[GRASS-SVN] r60625 - grass/trunk/scripts/m.proj
svn_grass at osgeo.org
Sat May 31 02:30:04 PDT 2014
Author: hcho
Date: 2014-05-31 02:30:04 -0700 (Sat, 31 May 2014)
New Revision: 60625
grass/trunk/scripts/m.proj/m.proj.py
m.proj: use grass.separator and allow multi-character separators
Modified: grass/trunk/scripts/m.proj/m.proj.py
--- grass/trunk/scripts/m.proj/m.proj.py 2014-05-31 09:28:11 UTC (rev 60624)
+++ grass/trunk/scripts/m.proj/m.proj.py 2014-05-31 09:30:04 UTC (rev 60625)
@@ -46,7 +46,6 @@
#%end
#%option G_OPT_F_SEP
#% label: Field separator (format: input[,output])
-#% description: Valid field separators are also "space", "tab", or "comma"
#% required : no
#% guisection: Input coordinates
#%end
@@ -159,34 +158,8 @@
except ValueError:
ifs = ofs = fs
- ifs = ifs.lower()
- ofs = ofs.lower()
- if ifs in ('space', 'tab'):
- ifs = ' '
- elif ifs == 'comma':
- ifs = ','
- else:
- if len(ifs) > 1:
- grass.warning(_("Invalid field separator, using '%s'") % ifs[0])
- try:
- ifs = ifs[0]
- except IndexError:
- grass.fatal(_("Invalid field separator '%s'") % ifs)
- if ofs.lower() == 'space':
- ofs = ' '
- elif ofs.lower() == 'tab':
- ofs = '\t'
- elif ofs.lower() == 'comma':
- ofs = ','
- else:
- if len(ofs) > 1:
- grass.warning(_("Invalid field separator, using '%s'") % ofs[0])
- try:
- ofs = ofs[0]
+ ifs = grass.separator(ifs)
+ ofs = grass.separator(ofs)
#### set up projection params
s = grass.read_command("g.proj", flags='j')
