[GRASS-SVN] r62563 - in grass/branches/releasebranch_7_0: . gui/wxpython/vnet
svn_grass at osgeo.org
Sun Nov 2 15:07:37 PST 2014
Author: annakrat
Date: 2014-11-02 15:07:37 -0800 (Sun, 02 Nov 2014)
New Revision: 62563
grass/branches/releasebranch_7_0/
grass/branches/releasebranch_7_0/gui/wxpython/vnet/widgets.py
wxGUI/vnet: fix encoding problem with French locale #2145, merge from trunk, r62562
Property changes on: grass/branches/releasebranch_7_0
___________________________________________________________________
Modified: svn:mergeinfo
- /grass/trunk:62179-62180,62182,62403,62466,62487,62491,62494,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555
+ /grass/trunk:62179-62180,62182,62403,62466,62487,62491,62494,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562
Modified: grass/branches/releasebranch_7_0/gui/wxpython/vnet/widgets.py
--- grass/branches/releasebranch_7_0/gui/wxpython/vnet/widgets.py 2014-11-02 23:05:50 UTC (rev 62562)
+++ grass/branches/releasebranch_7_0/gui/wxpython/vnet/widgets.py 2014-11-02 23:07:37 UTC (rev 62563)
@@ -227,7 +227,9 @@
self.selIdxs[key][colNum] = -1
self.itemDataMap[key][colNum] = cellVal
- self.SetStringItem(index, colNum, str(cellVal))
+ if not isinstance(cellVal, basestring):
+ cellVal = str(cellVal)
+ self.SetStringItem(index, colNum, cellVal)
def EditCellKey(self, key, colName, cellData):
"""!Changes value in list using index (changes during sorting)"""
@@ -245,7 +247,9 @@
index = self._findIndex(key)
if index != -1:
def _findIndex(self, key):
"""!Find index for key"""
@@ -375,7 +379,10 @@
i = 0
for editedCell in editedData:
if editedCell[1] != data[i][1]:
- self.SetStringItem(index, editedCell[0], str(editedCell[1]))
+ value = editedCell[1]
+ if not isinstance(editedCell[1], basestring):
+ value = str(editedCell[1])
+ self.SetStringItem(index, editedCell[0], value)
self.itemDataMap[key][editedCell[0]] = editedCell[1]
changed = True
i += 1
@@ -562,7 +569,10 @@
else:
self.fields.append(wx.TextCtrl(parent=panel, id=wx.ID_ANY,
size=(150, -1)))
- self.fields[iField].SetValue(str(cell[1]))
+ value = cell[1]
+ if not isinstance(cell[1], basestring):
+ value = str(cell[1])
+ self.fields[iField].SetValue(value)
label = wx.StaticText(parent = panel, id=wx.ID_ANY,
label = _(parent.GetColumn(cell[0]).GetText()) + ":") # name of column)
