[GRASS-SVN] r60607 - grass/trunk/locale/po
Fri May 30 04:55:10 PDT 2014
Author: hcho
Date: 2014-05-30 04:55:10 -0700 (Fri, 30 May 2014)
New Revision: 60607
   grass/trunk/locale/po/grasslibs_ko.po
   grass/trunk/locale/po/grassmods_ko.po
Korean translation
Modified: grass/trunk/locale/po/grasslibs_ko.po
--- grass/trunk/locale/po/grasslibs_ko.po	2014-05-30 10:50:09 UTC (rev 60606)
+++ grass/trunk/locale/po/grasslibs_ko.po	2014-05-30 11:55:10 UTC (rev 60607)
@@ -6603,12 +6603,12 @@
 #: ../lib/vector/Vlib/merge_lines.c:240
 #, c-format
 msgid "%d boundaries merged"
-msgstr ""
+msgstr "%d개의 경계를 병합했습니다"
 #: ../lib/vector/Vlib/merge_lines.c:241
 #, c-format
 msgid "%d new boundaries"
-msgstr ""
+msgstr "%d개의 새경계"
 #: ../lib/vector/Vlib/level.c:34
 msgid "Map structure was never initialized"
@@ -7513,7 +7513,7 @@
 #: ../lib/vector/Vlib/build.c:867
 msgid "Topology was built"
-msgstr ""
+msgstr "위상을 생성했습니다"
 #: ../lib/vector/Vlib/build.c:878
 #, c-format
@@ -8123,14 +8123,14 @@
 msgstr "Datum %s 표파일을 열 수 없습니다"
 #: ../lib/vector/Vlib/bridges.c:213
-#, fuzzy, c-format
+#, c-format
 msgid "Removed lines: %d"
-msgstr "Datum %s 표파일을 열 수 없습니다"
+msgstr "지워진 선: %d"
 #: ../lib/vector/Vlib/bridges.c:214
-#, fuzzy, c-format
+#, c-format
 msgid "Removed bridges: %d"
+msgstr "지워진 다리: %d"
 #: ../lib/vector/Vlib/ascii.c:84
 #, fuzzy, c-format
@@ -8484,20 +8484,19 @@
 #: ../lib/vector/Vlib/open.c:879
 #, c-format
 msgid "Using OGR/%s format"
-msgstr ""
+msgstr "OGR/%s 포맷을 씀"
 #: ../lib/vector/Vlib/open.c:883
 msgid "Using PostGIS Topology format"
-msgstr ""
+msgstr "PostGIS 위상포맷을 씀"
 #: ../lib/vector/Vlib/open.c:885
 msgid "Using PostGIS format"
-msgstr ""
+msgstr "PostGIS 포맷을 씀"
 #: ../lib/vector/Vlib/open.c:888
-#, fuzzy
 msgid "Using native format"
-msgstr "잘못된 좌표"
+msgstr "자체포맷을 씀"
 #: ../lib/vector/Vlib/open.c:979
 #, fuzzy, c-format
Modified: grass/trunk/locale/po/grassmods_ko.po
--- grass/trunk/locale/po/grassmods_ko.po	2014-05-30 10:50:09 UTC (rev 60606)
+++ grass/trunk/locale/po/grassmods_ko.po	2014-05-30 11:55:10 UTC (rev 60607)
@@ -24619,7 +24619,7 @@
 #: ../raster/r.report/parse.c:132
 msgid "Scientific format"
-msgstr "과학적 양식"
+msgstr "과학적 기수법"
 #: ../raster/r.report/parse.c:137 ../raster/r.stats/main.c:204
 msgid "Do not report no data value"
@@ -33784,9 +33784,8 @@
 #: ../vector/v.category/main.c:364 ../vector/v.delaunay/main.c:172
 #: ../vector/v.in.ogr/main.c:1310
-#, fuzzy
 msgid "Unable to calculate area centroid"
-msgstr "출력할 격자지도"
+msgstr "면의 중심점을 계산하지 못 했습니다"
 #: ../vector/v.category/main.c:378
 #, fuzzy, c-format
