[GRASS-SVN] r60634 - grass/trunk/gui/wxpython/core
svn_grass at osgeo.org
Sat May 31 07:14:53 PDT 2014
Author: hcho
Date: 2014-05-31 07:14:53 -0700 (Sat, 31 May 2014)
New Revision: 60634
grass/trunk/gui/wxpython/core/gcmd.py
gcmd.py: escape special characters (^|&) on Windows
Modified: grass/trunk/gui/wxpython/core/gcmd.py
--- grass/trunk/gui/wxpython/core/gcmd.py 2014-05-31 14:11:29 UTC (rev 60633)
+++ grass/trunk/gui/wxpython/core/gcmd.py 2014-05-31 14:14:53 UTC (rev 60634)
@@ -168,7 +168,33 @@
def __init__(self, args, **kwargs):
if subprocess.mswindows:
args = map(EncodeString, args)
+ # The Windows shell (cmd.exe) requires some special characters to
+ # be escaped by preceding them with 3 carets (^^^). cmd.exe /?
+ # mentions <space> and &()[]{}^=;!'+,`~. The vertical bar (|)
+ # should also be included. A quick test revealed that only ^|& need
+ # to be escaped.
+ for i in range(2, len(args)):
+ for c in ("^", "|", "&"):
+ if c in args[i]:
+ if "=" in args[i]:
+ k, v = args[i].split("=")
+ k = k + "="
+ else:
+ k = ""
+ v = args[i]
+ # If there are spaces, the argument was already
+ # esscaped with double quotes, so don't escape it
+ # again.
+ if c in v and not " " in v:
+ # Here, we escape each ^ in ^^^ with ^^ and a
+ # <special character> with ^ + <special character>,
+ # so we need 7 carets.
+ v = v.replace(c, "^^^^^^^" + c)
+ args[i] = k + v
subprocess.Popen.__init__(self, args, **kwargs)
def recv(self, maxsize = None):
