[GRASS-SVN] r62547 - grass/branches/releasebranch_7_0/include/Make
svn_grass at osgeo.org
Sun Nov 2 11:20:21 PST 2014
Author: neteler
Date: 2014-11-02 11:20:20 -0800 (Sun, 02 Nov 2014)
New Revision: 62547
grass/branches/releasebranch_7_0/include/Make/Doxyfile_arch_html.in
grass/branches/releasebranch_7_0/include/Make/Doxyfile_arch_latex.in
Doxyfile_arch_*.in: sync to trunk
Modified: grass/branches/releasebranch_7_0/include/Make/Doxyfile_arch_html.in
--- grass/branches/releasebranch_7_0/include/Make/Doxyfile_arch_html.in 2014-11-02 19:19:21 UTC (rev 62546)
+++ grass/branches/releasebranch_7_0/include/Make/Doxyfile_arch_html.in 2014-11-02 19:20:20 UTC (rev 62547)
@@ -359,7 +359,7 @@
# defined locally in source files will be included in the documentation.
# If set to NO only classes defined in header files are included.
-EXTRACT_LOCAL_CLASSES = YES
+EXTRACT_LOCAL_CLASSES = NO
# This flag is only useful for Objective-C code. When set to YES local
# methods, which are defined in the implementation section but not in
@@ -659,8 +659,7 @@
FILE_PATTERNS = *.h \
*.c \
- *.i \
- *.py \
+ *.cpp \
*.dox
# The RECURSIVE tag can be used to turn specify whether or not subdirectories
@@ -683,11 +682,7 @@
dist. at ARCH@ \
doc \
general \
- gui/scripts \
- gui/wxpython/compat \
- gui/wxpython/icons \
- gui/wxpython/scripts \
- gui/wxpython/tools \
+ gui \
imagery \
include/defs \
lib/btree/test \
@@ -697,7 +692,7 @@
lib/gpde/test \
lib/linkm/test \
lib/raster3d/test \
- lib/python/ctypes \
+ lib/python \
lib/vector/dglib/examples \
lib/vector/rtree/docs \
locale \
@@ -739,8 +734,7 @@
*/testsuite/* \
*/test_* \
*/test.* \
- */*local_proto.h \
- */g.gui.*.py
+ */*local_proto.h
# The EXCLUDE_SYMBOLS tag can be used to specify one or more symbol names
# (namespaces, classes, functions, etc.) that should be excluded from the
@@ -957,7 +951,7 @@
# 180 is cyan, 240 is blue, 300 purple, and 360 is red again.
# The allowed range is 0 to 359.
-HTML_COLORSTYLE_HUE = 220
+HTML_COLORSTYLE_HUE = 120
# The HTML_COLORSTYLE_SAT tag controls the purity (or saturation) of
# the colors in the HTML output. For a value of 0 the output will use
@@ -972,7 +966,7 @@
# so 80 represents a gamma of 0.8, The value 220 represents a gamma of 2.2,
# and 100 does not change the gamma.
-HTML_COLORSTYLE_GAMMA = 80
+HTML_COLORSTYLE_GAMMA = 56
# If the HTML_TIMESTAMP tag is set to YES then the footer of each generated HTML
# page will contain the date and time when the page was generated. Setting
Modified: grass/branches/releasebranch_7_0/include/Make/Doxyfile_arch_latex.in
--- grass/branches/releasebranch_7_0/include/Make/Doxyfile_arch_latex.in 2014-11-02 19:19:21 UTC (rev 62546)
+++ grass/branches/releasebranch_7_0/include/Make/Doxyfile_arch_latex.in 2014-11-02 19:20:20 UTC (rev 62547)
@@ -359,7 +359,7 @@
@@ -659,8 +659,7 @@
*.c \
- *.i \
- *.py \
+ *.cpp \
*.dox
dist. at ARCH@ \
doc \
general \
- gui/scripts \
+ gui \
imagery \
include/defs \
lib/btree/test \
@@ -697,7 +692,7 @@
lib/gpde/test \
lib/linkm/test \
lib/raster3d/test \
+ lib/python \
locale \
@@ -739,8 +734,7 @@
*/testsuite/* \
*/test_* \
*/test.* \
- */g.gui.*.py
+ */*local_proto.h
@@ -957,7 +951,7 @@
@@ -972,7 +966,7 @@
@@ -1166,7 +1160,7 @@
# Since the tree basically has the same information as the tab index you
# could consider to set DISABLE_INDEX to NO when enabling this option.
-GENERATE_TREEVIEW = NO
+GENERATE_TREEVIEW = YES
# The ENUM_VALUES_PER_LINE tag can be used to set the number of enum values
# (range [0,1..20]) that doxygen will group on one line in the generated HTML
@@ -1261,7 +1255,7 @@
# If a relative path is entered the value of OUTPUT_DIRECTORY will be
# put in front of it. If left blank `latex' will be used as the default path.
-LATEX_OUTPUT =
+LATEX_OUTPUT = latex
# The LATEX_CMD_NAME tag can be used to specify the LaTeX command name to be
# invoked. If left blank `latex' will be used as the default command name.
