[GRASS-SVN] r60591 - grass/trunk/scripts/r.out.xyz
svn_grass at osgeo.org
Thu May 29 16:27:47 PDT 2014
Author: glynn
Date: 2014-05-29 16:27:47 -0700 (Thu, 29 May 2014)
New Revision: 60591
grass/trunk/scripts/r.out.xyz/r.out.xyz.py
Manually revert r57904, r60569
Modified: grass/trunk/scripts/r.out.xyz/r.out.xyz.py
--- grass/trunk/scripts/r.out.xyz/r.out.xyz.py 2014-05-29 22:23:24 UTC (rev 60590)
+++ grass/trunk/scripts/r.out.xyz/r.out.xyz.py 2014-05-29 23:27:47 UTC (rev 60591)
@@ -31,7 +31,6 @@
#% required: no
#%end
#%option G_OPT_F_SEP
-#% answer: space
#%end
import sys
@@ -41,18 +40,12 @@
def main():
# if no output filename, output to stdout
output = options['output']
- sep = options['separator']
parameters = dict(flags="1gn",
- input=options['input'])
+ input=options['input'],
+ separator=options['separator'])
if output:
parameters.update(output=output)
- # windows don't like pipe so we don't include it in the command explicitly
- if sep == '|':
- grass.warning(_("Separator '|' is not allowed. Using a space."))
- # but why?
- else:
- parameters.update(separator=sep)
ret = grass.run_command("r.stats", **parameters)
sys.exit(ret)
