[GRASS-SVN] r62580 - in grass/branches/releasebranch_7_0: . lib/init
svn_grass at osgeo.org
Mon Nov 3 10:41:40 PST 2014
Author: martinl
Date: 2014-11-03 10:41:40 -0800 (Mon, 03 Nov 2014)
New Revision: 62580
grass/branches/releasebranch_7_0/
grass/branches/releasebranch_7_0/lib/init/grass.py
grass/branches/releasebranch_7_0/lib/init/grass7.html
grass.py: support datum_trans when creating new location based on EPSG code
(merge r62424 from trunk)
Property changes on: grass/branches/releasebranch_7_0
___________________________________________________________________
Modified: svn:mergeinfo
- /grass/trunk:61096,62179-62180,62182,62403,62422,62437,62466,62487,62491,62494,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62570,62573,62575
+ /grass/trunk:61096,62179-62180,62182,62403,62422,62424,62437,62466,62487,62491,62494,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62570,62573,62575
Modified: grass/branches/releasebranch_7_0/lib/init/grass.py
--- grass/branches/releasebranch_7_0/lib/init/grass.py 2014-11-03 18:33:12 UTC (rev 62579)
+++ grass/branches/releasebranch_7_0/lib/init/grass.py 2014-11-03 18:41:40 UTC (rev 62580)
@@ -167,7 +167,7 @@
Geographic Resources Analysis Support System (GRASS GIS).
%s:
- $CMD_NAME [-h | -help | --help] [-v | --version] [-c | -c geofile | -c EPSG:code]
+ $CMD_NAME [-h | -help | --help] [-v | --version] [-c | -c geofile | -c EPSG:code[:datum_trans]]
[-e] [-text | -gui] [--config param]
[[[<GISDBASE>/]<LOCATION_NAME>/]<MAPSET>]
@@ -646,8 +646,12 @@
if geofile and geofile.upper().find('EPSG:') > -1:
# create location using EPSG code
epsg = geofile.split(':', 1)[1]
+ if ':' in epsg:
+ epsg, datum_trans = epsg.split(':', 1)
+ else:
+ datum_trans = None
grass.create_location(gisdbase, location_name,
- epsg=epsg)
+ epsg=epsg, datum_trans=datum_trans)
else:
# create location using georeferenced file
Modified: grass/branches/releasebranch_7_0/lib/init/grass7.html
--- grass/branches/releasebranch_7_0/lib/init/grass7.html 2014-11-03 18:33:12 UTC (rev 62579)
+++ grass/branches/releasebranch_7_0/lib/init/grass7.html 2014-11-03 18:41:40 UTC (rev 62580)
@@ -3,7 +3,7 @@
<h2>SYNOPSIS</h2>
<b>grass70</b> [<b>-h</b> | <b>-help</b> | <b>--help</b>] [<b>-v</b> | <b>--version</b>]
- [<b>-c</b> | <b>-c geofile</b> | <b>-c EPSG:code</b>]
+ [<b>-c</b> | <b>-c geofile</b> | <b>-c EPSG:code[:datum_trans]</b>]
[<b>-text</b> | <b>-gtext</b> | <b>-gui</b>]
[[[<b><GISDBASE>/</b>]<b><LOCATION_NAME>/</b>]
<b><MAPSET></b>]
@@ -27,6 +27,9 @@
<dt><b>-c EPSG:code</b>
<dd> Creates new GRASS projected location in specified GISDBASE with given EPSG code
+<dt><b>-c EPSG:code:datum_trans</b>
+ <dd> Creates new GRASS projected location in specified GISDBASE with given EPSG code and datum transform parameters
<dt><b>-text</b>
<dd> Indicates that Text-based User Interface should be used (skip welcome screen)
@@ -238,6 +241,11 @@
<dd> Creates new GRASS location with EPSG code 4326 (latitude-longitude, WGS84)
in the specified GISDBASE
+<dt><b>grass70 -c EPSG:5514:3 $HOME/grassdata/mylocation</b>
+<dd> Creates new GRASS location with EPSG code 5514 (S-JTSK / Krovak
+ East North - SJTSK) with datum transformation paramaters used in
+ Czech Republic in the specified GISDBASE
<dt><b>grass70 -c myvector.shp $HOME/grassdata/mylocation</b>
<dd> Creates new GRASS location based on georeferenced Shapefile
