[GRASS-SVN] r62550 - in grass-addons/grass7/raster: r.in.arc r.out.arc r.out.tiff
Sun Nov 2 11:52:58 PST 2014
Author: neteler
Date: 2014-11-02 11:52:58 -0800 (Sun, 02 Nov 2014)
New Revision: 62550
   grass-addons/grass7/raster/r.in.arc/r.in.arc.html
   grass-addons/grass7/raster/r.out.arc/r.out.arc.html
   grass-addons/grass7/raster/r.out.tiff/r.out.tiff.html
Addons: hint added about current alternatives in core system to be used
Modified: grass-addons/grass7/raster/r.in.arc/r.in.arc.html
--- grass-addons/grass7/raster/r.in.arc/r.in.arc.html	2014-11-02 19:46:23 UTC (rev 62549)
+++ grass-addons/grass7/raster/r.in.arc/r.in.arc.html	2014-11-02 19:52:58 UTC (rev 62550)
@@ -1,5 +1,8 @@
 <h2>DESCRIPTION</h2>
+Note: this module is superseded by <a href="r.in.gdal.html">r.in.gdal</a>.
+<p>
 <em>r.in.arc</em> allows a user to create a (binary) GRASS raster map layer
 from an ESRI ARC/INFO ascii GRID file with (optional) title.
@@ -42,8 +45,10 @@
 <h2>SEE ALSO</h2>
-<i><a href="r.in.gdal.html">r.in.gdal</a></i>
-<i><a href="r.out.arc.html">r.out.arc</a></i>
+<em>
+<a href="r.in.gdal.html">r.in.gdal</a>,
+<a href="r.out.arc.html">r.out.arc</a>
+</em>
 <h2>AUTHOR</h2>
 Unknown German author, updated by Bill Brown to floating point support.
Modified: grass-addons/grass7/raster/r.out.arc/r.out.arc.html
--- grass-addons/grass7/raster/r.out.arc/r.out.arc.html	2014-11-02 19:46:23 UTC (rev 62549)
+++ grass-addons/grass7/raster/r.out.arc/r.out.arc.html	2014-11-02 19:52:58 UTC (rev 62550)
@@ -1,5 +1,8 @@
+Note: this module is superseded by <a href="r.out.gdal.html">r.out.gdal</a>.
+<p>
 <em>r.out.arc</em> converts a user-specified raster map layer
 (<b>input=</b><em>name</em>) into an ESRI ARC-GRID ascii file
 (<b>output=</b><em>name</em>) suitable for export to other computer systems.
@@ -10,7 +13,6 @@
 number of digits occurring in the output file by running <em>r.out.arc</em>
 without the <b>dp=</b><em>value</em> option.
 <p>
 The GRASS program <em><a href="r.in.arc.html">r.in.arc</a></em> can be used
 to perform the reverse function, converting an ESRI ARC-GRID ascii file in
@@ -29,7 +31,7 @@
 The output file <em>out.grd</em> can then be copied
 onto a CDROM or floppy disk for export purposes.
-<p><br>
+<p>
 An Arc ASCII grid can be loaded into ArcGIS 8.3 though ArcToolbox.<br>
 Use the "Import to Raster" -> "ASCII to Grid" tool to create a binary grid
 which can be selected using ArcCatalog. The spatial analyst extension may
@@ -38,11 +40,13 @@
 ArcMap -> Toolbox -> Conversion Tools -> To Raster -> ASCII to Raster
 <p>A GeoTIFF created with <em><a href="r.out.gdal.html">r.out.gdal</a></em> is
 sometimes a better solution for transferring raster maps to other GIS software.
-<p><h2>SEE ALSO</h2>
-<em><a href="r.in.arc.html">r.in.arc</a></em><br>
-<em><a href="r.out.gdal.html">r.out.gdal</a></em><br>
+<h2>SEE ALSO</h2>
+<em>
+<a href="r.in.arc.html">r.in.arc</a>,
+<a href="r.out.gdal.html">r.out.gdal</a>
+</em>
 <h2>AUTHOR</h2>
Modified: grass-addons/grass7/raster/r.out.tiff/r.out.tiff.html
--- grass-addons/grass7/raster/r.out.tiff/r.out.tiff.html	2014-11-02 19:46:23 UTC (rev 62549)
+++ grass-addons/grass7/raster/r.out.tiff/r.out.tiff.html	2014-11-02 19:52:58 UTC (rev 62550)
@@ -1,6 +1,9 @@
-<p>This program converts a GRASS raster map to a TIFF raster map. Output may
+<p>
+<em>r.out.tiff</em> converts a GRASS raster map to a TIFF raster map. Output may
 be 8 or 24 bit (TrueColor).  Optionally, a TIFF World file compatible with
 ESRI's and other's products may be output.
@@ -27,9 +30,11 @@
 <h2>SEE ALSO</h2>
-<em><a href="g.region.html">g.region</a>,</em>
-<em><a href="r.in.gdal.html">r.in.gdal</a>,</em>
+<em>
+<a href="g.region.html">g.region</a>,
+</em>
 <h2>AUTHOR</h2>
 Michael Shapiro,
