[GRASS-SVN] r62574 - in grass/branches/releasebranch_7_0: . gui/wxpython/docs
Mon Nov 3 07:28:57 PST 2014
Author: annakrat
Date: 2014-11-03 07:28:57 -0800 (Mon, 03 Nov 2014)
New Revision: 62574
   grass/branches/releasebranch_7_0/
   grass/branches/releasebranch_7_0/gui/wxpython/docs/wxGUI.html
wxGUI/docs: clarify misleading text about removing/renaming layers (merge from trunk, 62573)
Property changes on: grass/branches/releasebranch_7_0
___________________________________________________________________
Modified: svn:mergeinfo
   - /grass/trunk:61096,62179-62180,62182,62403,62466,62487,62491,62494,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62570
   + /grass/trunk:61096,62179-62180,62182,62403,62466,62487,62491,62494,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62570,62573
Modified: grass/branches/releasebranch_7_0/gui/wxpython/docs/wxGUI.html
--- grass/branches/releasebranch_7_0/gui/wxpython/docs/wxGUI.html	2014-11-03 15:27:44 UTC (rev 62573)
+++ grass/branches/releasebranch_7_0/gui/wxpython/docs/wxGUI.html	2014-11-03 15:28:57 UTC (rev 62574)
@@ -104,7 +104,7 @@
 <p>
 A right mouse click on a layer or left clicking the button to the right of
 the layer opens a dropdown menu with options to remove or rename the layer
-(g.remove, g.rename), change its display properties (d.rast and d.vect
+(not the actual map), change its display properties (d.rast and d.vect
 options such as color, symbol, etc.), show its metadata (r.info, v.info) or
 attributes, if applicable.
 <p>
