RastRow
@@ -351,46 +253,7 @@
.. autoclass:: pygrass.raster.RasterNumpy
:members:
-.. _Buffer-label:
-Buffer
-The buffer class is used to interact with a memory buffer of a map like a
-raster row. The buffer class is based on the `numpy.ndarray`_ class. Therefore
-all the nice feature of the ndarray are allowed.
-.. autoclass:: pygrass.raster.buffer.Buffer
- :members:
-.. _numpy.ndarray: http://docs.scipy.org/doc/numpy/reference/generated/numpy.ndarray.html
-.. _RowIO-label:
-RowIO
-.. autoclass:: pygrass.raster.rowio.RowIO
- :members:
-.. _Segment-label:
-Segment
-.. autoclass:: pygrass.raster.segment.Segment
- :members:
-.. _History-label:
-History
-.. autoclass:: pygrass.raster.history.History
- :members:
.. _Raster library: http://grass.osgeo.org/programming7/rasterlib.html
.. _RowIO library: http://grass.osgeo.org/programming7/rowiolib.html
.. _Segmentation library: http://grass.osgeo.org/programming7/segmentlib.html
Added: grass/trunk/lib/python/pygrass/docs/raster_elements.rst
--- grass/trunk/lib/python/pygrass/docs/raster_elements.rst (rev 0)
+++ grass/trunk/lib/python/pygrass/docs/raster_elements.rst 2014-05-29 10:48:13 UTC (rev 60583)
@@ -0,0 +1,136 @@
+Raster elements
+.. _RasterCategory-label:
+Categories
+All the raster classes support raster categories and share commons methods
+to modify the raster category.
+It is possible to check if the map has or not the categories with the
+``has_cats`` method. ::
+ >>> elev.has_cats()
+ False
+Opening a map that has category, for example the "landcove_1m" raster map
+from the North Carolina mapset. The ``has_cats`` method return True. ::
+ >>> land = raster.RasterRow('landcover_1m')
+ >>> land.has_cats()
+ True
+Get and set the categories title, with: ::
+ >>> land.cats_title
+ 'Rural area: Landcover'
+ >>> land.cats_title = 'Rural area: Landcover2'
+ 'Rural area: Landcover2'
+ >>> land.cats_title = 'Rural area: Landcover'
+Get the number of categories of the map with: ::
+ >>> land.num_cats()
+ 11
+See all the categories with: ::
+ >>> land.cats
+ [('pond', 1, None),
+ ('forest', 2, None),
+ ('developed', 3, None),
+ ('bare', 4, None),
+ ('paved road', 5, None),
+ ('dirt road', 6, None),
+ ('vineyard', 7, None),
+ ('agriculture', 8, None),
+ ('wetland', 9, None),
+ ('bare ground path', 10, None),
+ ('grass', 11, None)]
+Access a single category, using Rast_get_ith_cat(), with: ::
+ >>> land.cats[0]
+ ('pond', 1, None)
+ >>> land.cats['pond']
+ ('pond', 1, None)
+ >>> land.get_cat(0)
+ ('pond', 1, None)
+ >>> land.get_cat('pond')
+ ('pond', 1, None)
+Add new or change existing categories: ::
+ >>> land.set_cat('label', 1)
+ >>> land.get_cat('label')
+ ('label', 1, None)
+ >>> land.set_cat('pond', 1, 1)
+Sort categories, with: ::
+ >>> land.sort_cats()
+Copy categories from another raster map with: ::
+ >>> land.copy_cats(elev)
+Read and Write: ::
+ >>> land.read_cats()
+ >>> #land.write_cats()
+Get a Category object or set from a Category object: ::
+ >>> cats = land.get_cats()
+ >>> land.set_cats(cats)
+Export and import from a file: ::
+ >>> land.write_cats_rules('land_rules.csv', ';')
+ >>> land.read_cats_rules('land_rules.csv', ';')
+.. autoclass:: pygrass.raster.category.Category
+ :members:
+.. _Buffer-label:
+Buffer
+The buffer class is used to interact with a memory buffer of a map like a
+raster row. The buffer class is based on the `numpy.ndarray`_ class. Therefore
+all the nice feature of the ndarray are allowed.
+.. autoclass:: pygrass.raster.buffer.Buffer
+ :members:
+.. _numpy.ndarray: http://docs.scipy.org/doc/numpy/reference/generated/numpy.ndarray.html
+.. _RowIO-label:
+RowIO
+.. autoclass:: pygrass.raster.rowio.RowIO
+ :members:
+.. _Segment-label:
+Segment
+.. autoclass:: pygrass.raster.segment.Segment
+ :members:
+.. _History-label:
+History
+.. autoclass:: pygrass.raster.history.History
+ :members:
\ No newline at end of file
Modified: grass/trunk/lib/python/pygrass/docs/vector.rst
--- grass/trunk/lib/python/pygrass/docs/vector.rst 2014-05-29 10:33:59 UTC (rev 60582)
+++ grass/trunk/lib/python/pygrass/docs/vector.rst 2014-05-29 10:48:13 UTC (rev 60583)
@@ -126,73 +126,3 @@
.. autoclass:: pygrass.vector.VectorTopo
:members:
-Vector Features
-Point
-.. autoclass:: pygrass.vector.geometry.Point
- :members:
-Line
-.. autoclass:: pygrass.vector.geometry.Line
- :members:
-Boundary
-.. autoclass:: pygrass.vector.geometry.Boundary
- :members:
-Isle
-.. autoclass:: pygrass.vector.geometry.Isle
- :members:
-Isles
-.. autoclass:: pygrass.vector.geometry.Isles
- :members:
-Area
-.. autoclass:: pygrass.vector.geometry.Area
- :members:
-Utils
-Bbox
-.. autoclass:: pygrass.vector.basic.Bbox
- :members:
-BoxList
-.. autoclass:: pygrass.vector.basic.BoxList
- :members:
-Ilist
-.. autoclass:: pygrass.vector.basic.Ilist
- :members:
-Cats
-.. autoclass:: pygrass.vector.basic.Cats
- :members:
Copied: grass/trunk/lib/python/pygrass/docs/vector_attributes.rst (from rev 60578, grass/trunk/lib/python/pygrass/docs/attributes.rst)
--- grass/trunk/lib/python/pygrass/docs/vector_attributes.rst (rev 0)
+++ grass/trunk/lib/python/pygrass/docs/vector_attributes.rst 2014-05-29 10:48:13 UTC (rev 60583)
@@ -0,0 +1,144 @@
+Vector Attributes
+It is possible to access the vector attributes with: ::
+ >>> from pygrass.vector import Vector
+ >>> municip = Vector('boundary_municp_sqlite')
+ >>> municip.open()
+ >>> municip.dblinks
+ DBlinks([[Link(1, boundary_municp, sqlite)]])
+The vector map have a ``table`` attributes that contain a Table object, that
+have some useful attributes like: layer, name, driver, etc.
+ >>> link = municip.dblinks[1]
+ >>> link.number
+ 1
+ >>> link.name
+ 'boundary_municp'
+ >>> link.table_name
+ 'boundary_municp_sqlite'
+ >>> link.driver
+ 'sqlite'
+ >>> link.database # doctest: +ELLIPSIS
+ '.../sqlite.db'
+ >>> link.key
+ 'cat'
+It is possible to change values, like: ::
+ >>> link.name = 'boundary'
+ >>> link.driver = 'pg'
+ >>> link.database = 'host=localhost,dbname=grassdb'
+ >>> link.key = 'gid'
+Now change again to old values: ::
+ >>> link.name = 'boundary_municp_sqlite'
+ >>> link.driver = 'sqlite'
+ >>> link.database = '$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite.db'
+ >>> link.key = 'cat'
+Link object have methods that return a
+:ref:`Connection object <python:library:sqlite3:connection-objects>`, and to
+return a Table object: ::
+ >>> conn = link.connection()
+ >>> cur = conn.cursor()
+ >>> import sql
+ >>> cur.execute(sql.SELECT.format(cols=', '.join(['cat', 'AREA']),
+ ... tname=link.name)) # doctest: +ELLIPSIS
+ <sqlite3.Cursor object at ...>
+ >>> cur.fetchone()
+ (1, 0.0)
+ >>> cur.close()
+ >>> conn.close()
+From the Link object we can instantiate a Table object that allow user to
+make simple query with the Filters object: ::
+ >>> table = link.table()
+ >>> table.filters.select('cat', 'COUNTY',
+ ... 'AREA','PERIMETER').order_by('AREA').limit(3)
+ Filters('SELECT cat, COUNTY, AREA, PERIMETER FROM boundary_municp_sqlite ORDER BY AREA LIMIT 3;')
+ >>> cur = table.execute()
+ >>> for row in cur.fetchall():
+ ... print repr(row)
+ (1, u'SURRY', 0.0, 1415.331)
+ (2, u'SURRY', 0.0, 48286.011)
+ (3, u'CASWELL', 0.0, 5750.087)
+Then we can get table information about table columns, from the columns
+attribute that is an instantiation of a Columns class.
+ >>> table.columns # doctest: +ELLIPSIS
+ Columns([(u'cat', u'integer'), ..., (u'ACRES', u'double precision')])
+ >>> table.columns.names() # doctest: +ELLIPSIS
+ [u'cat', u'OBJECTID', u'AREA', u'PERIMETER', ..., u'ACRES']
+ >>> table.columns.types() # doctest: +ELLIPSIS
+ [u'integer', u'integer', u'double precision', ..., u'double precision']
+.. note ::
+ If the map use postgresql it is possible to: add/rename/cast/remove columns
+ the sqlite does not support these operations.
+For people that are used to the standardized Python SQL 2.0 interface:
+ * http://docs.python.org/library/sqlite3.html
+ * http://www.python.org/dev/peps/pep-0249/
+Therefore advanced user can just use, the connect attribute to build
+a new cursor object and interact with the database. ::
+ >>> cur = table.conn.cursor()
+ >>> cur.execute("SELECT * FROM %s" % table.name) # doctest: +ELLIPSIS
+ >>> cur.fetchone()[:5] # doctest: +ELLIPSIS
+ (1, 1, 0.0, 1415.331, 2.0)
+ >>> # Close communication with the database
+ >>> cur.close()
+ >>> conn.close()
+DBlinks
+.. autoclass:: pygrass.vector.table.DBlinks
+ :members:
+Link
+.. autoclass:: pygrass.vector.table.Link
+ :members:
+Table
+.. autoclass:: pygrass.vector.table.Table
+ :members:
+Columns
+.. autoclass:: pygrass.vector.table.Columns
+ :members:
+Filters
+.. autoclass:: pygrass.vector.table.Filters
+ :members:
+SQL
+.. automodule:: pygrass.vector.sql
+ :members:
Deleted: grass/trunk/lib/python/pygrass/docs/vector_database.rst
--- grass/trunk/lib/python/pygrass/docs/vector_database.rst 2014-05-29 10:33:59 UTC (rev 60582)
+++ grass/trunk/lib/python/pygrass/docs/vector_database.rst 2014-05-29 10:48:13 UTC (rev 60583)
@@ -1,38 +0,0 @@
-Vector Databases
-DBlinks
- :members:
-Link
- :members:
-Table
- :members:
-Columns
- :members:
-Filters
- :members:
-SQL
-.. automodule:: pygrass.vector.sql
- :members:
Added: grass/trunk/lib/python/pygrass/docs/vector_features.rst
--- grass/trunk/lib/python/pygrass/docs/vector_features.rst (rev 0)
+++ grass/trunk/lib/python/pygrass/docs/vector_features.rst 2014-05-29 10:48:13 UTC (rev 60583)
@@ -0,0 +1,41 @@
+Vector Features
+Point
+.. autoclass:: pygrass.vector.geometry.Point
+ :members:
+Line
+.. autoclass:: pygrass.vector.geometry.Line
+ :members:
+Boundary
+.. autoclass:: pygrass.vector.geometry.Boundary
+ :members:
+Isle
+.. autoclass:: pygrass.vector.geometry.Isle
+ :members:
+Isles
+.. autoclass:: pygrass.vector.geometry.Isles
+ :members:
+Area
+.. autoclass:: pygrass.vector.geometry.Area
+ :members:
Added: grass/trunk/lib/python/pygrass/docs/vector_utils.rst
--- grass/trunk/lib/python/pygrass/docs/vector_utils.rst (rev 0)
+++ grass/trunk/lib/python/pygrass/docs/vector_utils.rst 2014-05-29 10:48:13 UTC (rev 60583)
@@ -0,0 +1,27 @@
+Vector Utils
+Bbox
+.. autoclass:: pygrass.vector.basic.Bbox
+ :members:
+BoxList
+.. autoclass:: pygrass.vector.basic.BoxList
+ :members:
+Ilist
+.. autoclass:: pygrass.vector.basic.Ilist
+ :members:
+Cats
+.. autoclass:: pygrass.vector.basic.Cats
+ :members:
Modified: grass/trunk/lib/python/pygrass/modules/interface/flag.py
--- grass/trunk/lib/python/pygrass/modules/interface/flag.py 2014-05-29 10:33:59 UTC (rev 60582)
+++ grass/trunk/lib/python/pygrass/modules/interface/flag.py 2014-05-29 10:48:13 UTC (rev 60583)
@@ -8,8 +8,12 @@
with_statement, print_function, unicode_literals)
from grass.pygrass.modules.interface import read
+# TODO add documentation
+class Flag(object):
+ """The Flag object store all information about a flag of module.
-class Flag(object):
+ It is possible to set flags of command using this object.
def __init__(self, xflag=None, diz=None):
self.value = False
diz = read.element2dict(xflag) if xflag is not None else diz
@@ -21,6 +25,7 @@
self.guisection = diz.get('guisection', None)
def get_bash(self):
+ """Prova"""
if self.value:
if self.special:
return '--%s' % self.name[0]
@@ -30,6 +35,7 @@
return ''
def get_python(self):
+ """Prova"""
if self.value:
if self.special:
return '%s=True' % self.name
Modified: grass/trunk/lib/python/pygrass/modules/interface/module.py
--- grass/trunk/lib/python/pygrass/modules/interface/module.py 2014-05-29 10:33:59 UTC (rev 60582)
+++ grass/trunk/lib/python/pygrass/modules/interface/module.py 2014-05-29 10:48:13 UTC (rev 60583)
@@ -68,7 +68,7 @@
class ParallelModuleQueue(object):
- """!This class is designed to run an arbitrary number of pygrass Module
+ """This class is designed to run an arbitrary number of pygrass Module
processes in parallel.
Objects of type grass.pygrass.modules.Module can be put into the
@@ -82,8 +82,6 @@
Usage:
- @code
>>> import copy
>>> import grass.pygrass.modules as pymod
>>> mapcalc_list = []
@@ -106,27 +104,27 @@
0
0
- @endcode
def __init__(self, max_num_procs=1):
- """!Constructor
+ """Constructor
- @param max_num_procs The maximum number of Module processes that
- can be run in parallel
+ :param max_num_procs: The maximum number of Module processes that
+ can be run in parallel
+ :type max_num_procs: int
self._num_procs = int(max_num_procs)
self._list = int(max_num_procs) * [None]
self._proc_count = 0
def put(self, module):
- """!Put the next Module object in the queue
+ """Put the next Module object in the queue
To run the Module objects in parallel the run_ and finish_ options
of the Module must be set to False.
- @param module A preconfigured Module object with run_ and finish_
- set to False
+ :param module: a preconfigured Module object with run_ and finish_
+ set to False
+ :type module: Module object
self._list[self._proc_count] = module
self._list[self._proc_count].run()
@@ -136,38 +134,43 @@
self.wait()
def get(self, num):
- """!Get a Module object from the queue
+ """Get a Module object from the queue
- @param num The number of the object in queue
- @return The Module object or None if num is not in the queue
+ :param num: the number of the object in queue
+ :type num: int
+ :returns: the Module object or None if num is not in the queue
if num < self._num_procs:
return self._list[num]
return None
def get_num_run_procs(self):
- """!Get the number of Module processes that are in the queue running
+ """Get the number of Module processes that are in the queue running
or finished
- @return The maximum number fo Module processes running/finished in
- the queue
+ :returns: the maximum number fo Module processes running/finished in
+ the queue
return len(self._list)
def get_max_num_procs(self):
- """!Return the maximum number of parallel Module processes
+ """Return the maximum number of parallel Module processes
return self._num_procs
def set_max_num_procs(self, max_num_procs):
- """!Set the maximum number of Module processes that should run
- in parallel
+ """Set the maximum number of Module processes that should run
+ in parallel
self.wait()
def wait(self):
- """!Wait for all Module processes that are in the list to finish
+ """Wait for all Module processes that are in the list to finish
and set the modules stdout and stderr output options
for proc in self._list:
@@ -185,24 +188,22 @@
class Module(object):
Python allow developers to not specify all the arguments and
keyword arguments of a method or function.
def f(*args):
for arg in args:
print arg
- therefore if we call the function like: ::
+ therefore if we call the function like:
>>> f('grass', 'gis', 'modules')
grass
gis
modules
- or we can define a new list: ::
+ or we can define a new list:
>>> words = ['grass', 'gis', 'modules']
>>> f(*words)
@@ -210,7 +211,7 @@
gis
modules
- we can do the same with keyword arguments, rewrite the above function: ::
+ we can do the same with keyword arguments, rewrite the above function:
def f(*args, **kargs):
for arg in args:
@@ -218,7 +219,7 @@
for key, value in kargs.items():
print "%s = %r" % (key, value)
- now we can use the new function, with: ::
+ now we can use the new function, with:
>>> f('grass', 'gis', 'modules', os = 'linux', language = 'python')
grass
@@ -228,7 +229,7 @@
language = 'python'
or, as before we can, define a dictionary and give the dictionary to
- the function, like: ::
+ the function, like:
>>> keywords = {'os' : 'linux', 'language' : 'python'}
>>> f(*words, **keywords)
@@ -376,11 +377,12 @@
raise ParameterError(msg % k)
return self.run()
def get_bash(self):
+ """Prova"""
return ' '.join(self.make_cmd())
+ """Prova"""
prefix = self.name.split('.')[0]
name = '_'.join(self.name.split('.')[1:])
params = ', '.join([par.get_python() for par in self.params_list
@@ -403,7 +405,7 @@
return "%s.%s(%s)" % (prefix, name, params)
def __str__(self):
- """!Return the command string that can be executed in a shell
+ """Return the command string that can be executed in a shell
@@ -415,7 +417,7 @@
"""{cmd_name}({cmd_params})
head = DOC['head'].format(cmd_name=self.name,
- cmd_params=('\n' + # go to a new line
+ cmd_params=('\n' + # go to a new line
# give space under the function name
(' ' * (len(self.name) + 1))).join([', '.join(
# transform each parameter in string
@@ -427,8 +429,8 @@
return '\n'.join([head, params, DOC['flag_head'], flags, DOC['foot']])
def get_dict(self):
- """!Return a dictionary that includes the name, all valid
- inputs, outputs and flags
+ """Return a dictionary that includes the name, all valid
+ inputs, outputs and flags
dic = {}
dic['name'] = self.name
@@ -440,9 +442,9 @@
return dic
def make_cmd(self):
- """!Create the command string that can be executed in a shell
+ """Create the command string that can be executed in a shell
- @return The command string
+ :returns: the command string
skip = ['stdin', 'stdout', 'stderr']
args = [self.name, ]
@@ -458,15 +460,17 @@
return args
def run(self, node=None):
- """!Run the module
+ """Run the module
- This function will wait for the process to terminate
- in case finish_==True and sets up stdout and stderr.
- If finish_==False this function will return after starting
- the process. Use self.popen.communicate() of self.popen.wait()
- to wait for the process termination. The handling
- of stdout and stderr must then be done outside of this
- function.
+ :param node:
+ :type node:
+ This function will wait for the process to terminate in case
+ finish_==True and sets up stdout and stderr. If finish_==False this
+ function will return after starting the process. Use
+ self.popen.communicate() of self.popen.wait() to wait for the process
+ termination. The handling of stdout and stderr must then be done
+ outside of this function.
if self.inputs['stdin'].value:
self.stdin = self.inputs['stdin'].value
Modified: grass/trunk/lib/python/pygrass/modules/interface/parameter.py
--- grass/trunk/lib/python/pygrass/modules/interface/parameter.py 2014-05-29 10:33:59 UTC (rev 60582)
+++ grass/trunk/lib/python/pygrass/modules/interface/parameter.py 2014-05-29 10:48:13 UTC (rev 60583)
@@ -12,8 +12,12 @@
from grass.pygrass.modules.interface.read import GETTYPE, element2dict, DOC
class Parameter(object):
+ """The Parameter object store all information about a parameter of module.
+ It is possible to set parameter of command using this object.
def __init__(self, xparameter=None, diz=None):
self._value = None
diz = element2dict(xparameter) if xparameter is not None else diz
@@ -138,9 +142,11 @@
# here the property function is used to transform value in an attribute
# in this case we define which function must be use to get/set the value
- value = property(fget=_get_value, fset=_set_value)
+ value = property(fget=_get_value, fset=_set_value,
+ doc="Set or obtain value")
def get_bash(self):
+ """Prova"""
if isinstance(self._value, list) or isinstance(self._value, tuple):
value = ','.join([str(v) for v in self._value])
else:
@@ -148,6 +154,7 @@
return """%s=%s""" % (self.name, value)
+ """Prova"""
if not self.value:
return ''
return """%s=%r""" % (self.name, self._value)
Modified: grass/trunk/lib/python/pygrass/vector/basic.py
--- grass/trunk/lib/python/pygrass/vector/basic.py 2014-05-29 10:33:59 UTC (rev 60582)
+++ grass/trunk/lib/python/pygrass/vector/basic.py 2014-05-29 10:48:13 UTC (rev 60583)
@@ -125,16 +125,17 @@
return ['north', 'south', 'west', 'east', 'top', 'bottom']
def contains(self, point):
- """Return True if the object is contained by the BoundingBox.
+ """Return True if the object is contained by the BoundingBox
- :param point:the point to analyze
+ :param point: the point to analyze
:type point: a Point object or a tuple with the coordinates
- >>> from grass.pygrass.vector.geometry import Point
- >>> poi = Point(5,5)
- >>> bbox = Bbox(north=10, south=0, west=0, east=10)
- >>> bbox.contains(poi)
- True
+ >>> from grass.pygrass.vector.geometry import Point
+ >>> poi = Point(5,5)
+ >>> bbox = Bbox(north=10, south=0, west=0, east=10)
+ >>> bbox.contains(poi)
+ True
return bool(libvect.Vect_point_in_box(point.x, point.y,
point.z if point.z else 0,
@@ -149,6 +150,7 @@
:param tb: if tb parameter is False return only: north, south, east,
west and not top and bottom
:type tb: bool
if tb:
return (self.north, self.south, self.east, self.west,
@@ -201,23 +203,23 @@
def append(self, box):
"""Append a Bbox object to a Boxlist object, using the
- ``Vect_boxlist_append`` C fuction.
+ ``Vect_boxlist_append`` C fuction.
:param bbox: the bounding box to add to the list
:param bbox: a Bbox object
- >>> box0 = Bbox()
- >>> box1 = Bbox(1,2,3,4)
- >>> box2 = Bbox(5,6,7,8)
- >>> boxlist = BoxList([box0, box1])
- >>> boxlist
- Boxlist([Bbox(0.0, 0.0, 0.0, 0.0), Bbox(1.0, 2.0, 3.0, 4.0)])
- >>> len(boxlist)
- 2
- >>> boxlist.append(box2)
- >>> len(boxlist)
- 3
+ >>> box0 = Bbox()
+ >>> box1 = Bbox(1,2,3,4)
+ >>> box2 = Bbox(5,6,7,8)
+ >>> boxlist = BoxList([box0, box1])
+ >>> boxlist
+ Boxlist([Bbox(0.0, 0.0, 0.0, 0.0), Bbox(1.0, 2.0, 3.0, 4.0)])
+ >>> len(boxlist)
+ 2
+ >>> boxlist.append(box2)
+ >>> len(boxlist)
+ 3
indx = self.__len__()
libvect.Vect_boxlist_append(self.c_boxlist, indx, box.c_bbox)
@@ -261,13 +263,14 @@
:param indx: the index value of the Bbox to remove
:param indx: int
- >>> boxlist = BoxList([Bbox(),
- ... Bbox(1, 0, 0, 1),
- ... Bbox(1, -1, -1, 1)])
- >>> boxlist.remove(0)
- >>> boxlist
- Boxlist([Bbox(1.0, 0.0, 0.0, 1.0), Bbox(1.0, -1.0, -1.0, 1.0)])
+ >>> boxlist = BoxList([Bbox(),
+ ... Bbox(1, 0, 0, 1),
+ ... Bbox(1, -1, -1, 1)])
+ >>> boxlist.remove(0)
+ >>> boxlist
+ Boxlist([Bbox(1.0, 0.0, 0.0, 1.0), Bbox(1.0, -1.0, -1.0, 1.0)])
if hasattr(indx, 'c_boxlist'):
libvect.Vect_boxlist_delete_boxlist(self.c_boxlist, indx.c_boxlist)
@@ -279,18 +282,17 @@
def reset(self):
"""Reset the c_boxlist C struct, using the ``Vect_reset_boxlist`` C
- function. ::
+ function.
- >>> len(boxlist)
- 3
- >>> boxlist.reset()
- >>> len(boxlist)
- 0
+ >>> len(boxlist)
+ 3
+ >>> boxlist.reset()
+ >>> len(boxlist)
+ 0
libvect.Vect_reset_boxlist(self.c_boxlist)
Modified: grass/trunk/lib/python/pygrass/vector/geometry.py
--- grass/trunk/lib/python/pygrass/vector/geometry.py 2014-05-29 10:33:59 UTC (rev 60582)
+++ grass/trunk/lib/python/pygrass/vector/geometry.py 2014-05-29 10:48:13 UTC (rev 60583)
@@ -476,14 +476,14 @@
:type tol: float
:returns: the buffer as Area object
- >>> pnt = Point(0, 0)
- >>> area = pnt.buffer(10)
- >>> area.boundary #doctest: +ELLIPSIS
- Line([Point(10.000000, 0.000000),...Point(10.000000, 0.000000)])
- >>> area.centroid
- Point(0.000000, 0.000000)
- >>> area.isles
+ >>> pnt = Point(0, 0)
+ >>> area = pnt.buffer(10)
+ >>> area.boundary #doctest: +ELLIPSIS
+ Line([Point(10.000000, 0.000000),...Point(10.000000, 0.000000)])
+ >>> area.centroid
+ Point(0.000000, 0.000000)
+ >>> area.isles
if dist is not None:
@@ -997,14 +997,14 @@
:type tol: float
- >>> line = Line([(0, 0), (0, 2)])
- >>> area = line.buffer(10)
- Line([Point(-10.000000, 0.000000),...Point(-10.000000, 0.000000)])
- >>> area.centroid
- >>> area.isles
+ >>> line = Line([(0, 0), (0, 2)])
+ >>> area = line.buffer(10)
+ Line([Point(-10.000000, 0.000000),...Point(-10.000000, 0.000000)])
+ >>> area.centroid
+ >>> area.isles
Modified: grass/trunk/lib/python/pygrass/vector/sql.py
--- grass/trunk/lib/python/pygrass/vector/sql.py 2014-05-29 10:33:59 UTC (rev 60582)
+++ grass/trunk/lib/python/pygrass/vector/sql.py 2014-05-29 10:48:13 UTC (rev 60583)
@@ -1,8 +1,5 @@
# -*- coding: utf-8 -*-
-SQL
It is a collection of strings to avoid to repeat the code.
>>> SELECT.format(cols=', '.join(['cat', 'area']), tname='table')
