[GRASS-SVN] r62588 - grass/trunk/gui/wxpython/dbmgr
svn_grass at osgeo.org
Tue Nov 4 04:22:00 PST 2014
Author: martinl
Date: 2014-11-04 04:22:00 -0800 (Tue, 04 Nov 2014)
New Revision: 62588
grass/trunk/gui/wxpython/dbmgr/base.py
wxGUI/dbmgr: fix ids for contextual menu
add null/stddev to field statistics
fix field statistics for DBF driver
Modified: grass/trunk/gui/wxpython/dbmgr/base.py
--- grass/trunk/gui/wxpython/dbmgr/base.py 2014-11-04 07:54:27 UTC (rev 62587)
+++ grass/trunk/gui/wxpython/dbmgr/base.py 2014-11-04 12:22:00 UTC (rev 62588)
@@ -35,6 +35,7 @@
import tempfile
import copy
import types
+import math
from core import globalvar
import wx
@@ -399,68 +400,66 @@
popupMenu = wx.Menu()
- if not hasattr (self, "popupID1"):
- #TODO put to dict
- self.popupID1 = wx.NewId()
- self.popupID2 = wx.NewId()
- self.popupID3 = wx.NewId()
- self.popupID4 = wx.NewId()
- self.popupID5 = wx.NewId()
- self.popupID6 = wx.NewId()
- self.popupID7 = wx.NewId()
- self.popupID8 = wx.NewId()
- self.popupID9 = wx.NewId()
- self.popupID10 = wx.NewId()
- self.popupID11 = wx.NewId()
- self.popupID12 = wx.NewId()
- self.popupID13 = wx.NewId()
- self.popupID14 = wx.NewId()
- popupMenu.Append(self.popupID1, text = _("Sort ascending"))
- popupMenu.Append(self.popupID2, text = _("Sort descending"))
+ if not hasattr (self, "popupID"):
+ self.popupId = { 'sortAsc' : wx.NewId(),
+ 'sortDesc' : wx.NewId(),
+ 'calculate' : wx.NewId(),
+ 'area' : wx.NewId(),
+ 'length' : wx.NewId(),
+ 'compact' : wx.NewId(),
+ 'fractal' : wx.NewId(),
+ 'perimeter' : wx.NewId(),
+ 'ncats' : wx.NewId(),
+ 'slope' : wx.NewId(),
+ 'lsin' : wx.NewId(),
+ 'lazimuth' : wx.NewId(),
+ 'calculator' : wx.NewId(),
+ 'stats' : wx.NewId() }
+ popupMenu.Append(self.popupId['sortAsc'], text = _("Sort ascending"))
+ popupMenu.Append(self.popupId['sortDesc'], text = _("Sort descending"))
popupMenu.AppendSeparator()
subMenu = wx.Menu()
- popupMenu.AppendMenu(self.popupID3, _("Calculate (only numeric columns)"),
+ popupMenu.AppendMenu(self.popupId['calculate'], _("Calculate (only numeric columns)"),
subMenu)
- popupMenu.Append(self.popupID13, text = _("Field calculator"))
+ popupMenu.Append(self.popupId['calculator'], text = _("Field calculator"))
- popupMenu.Append(self.popupID14, text = _("Statistics"))
+ popupMenu.Append(self.popupId['stats'], text = _("Statistics"))
if not self.pages['manageTable']:
- popupMenu.Append(self.popupID14, text = _("Add column"))
+ self.popupId['addCol'] = wx.NewId()
+ popupMenu.Append(self.popupId['addCol'], text = _("Add column"))
if not self.dbMgrData['editable']:
- popupMenu.Enable(self.popupID14, False)
+ popupMenu.Enable(self.popupId['addCol'], False)
- popupMenu.Enable(self.popupID13, False)
+ popupMenu.Enable(self.popupId['calculator'], False)
if not self.dbMgrData['editable'] or \
self.columns[self.GetColumn(self._col).GetText()]['ctype'] not in (types.IntType, types.FloatType):
- popupMenu.Enable(self.popupID3, False)
+ popupMenu.Enable(self.popupId['calculate'], False)
- subMenu.Append(self.popupID4, text = _("Area size"))
- subMenu.Append(self.popupID5, text = _("Line length"))
- subMenu.Append(self.popupID6, text = _("Compactness of an area"))
- subMenu.Append(self.popupID7, text = _("Fractal dimension of boundary defining a polygon"))
- subMenu.Append(self.popupID8, text = _("Perimeter length of an area"))
- subMenu.Append(self.popupID9, text = _("Number of features for each category"))
- subMenu.Append(self.popupID10, text = _("Slope steepness of 3D line"))
- subMenu.Append(self.popupID11, text = _("Line sinuousity"))
- subMenu.Append(self.popupID12, text = _("Line azimuth"))
+ subMenu.Append(self.popupId['area'], text = _("Area size"))
+ subMenu.Append(self.popupId['length'], text = _("Line length"))
+ subMenu.Append(self.popupId['compact'], text = _("Compactness of an area"))
+ subMenu.Append(self.popupId['fractal'], text = _("Fractal dimension of boundary defining a polygon"))
+ subMenu.Append(self.popupId['perimeter'], text = _("Perimeter length of an area"))
+ subMenu.Append(self.popupId['ncats'], text = _("Number of features for each category"))
+ subMenu.Append(self.popupId['slope'], text = _("Slope steepness of 3D line"))
+ subMenu.Append(self.popupId['lsin'], text = _("Line sinuousity"))
+ subMenu.Append(self.popupId['lazimuth'], text = _("Line azimuth"))
- self.Bind (wx.EVT_MENU, self.OnColumnSortAsc, id = self.popupID10)
- self.Bind (wx.EVT_MENU, self.OnColumnSortDesc, id = self.popupID2)
- self.Bind(wx.EVT_MENU, self.OnFieldCalculator, id = self.popupID13)
- self.Bind(wx.EVT_MENU, self.OnFieldStatistics, id = self.popupID14)
+ self.Bind (wx.EVT_MENU, self.OnColumnSortAsc, id = self.popupId['sortAsc'])
+ self.Bind (wx.EVT_MENU, self.OnColumnSortDesc, id = self.popupId['sortDesc'])
+ self.Bind(wx.EVT_MENU, self.OnFieldCalculator, id = self.popupId['calculator'])
+ self.Bind(wx.EVT_MENU, self.OnFieldStatistics, id = self.popupId['stats'])
- self.Bind(wx.EVT_MENU, self.OnAddColumn, id = self.popupID14)
+ self.Bind(wx.EVT_MENU, self.OnAddColumn, id = self.popupId['addCol'])
- for id in (self.popupID4, self.popupID5, self.popupID6,
- self.popupID7, self.popupID8, self.popupID9,
- self.popupID10, self.popupID11, self.popupID12):
+ for id in (self.popupId['area'], self.popupId['length'], self.popupId['compact'],
+ self.popupId['fractal'], self.popupId['perimeter'], self.popupId['ncats'],
+ self.popupId['slope'], self.popupId['lsin'], self.popupId['lazimuth']):
self.Bind(wx.EVT_MENU, self.OnColumnCompute, id = id)
self.PopupMenu(popupMenu)
@@ -489,23 +488,23 @@
id = event.GetId()
option = None
- if id == self.popupID4:
+ if id == self.popupId['area']:
option = 'area'
- elif id == self.popupID5:
+ elif id == self.popupId['length']:
option = 'length'
- elif id == self.popupID6:
+ elif id == self.popupId['compact']:
option = 'compact'
- elif id == self.popupID7:
+ elif id == self.popupId['fractal']:
option = 'fd'
- elif id == self.popupID8:
+ elif id == self.popupId['perimeter']:
option = 'perimeter'
- elif id == self.popupID9:
+ elif id == self.popupId['ncats']:
option = 'count'
- elif id == self.popupID10:
+ elif id == self.popupId['slope']:
option = 'slope'
- elif id == self.popupID11:
+ elif id == self.popupId['lsin']:
option = 'sinuous'
- elif id == self.popupID12:
+ elif id == self.popupId['lazimuth']:
option = 'azimuth'
if not option:
@@ -3389,17 +3388,21 @@
self.parent = parent
wx.Frame.__init__(self, parent, id, style = style, **kwargs)
self.SetTitle(_("Field statistics"))
+ self.SetIcon(wx.Icon(os.path.join(globalvar.ICONDIR, 'grass_sql.ico'), wx.BITMAP_TYPE_ICO))
+ self.panel = wx.Panel(parent = self, id = wx.ID_ANY)
- self.sp = scrolled.ScrolledPanel(parent=self, id=wx.ID_ANY, size=(300, 200),
+ self.sp = scrolled.ScrolledPanel(parent=self.panel, id=wx.ID_ANY, size=(250, 150),
style = wx.TAB_TRAVERSAL|wx.SUNKEN_BORDER, name="Statistics" )
self.text = wx.TextCtrl(parent=self.sp, id=wx.ID_ANY, style=wx.TE_MULTILINE|wx.TE_READONLY)
self.text.SetBackgroundColour("white")
# buttons
- self.btnClipboard = wx.Button(self, id = wx.ID_COPY)
+ self.btnClipboard = wx.Button(parent=self.panel, id = wx.ID_COPY)
self.btnClipboard.SetToolTipString(_("Copy statistics the clipboard (Ctrl+C)"))
- self.btnCancel = wx.Button(self, wx.ID_CLOSE)
+ self.btnCancel = wx.Button(parent=self.panel, id=wx.ID_CLOSE)
self.btnCancel.SetDefault()
# bindings
@@ -3423,7 +3426,7 @@
sizer.Add(item = self.sp, proportion = 1, flag = wx.GROW |
wx.LEFT | wx.RIGHT | wx.BOTTOM, border = 3)
- line = wx.StaticLine(parent = self, id = wx.ID_ANY,
+ line = wx.StaticLine(parent = self.panel, id = wx.ID_ANY,
size = (20, -1), style = wx.LI_HORIZONTAL)
sizer.Add(item = line, proportion = 0,
flag = wx.GROW|wx.ALIGN_CENTER_VERTICAL|wx.LEFT|wx.RIGHT, border = 3)
@@ -3435,8 +3438,8 @@
flag = wx.ALIGN_RIGHT | wx.ALL, border = 5)
sizer.Add(item = btnSizer, proportion = 0, flag = wx.ALIGN_RIGHT | wx.ALL, border = 5)
- self.SetSizer(sizer)
- sizer.Fit(self)
+ self.panel.SetSizer(sizer)
+ sizer.Fit(self.panel)
def OnCopy(self, event):
"""!Copy the statistics to the clipboard
@@ -3456,14 +3459,23 @@
def Update(self, driver, database, table, column):
"""!Update statistics for given column
:param: column column name
+ if driver == 'dbf':
+ GError(parent=self,
+ message=_("Statistics is not support for DBF tables."))
+ self.Close()
+ return
fd, sqlFilePath = tempfile.mkstemp(text=True)
sqlFile = open(sqlFilePath, 'w')
- stats = ['count', 'min', 'max', 'avg', 'sum']
+ stats = ['count', 'min', 'max', 'avg', 'sum', 'null']
for fn in stats:
- sqlFile.write('select %s(%s) from %s;%s' % (fn, column, table, os.linesep))
+ if fn == 'null':
+ sqlFile.write('select count(*) from %s where %s is null;%s' % (table, column, os.linesep))
+ else:
+ sqlFile.write('select %s(%s) from %s;%s' % (fn, column, table, os.linesep))
sqlFile.close()
dataStr = RunCommand('db.select',
@@ -3474,15 +3486,40 @@
driver = driver,
database = database)
if not dataStr:
+ GError(parent = self.parent,
+ message = _("Unable to calculte statistics."))
+ self.Close()
return
dataLines = dataStr.splitlines()
if len(dataLines) != len(stats):
message = _("Unable to calculte statistics. "
"Invalid number of lines %d (should be %d).") % (len(dataLines), len(stats)))
+ self.Close()
+ return
+ # calculate stddev
+ avg = float(dataLines[stats.index('avg')])
+ count = float(dataLines[stats.index('count')])
+ sql = "select (%(column)s - %(avg)f)*(%(column)s - %(avg)f) from %(table)s" % { 'column' : column, 'avg' : avg, 'table' : table }
+ dataVar = RunCommand('db.select',
+ parent = self.parent,
+ read = True,
+ flags='c',
+ sql = sql,
+ driver = driver,
+ database = database)
+ if not dataVar:
+ GWarning(parent = self.parent,
+ message = _("Unable to calculte standard deviation."))
+ varSum = 0
+ for var in dataVar.splitlines():
+ varSum += float(var)
+ stddev = math.sqrt(varSum/count)
self.SetTitle(_("Field statistics <%s>") % column)
self.text.Clear()
for idx in range(len(stats)):
self.text.AppendText('%s: %s\n' % (stats[idx], dataLines[idx]))
+ self.text.AppendText('stddev: %f\n' % stddev)
