[GRASS-SVN] r62594 - in grass/trunk/lib/python/temporal: . testsuite
svn_grass at osgeo.org
Tue Nov 4 07:45:52 PST 2014
Author: huhabla
Date: 2014-11-04 07:45:52 -0800 (Tue, 04 Nov 2014)
New Revision: 62594
Added:
grass/trunk/lib/python/temporal/temporal_operator.py
grass/trunk/lib/python/temporal/testsuite/unittests_temporal_algebra.py
grass/trunk/lib/python/temporal/testsuite/unittests_temporal_conditionals.py
grass/trunk/lib/python/temporal/testsuite/unittests_temporal_raster3d_algebra.py
grass/trunk/lib/python/temporal/testsuite/unittests_temporal_raster_algebra.py
grass/trunk/lib/python/temporal/testsuite/unittests_temporal_raster_conditionals.py
grass/trunk/lib/python/temporal/testsuite/unittests_temporal_vector_algebra.py
Removed:
grass/trunk/lib/python/temporal/temporal_raster_operator.py
grass/trunk/lib/python/temporal/temporal_vector_operator.py
grass/trunk/lib/python/temporal/testsuite/test_temporal_raster3d_algebra.py
grass/trunk/lib/python/temporal/testsuite/test_temporal_raster_algebra.py
grass/trunk/lib/python/temporal/Makefile
grass/trunk/lib/python/temporal/__init__.py
grass/trunk/lib/python/temporal/temporal_algebra.py
grass/trunk/lib/python/temporal/temporal_raster3d_algebra.py
grass/trunk/lib/python/temporal/temporal_raster_algebra.py
grass/trunk/lib/python/temporal/temporal_raster_base_algebra.py
grass/trunk/lib/python/temporal/temporal_vector_algebra.py
grass/trunk/lib/python/temporal/testsuite/test_doctests.py
grass/trunk/lib/python/temporal/testsuite/test_register_function.py
temporal framework: New temporal algebra approach implemented by Thomas Leppelt. Additional algebra tests implemented.
Modified: grass/trunk/lib/python/temporal/Makefile
--- grass/trunk/lib/python/temporal/Makefile 2014-11-04 15:04:13 UTC (rev 62593)
+++ grass/trunk/lib/python/temporal/Makefile 2014-11-04 15:45:52 UTC (rev 62594)
@@ -2,12 +2,13 @@
include $(MODULE_TOPDIR)/include/Make/Other.make
include $(MODULE_TOPDIR)/include/Make/Python.make
+include $(MODULE_TOPDIR)/include/Make/Doxygen.make
PYDIR = $(ETC)/python
GDIR = $(PYDIR)/grass
DSTDIR = $(GDIR)/temporal
-MODULES = base core abstract_dataset abstract_map_dataset abstract_space_time_dataset space_time_datasets open_stds factory gui_support list_stds register sampling metadata spatial_extent temporal_extent datetime_math temporal_granularity spatio_temporal_relationships unit_tests aggregation stds_export stds_import extract mapcalc univar_statistics temporal_topology_dataset_connector spatial_topology_dataset_connector c_libraries_interface temporal_algebra temporal_vector_algebra temporal_vector_operator temporal_raster_operator temporal_raster_base_algebra temporal_raster_algebra temporal_raster3d_algebra
+MODULES = base core abstract_dataset abstract_map_dataset abstract_space_time_dataset space_time_datasets open_stds factory gui_support list_stds register sampling metadata spatial_extent temporal_extent datetime_math temporal_granularity spatio_temporal_relationships unit_tests aggregation stds_export stds_import extract mapcalc univar_statistics temporal_topology_dataset_connector spatial_topology_dataset_connector c_libraries_interface temporal_algebra temporal_vector_algebra temporal_raster_base_algebra temporal_raster_algebra temporal_raster3d_algebra temporal_operator
PYFILES := $(patsubst %,$(DSTDIR)/%.py,$(MODULES) __init__)
PYCFILES := $(patsubst %,$(DSTDIR)/%.pyc,$(MODULES) __init__)
@@ -25,3 +26,6 @@
$(DSTDIR)/%: % | $(DSTDIR)
$(INSTALL_DATA) $< $@
+#doxygen:
+DOXNAME = pythontemporal
Modified: grass/trunk/lib/python/temporal/__init__.py
--- grass/trunk/lib/python/temporal/__init__.py 2014-11-04 15:04:13 UTC (rev 62593)
+++ grass/trunk/lib/python/temporal/__init__.py 2014-11-04 15:45:52 UTC (rev 62594)
@@ -1,17 +1,12 @@
from core import *
from base import *
-from temporal_extent import *
from spatial_extent import *
from metadata import *
-from temporal_topology_dataset_connector import *
-from spatial_topology_dataset_connector import *
from abstract_dataset import *
from abstract_map_dataset import *
from abstract_space_time_dataset import *
from space_time_datasets import *
from datetime_math import *
-from temporal_granularity import *
-from spatio_temporal_relationships import *
from open_stds import *
from factory import *
from gui_support import *
@@ -25,10 +20,14 @@
from mapcalc import *
from univar_statistics import *
from c_libraries_interface import *
+from spatio_temporal_relationships import *
+from spatial_topology_dataset_connector import *
+from temporal_extent import *
+from temporal_topology_dataset_connector import *
+from temporal_granularity import *
from temporal_algebra import *
from temporal_vector_algebra import *
-from temporal_vector_operator import *
-from temporal_raster_operator import *
from temporal_raster_base_algebra import *
from temporal_raster_algebra import *
from temporal_raster3d_algebra import *
+from temporal_operator import *
Modified: grass/trunk/lib/python/temporal/temporal_algebra.py
--- grass/trunk/lib/python/temporal/temporal_algebra.py 2014-11-04 15:04:13 UTC (rev 62593)
+++ grass/trunk/lib/python/temporal/temporal_algebra.py 2014-11-04 15:45:52 UTC (rev 62594)
@@ -1,4 +1,5 @@
+"""@package grass.temporal
Temporal algebra parser class
(C) 2014 by the GRASS Development Team
@@ -31,21 +32,21 @@
LexToken(NAME,'test1',1,4)
LexToken(T_NOT_SELECT,'!:',1,10)
LexToken(NAME,'test2',1,13)
- >>> expression = "C = test1 {equal,:} test2"
+ >>> expression = "C = test1 {:,equal} test2"
>>> p.test(expression)
- C = test1 {equal,:} test2
+ C = test1 {:,equal} test2
LexToken(NAME,'C',1,0)
LexToken(EQUALS,'=',1,2)
- LexToken(T_SELECT_OPERATOR,'{equal,:}',1,10)
+ LexToken(T_SELECT_OPERATOR,'{:,equal}',1,10)
LexToken(NAME,'test2',1,20)
- >>> expression = "C = test1 {equal,!:} test2"
+ >>> expression = "C = test1 {!:,equal} test2"
>>> p.test(expression)
- C = test1 {equal,!:} test2
+ C = test1 {!:,equal} test2
- LexToken(T_SELECT_OPERATOR,'{equal,!:}',1,10)
+ LexToken(T_SELECT_OPERATOR,'{!:,equal}',1,10)
LexToken(NAME,'test2',1,21)
>>> expression = "C = test1 # test2"
>>> p.test(expression)
@@ -63,21 +64,21 @@
LexToken(T_HASH_OPERATOR,'{#}',1,10)
LexToken(NAME,'test2',1,14)
- >>> expression = "C = test1 {equal,#} test2"
+ >>> expression = "C = test1 {#,equal} test2"
>>> p.test(expression)
- C = test1 {equal,#} test2
+ C = test1 {#,equal} test2
- LexToken(T_HASH_OPERATOR,'{equal,#}',1,10)
+ LexToken(T_HASH_OPERATOR,'{#,equal}',1,10)
- >>> expression = "C = test1 {equal|during,#} test2"
+ >>> expression = "C = test1 {#,equal|during} test2"
>>> p.test(expression)
- C = test1 {equal|during,#} test2
+ C = test1 {#,equal|during} test2
- LexToken(T_HASH_OPERATOR,'{equal|during,#}',1,10)
+ LexToken(T_HASH_OPERATOR,'{#,equal|during}',1,10)
LexToken(NAME,'test2',1,27)
>>> expression = "E = test1 : test2 !: test1"
>>> p.test(expression)
@@ -112,15 +113,15 @@
LexToken(LPAREN,'(',1,9)
LexToken(NAME,'test1',1,10)
LexToken(RPAREN,')',1,15)
- >>> expression = 'H = tsnap(test2 {during,:} buff_t(test1, "1 days"))'
+ >>> expression = 'H = tsnap(test2 {:,during} buff_t(test1, "1 days"))'
>>> p.test(expression)
- H = tsnap(test2 {during,:} buff_t(test1, "1 days"))
+ H = tsnap(test2 {:,during} buff_t(test1, "1 days"))
LexToken(NAME,'H',1,0)
LexToken(TSNAP,'tsnap',1,4)
LexToken(NAME,'test2',1,10)
- LexToken(T_SELECT_OPERATOR,'{during,:}',1,16)
+ LexToken(T_SELECT_OPERATOR,'{:,during}',1,16)
LexToken(BUFF_T,'buff_t',1,27)
LexToken(LPAREN,'(',1,33)
LexToken(NAME,'test1',1,34)
@@ -131,15 +132,15 @@
LexToken(QUOTE,'"',1,48)
LexToken(RPAREN,')',1,49)
LexToken(RPAREN,')',1,50)
- >>> expression = 'H = tshift(test2 {during,:} buff_t(test1, "1 days"), "1 months")'
+ >>> expression = 'H = tshift(test2 {:,during} buff_t(test1, "1 days"), "1 months")'
>>> p.test(expression)
- H = tshift(test2 {during,:} buff_t(test1, "1 days"), "1 months")
+ H = tshift(test2 {:,during} buff_t(test1, "1 days"), "1 months")
LexToken(TSHIFT,'tshift',1,4)
LexToken(LPAREN,'(',1,10)
LexToken(NAME,'test2',1,11)
- LexToken(T_SELECT_OPERATOR,'{during,:}',1,17)
+ LexToken(T_SELECT_OPERATOR,'{:,during}',1,17)
LexToken(BUFF_T,'buff_t',1,28)
LexToken(LPAREN,'(',1,34)
LexToken(NAME,'test1',1,35)
@@ -200,9 +201,9 @@
LexToken(COMMA,',',1,20)
LexToken(NAME,'B',1,22)
LexToken(RPAREN,')',1,23)
- >>> expression = 'I = if(equals,td(A) > 10 {equals,||} td(B) < 10, A)'
+ >>> expression = 'I = if(equals,td(A) > 10 {||,equals} td(B) < 10, A)'
>>> p.test(expression)
- I = if(equals,td(A) > 10 {equals,||} td(B) < 10, A)
+ I = if(equals,td(A) > 10 {||,equals} td(B) < 10, A)
LexToken(NAME,'I',1,0)
LexToken(IF,'if',1,4)
@@ -215,7 +216,7 @@
LexToken(RPAREN,')',1,18)
LexToken(GREATER,'>',1,20)
LexToken(INT,10,1,22)
- LexToken(T_COMP_OPERATOR,'{equals,||}',1,25)
+ LexToken(T_COMP_OPERATOR,'{||,equals}',1,25)
LexToken(TD,'td',1,37)
LexToken(LPAREN,'(',1,39)
LexToken(NAME,'B',1,40)
@@ -250,9 +251,9 @@
LexToken(COMMA,',',1,44)
LexToken(NAME,'A',1,46)
LexToken(RPAREN,')',1,47)
- >>> expression = 'E = if({equals},td(A) >= 4 {contain,&&} td(B) == 2, C : D)'
+ >>> expression = 'E = if({equals},td(A) >= 4 {&&,contain} td(B) == 2, C : D)'
>>> p.test(expression)
- E = if({equals},td(A) >= 4 {contain,&&} td(B) == 2, C : D)
+ E = if({equals},td(A) >= 4 {&&,contain} td(B) == 2, C : D)
LexToken(NAME,'E',1,0)
@@ -265,7 +266,7 @@
LexToken(RPAREN,')',1,20)
LexToken(GREATER_EQUALS,'>=',1,22)
LexToken(INT,4,1,25)
- LexToken(T_COMP_OPERATOR,'{contain,&&}',1,27)
+ LexToken(T_COMP_OPERATOR,'{&&,contain}',1,27)
LexToken(TD,'td',1,40)
LexToken(LPAREN,'(',1,42)
LexToken(NAME,'B',1,43)
@@ -277,9 +278,9 @@
LexToken(T_SELECT,':',1,54)
LexToken(NAME,'D',1,56)
LexToken(RPAREN,')',1,57)
- >>> expression = 'F = if({equals},A {equal,#}, B, C : D)'
+ >>> expression = 'F = if({equals},A {#,equal}, B, C : D)'
>>> p.test(expression)
- F = if({equals},A {equal,#}, B, C : D)
+ F = if({equals},A {#,equal}, B, C : D)
LexToken(NAME,'F',1,0)
@@ -287,7 +288,7 @@
LexToken(T_REL_OPERATOR,'{equals}',1,7)
LexToken(COMMA,',',1,15)
LexToken(NAME,'A',1,16)
- LexToken(T_HASH_OPERATOR,'{equal,#}',1,18)
+ LexToken(T_HASH_OPERATOR,'{#,equal}',1,18)
LexToken(COMMA,',',1,27)
LexToken(NAME,'B',1,29)
LexToken(COMMA,',',1,30)
@@ -298,33 +299,20 @@
>>> p = tgis.TemporalAlgebraParser()
>>> p.run = False
>>> p.debug = True
- >>> expression = "D = A : (B !: C)"
- >>> p.parse(expression)
- B* = B !: C
- A* = A : B*
- D = A*
- >>> expression = "D = A {!:} B {during,:} C"
+ >>> expression = "D = A {!:} B {:,during} C"
>>> print(expression)
- D = A {!:} B {during,:} C
+ D = A {!:} B {:,during} C
>>> p.parse(expression)
A* = A {!:} B
- A** = A* {during,:} C
+ A** = A* {:,during} C
D = A**
- >>> expression = "D = A {:} B {during,!:} C"
+ >>> expression = "D = A {:} B {!:,during} C"
>>> print(expression)
- D = A {:} B {during,!:} C
+ D = A {:} B {!:,during} C
>>> p.parse(expression)
A* = A {:} B
- A** = A* {during,!:} C
+ A** = A* {!:,during} C
D = A**
- >>> expression = "D = A {:} (B {during,!:} (C : E))"
- >>> print(expression)
- D = A {:} (B {during,!:} (C : E))
- C* = C : E
- B* = B {during,!:} C*
- A* = A {:} B*
- D = A*
>>> p.run = False
>>> p.debug = False
>>> expression = "C = test1 : test2"
@@ -335,24 +323,24 @@
>>> print(expression)
D = buff_t(test1,"10 months")
>>> p.parse(expression, 'stvds')
- >>> expression = 'E = test2 {during,:} buff_t(test1,"1 days")'
+ >>> expression = 'E = test2 {:,during} buff_t(test1,"1 days")'
>>> print(expression)
- E = test2 {during,:} buff_t(test1,"1 days")
+ E = test2 {:,during} buff_t(test1,"1 days")
- >>> expression = 'F = test2 {equal,:} buff_t(test1,"1 days")'
+ >>> expression = 'F = test2 {:,equal} buff_t(test1,"1 days")'
>>> print(expression)
- F = test2 {equal,:} buff_t(test1,"1 days")
+ F = test2 {:,equal} buff_t(test1,"1 days")
>>> p.debug = True
test1* = buff_t( test1 , " 1 days " )
- test2* = test2 {during,:} test1*
+ test2* = test2 {:,during} test1*
test2** = tsnap( test2* )
H = test2**
- >>> expression = 'H = tshift(test2 {during,:} test1, "1 days")'
+ >>> expression = 'H = tshift(test2 {:,during} test1, "1 days")'
test2** = tshift( test2* , " 1 days " )
H = test2**
>>> expression = 'H = tshift(H, 3)'
@@ -363,21 +351,21 @@
td(A)
td(A) == 2
- A* = if condition True then A
+ A* = if condition None then A
C = A*
>>> expression = 'C = if(td(A) == 5, A, B)'
td(A)
td(A) == 5
- A* = if condition True then A else B
+ A* = if condition None then A else B
C = A*
- >>> expression = 'C = if(td(A) == 5 || start_date() > "2010-01-01", A, B)'
+ >>> expression = 'C = if(td(A) == 5 || start_date(A) > "2010-01-01", A, B)'
td(A)
td(A) == 5
- start_date > "2010-01-01"
- True || True
+ start_date A > "2010-01-01"
+ None || None
C = A*
@@ -389,34 +377,36 @@
pass
import os
+import copy
+import grass.pygrass.modules as pymod
-from grass.exceptions import FatalError
class TemporalAlgebraLexer(object):
"""Lexical analyzer for the GRASS GIS temporal algebra"""
- # Functions that defines an if condition, temporal buffering and snapping
+ # Functions that defines an if condition, temporal buffering, snapping and
+ # selection of maps with temporal extent.
conditional_functions = {
- 'if': 'IF',
+ 'if' : 'IF',
'buff_t': 'BUFF_T',
- 'tsnap': 'TSNAP',
- 'tshift': 'TSHIFT',
+ 'tsnap' : 'TSNAP',
+ 'tshift' : 'TSHIFT',
+ 'tmap' : 'TMAP',
# Variables with date and time strings
datetime_functions = {
- 'start_time': 'START_TIME', # start time as HH::MM:SS
- 'start_date': 'START_DATE', # start date as yyyy-mm-DD
- 'start_datetime': 'START_DATETIME', # start datetime as yyyy-mm-DD HH:MM:SS
- 'end_time': 'END_TIME', # end time as HH:MM:SS
- 'end_date': 'END_DATE', # end date as yyyy-mm-DD
- 'end_datetime': 'END_DATETIME', # end datetime as yyyy-mm-DD HH:MM:SS
+ 'start_time' : 'START_TIME', # start time as HH::MM:SS
+ 'start_date' : 'START_DATE', # start date as yyyy-mm-DD
+ 'start_datetime' : 'START_DATETIME', # start datetime as yyyy-mm-DD HH:MM:SS
+ 'end_time' : 'END_TIME', # end time as HH:MM:SS
+ 'end_date' : 'END_DATE', # end date as yyyy-mm-DD
+ 'end_datetime' : 'END_DATETIME', # end datetime as yyyy-mm-DD HH:MM:SS
# Time functions
@@ -496,13 +486,13 @@
+ tuple(conditional_functions.values())
# Regular expression rules for simple tokens
- t_T_SELECT_OPERATOR = r'\{([a-zA-Z\| ]+[,])?([\|&+=]?[!]?[:])\}'
- t_T_HASH_OPERATOR = r'\{([a-zA-Z\| ]+[,])?[#]\}'
- t_T_COMP_OPERATOR = r'\{([a-zA-Z\| ]+[,])?(\|\||&&)\}'
+ t_T_SELECT_OPERATOR = r'\{[!]?[:][,]?[a-zA-Z\| ]*([,])?([lrudi]|left|right|union|disjoint|intersect)?\}'
+ t_T_HASH_OPERATOR = r'\{[#][,]?[a-zA-Z\| ]*([,])?([lrudi]|left|right|union|disjoint|intersect)?\}'
+ t_T_COMP_OPERATOR = r'\{(\|\||&&)[,][a-zA-Z\| ]*[,]?[\|&]?([,])?([lrudi]|left|right|union|disjoint|intersect)?\}'
t_T_REL_OPERATOR = r'\{([a-zA-Z\| ])+\}'
t_T_SELECT = r':'
t_T_NOT_SELECT = r'!:'
- t_LPAREN = r'\('
+ t_LPAREN = r'\('
t_RPAREN = r'\)'
t_COMMA = r','
t_CEQUALS = r'=='
@@ -526,6 +516,7 @@
# t.value = int(t.value)
return t
# Read date string and convert it into a date object
def t_DATE(self, t):
r'"\d\d\d\d-(0[1-9]|1[012])-(0[1-9]|[12][0-9]|3[01])"'
@@ -549,9 +540,8 @@
r'-?\d+'
return t
# Read in a list of maps.
- def t_LIST(self, t):
+ def t_LIST(self, t):
r'[\[][.]*[\]]'
t.value = list(t.value)
return t
@@ -587,52 +577,49 @@
# Handle errors.
def t_error(self, t):
raise SyntaxError("syntax error on line %d near '%s'" %
- (t.lineno, t.value))
+ (t.lineno, t.value))
# Build the lexer
- def build(self, **kwargs):
- self.lexer = lex.lex(module=self, optimize=False, debug=False,
- **kwargs)
+ def build(self,**kwargs):
+ self.lexer = lex.lex(module=self, optimize=False, debug=False, **kwargs)
# Just for testing
- def test(self, data):
+ def test(self,data):
self.name_list = {}
print(data)
self.lexer.input(data)
while True:
- tok = self.lexer.token()
- if not tok: break
- print tok
+ tok = self.lexer.token()
+ if not tok: break
+ print tok
class GlobalTemporalVar(object):
""" This class handles global temporal variable conditional expressions,
like start_doy() == 3.
The three parts of the statement are stored separately in
tfunc (START_DOY), compop (==) and value (3).
- But also boolean values, time differences and relation operators for
- comparison in if-statements can be stored in this class.
+ But also boolean values, time differences and relation operators for comparison in
+ if-statements can be stored in this class.
def __init__(self):
- self.tfunc = None
- self.compop = None
- self.value = None
- self.boolean = None
- self.relationop = None
- self.topology = []
- self.td = None
+ self.tfunc = None
+ self.compop = None
+ self.value = None
+ self.boolean = None
+ self.relationop = None
+ self.topology = []
+ self.td = None
def get_type(self):
- if self.tfunc is not None and self.compop is not None and \
- self.value is not None:
+ if self.tfunc != None and self.compop != None and self.value != None:
return("global")
- elif self.boolean is not None:
+ elif self.boolean != None:
return("boolean")
- elif self.relationop is not None and self.topology is not []:
+ elif self.relationop != None and self.topology != []:
return("operator")
- elif self.td is not None:
+ elif self.td != None:
return("timediff")
def get_type_value(self):
@@ -653,10 +640,17 @@
def __str__(self):
return str(self.tfunc) + str(self.compop) + str(self.value)
+class FatalError(Exception):
+ def __init__(self, msg):
+ self.value = msg
+ def __str__(self):
+ return self.value
class TemporalAlgebraParser(object):
"""The temporal algebra class"""
@@ -665,12 +659,12 @@
# Setting equal precedence level for select and hash operations.
precedence = (
- ('left', 'T_SELECT_OPERATOR', 'T_SELECT', 'T_NOT_SELECT'), # 1
- ('left', 'AND', 'OR', 'T_COMP_OPERATOR'), # 2
+ ('left', 'T_SELECT_OPERATOR', 'T_SELECT', 'T_NOT_SELECT'), # 1
+ ('left', 'AND', 'OR', 'T_COMP_OPERATOR'), #2
- def __init__(self, pid=None, run=True, debug=False, spatial=False,
- null=False):
+ def __init__(self, pid=None, run = True, debug = False, spatial = False,
+ null = False, register_null = False, nprocs = 1):
self.run = run
self.debug = debug
self.pid = pid
@@ -684,13 +678,17 @@
self.msgr = get_tgis_message_interface()
self.dbif = SQLDatabaseInterfaceConnection()
self.dbif.connect()
+ self.register_null = register_null
+ self.empty_maps = {}
+ self.m_mremove = pymod.Module('g.remove')
+ self.m_copy = pymod.Module('g.copy')
+ self.nprocs = nprocs
def __del__(self):
if self.dbif.connected:
self.dbif.close()
- def parse(self, expression, stdstype='strds', basename=None,
- overwrite=False):
+ def parse(self, expression, stdstype = 'strds', maptype = 'rast', mapclass = RasterDataset, basename = None, overwrite=False):
self.lexer = TemporalAlgebraLexer()
self.lexer.build()
self.parser = yacc.yacc(module=self, debug=self.debug)
@@ -698,6 +696,8 @@
self.overwrite = overwrite
self.count = 0
self.stdstype = stdstype
+ self.maptype = maptype
+ self.mapclass = mapclass
self.basename = basename
self.expression = expression
self.parser.parse(expression)
@@ -710,18 +710,25 @@
same object for map name generation in multiple threads.
self.count += 1
- if self.pid is not None:
+ if self.pid != None:
pid = self.pid
else:
pid = os.getpid()
- name = "tmp_map_name_%i_%i" % (pid, self.count)
+ name = "tmp_map_name_%i_%i"%(pid, self.count)
self.names[name] = name
return name
- def generate_new_map(self, base_map, bool_op='and', copy=True):
+ def generate_new_map(self, base_map, bool_op = 'and', copy = True, rename = True):
"""Generate a new map using the spatio-temporal extent of the base map
- :param base_map This map is used to create the new map
+ :param base_map: This map is used to create the new map
+ :param bool_op: The boolean operator specifying the spatial extent
+ operation (intersection, union, disjoint union)
+ :param copy: Specifies if the temporal extent of mapB should be
+ copied to mapA
+ :param rename: Specifies if the generated map get a random name or get
+ the id from the base map.
+ :return: Map object
# Generate an intermediate name for the result map list.
name = self.generate_map_name()
@@ -730,12 +737,14 @@
# Create new map based on the related map list.
map_new = base_map.get_new_instance(mapname)
# Set initial map extend of new vector map.
- self.overlay_map_extent(map_new, base_map, bool_op=bool_op, copy=copy)
+ self.overlay_map_extent(map_new, base_map, bool_op = bool_op, copy = copy)
+ if not rename:
+ name = base_map.get_id()
+ map_new.set_id(name)
return map_new
- def overlay_map_extent(self, mapA, mapB, bool_op=None, temp_op='=',
- copy=False):
+ def overlay_map_extent(self, mapA, mapB, bool_op = None, temp_op = 'l',
+ copy = False):
"""Compute the spatio-temporal extent of two topological related maps
:param mapA: The first map
@@ -743,7 +752,8 @@
:param temp_op: The temporal operator specifying the temporal
- extent operation (intersection, union, disjoint union)
+ extent operation (intersection, union, disjoint union, right reference)
+ Left reference is the default temporal extent behaviour.
copied to mapA
:return: 0 if there is no overlay
@@ -757,62 +767,128 @@
mapA.set_temporal_extent(map_extent_temporal)
if "cmd_list" in dir(mapB):
mapA.cmd_list = mapB.cmd_list
+ if "condition_value" in dir(mapB):
+ mapA.condition_value = mapB.condition_value
else:
# Calculate spatial extent for different overlay operations.
if bool_op == 'and':
overlay_ext = mapA.spatial_intersection(mapB)
- if overlay_ext is not None:
+ if overlay_ext != None:
mapA.set_spatial_extent(overlay_ext)
else:
returncode = 0
elif bool_op in ['or', 'xor']:
overlay_ext = mapA.spatial_union(mapB)
else:
returncode = 0
elif bool_op == 'disor':
overlay_ext = mapA.spatial_disjoint_union(mapB)
else:
returncode = 0
# Calculate temporal extent for different temporal operators.
- if temp_op == '&':
+ if temp_op == 'i':
temp_ext = mapA.temporal_intersection(mapB)
- if temp_ext is not None:
+ if temp_ext != None:
mapA.set_temporal_extent(temp_ext)
else:
returncode = 0
- elif temp_op == '|':
+ elif temp_op == 'u':
temp_ext = mapA.temporal_union(mapB)
else:
- returncode = 0
- elif temp_op == '+':
+ returncode = 0
+ elif temp_op == 'd':
temp_ext = mapA.temporal_disjoint_union(mapB)
else:
returncode = 0
+ elif temp_op == 'r':
+ temp_ext = mapB.get_temporal_extent()
+ mapA.set_temporal_extent(temp_ext)
+ else:
+ returncode = 0
return(returncode)
+ def set_temporal_extent_list(self, maplist, topolist = ["EQUAL"], temporal = 'l' ):
+ """ Change temporal extent of map list based on temporal relations to
+ other map list and given temporal operator.
+ :param maplist: List of map objects for which relations has been build
+ correctely.
+ :param topolist: List of strings of temporal relations.
+ :param temporal: The temporal operator specifying the temporal
+ union, right reference, left reference).
+ :return: Map list with specified temporal extent.
+ resultdict = {}
+ for map_i in maplist:
+ # Loop over temporal related maps and create overlay modules.
+ tbrelations = map_i.get_temporal_relations()
+ # Generate an intermediate map for the result map list.
+ map_new = self.generate_new_map(base_map=map_i, bool_op = 'and',
+ copy = True, rename = True)
+ # Combine temporal and spatial extents of intermediate map with related maps.
+ for topo in topolist:
+ if topo in tbrelations.keys():
+ for map_j in (tbrelations[topo]):
+ if temporal == 'r':
+ # Create overlayed map extent.
+ returncode = self.overlay_map_extent(map_new, map_j, 'and', \
+ temp_op = temporal)
+ # Stop the loop if no temporal or spatial relationship exist.
+ if returncode == 0:
+ break
+ # Append map to result map list.
+ elif returncode == 1:
+ print(map_new.get_id() + " " + str(map_new.get_temporal_extent_as_tuple()))
+ print(map_new.condition_value)
+ # print(map_new.cmd_list)
+ # resultlist.append(map_new)
+ resultdict[map_new.get_id()] = map_new
+ # Create r.mapcalc expression string for the operation.
+ #cmdstring = self.build_command_string(s_expr_a = map_new,
+ # s_expr_b = map_j,
+ # operator = function)
+ # Conditional append of module command.
+ #map_new.cmd_list = cmdstring
+ break
+ #if returncode == 1:
+ # Get sorted map objects as values from result dictionoary.
+ resultlist = resultdict.values()
+ resultlist = sorted(resultlist, key = AbstractDatasetComparisonKeyStartTime)
+ return(resultlist)
######################### Temporal functions ##############################
- def check_stds(self, input, clear=False):
- """Check if input space time dataset exist in database and return its
- map list.
+ def check_stds(self, input, clear = False):
+ """ Check if input space time dataset exist in database and return its map list.
- :param input: Name of space time data set as string or list of maps.
- :param clear: Reset the stored conditional values to empty list.
+ :param input: Name of space time data set as string or list of maps.
+ :param clear: Reset the stored conditional values to empty list.
- :return: List of maps.
+ :return: List of maps.
- if not isinstance(input, list):
+ if isinstance(input, str):
# Check for mapset in given stds input.
if input.find("@") >= 0:
id_input = input
@@ -821,10 +897,9 @@
# Create empty spacetime dataset.
stds = dataset_factory(self.stdstype, id_input)
# Check for occurence of space time dataset.
- if stds.is_in_db(dbif=self.dbif) is False:
+ if stds.is_in_db(dbif=self.dbif) == False:
raise FatalError(_("Space time %s dataset <%s> not found") %
- (stds.get_new_map_instance(None).get_type(),
- id_input))
+ (stds.get_new_map_instance(None).get_type(), id_input))
else:
# Select temporal dataset entry from database.
stds.select(dbif=self.dbif)
@@ -836,20 +911,23 @@
if "condition_value" not in dir(map_i):
map_i.condition_value = []
# Set and check global temporal type variable and map.
- if map_i.is_time_absolute() and self.temporaltype is None:
+ if map_i.is_time_absolute() and self.temporaltype == None:
self.temporaltype = 'absolute'
- elif map_i.is_time_relative() and self.temporaltype is None:
+ elif map_i.is_time_relative() and self.temporaltype == None:
self.temporaltype = 'relative'
elif map_i.is_time_absolute() and self.temporaltype == 'relative':
- self.msgr.fatal(_("Wrong temporal type of space time"
- " dataset <%s> <%s> time is required") %
- (id_input, self.temporaltype))
+ self.msgr.fatal(_("Wrong temporal type of space time dataset <%s> \
+ <%s> time is required") %
+ (id_input, self.temporaltype))
elif map_i.is_time_relative() and self.temporaltype == 'absolute':
- else:
+ elif isinstance(input, self.mapclass):
+ # Check if the input is a single map and return it as list with one entry.
+ maplist = [input]
+ elif isinstance(input, list):
maplist = input
# Create map_value as empty list item.
@@ -861,25 +939,31 @@
elif clear:
+ else:
+ self.msgr.fatal(_("Wrong type of input"))
return(maplist)
- def get_temporal_topo_list(self, maplistA, maplistB=None,
- topolist=["EQUAL"], assign_val=False,
- count_map=False):
+ def get_temporal_topo_list(self, maplistA, maplistB = None, topolist = ["EQUAL"],
+ assign_val = False, count_map = False, compare_bool = False,
+ compop = None, aggregate = None):
"""Build temporal topology for two space time data sets, copy map objects
for given relation into map list.
:param maplistA: List of maps.
:param maplistB: List of maps.
:param assign_val: Boolean for assigning a boolean map value based on
- the map_values from the compared map list by
- topological relationships.
+ the map_values from the compared map list by
+ topological relationships.
:param count_map: Boolean if the number of topological related maps
- should be returned.
- :return: List of maps from maplistA that fulfil the topological
- relationships to maplistB specified in topolist.
+ should be returned.
+ :param compare_bool: Boolean for comparing boolean map values based on
+ related map list and compariosn operator.
+ :param compop: Comparison operator, && or ||.
+ :param aggregate: Aggregation operator for relation map list, & or |.
+ :return: List of maps from maplistA that fulfil the topological relationships
+ to maplistB specified in topolist.
.. code-block:: python
@@ -1003,55 +1087,40 @@
... print(map.get_id())
- topologylist = ["EQUAL", "FOLLOWS", "PRECEDES", "OVERLAPS",
- "OVERLAPPED", "DURING", "STARTS", "FINISHES",
- "CONTAINS", "STARTED", "FINISHED"]
- complementdict = {"EQUAL": "EQUAL", "FOLLOWS": "PRECEDES",
- "PRECEDES": "FOLLOWS", "OVERLAPS": "OVERLAPPED",
- "OVERLAPPED": "OVERLAPS", "DURING": "CONTAINS",
- "CONTAINS": "DURING", "STARTS": "STARTED",
- "STARTED": "STARTS", "FINISHES": "FINISHED",
- "FINISHED": "FINISHES"}
+ topologylist = ["EQUAL", "FOLLOWS", "PRECEDES", "OVERLAPS", "OVERLAPPED", \
+ "DURING", "STARTS", "FINISHES", "CONTAINS", "STARTED", \
+ "FINISHED"]
+ complementdict = {"EQUAL": "EQUAL", "FOLLOWS" : "PRECEDES",
+ "PRECEDES" : "FOLLOWS", "OVERLAPS" : "OVERLAPPED",
+ "OVERLAPPED" : "OVERLAPS", "DURING" : "CONTAINS",
+ "CONTAINS" : "DURING", "STARTS" : "STARTED",
+ "STARTED" : "STARTS", "FINISHES" : "FINISHED",
+ "FINISHED" : "FINISHES"}
resultdict = {}
# Check if given temporal relation are valid.
- if topo.upper() not in topologylist:
- raise SyntaxError("Unpermitted temporal relation name '" +
- topo + "'")
+ if topo.upper() not in topologylist:
+ raise SyntaxError("Unpermitted temporal relation name '" + topo + "'")
# Create temporal topology for maplistA to maplistB.
tb = SpatioTemporalTopologyBuilder()
- # Dictionary with different spatial variables used for topology builder
- spatialdict = {'strds': '2D', 'stvds': '2D', 'str3ds': '3D'}
+ # Dictionary with different spatial variables used for topology builder.
+ spatialdict = {'strds' : '2D', 'stvds' : '2D', 'str3ds' : '3D'}
# Build spatial temporal topology
if self.spatial:
- tb.build(maplistA, maplistB, spatial=spatialdict[self.stdstype])
+ tb.build(maplistA, maplistB, spatial = spatialdict[self.stdstype])
else:
tb.build(maplistA, maplistB)
# Iterate through maps in maplistA and search for relationships given
# in topolist.
- # TODO: Better implementation with less nesting
for map_i in maplistA:
+ if assign_val:
+ self.assign_bool_value(map_i, tbrelations, topolist)
+ elif compare_bool:
+ self.compare_bool_value(map_i, tbrelations, compop, aggregate, topolist)
if topo.upper() in tbrelations.keys():
- if assign_val:
- mapvaluelist = []
- if complementdict[topo.upper()] in tbrelations:
- relationmaplist = tbrelations[complementdict[topo.upper()]]
- for relationmap in relationmaplist:
- if "map_value" in dir(relationmap):
- for element in relationmap.map_value:
- if isinstance(element, GlobalTemporalVar):
- if element.get_type() == "boolean":
- mapvaluelist.append(element.boolean)
- if all(mapvaluelist):
- resultbool = True
- else:
- resultbool = False
- if "condition_value" in dir(map_i):
- if isinstance(map_i.condition_value, list):
- map_i.condition_value.append(resultbool)
if count_map:
relationmaplist = tbrelations[topo.upper()]
gvar = GlobalTemporalVar()
@@ -1062,137 +1131,129 @@
map_i.map_value = gvar
resultdict[map_i.get_id()] = map_i
# Sort list of maps chronological.
- resultlist = sorted(resultlist,
- key=AbstractDatasetComparisonKeyStartTime)
return(resultlist)
+ def assign_bool_value(self, map_i, tbrelations, topolist = ["EQUAL"]):
+ """ Function to assign boolean map value based on the map_values from the
+ compared map list by topological relationships.
+ :param map_i: Map object with temporal extent.
+ :param tbrelations: List of temporal relation to map_i.
+ :param topolist: List of strings for given temporal relations.
+ :return: Map object with conditional value that has been assigned by
+ relation maps that fulfil the topological relationships to
+ maplistB specified in topolist.
+ condition_value_list = []
+ if topo.upper() in tbrelations.keys():
+ #relationmaplist = tbrelations[complementdict[topo.upper()]]
+ relationmaplist = tbrelations[topo.upper()]
+ for relationmap in relationmaplist:
+ for boolean in relationmap.condition_value:
+ if isinstance(boolean, bool):
+ condition_value_list.append(boolean)
+ print(str(relationmap.get_temporal_extent_as_tuple()) + str(boolean))
+ if all(condition_value_list):
+ resultbool = True
+ else:
+ resultbool = False
+ map_i.condition_value = [resultbool]
+ return(resultbool)
- def eval_toperator(self, operator):
+ def compare_bool_value(self, map_i, tbrelations, compop, aggregate, topolist = ["EQUAL"]):
+ """ Function to evaluate two map lists with boolean values by boolean
+ comparison operator.
+ :return: Map object with conditional value that has been evaluated by
+ comparison operators.
+ # Build conditional list with elements from related maps and given relation operator.
+ leftbool = map_i.condition_value[0]
+ condition_value_list = [leftbool]
+ count = 0
+ if count == 0:
+ condition_value_list.append(compop[0])
+ condition_value_list.append('(')
+ if count > 0:
+ condition_value_list.append(aggregate)
+ count = count + 1
+ if count > 0:
+ condition_value_list.append(')')
+ # Convert conditional list to concatenated string and evaluate booleans.
+ condition_value_str = ''.join(map(str, condition_value_list))
+ print(condition_value_str)
+ resultbool = eval(condition_value_str)
+ print(resultbool)
+ # Add boolean value to result list.
+ def eval_toperator(self, operator, optype = 'relation'):
"""This function evaluates a string containing temporal operations.
- :param operator: String of temporal operations, e.g. {equal|during,=!:}.
+ :param operator: String of temporal operations, e.g. {!=,equal|during,l}.
+ :param optype: String to define operator type.
+ :return :List of temporal relations (equal, during), the given function
+ (!:) and the interval/instances (l).
+ .. code-block:: python
+ >>> import grass.temporal as tgis
+ >>> tgis.init()
+ >>> p = tgis.TemporalOperatorParser()
+ >>> operator = "{+, during}"
+ >>> p.parse(operator, optype = 'raster')
+ >>> print(p.relations, p.temporal, p.function)
+ (['during'], 'l', '+')
- :return: List of temporal relations (equal, during), the given
- function (!:) and the interval/instances (=).
- .. code-block:: python
- >>> import grass.temporal as tgis
- >>> tgis.init()
- >>> p = tgis.TemporalAlgebraParser()
- >>> operator = "{equal,:}"
- >>> p.eval_toperator(operator)
- (['equal'], '=', ':')
- >>> operator = "{equal|during,:}"
- (['equal', 'during'], '=', ':')
- >>> operator = "{equal,!:}"
- (['equal'], '=', '!:')
- >>> operator = "{equal|during,!:}"
- (['equal', 'during'], '=', '!:')
- >>> operator = "{equal|during,=!:}"
- >>> operator = "{equal|during|starts,#}"
- (['equal', 'during', 'starts'], '=', '#')
- >>> operator = "{!:}"
- >>> operator = "{=:}"
- >>> operator = "{#}"
- (['equal'], '=', '#')
- >>> operator = "{equal|during}"
- (['equal', 'during'], '=', '')
- >>> operator = "{equal}"
- (['equal'], '=', '')
- >>> operator = "{equal,||}"
- (['equal'], '=', '||')
- >>> operator = "{equal|during,&&}"
- (['equal', 'during'], '=', '&&')
- functionlist = [":", "!:", "#"]
- intervallist = ["=", "|", "&", "+"]
- comparelist = ["||", "&&"]
- relations = []
- interval = '='
- function = ''
- op = operator.strip('{}')
- oplist = op.split(',')
- if len(oplist) > 1:
- relationlist = oplist[0].split('|')
- for relation in relationlist:
- if relation.upper() in topologylist and relation not in relations:
- relations.append(relation)
- else:
- raise SyntaxError("invalid syntax")
- opright = oplist[1]
- if opright in comparelist:
- function = opright
- elif opright[0] in intervallist:
- interval = opright[0]
- if opright[1:] in functionlist:
- function = opright[1:]
- else:
- elif opright in functionlist:
- else:
- elif all([rel.upper() in topologylist for rel in oplist[0].split('|')]):
- relations = oplist[0].split('|')
- else:
- relations = ['equal']
- opstr = str(oplist[0])
- if opstr[0] in intervallist:
- interval = opstr[0]
- if opstr[1:] in functionlist:
- function = opstr[1:]
- else:
- elif opstr in functionlist:
- function = opstr
- #else:
- #raise SyntaxError("invalid syntax")
+ p = TemporalOperatorParser()
+ p.parse(operator, optype)
+ p.relations = [rel.upper() for rel in p.relations]
+ return(p.relations, p.temporal, p.function, p.aggregate)
- return(relations, interval, function)
- def perform_temporal_selection(self, maplistA, maplistB,
- inverse=False, assign_val=False):
+ def perform_temporal_selection(self, maplistA, maplistB, topolist = ["EQUAL"],
+ inverse = False, assign_val = False):
"""This function performs temporal selection operation.
- :param maplistA: List of maps representing the left side of a
- temporal expression.
- :param maplistB: List of maps representing the right side of a
+ :param maplistA: List of maps representing the left side of a temporal
+ expression.
+ :param maplistB: List of maps representing the right side of a temporal
+ expression.
- :param inverse: Boolean value that specifies if the selection
- should be inverted.
+ :param inverse: Boolean value that specifies if the selection should be
+ inverted.
:return: List of selected maps from maplistA.
>>> tgis.init()
>>> l = tgis.TemporalAlgebraParser()
>>> # Example with two lists of maps
@@ -1233,127 +1294,133 @@
if not inverse:
- topolist = self.get_temporal_topo_list(maplistA, maplistB,
- topolist,
- assign_val=assign_val)
+ topolist = self.get_temporal_topo_list(maplistA, maplistB, topolist,
+ assign_val = assign_val)
resultlist = topolist
else:
- topolist, assign_val=False)
resultlist = []
if map_i not in topolist:
resultlist.append(map_i)
- if assign_val:
- map_i.condition_value.append(False)
+ #if assign_val:
+ # if "condition_value" in dir(map_i):
+ # map_i.condition_value.append(False)
return(resultlist)
- def set_granularity(self, maplistA, maplistB, toperator='=',
- topolist=["EQUAL"]):
+ def set_granularity(self, maplistA, maplistB, toperator = 'l', topolist = ["EQUAL"]):
"""This function sets the temporal extends of a list of maps based on
- another map list.
+ another map list.
- :param maplistB: List of maps.
- :param toperator: String containing the temporal operator: =, +, &, \|.
- :param topolist: List of topological relations.
+ :param maplistB: List of maps.
+ :param toperator: String containing the temporal operator: l, r, d, i, u.
+ :param topolist: List of topological relations.
- :return: List of maps with the new temporal extends.
+ :return: List of maps with the new temporal extends.
- >>> tgis.init()
- >>> # Create two list of maps with equal time stamps
- >>> mapsA = []
- >>> mapsB = []
- >>> for i in range(10):
- ... idA = "a%i at B"%(i)
- ... mapA = tgis.RasterDataset(idA)
- ... idB = "b%i at B"%(i)
- ... mapB = tgis.RasterDataset(idB)
- ... check = mapA.set_relative_time(i, i + 1, "months")
- ... check = mapB.set_relative_time(i*2, i*2 + 2, "months")
- ... mapsA.append(mapA)
- ... mapsB.append(mapB)
- >>> resultlist = p.set_granularity(mapsA, mapsB, toperator = "|", topolist = ["during"])
- >>> for map in resultlist:
- ... start,end,unit = map.get_relative_time()
- ... print(map.get_id() + ' - start: ' + str(start) + ' end: ' + str(end))
- a1 at B - start: 0 end: 2
- a0 at B - start: 0 end: 2
- a3 at B - start: 2 end: 4
- a2 at B - start: 2 end: 4
- a5 at B - start: 4 end: 6
- a4 at B - start: 4 end: 6
- a7 at B - start: 6 end: 8
- a6 at B - start: 6 end: 8
- a9 at B - start: 8 end: 10
- a8 at B - start: 8 end: 10
+ >>> tgis.init()
+ >>> p = tgis.TemporalAlgebraParser()
+ >>> # Create two list of maps with equal time stamps
+ >>> mapsA = []
+ >>> mapsB = []
+ >>> for i in range(10):
+ ... idA = "a%i at B"%(i)
+ ... mapA = tgis.RasterDataset(idA)
+ ... idB = "b%i at B"%(i)
+ ... mapB = tgis.RasterDataset(idB)
+ ... check = mapA.set_relative_time(i, i + 1, "months")
+ ... check = mapB.set_relative_time(i*2, i*2 + 2, "months")
+ ... mapsA.append(mapA)
+ ... mapsB.append(mapB)
+ >>> resultlist = p.set_granularity(mapsA, mapsB, toperator = "u", topolist = ["during"])
+ >>> for map in resultlist:
+ ... start,end,unit = map.get_relative_time()
+ ... print(map.get_id() + ' - start: ' + str(start) + ' end: ' + str(end))
+ a1 at B - start: 0 end: 2
+ a0 at B - start: 0 end: 2
+ a3 at B - start: 2 end: 4
+ a2 at B - start: 2 end: 4
+ a5 at B - start: 4 end: 6
+ a4 at B - start: 4 end: 6
+ a7 at B - start: 6 end: 8
+ a6 at B - start: 6 end: 8
+ a9 at B - start: 8 end: 10
+ a8 at B - start: 8 end: 10
+ "FINISHED"]
- topo + "'")
# Build spatial temporal topology for maplistB to maplistB.
if self.spatial:
else:
resultdict = {}
# in topolist.
+ map_extent = map_i.get_temporal_extent()
+ map_start = map_extent.get_start_time()
+ map_end = map_extent.get_end_time()
+ unchanged = True
- newextend = None
- if toperator == "&":
- newextend = map_i.temporal_intersection(relationmap)
- elif toperator == "|":
- newextend = map_i.temporal_union(relationmap)
- elif toperator == "+":
- newextend = map_i.temporal_disjoint_union(relationmap)
- elif toperator == "=":
- resultdict[map_i.get_id()] = map_i
- if newextend is not None:
- start = newextend.get_start_time()
- end = newextend.get_end_time()
+ newextent = None
+ if toperator == "i":
+ newextent = map_i.temporal_intersection(relationmap)
+ elif toperator == "u":
+ newextent = map_i.temporal_union(relationmap)
+ elif toperator == "d":
+ newextent = map_i.temporal_disjoint_union(relationmap)
+ elif toperator == "l":
+ newextent = map_i.get_temporal_extent()
+ elif toperator == "r":
+ newextent = relationmap.get_temporal_extent()
+ if newextent != None:
+ start = newextent.get_start_time()
+ end = newextent.get_end_time()
#print(map_i.get_id() + ' - start: ' + str(start) + ' end: ' + str(end))
+ # Track changes in temporal extents of maps.
+ if map_start != start or map_end != end :
+ unchanged = False
if map_i.is_time_absolute():
map_i.set_absolute_time(start, end)
else:
relunit = map_i.get_relative_time_unit()
- map_i.set_relative_time(int(start), int(end),
- relunit)
+ map_i.set_relative_time(int(start), int(end), relunit)
+ else:
+ print('Topologic relation: ' + topo.upper() + ' not found.')
+ resultdict[map_i.get_id()] = map_i
+ if unchanged == True:
+ print('Leave temporal extend of result map: ' + map_i.get_map_id() + ' unchanged.')
# Get relations to maplistB per map in A.
# Loop over all relations from list
# temporal extent = map.temporal_intersection(map)
@@ -1363,14 +1430,14 @@
def get_temporal_func_dict(self, map):
""" This function creates a dictionary containing temporal functions for a
- map dataset with time stamp.
+ map dataset with time stamp.
:param map: Map object with time stamps.
:return: Dictionary with temporal functions for given input map.
>>> import datetime
>>> tgis.init()
@@ -1392,17 +1459,15 @@
>>> print(tfuncdict["START_DATETIME"])
2000-01-01 00:00:00
- tvardict = {"START_DOY": None, "START_DOW": None, "START_YEAR": None,
- "START_MONTH": None, "START_WEEK": None, "START_DAY": None,
- "START_HOUR": None, "START_MINUTE": None,
- "START_SECOND": None, "END_DOY": None, "END_DOW": None,
- "END_YEAR": None, "END_MONTH": None, "END_WEEK": None,
- "END_DAY": None, "END_HOUR": None, "END_MINUTE": None,
- "END_SECOND": None, "START_DATE": None,
- "START_DATETIME": None, "START_TIME": None,
- "END_DATE": None, "END_DATETIME": None, "END_TIME": None}
+ tvardict = {"START_DOY" : None, "START_DOW" : None, "START_YEAR" : None,
+ "START_MONTH" : None, "START_WEEK" : None, "START_DAY" : None,
+ "START_HOUR" : None, "START_MINUTE" : None, "START_SECOND" : None,
+ "END_DOY" : None, "END_DOW" : None, "END_YEAR" : None,
+ "END_MONTH" : None, "END_WEEK" : None, "END_DAY" : None,
+ "END_HOUR" : None, "END_MINUTE" : None, "END_SECOND" : None,
+ "START_DATE" : None, "START_DATETIME" : None, "START_TIME" : None,
+ "END_DATE" : None, "END_DATETIME" : None, "END_TIME" : None}
# Compute temporal function only for maps with absolute time reference.
if map.is_time_absolute:
@@ -1447,7 +1512,8 @@
tvardict["END_DATE"] = end.date()
tvardict["END_DATETIME"] = end
tvardict["END_TIME"] = end.time()
+ #core.fatal(_("The temporal functions for map <%s> only supported for absolute"\
+ # "time." % (str(map.get_id()))))
return(tvardict)
def eval_datetime_str(self, tfuncval, comp, value):
@@ -1471,12 +1537,12 @@
""" This function evaluates a global variable expression for a map list.
For example: start_day() > 5 , end_month() == 2.
- :param gvar: Object of type GlobalTemporalVar containing temporal.
+ :param gvar: Object of type GlobalTemporalVar containing temporal.
:param maplist: List of map objects.
- :return: List of maps from maplist with added conditional boolean
- values.
+ :return: List of maps from maplist with added conditional boolean values.
+ boollist = []
# Loop over maps of input map list.
# Get dictionary with temporal variables for the map.
@@ -1491,18 +1557,15 @@
tfuncval = tfuncdict[tfunc]
# Check if value has to be transfered to datetime object for comparison.
if tfunc in ["START_DATE", "END_DATE"]:
- timeobj = datetime.strptime(value.replace("\"", ""),
- '%Y-%m-%d')
+ timeobj = datetime.strptime(value.replace("\"",""), '%Y-%m-%d')
value = timeobj.date()
boolname = self.eval_datetime_str(tfuncval, comp_op, value)
elif tfunc in ["START_TIME", "END_TIME"]:
- '%H:%M:%S')
+ timeobj = datetime.strptime(value.replace("\"",""), '%H:%M:%S')
value = timeobj.time()
elif tfunc in ["START_DATETIME", "END_DATETIME"]:
- '%Y-%m-%d %H:%M:%S')
+ timeobj = datetime.strptime(value.replace("\"",""), '%Y-%m-%d %H:%M:%S')
value = timeobj
else:
@@ -1512,150 +1575,103 @@
map_i.condition_value.append(boolname)
else:
map_i.condition_value = boolname
return(maplist)
- def eval_map_list(self, maplist, thenlist, topolist=["EQUAL"]):
+ def eval_map_list(self, maplist ,thenlist, topolist = ["EQUAL"]):
""" This function transfers boolean values from temporal expression
- from one map list to another by their topology. These boolean
- values are added to the maps as condition_value.
+ from one map list to another by their topology. These boolean
+ values are added to the maps as condition_value.
- :param maplist: List of map objects containing boolean map values.
- :param thenlist: List of map objects where the boolean values
- should be added.
+ :param maplist: List of map objects containing boolean map values.
+ :param thenlist: List of map objects where the boolean values
+ should be added.
- :return: List of maps from thenlist with added conditional boolean
- values.
+ :return: List of maps from thenlist with added conditional boolean values.
- # Get topology of then statement map list in relation to the other
- # maplist and assign boolean values of the maplist to the thenlist.
+ # Get topology of then statement map list in relation to the other maplist
+ # and assign boolean values of the maplist to the thenlist.
containlist = self.perform_temporal_selection(thenlist, maplist,
- assign_val=True,
- topolist=topolist)
+ assign_val = True,
+ topolist = topolist)
# Inverse selection of maps from thenlist and assigning False values.
- excludelist = self.perform_temporal_selection(thenlist, maplist,
- assign_val=True,
- inverse=True,
+ #excludelist = self.perform_temporal_selection(thenlist, maplist,
+ # assign_val = True,
+ # inverse = True,
+ # topolist = topolist)
# Combining the selection and inverse selection list.
- resultlist = containlist + excludelist
+ resultlist = containlist# + excludelist
return(resultlist)
- def build_condition_list(self, tvarexpr, thenlist, topolist=["EQUAL"]):
- """This function evaluates temporal variable expressions of a
- conditional expression related to the map list of the then statement.
- Global variables or map lists with booleans are compared to the
- topology of the conclusion map list and a conditional list will be
- appended to every map. It contain the boolean expressions from
- these comparisons and optional operators to combine several
- temporal expressions, like "&&" or "||".
+ def build_condition_list(self, tvarexpr, thenlist, topolist = ["EQUAL"]):
+ """ This function evaluates temporal variable expressions of a conditional
+ expression in two steps.
+ At first it combines stepwise the single conditions by their relations with LALR.
+ In this prossess sub condition map lists will be created which will include
+ information of the underlying single conditions. Important: The temporal
+ relations between conditions are evaluated by implicit aggregation.
+ In the second step the aggregated condition map list will be compared with the
+ map list of conclusion statements by the given temporal relation.
+ The result is writen as 'condition_value' attribute to the resulting map objects.
+ These attribute consists of boolean expressions and operators which can be
+ evaluated with the eval_condition_list function.
+ [True, '||', False, '&&', True]
- For example: td(A) == 1 && start_day() > 5 --> [True || False]
+ For example: td(A) == 1 && start_day() > 5 --> [True || False]
(for one map.condition_value in a then map list)
- :param tvarexpr: List of GlobalTemporalVar objects and map lists.
- The list is constructed by the TemporalAlgebraParser
- in order of expression evaluation in the parser.
+ :param tvarexpr List of GlobalTemporalVar objects and map lists.
+ The list is constructed by the TemporalAlgebraParser
+ in order of expression evaluation in the parser.
- :param thenlist: Map list object of the conclusion statement.
- It will be compared and evaluated by the conditions.
+ :param thenlist Map list object of the conclusion statement.
+ It will be compared and evaluated by the conditions.
+ :param topolist List of temporal relations between the conditions and the
+ conclusions.
+ :return: Map list with conditional values for all temporal expressions.
- :return: Map list with conditional values for all temporal expressions.
- >>> tgis.init()
- >>> # Example with two lists of maps
- >>> mapsA = []
- >>> mapsB = []
- ... check = mapA.set_absolute_time(datetime(2000,1,i + 1),
- ... datetime(2000,1,i + 2))
- ... check = mapB.set_absolute_time(datetime(2000,1,i + 6),
- ... datetime(2000,1,i + 7))
- >>> mapsA = p.check_stds(mapsA)
- >>> mapsB = p.check_stds(mapsB)
- >>> # Create global expression object.
- >>> gvarA = tgis.GlobalTemporalVar()
- >>> gvarA.tfunc = "start_day"
- >>> gvarA.compop = ">"
- >>> gvarA.value = 5
- >>> gvarB = tgis.GlobalTemporalVar()
- >>> gvarB.tfunc = "start_day"
- >>> gvarB.compop = "<="
- >>> gvarB.value = 8
- >>> gvarOP = tgis.GlobalTemporalVar()
- >>> gvarOP.relationop = "&&"
- >>> gvarOP.topology.append("EQUAL")
- >>> tvarexpr = gvarA
- >>> result = p.build_condition_list(tvarexpr, mapsA)
- >>> for map_i in result:
- ... print(map_i.get_map_id() + ' ' + str(map_i.condition_value))
- a0 at B [False]
- a1 at B [False]
- a2 at B [False]
- a3 at B [False]
- a4 at B [False]
- a5 at B [True]
- a6 at B [True]
- a7 at B [True]
- a8 at B [True]
- a9 at B [True]
- >>> tvarexpr = [gvarA, gvarOP, gvarB]
- >>> result = p.build_condition_list(tvarexpr, mapsB)
- b0 at B [True, ['EQUAL'], '&&', True]
- b1 at B [True, ['EQUAL'], '&&', True]
- b2 at B [True, ['EQUAL'], '&&', True]
- b3 at B [True, ['EQUAL'], '&&', False]
- b4 at B [True, ['EQUAL'], '&&', False]
- b5 at B [True, ['EQUAL'], '&&', False]
- b6 at B [True, ['EQUAL'], '&&', False]
- b7 at B [True, ['EQUAL'], '&&', False]
- b8 at B [True, ['EQUAL'], '&&', False]
- b9 at B [True, ['EQUAL'], '&&', False]
+ # Evaluate the temporal variable expression and compute the temporal combination
+ # of conditions.
# Check if the input expression is a valid single global variable.
- if not isinstance(tvarexpr, list):
- if isinstance(tvarexpr, GlobalTemporalVar):
- if tvarexpr.get_type() == "global":
- # Use method eval_global_var to evaluate expression.
- resultlist = self.eval_global_var(tvarexpr, thenlist)
- else:
- # Check if a given list is a list of maps.
- if all([issubclass(type(ele), AbstractMapDataset) for ele in tvarexpr]):
- # Use method eval_map_list to evaluate map_list in comparison
- # to thenlist.
- resultlist = self.eval_map_list(tvarexpr, thenlist, topolist)
+ if isinstance(tvarexpr, GlobalTemporalVar) and tvarexpr.get_type() == "global" :
+ # Use method eval_global_var to evaluate expression.
+ resultlist = self.eval_global_var(tvarexpr, thenlist)
+ # Check if a given list is a list of maps.
+ elif all([issubclass(type(ele), AbstractMapDataset) for ele in tvarexpr]):
+ # Use method eval_map_list to evaluate map_list in comparison to thenlist.
+ resultlist = self.eval_map_list(tvarexpr, thenlist, topolist)
+ elif len(tvarexpr) % 2 != 0:
+ # Define variables for map list comparisons.
+ left_obj = []
+ operator = []
+ right_obj =[]
+ count = 0
+ #self.msgr.fatal("Condition list is not complete. Elements missing")
+ for iter in range(len(tvarexpr)):
+ expr = tvarexpr[iter]
+ operator = tvarexpr[iter +1]
+ relexpr = tvarexpr[iter +2]
+ if all([issubclass(type(ele), list) for ele in [expr, relexpr]]):
+ resultlist = self.get_temporal_topo_list(expr, relexpr)
# Loop through the list, search for map lists or global variables.
for expr in tvarexpr:
if isinstance(expr, list):
if all([issubclass(type(ele), AbstractMapDataset) for ele in expr]):
- resultlist = self.eval_map_list(expr, thenlist,
- topolist)
+ resultlist = self.eval_map_list(expr, thenlist, topolist)
else:
- # Recursive function call to look into nested list
- # elements.
+ # Recursive function call to look into nested list elements.
self.build_condition_list(expr, thenlist)
elif isinstance(expr, GlobalTemporalVar):
- # Use according functions for different global variable
- # types.
+ # Use according functions for different global variable types.
if expr.get_type() == "operator":
if all(["condition_value" in dir(map_i) for map_i in thenlist]):
# Add operator string to the condition list.
@@ -1665,15 +1681,14 @@
resultlist = self.eval_global_var(expr, thenlist)
# Sort resulting list of maps chronological.
return(resultlist)
- def eval_condition_list(self, maplist, inverse=False):
+ def eval_condition_list(self, maplist, inverse = False):
""" This function evaluates conditional values of a map list.
- A recursive function is used to evaluate comparison statements
- from left to right in the given conditional list.
+ A recursive function is used to evaluate comparison statements
+ from left to right in the given conditional list.
For example: [True, '||', False, '&&', True] -> True
[True, '||', False, '&&', False] -> False
@@ -1685,56 +1700,19 @@
[True, '&&', False] -> False
[False, '||', True] -> True
+ :param tvarexpr: List of GlobalTemporalVar objects and map lists.
- >>> tgis.init()
- >>> mapsA = []
- >>> mapsB = []
- >>> tvarexpr = [mapsA, gvarOP,gvarA]
def recurse_compare(conditionlist):
for ele in conditionlist:
if ele == '||':
ele_index = conditionlist.index(ele)
- topolist = conditionlist.pop(ele_index - 1)
+ topolist = conditionlist.pop(ele_index -1)
right = conditionlist.pop(ele_index)
- left = conditionlist.pop(ele_index - 2)
+ left = conditionlist.pop(ele_index - 2)
if any([left, right]):
result = True
else:
@@ -1743,9 +1721,9 @@
if ele == '&&':
if all([left, right]):
result = True
else:
@@ -1756,13 +1734,14 @@
return(resultlist)
- resultlist = []
+ resultlist = []
inverselist = []
+ # Loop through map list and evaluate conditional values.
# Get condition values from map object.
conditionlist = map_i.condition_value
- #print(map_i.get_map_id() + ' ' + str(map_i.condition_value))
# Evaluate conditions in list with recursive function.
resultbool = recurse_compare(conditionlist)
# Set conditional value of map to resulting boolean.
@@ -1770,9 +1749,9 @@
# Add all maps that fulfill the conditions to result list.
if resultbool[0]:
+ print(map_i.get_map_id() + ' ' + str(map_i.condition_value))
else:
inverselist.append(map_i)
if inverse:
return(inverselist)
else:
@@ -1787,25 +1766,99 @@
if self.run:
- resultstds = open_new_stds(t[1], self.stdstype, self.temporaltype,
- "", "", 'mean', dbif=self.dbif,
- overwrite=self.overwrite)
if isinstance(t[3], list):
num = len(t[3])
count = 0
+ changeflag = False
+ register_list = []
if num > 0:
- dbif, connected = init_dbif(None)
- for map in t[3]:
- map.select(dbif=dbif)
- # map.update()
- resultstds.register_map(map, dbif=dbif)
- count += 1
- if count % 10 == 0:
- self.msgr.percent(count, num, 1)
- resultstds.update_from_registered_maps(dbif=dbif)
- if connected:
- dbif.close()
+ for map_i in t[3]:
+ # Test if temporal extents have been changed by temporal
+ # relation oeprators (&|+).
+ map_i_extent = map_i.get_temporal_extent_as_tuple()
+ map_test = map_i.get_new_instance(map_i.get_id())
+ map_test.select()
+ map_test_extent = map_test.get_temporal_extent_as_tuple()
+ if map_test_extent != map_i_extent:
+ changeflag = True
+ if changeflag:
+ # Check if resultmap names exist in GRASS database.
+ mapname = self.basename + "_" + str(count) + "@" + self.mapset
+ process_queue = pymod.ParallelModuleQueue(int(self.nprocs))
+ if self.stdstype == 'strds':
+ map_test = RasterDataset(mapname)
+ elif self.stdstype == 'stvds':
+ map_test = VectorDataset(mapname)
+ if map_test.map_exists() and self.overwrite == False:
+ self.msgr.fatal("Error raster maps with basename %s exist. Use --o flag to overwrite existing file" \
+ %(mapname))
+ # Create new maps with basename.
+ newident = self.basename + "_" + str(count)
+ map_result = map_i.get_new_instance(newident + "@" + self.mapset)
+ map_result.set_temporal_extent(map_i.get_temporal_extent())
+ map_result.set_spatial_extent(map_i.get_spatial_extent())
+ register_list.append(map_result)
+ m = copy.deepcopy(self.m_copy)
+ m.inputs["rast"].value = map_i.get_id(), newident
+ m.flags["overwrite"].value = self.overwrite
+ process_queue.put(m)
+ m.inputs["vect"].value = map_i.get_id(), newident
+ else:
+ register_list.append(map_i)
+ count += 1
+ if changeflag:
+ process_queue.wait()
+ # Open connection to temporal database.
+ dbif, connect = init_dbif(self.dbif)
+ # Create result space time dataset.
+ resultstds = open_new_stds(t[1], self.stdstype, \
+ 'absolute', t[1], t[1], \
+ 'mean', self.dbif, \
+ overwrite = self.overwrite)
+ for map_i in register_list:
+ # Get meta data from grass database.
+ map_i.load()
+ # Check if temporal extents have changed.
+ if changeflag:
+ # Do not register empty maps if not required
+ # In case of a null map continue, do not register null maps
+ if map_i.metadata.get_min() is None and \
+ map_i.metadata.get_max() is None:
+ if not self.register_null:
+ self.empty_maps[map_i.get_name()] = map_i.get_name()
+ continue
+ if map_i.is_in_db(dbif) and self.overwrite:
+ # Update map in temporal database.
+ map_i.update_all(dbif)
+ elif map_i.is_in_db(dbif) and self.overwrite == False:
+ # Raise error if map exists and no overwrite flag is given.
+ self.msgr.fatal("Error vector map %s exist in temporal database. Use overwrite flag. : \n%s" \
+ %(map_i.get_map_id(), cmd.popen.stderr))
+ else:
+ # Insert map into temporal database.
+ map_i.insert(dbif)
+ # Register map in result space time dataset.
+ success = resultstds.register_map(map_i, dbif)
+ resultstds.update_from_registered_maps(dbif)
+ dbif.close()
+ elif num == 0:
+ self.msgr.warning('Empty result space time dataset. No map has \
+been registered in %s' %(t[1] ))
+ dbif.close()
t[0] = t[3]
else:
@@ -1825,44 +1878,73 @@
""" expr : LPAREN expr RPAREN"""
t[0] = t[2]
- def p_number(self, t):
+ def p_number(self,t):
"""number : INT
| FLOAT
t[0] = t[1]
- def p_t_hash(self, t):
+ def p_expr_tmap_function(self, t):
+ # Add a single map.
+ # Only the spatial extent of the map is evaluated.
+ # Temporal extent is not existing.
+ # Examples:
+ # R = tmap(A)
+ expr : TMAP LPAREN stds RPAREN
+ if self.run:
+ # Check input map.
+ input = t[3]
+ if not isinstance(input, list):
+ # Check for mapset in given stds input.
+ if input.find("@") >= 0:
+ id_input = input
+ else:
+ id_input = input + "@" + self.mapset
+ # Create empty map dataset.
+ map_i = dataset_factory(self.maptype, id_input)
+ # Check for occurence of space time dataset.
+ if map_i.map_exists() == False:
+ raise FatalError(_("%s map <%s> not found in GRASS spatial database") %
+ (map_i.get_type(), id_input))
+ else:
+ # Select dataset entry from database.
+ map_i.select(dbif=self.dbif)
+ else:
+ raise FatalError(_("Wrong map type <%s> . TMAP only supports single maps that are registered in the temporal GRASS database") %
+ (map_i.get_type()))
+ # Return map object.
+ t[0] = [map_i]
+ else:
+ t[0] = "tmap(", t[3] , ")"
+ if self.debug:
+ print "tmap(", t[3] , ")"
+ def p_t_hash(self,t):
t_hash_var : stds HASH stds
- | stds HASH expr
- | expr HASH stds
- | expr HASH expr
if self.run:
- maplistA = self.check_stds(t[1])
- maplistB = self.check_stds(t[3])
+ maplistA = self.check_stds(t[1])
+ maplistB = self.check_stds(t[3])
resultlist = self.get_temporal_topo_list(maplistA, maplistB,
- count_map=True)
+ count_map = True)
t[0] = resultlist
- def p_t_hash2(self, t):
+ def p_t_hash2(self,t):
t_hash_var : stds T_HASH_OPERATOR stds
- | stds T_HASH_OPERATOR expr
- | expr T_HASH_OPERATOR stds
- | expr T_HASH_OPERATOR expr
if self.run:
- topolist = self.eval_toperator(t[2])[0]
- resultlist = self.get_temporal_topo_list(maplistA, maplistB,
- topolist,
- count_map=True)
+ topolist = self.eval_toperator(t[2], optype = 'hash')[0]
+ resultlist = self.get_temporal_topo_list(maplistA, maplistB, topolist,
+ count_map = True)
t[0] = resultlist
def p_t_td_var(self, t):
@@ -1875,11 +1957,11 @@
if map_i.is_time_absolute:
start, end = map_i.get_absolute_time()
- if end is not None:
+ if end != None:
td = time_delta_to_relative_time(end - start)
else:
start, end, unit = current.get_relative_time()
+ if end != None:
td = end - start
if "map_value" in dir(map_i):
@@ -1895,6 +1977,7 @@
if self.debug:
print "td(" + str(t[3]) + ")"
def p_t_time_var(self, t):
# Temporal variables that return a double or integer value
@@ -1932,102 +2015,102 @@
t[0] = t[1]
- def p_t_var_expr(self, t):
+ def p_t_var_expr_td_hash(self, t):
# Examples:
- # start_month() > 2
- # start_day() < 14
- # start_day() < start_month()
- # td() < 31
+ # A # B == 2
+ # td(A) < 31
- t_var_expr : t_var LPAREN RPAREN comp_op number
- | t_var LPAREN RPAREN comp_op t_var
- | t_td_var comp_op number
- | t_td_var comp_op t_var
- | t_hash_var comp_op number
- | t_hash_var comp_op t_var
+ t_var_expr : t_td_var comp_op number
+ | t_hash_var comp_op number
if self.run:
- if len(t) == 4:
- maplist = self.check_stds(t[1])
- comp_op = t[2]
- for map_i in maplist:
- for obj in map_i.map_value:
- if isinstance(obj, GlobalTemporalVar):
- td = obj.td
- boolnum = eval(str(td) + comp_op + str(t[3]))
- gvar = GlobalTemporalVar()
- gvar.boolean = boolnum
- if obj.get_type() == "timediff":
- index = map_i.map_value.index(obj)
- map_i.map_value[index] = gvar
- t[0] = maplist
- if len(t) == 6:
- if isinstance(t[1], GlobalTemporalVar):
- pass
- gvar.tfunc = t[1]
- gvar.compop = t[4]
- gvar.value = t[5]
- t[0] = gvar
- else:
- t[0] = True
+ maplist = self.check_stds(t[1])
+ comp_op = t[2]
+ value = str(t[3])
+ # Evaluate time diferences and hash operator statements for each map.
+ try:
+ td = map_i.map_value[0].td
+ boolname = eval(str(td) + comp_op + value)
+ # Add conditional boolean value to the map.
+ if "condition_value" in dir(map_i):
+ map_i.condition_value.append(boolname)
+ else:
+ map_i.condition_value = boolname
+ except:
+ self.msgr.fatal("Error: the given expression does not contain a correct time difference object.")
+ t[0] = maplist
if self.debug:
- if len(t) == 6:
- print t[1], t[4], t[5]
- if len(t) == 4:
- print t[1], t[2], t[3]
+ print t[1], t[2], t[3]
- def p_t_var_expr_time1(self, t):
+ def p_t_var_expr_number(self, t):
# Examples:
- # start_time() == "12:30:00"
- # start_date() <= "2001-01-01"
- # start_datetime() > "2001-01-01 12:30:00"
+ # start_month(A) > 2
+ # start_day(B) < 14
+ # start_day(B) < start_month(A)
- t_var_expr : START_TIME LPAREN RPAREN comp_op TIME
- | START_DATE LPAREN RPAREN comp_op DATE
- | START_DATETIME LPAREN RPAREN comp_op DATETIME
- | END_TIME LPAREN RPAREN comp_op TIME
- | END_DATE LPAREN RPAREN comp_op DATE
- | END_DATETIME LPAREN RPAREN comp_op DATETIME
+ t_var_expr : t_var LPAREN stds RPAREN comp_op number
+ | t_var LPAREN expr RPAREN comp_op number
+ # TODO: Implement comparison operator for map lists.
+ #| t_var LPAREN stds RPAREN comp_op t_var LPAREN stds RPAREN
+ #| t_var LPAREN stds RPAREN comp_op t_var LPAREN expr RPAREN
+ #| t_var LPAREN expr RPAREN comp_op t_var LPAREN expr RPAREN
+ #| t_var LPAREN expr RPAREN comp_op t_var LPAREN stds RPAREN
+ # TODO: Implement statement in backward direction:
+ # number comp_op t_var LPAREN stds RPAREN
if self.run:
+ maplist = self.check_stds(t[3])
- gvar.tfunc = t[1]
- gvar.value = t[5]
- t[0] = gvar
- else:
- t[0] = True
+ gvar.tfunc = t[1]
+ gvar.compop = t[5]
+ gvar.value = t[6]
+ # Evaluate temporal variable for given maplist.
+ resultlist = self.eval_global_var(gvar, maplist)
+ t[0] = resultlist
if self.debug:
+ print t[1], t[3], t[5], t[6]
- def p_t_var_expr_time2(self, t):
+ def p_t_var_expr_time(self, t):
+ # Examples:
+ # start_time(A) == "12:30:00"
+ # start_date(B) <= "2001-01-01"
+ # start_datetime(C) > "2001-01-01 12:30:00"
+ # TIME comp_op START_TIME LPAREN stds RPAREN
- t_var_expr : TIME comp_op START_TIME LPAREN RPAREN
- | DATE comp_op START_DATE LPAREN RPAREN
- | DATETIME comp_op START_DATETIME LPAREN RPAREN
- | TIME comp_op END_TIME LPAREN RPAREN
- | DATE comp_op END_DATE LPAREN RPAREN
- | DATETIME comp_op END_DATETIME LPAREN RPAREN
+ t_var_expr : START_TIME LPAREN stds RPAREN comp_op TIME
+ | START_DATE LPAREN stds RPAREN comp_op DATE
+ | START_DATETIME LPAREN stds RPAREN comp_op DATETIME
+ | END_TIME LPAREN stds RPAREN comp_op TIME
+ | END_DATE LPAREN stds RPAREN comp_op DATE
+ | END_DATETIME LPAREN stds RPAREN comp_op DATETIME
+ | START_TIME LPAREN expr RPAREN comp_op TIME
+ | START_DATE LPAREN expr RPAREN comp_op DATE
+ | START_DATETIME LPAREN expr RPAREN comp_op DATETIME
+ | END_TIME LPAREN expr RPAREN comp_op TIME
+ | END_DATE LPAREN expr RPAREN comp_op DATE
+ | END_DATETIME LPAREN expr RPAREN comp_op DATETIME
if self.run:
- reverseop = {"<": ">", ">": "<", "<=": ">=", ">=": "<=",
+ # Check input maplist.
+ # Build global temporal variable.
- gvar.tfunc = t[3]
- gvar.compop = reverseop[t[2]]
- gvar.value = t[1]
- t[0] = gvar
- else:
- t[0] = True
+ gvar.tfunc = t[1]
+ gvar.value = t[6]
+ t[0] = resultlist
if self.debug:
- print(t[4])
def p_t_var_expr_comp(self, t):
@@ -2035,19 +2118,21 @@
| t_var_expr OR OR t_var_expr
if self.run:
- tvarexprA = t[1]
- tvarexprB = t[4]
- operator = GlobalTemporalVar()
- operator.relationop = t[2] + t[3]
- operator.topology.append("EQUAL")
- resultlist = []
- resultlist.append(tvarexprA)
- resultlist.append(operator)
- resultlist.append(tvarexprB)
+ # Check input maplists and operators.
+ tvarexprA = t[1]
+ tvarexprB = t[4]
+ relations = ["EQUAL"]
+ temporal = "l"
+ function = t[2] + t[3]
+ aggregate = t[2]
+ # Build conditional values based on topological relationships.
+ complist = self.get_temporal_topo_list(tvarexprA, tvarexprB, topolist = relations,
+ compare_bool = True, compop = function[0], aggregate = aggregate)
+ # Set temporal extent based on topological relationships.
+ resultlist = self.set_temporal_extent_list(complist, topolist = relations,
+ temporal = temporal)
t[0] = resultlist
- else:
- t[0] = True
if self.debug:
print t[1], t[2] + t[3], t[4]
@@ -2057,22 +2142,18 @@
t_var_expr : t_var_expr T_COMP_OPERATOR t_var_expr
if self.run:
- tvarexprA = t[1]
- tvarexprB = t[3]
- toperator = self.eval_toperator(t[2])[0]
- relationop = toperator[2]
- relations = toperator[0]
- operator.relationop = relationop
- operator.topology.extend(relations)
- resultlist = []
+ tvarexprA = t[1]
+ tvarexprB = t[3]
+ # Evaluate temporal comparison operator.
+ relations, temporal, function, aggregate = self.eval_toperator(t[2], optype = 'boolean')
t[0] = resultlist
- else:
- t[0] = True
if self.debug:
@@ -2092,17 +2173,17 @@
# Setup database connection.
# Check input stds.
# Perform selection.
selectlist = self.perform_temporal_selection(maplistA, maplistB)
# Return map list.
t[0] = selectlist
else:
- t[0] = t[1] + "*"
+ t[0] = t[1] , "*"
if self.debug:
- print t[1] + "* = ", t[1], t[2], t[3]
+ print str(t[1]), "* = ", t[1], t[2], t[3]
def p_expr_t_not_select(self, t):
# Temporal equal selection
@@ -2117,11 +2198,11 @@
if self.run:
# Check input stds.
# Perform negative selection.
selectlist = self.perform_temporal_selection(maplistA, maplistB,
- inverse=True)
+ inverse = True)
# Return map list.
t[0] = selectlist
else:
@@ -2130,6 +2211,7 @@
if self.debug:
def p_expr_t_select_operator(self, t):
# The temporal topology relation equals is implicit
@@ -2148,10 +2230,10 @@
if self.run:
# Check input stds.
# Evaluate temporal operator.
- operators = self.eval_toperator(t[2])
+ operators = self.eval_toperator(t[2], optype = 'select')
# Check for negative selection.
if operators[2] == "!:":
negation = True
@@ -2159,11 +2241,9 @@
negation = False
- topolist=operators[0],
- inverse=negation)
- selectlist = self.set_granularity(selectlist, maplistB,
- operators[1], operators[0])
+ topolist = operators[0], inverse = negation)
+ selectlist = self.set_granularity(selectlist, maplistB, operators[1],
+ operators[0])
# Return map list.
t[0] = selectlist
else:
@@ -2172,6 +2252,7 @@
if self.debug:
def p_expr_condition_if(self, t):
# Examples
# if( start_date() < "2005-06-01", A:B)
@@ -2181,13 +2262,13 @@
if self.run:
# Get stds/map list of then statement.
- thenlist = self.check_stds(t[5])
+ thenlist = self.check_stds(t[5])
# Get temporal conditional statement.
- tvarexpr = t[3]
- thencond = self.build_condition_list(tvarexpr, thenlist)
- thenresult = self.eval_condition_list(thencond)
+ tvarexpr = t[3]
+ thencond = self.build_condition_list(tvarexpr, thenlist)
+ thenresult = self.eval_condition_list(thencond)
# Clear the map and conditional values of the map list.
- resultlist = self.check_stds(thenresult, clear=True)
+ resultlist = self.check_stds(thenresult, clear = True)
# Return resulting map list.
t[0] = resultlist
else:
@@ -2205,14 +2286,14 @@
if self.run:
- thenlist = self.check_stds(t[7])
+ thenlist = self.check_stds(t[7])
- tvarexpr = t[5]
- topolist = self.eval_toperator(t[3])[0]
- thencond = self.build_condition_list(tvarexpr, thenlist, topolist)
+ tvarexpr = t[5]
+ topolist = self.eval_toperator(t[3], optype = 'relation')[0]
+ thencond = self.build_condition_list(tvarexpr, thenlist, topolist)
t[0] = resultlist
else:
@@ -2232,21 +2313,20 @@
if self.run:
- elselist = self.check_stds(t[7])
+ elselist = self.check_stds(t[7])
# Get temporal conditional statement for then and else expressions.
- tvarexpr = t[3]
- elsecond = self.build_condition_list(tvarexpr, elselist)
- elseresult = self.eval_condition_list(elsecond, inverse=True)
+ tvarexpr = t[3]
+ elsecond = self.build_condition_list(tvarexpr, elselist)
+ elseresult = self.eval_condition_list(elsecond, inverse = True)
# Combine and sort else and then statement to result map list.
combilist = thenresult + elseresult
- resultlist = sorted(combilist,
+ resultlist = sorted(combilist, key = AbstractDatasetComparisonKeyStartTime)
- resultlist = self.check_stds(resultlist, clear=True)
+ resultlist = self.check_stds(resultlist, clear = True)
t[0] = resultlist
else:
@@ -2268,22 +2348,21 @@
if self.run:
- elselist = self.check_stds(t[9])
+ elselist = self.check_stds(t[9])
- tvarexpr = t[5]
- elsecond = self.build_condition_list(tvarexpr, elselist, topolist)
+ tvarexpr = t[5]
+ elsecond = self.build_condition_list(tvarexpr, elselist, topolist)
t[0] = resultlist
else:
@@ -2310,7 +2389,7 @@
if self.run:
# Check input stds.
- bufflist = self.check_stds(t[3])
+ bufflist = self.check_stds(t[3])
for map in bufflist:
# Get increment format.
if len(t) == 10:
@@ -2338,7 +2417,7 @@
if self.run:
# Check input stds.
- maplist = self.check_stds(t[3])
# Perform snapping.
snaplist = AbstractSpaceTimeDataset.snap_map_list(maplist)
t[0] = snaplist
@@ -2360,15 +2439,14 @@
if self.run:
# Check input stds.
if len(t) == 10:
increment = str(t[6]) + " " + t[7]
elif len(t) == 7:
increment = str(t[5])
# Perform shifting.
- shiftlist = AbstractSpaceTimeDataset.shift_map_list(maplist,
- increment)
+ shiftlist = AbstractSpaceTimeDataset.shift_map_list(maplist, increment)
t[0] = shiftlist
else:
t[0] = t[3] + "*"
@@ -2382,9 +2460,8 @@
# Handle errors.
def p_error(self, t):
if t:
- raise SyntaxError("syntax error on line %d, token %s near '%s'"
- " expression '%s'" % (t.lineno, t.type, t.value,
- self.expression))
+ raise SyntaxError("syntax error on line %d, token %s near '%s' expression '%s'" %
+ (t.lineno, t.type, t.value, self.expression))
else:
raise SyntaxError("Unexpected syntax error")
Added: grass/trunk/lib/python/temporal/temporal_operator.py
--- grass/trunk/lib/python/temporal/temporal_operator.py (rev 0)
+++ grass/trunk/lib/python/temporal/temporal_operator.py 2014-11-04 15:45:52 UTC (rev 62594)
@@ -0,0 +1,615 @@
+"""!@package grass.temporal
+Temporal operator evaluation with PLY
+(C) 2013 by the GRASS Development Team
+This program is free software under the GNU General Public
+License (>=v2). Read the file COPYING that comes with GRASS
+for details.
+ at author Thomas Leppelt and Soeren Gebbert
+ at code
+ >>> p = TemporalOperatorParser()
+ >>> expression = "{equal| during}"
+ >>> p.parse(expression, optype = 'relation')
+ (['equal', 'during'], None, None)
+ >>> expression = "{contains | starts}"
+ >>> p.parse(expression)
+ (['contains', 'starts'], None, None)
+ >>> expression = "{&&, during}"
+ >>> p.parse(expression, optype = 'boolean')
+ >>> print(p.relations, p.temporal, p.function,p.aggregate)
+ (['during'], 'l', '&&', '&')
+ >>> expression = "{||, equal | during}"
+ (['equal', 'during'], 'l', '||', '|')
+ >>> expression = "{||, equal | during, &}"
+ (['equal', 'during'], 'l', '||', '&')
+ >>> expression = "{&&, during, |}"
+ (['during'], 'l', '&&', '|')
+ >>> expression = "{&&, during, |, r}"
+ (['during'], 'r', '&&', '|')
+ >>> expression = "{&&, during, u}"
+ (['during'], 'u', '&&', '&')
+ >>> expression = "{:, during, r}"
+ >>> p.parse(expression, optype = 'select')
+ (['during'], 'r', ':')
+ >>> expression = "{!:, equal | contains, d}"
+ (['equal', 'contains'], 'd', '!:')
+ >>> expression = "{#, during, r}"
+ >>> p.parse(expression, optype = 'hash')
+ (['during'], 'r', '#')
+ >>> expression = "{#, equal | contains}"
+ (['equal', 'contains'], 'l', '#')
+ >>> expression = "{+, during, r}"
+ >>> p.parse(expression, optype = 'raster')
+ (['during'], 'r', '+')
+ >>> expression = "{/, equal | contains}"
+ (['equal', 'contains'], 'l', '/')
+ >>> expression = "{+, equal | contains,intersect}"
+ (['equal', 'contains'], 'i', '+')
+ >>> expression = "{*, contains,disjoint}"
+ (['contains'], 'd', '*')
+ >>> expression = "{~, equal,left}"
+ >>> p.parse(expression, optype = 'overlay')
+ (['equal'], 'l', '~')
+ >>> expression = "{^, over,right}"
+ (['overlaps', 'overlapped'], 'r', '^')
+ at endcode
+try:
+ import ply.lex as lex
+ import ply.yacc as yacc
+except:
+ pass
+class TemporalOperatorLexer(object):
+ """!Lexical analyzer for the GRASS GIS temporal operator"""
+ # Functions that defines topological relations.
+ relations = {
+ 'equal' : "EQUAL",
+ 'follows' : "FOLLOWS",
+ 'precedes' : "PRECEDES",
+ 'overlaps' : "OVERLAPS",
+ 'overlapped' : "OVERLAPPED",
+ 'during' : "DURING",
+ 'starts' : "STARTS",
+ 'finishes' : "FINISHES",
+ 'contains' : "CONTAINS",
+ 'started' : "STARTED",
+ 'finished' : "FINISHED",
+ 'over' : "OVER"
+ # This is the list of token names.
+ tokens = (
+ 'COMMA',
+ 'LEFTREF',
+ 'RIGHTREF',
+ 'UNION',
+ 'DISJOINT',
+ 'INTERSECT',
+ 'HASH',
+ 'OR',
+ 'AND',
+ 'DISOR',
+ 'XOR',
+ 'NOT',
+ 'MOD',
+ 'DIV',
+ 'MULT',
+ 'ADD',
+ 'SUB',
+ 'T_SELECT',
+ 'T_NOT_SELECT',
+ 'CLPAREN',
+ 'CRPAREN',
+ # Build the token list
+ tokens = tokens + tuple(relations.values())
+ # Regular expression rules for simple tokens
+ t_T_SELECT = r':'
+ t_T_NOT_SELECT = r'!:'
+ t_COMMA = r','
+ t_LEFTREF = '^[l|left]'
+ t_RIGHTREF ='^[r|right]'
+ t_UNION = '^[u|union]'
+ t_DISJOINT = '^[d|disjoint]'
+ t_INTERSECT = '^[i|intersect]'
+ t_HASH = r'\#'
+ t_OR = r'[\|]'
+ t_AND = r'[&]'
+ t_DISOR = r'\+'
+ t_XOR = r'\^'
+ t_NOT = r'\~'
+ t_MOD = r'[\%]'
+ t_DIV = r'[\/]'
+ t_MULT = r'[\*]'
+ t_ADD = r'[\+]'
+ t_SUB = r'[-]'
+ t_CLPAREN = r'\{'
+ t_CRPAREN = r'\}'
+ # These are the things that should be ignored.
+ t_ignore = ' \t'
+ # Track line numbers.
+ def t_newline(self, t):
+ r'\n+'
+ t.lineno += len(t.value)
+ def t_NAME(self, t):
+ r'[a-zA-Z_][a-zA-Z_0-9]*'
+ self.temporal_symbol(t)
+ return t
+ # Parse symbols
+ def temporal_symbol(self, t):
+ # Check for reserved words
+ if t.value in TemporalOperatorLexer.relations.keys():
+ t.type = TemporalOperatorLexer.relations.get(t.value)
+ elif t.value == 'l' or t.value == 'left':
+ t.value = 'l'
+ t.type = 'LEFTREF'
+ elif t.value == 'r' or t.value == 'right':
+ t.value = 'r'
+ t.type = 'RIGHTREF'
+ elif t.value == 'u' or t.value == 'union':
+ t.value = 'u'
+ t.type = 'UNION'
+ elif t.value == 'd' or t.value == 'disjoint':
+ t.value = 'd'
+ t.type = 'DISJOINT'
+ elif t.value == 'i' or t.value == 'intersect':
+ t.value = 'i'
+ t.type = 'INTERSECT'
+ #else:
+ # t.type = 'NAME'
+ return(t)
+ # Handle errors.
+ def t_error(self, t):
+ raise SyntaxError("syntax error on line %d near '%s'" %
+ (t.lineno, t.value))
+ # Build the lexer
+ def build(self,**kwargs):
+ self.lexer = lex.lex(module=self, **kwargs)
+ # Just for testing
+ def test(self,data):
+ self.name_list = {}
+ print(data)
+ self.lexer.input(data)
+ while True:
+ tok = self.lexer.token()
+ if not tok: break
+ print tok
+class TemporalOperatorParser(object):
+ """The temporal operator class"""
+ def __init__(self):
+ self.lexer = TemporalOperatorLexer()
+ self.lexer.build()
+ self.parser = yacc.yacc(module=self)
+ self.relations = None
+ self.temporal = None
+ self.function = None
+ self.aggregate = None
+ def parse(self, expression, optype = 'relation'):
+ self.optype = optype
+ self.parser.parse(expression)
+ # The paramter optype can be of type: select {:, during, r}, boolean{&&, contains, |},
+ # raster{*, equal, |}, vector {|, starts, &},
+ # hash{#, during, l} or relation {during}.
+ # Error rule for syntax errors.
+ def p_error(self, t):
+ raise SyntaxError("Unexpected syntax error")
+ # Get the tokens from the lexer class
+ tokens = TemporalOperatorLexer.tokens
+ def p_relation_operator(self, t):
+ # The expression should always return a list of maps.
+ operator : CLPAREN relation CRPAREN
+ | CLPAREN relationlist CRPAREN
+ # Check for correct type.
+ if not self.optype == 'relation':
+ raise SyntaxError("invalid syntax")
+ else:
+ # Set three operator components.
+ if isinstance(t[2], list):
+ self.relations = t[2]
+ else:
+ self.relations = [t[2]]
+ t[0] = t[2]
+ def p_relation_bool_operator(self, t):
+ operator : CLPAREN OR OR COMMA relation CRPAREN
+ | CLPAREN AND AND COMMA relation CRPAREN
+ | CLPAREN OR OR COMMA relationlist CRPAREN
+ | CLPAREN AND AND COMMA relationlist CRPAREN
+ if not self.optype == 'boolean':
+ else:
+ if isinstance(t[5], list):
+ self.relations = t[5]
+ else:
+ self.relations = [t[5]]
+ self.temporal = "l"
+ self.function = t[2] + t[3]
+ self.aggregate = t[2]
+ t[0] = t[2]
+ def p_relation_bool_combi_operator(self, t):
+ operator : CLPAREN OR OR COMMA relation COMMA OR CRPAREN
+ | CLPAREN OR OR COMMA relation COMMA AND CRPAREN
+ | CLPAREN AND AND COMMA relation COMMA OR CRPAREN
+ | CLPAREN AND AND COMMA relation COMMA AND CRPAREN
+ | CLPAREN OR OR COMMA relationlist COMMA OR CRPAREN
+ | CLPAREN OR OR COMMA relationlist COMMA AND CRPAREN
+ | CLPAREN AND AND COMMA relationlist COMMA OR CRPAREN
+ | CLPAREN AND AND COMMA relationlist COMMA AND CRPAREN
+ else:
+ else:
+ self.aggregate = t[7]
+ t[0] = t[2]
+ def p_relation_bool_combi_operator2(self, t):
+ operator : CLPAREN OR OR COMMA relation COMMA temporal CRPAREN
+ | CLPAREN AND AND COMMA relation COMMA temporal CRPAREN
+ | CLPAREN OR OR COMMA relationlist COMMA temporal CRPAREN
+ | CLPAREN AND AND COMMA relationlist COMMA temporal CRPAREN
+ else:
+ else:
+ self.temporal = t[7]
+ t[0] = t[2]
+ def p_relation_bool_combi_operator3(self, t):
+ operator : CLPAREN OR OR COMMA relation COMMA OR COMMA temporal CRPAREN
+ | CLPAREN OR OR COMMA relation COMMA AND COMMA temporal CRPAREN
+ | CLPAREN AND AND COMMA relation COMMA OR COMMA temporal CRPAREN
+ | CLPAREN AND AND COMMA relation COMMA AND COMMA temporal CRPAREN
+ | CLPAREN OR OR COMMA relationlist COMMA OR COMMA temporal CRPAREN
+ | CLPAREN OR OR COMMA relationlist COMMA AND COMMA temporal CRPAREN
+ | CLPAREN AND AND COMMA relationlist COMMA OR COMMA temporal CRPAREN
+ | CLPAREN AND AND COMMA relationlist COMMA AND COMMA temporal CRPAREN
+ else:
+ else:
+ self.temporal = t[9]
+ t[0] = t[2]
+ def p_select_relation_operator(self, t):
+ operator : CLPAREN select CRPAREN
+ | CLPAREN select COMMA relation CRPAREN
+ | CLPAREN select COMMA relationlist CRPAREN
+ | CLPAREN select COMMA relation COMMA temporal CRPAREN
+ | CLPAREN select COMMA relationlist COMMA temporal CRPAREN
+ if not self.optype == 'select':
+ else:
+ if len(t) == 4:
+ self.relations = ['equal']
+ elif len(t) == 5:
+ self.temporal = t[3]
+ elif len(t) == 6:
+ if isinstance(t[4], list):
+ self.relations = t[4]
+ else:
+ self.relations = [t[4]]
+ elif len(t) == 8:
+ else:
+ self.temporal = t[6]
+ t[0] = t[2]
+ def p_hash_relation_operator(self, t):
+ operator : CLPAREN HASH CRPAREN
+ | CLPAREN HASH COMMA relation CRPAREN
+ | CLPAREN HASH COMMA relationlist CRPAREN
+ | CLPAREN HASH COMMA relation COMMA temporal CRPAREN
+ | CLPAREN HASH COMMA relationlist COMMA temporal CRPAREN
+ if not self.optype == 'hash':
+ else:
+ if len(t) == 4:
+ elif len(t) == 5:
+ elif len(t) == 6:
+ else:
+ elif len(t) == 8:
+ else:
+ t[0] = t[2]
+ def p_raster_relation_operator(self, t):
+ operator : CLPAREN arithmetic CRPAREN
+ | CLPAREN arithmetic COMMA relation CRPAREN
+ | CLPAREN arithmetic COMMA relationlist CRPAREN
+ | CLPAREN arithmetic COMMA relation COMMA temporal CRPAREN
+ | CLPAREN arithmetic COMMA relationlist COMMA temporal CRPAREN
+ if not self.optype == 'raster':
+ else:
+ if len(t) == 4:
+ elif len(t) == 5:
+ elif len(t) == 6:
+ else:
+ elif len(t) == 8:
+ else:
+ t[0] = t[2]
+ def p_overlay_relation_operator(self, t):
+ operator : CLPAREN overlay CRPAREN
+ | CLPAREN overlay COMMA relation CRPAREN
+ | CLPAREN overlay COMMA relationlist CRPAREN
+ | CLPAREN overlay COMMA relation COMMA temporal CRPAREN
+ | CLPAREN overlay COMMA relationlist COMMA temporal CRPAREN
+ if not self.optype == 'overlay':
+ else:
+ if len(t) == 4:
+ elif len(t) == 5:
+ elif len(t) == 6:
+ else:
+ elif len(t) == 8:
+ else:
+ t[0] = t[2]
+ def p_relation(self, t):
+ # The list of relations.
+ relation : EQUAL
+ | FOLLOWS
+ | PRECEDES
+ | OVERLAPS
+ | OVERLAPPED
+ | DURING
+ | STARTS
+ | FINISHES
+ | CONTAINS
+ | STARTED
+ | FINISHED
+ t[0] = t[1]
+ def p_over(self, t):
+ relation : OVER
+ over_list = ["overlaps", "overlapped"]
+ t[0] = over_list
+ def p_relationlist(self, t):
+ relationlist : relation OR relation
+ | relation OR relationlist
+ rel_list = []
+ rel_list.append(t[1])
+ if isinstance(t[3], list):
+ rel_list = rel_list + t[3]
+ else:
+ rel_list.append(t[3])
+ t[0] = rel_list
+ def p_temporal_operator(self, t):
+ temporal : LEFTREF
+ | RIGHTREF
+ | UNION
+ | DISJOINT
+ | INTERSECT
+ t[0] = t[1]
+ def p_select_operator(self, t):
+ select : T_SELECT
+ | T_NOT_SELECT
+ t[0] = t[1]
+ def p_arithmetic_operator(self, t):
+ arithmetic : MOD
+ | DIV
+ | MULT
+ | ADD
+ | SUB
+ t[0] = t[1]
+ def p_overlay_operator(self, t):
+ overlay : AND
+ | OR
+ | XOR
+ | DISOR
+ | NOT
+ t[0] = t[1]
+if __name__ == "__main__":
+ import doctest
+ doctest.testmod()
Modified: grass/trunk/lib/python/temporal/temporal_raster3d_algebra.py
--- grass/trunk/lib/python/temporal/temporal_raster3d_algebra.py 2014-11-04 15:04:13 UTC (rev 62593)
+++ grass/trunk/lib/python/temporal/temporal_raster3d_algebra.py 2014-11-04 15:45:52 UTC (rev 62594)
@@ -1,6 +1,7 @@
-Temporal 3d raster algebra
+Temporal raster algebra
@@ -10,24 +11,21 @@
+import grass.pygrass.modules as pygrass
from temporal_raster_base_algebra import *
class TemporalRaster3DAlgebraParser(TemporalRasterBaseAlgebraParser):
"""The temporal raster algebra class"""
- def __init__(self, pid=None, run=False, debug=True, spatial=False,
- nprocs=1, register_null=False):
- TemporalRasterBaseAlgebraParser.__init__(self, pid, run, debug,
- spatial, nprocs,
- register_null)
+ def __init__(self, pid=None, run=False, debug=True, spatial = False, nprocs = 1, register_null = False):
+ TemporalRasterBaseAlgebraParser.__init__(self, pid, run, debug, spatial, nprocs, register_null)
self.m_mapcalc = pymod.Module('r3.mapcalc')
- self.m_remove = pymod.Module('g.remove')
+ self.m_mremove = pymod.Module('g.remove')
- def parse(self, expression, basename=None, overwrite=False):
+ def parse(self, expression, basename = None, overwrite=False):
self.lexer = TemporalRasterAlgebraLexer()
self.lexer.build()
self.parser = yacc.yacc(module=self, debug=self.debug)
@@ -35,6 +33,8 @@
self.overwrite = overwrite
self.count = 0
self.stdstype = "str3ds"
+ self.maptype = "rast3d"
+ self.mapclass = Raster3DDataset
self.basename = basename
self.expression = expression
@@ -51,9 +51,9 @@
stringlist = ",".join(chunk)
if self.run:
- m = copy.deepcopy(self.m_remove)
+ m = copy.deepcopy(self.m_mremove)
m.inputs["type"].value = "rast3d"
- m.inputs["name"].value = stringlist
+ m.inputs["names"].value = stringlist
m.flags["f"].value = True
m.run()
@@ -105,24 +105,17 @@
# Get neighboring map and set temporal extent.
map_n = maplist[new_index]
# Generate an intermediate map for the result map list.
- map_new = self.generate_new_map(map_n, bool_op='and',
- copy=True)
+ map_new = self.generate_new_map(map_n, bool_op = 'and', copy = True)
map_new.set_temporal_extent(map_i_t_extent)
# Create r.mapcalc expression string for the operation.
if "cmd_list" in dir(map_new) and len(t) == 5:
- cmdstring = "%s" % (map_new.cmd_list)
+ cmdstring = "%s" %(map_new.cmd_list)
elif "cmd_list" not in dir(map_new) and len(t) == 5:
- cmdstring = "%s" % (map_n.get_id())
- elif "cmd_list" in dir(map_new) and len(t) in (9, 11):
- cmdstring = "%s[%s,%s,%s]" % (map_new.cmd_list,
- row_neighbor,
- col_neighbor,
- depth_neighbor)
- elif "cmd_list" not in dir(map_new) and len(t) in (9, 11):
- cmdstring = "%s[%s,%s,%s]" % (map_n.get_id(),
- row_neighbor,
- col_neighbor,
- depth_neighbor)
+ cmdstring = "%s" %(map_n.get_id())
+ elif "cmd_list" in dir(map_new) and len(t) in (9,11):
+ cmdstring = "%s[%s,%s,%s]" %(map_new.cmd_list, row_neighbor, col_neighbor, depth_neighbor)
+ elif "cmd_list" not in dir(map_new) and len(t) in (9,11):
+ cmdstring = "%s[%s,%s,%s]" %(map_n.get_id(), row_neighbor, col_neighbor, depth_neighbor)
# Set new command list for map.
map_new.cmd_list = cmdstring
# Append map with updated command list to result list.
@@ -135,3 +128,5 @@
import doctest
doctest.testmod()
Modified: grass/trunk/lib/python/temporal/temporal_raster_algebra.py
--- grass/trunk/lib/python/temporal/temporal_raster_algebra.py 2014-11-04 15:04:13 UTC (rev 62593)
+++ grass/trunk/lib/python/temporal/temporal_raster_algebra.py 2014-11-04 15:45:52 UTC (rev 62594)
@@ -1,4 +1,5 @@
@@ -55,20 +56,16 @@
class TemporalRasterAlgebraParser(TemporalRasterBaseAlgebraParser):
- spatial, nprocs,
- register_null)
- self.m_mapcalc = pymod.Module('r.mapcalc', run_=False, finish_=False)
+ self.m_mapcalc = pymod.Module('r.mapcalc')
self.lexer.build()
@@ -76,12 +73,14 @@
self.count = 0
self.stdstype = "strds"
+ self.maptype = "rast"
+ self.mapclass = RasterDataset
def remove_empty_maps(self):
- """! Removes the intermediate vector maps.
+ """! Removes the intermediate raster maps.
if self.empty_maps:
self.msgr.message(_("Removing empty raster maps"))
@@ -92,7 +91,7 @@
if self.run:
m.inputs["type"].value = "rast"
@@ -143,20 +142,17 @@
# Get neighbouring map and set temporal extent.
- copy=True)
elif "cmd_list" in dir(map_new) and len(t) in (7, 9):
- cmdstring = "%s[%s,%s]" % (map_new.cmd_list,
- row_neigbour, col_neigbour)
+ cmdstring = "%s[%s,%s]" %(map_new.cmd_list, row_neigbour, col_neigbour)
elif "cmd_list" not in dir(map_new) and len(t) in (7, 9):
- cmdstring = "%s[%s,%s]" % (map_n.get_id(),
+ cmdstring = "%s[%s,%s]" %(map_n.get_id(), row_neigbour, col_neigbour)
@@ -169,3 +165,5 @@
import doctest
doctest.testmod()
Modified: grass/trunk/lib/python/temporal/temporal_raster_base_algebra.py
--- grass/trunk/lib/python/temporal/temporal_raster_base_algebra.py 2014-11-04 15:04:13 UTC (rev 62593)
+++ grass/trunk/lib/python/temporal/temporal_raster_base_algebra.py 2014-11-04 15:45:52 UTC (rev 62594)
@@ -1,6 +1,7 @@
-Temporal raster algebra base class
+"""@package grass.temporal
@@ -13,94 +14,39 @@
>>> p = TemporalRasterAlgebraLexer()
>>> p.build()
>>> p.debug = True
- >>> expression = 'R = A / B * 20 + C - 2.45'
+ >>> expression = 'R = A {+,equal,l} B '
>>> p.test(expression)
- R = A / B * 20 + C - 2.45
+ R = A {+,equal,l} B
LexToken(NAME,'R',1,0)
LexToken(EQUALS,'=',1,2)
LexToken(NAME,'A',1,4)
- LexToken(DIV,'/',1,6)
- LexToken(NAME,'B',1,8)
- LexToken(MULT,'*',1,10)
- LexToken(INT,20,1,12)
- LexToken(ADD,'+',1,15)
- LexToken(NAME,'C',1,17)
- LexToken(SUB,'-',1,19)
- LexToken(FLOAT,2.45,1,21)
- >>> expression = 'R = A {equal,|/} B'
+ LexToken(T_ARITH2_OPERATOR,'{+,equal,l}',1,6)
+ LexToken(NAME,'B',1,18)
+ >>> expression = 'R = A {*,equal|during,r} B '
>>> p.test(expression)
- R = A {equal,|/} B
+ R = A {*,equal|during,r} B
- LexToken(T_ARITH1_OPERATOR,'{equal,|/}',1,6)
- LexToken(NAME,'B',1,17)
- >>> expression = 'R = A {equal,||} B'
+ LexToken(T_ARITH1_OPERATOR,'{*,equal|during,r}',1,6)
+ LexToken(NAME,'B',1,25)
+ >>> expression = 'R = A {+,equal|during} B '
>>> p.test(expression)
- R = A {equal,||} B
+ R = A {+,equal|during} B
- LexToken(T_COMP_OPERATOR,'{equal,||}',1,6)
- >>> expression = 'R = A {equal,&&} B'
- >>> p.test(expression)
- R = A {equal,&&} B
- LexToken(NAME,'R',1,0)
- LexToken(EQUALS,'=',1,2)
- LexToken(NAME,'A',1,4)
- LexToken(T_COMP_OPERATOR,'{equal,&&}',1,6)
- >>> expression = 'R = A {equal | during,+*} B'
- R = A {equal | during,+*} B
- LexToken(T_ARITH1_OPERATOR,'{equal | during,+*}',1,6)
- LexToken(NAME,'B',1,26)
- >>> expression = 'R = A {equal | during,+:} B'
- R = A {equal | during,+:} B
- LexToken(T_SELECT_OPERATOR,'{equal | during,+:}',1,6)
- >>> expression = 'R = abs(A) {equal,+:} exp(B) / sqrt(C) - log(D)'
- R = abs(A) {equal,+:} exp(B) / sqrt(C) - log(D)
- LexToken(ABS,'abs',1,4)
- LexToken(LPAREN,'(',1,7)
- LexToken(NAME,'A',1,8)
- LexToken(RPAREN,')',1,9)
- LexToken(T_SELECT_OPERATOR,'{equal,+:}',1,11)
- LexToken(EXP,'exp',1,22)
- LexToken(LPAREN,'(',1,25)
- LexToken(RPAREN,')',1,27)
- LexToken(DIV,'/',1,29)
- LexToken(SQRT,'sqrt',1,31)
- LexToken(LPAREN,'(',1,35)
- LexToken(NAME,'C',1,36)
- LexToken(RPAREN,')',1,37)
- LexToken(SUB,'-',1,39)
- LexToken(LOG,'log',1,41)
- LexToken(LPAREN,'(',1,44)
- LexToken(NAME,'D',1,45)
- LexToken(RPAREN,')',1,46)
+ LexToken(T_ARITH2_OPERATOR,'{+,equal|during}',1,6)
+ LexToken(NAME,'B',1,23)
import grass.pygrass.modules as pymod
-from temporal_raster_operator import *
+from temporal_operator import *
from temporal_algebra import *
class TemporalRasterAlgebraLexer(TemporalAlgebraLexer):
"""Lexical analyzer for the GRASS GIS temporal algebra"""
@@ -109,24 +55,27 @@
# Supported r.mapcalc functions.
mapcalc_functions = {
- 'exp': 'EXP',
- 'log': 'LOG',
- 'sqrt': 'SQRT',
- 'abs': 'ABS',
- 'cos': 'COS',
- 'acos': 'ACOS',
- 'sin': 'SIN',
- 'asin': 'ASIN',
- 'tan': 'TAN',
- 'double': 'DOUBLE',
- 'float': 'FLOATEXP',
- 'int': 'INTEXP',
- 'isnull': 'ISNULL',
+ 'exp' : 'EXP',
+ 'log' : 'LOG',
+ 'sqrt' : 'SQRT',
+ 'abs' : 'ABS',
+ 'cos' : 'COS',
+ 'acos' : 'ACOS',
+ 'sin' : 'SIN',
+ 'asin' : 'ASIN',
+ 'tan' : 'TAN',
+ 'double' : 'DOUBLE',
+ 'float' : 'FLOATEXP',
+ 'int' : 'INTEXP',
+ 'isnull' : 'ISNULL',
'isntnull': 'ISNTNULL',
- 'null': 'NULL',
- 'exist': 'EXIST',
+ 'null' : 'NULL',
+ 'exist' : 'EXIST',
+ # Functions that defines single maps with time stamp and without temporal extent.
+ map_functions = {'map' : 'MAP'}
raster_tokens = (
'MOD',
@@ -141,19 +90,21 @@
- tokens = TemporalAlgebraLexer.tokens + raster_tokens \
- + tuple(mapcalc_functions.values())
+ tokens = TemporalAlgebraLexer.tokens \
+ + raster_tokens \
+ + tuple(mapcalc_functions.values()) \
+ + tuple(map_functions.values())
- t_MOD = r'[\%]'
- t_DIV = r'[\/]'
- t_MULT = r'[\*]'
- t_ADD = r'[\+]'
- t_SUB = r'[-]'
- t_T_ARITH1_OPERATOR = r'\{([a-zA-Z\| ]+[,])?([\|&+=]?[\%\*\/])\}'
- t_T_ARITH2_OPERATOR = r'\{([a-zA-Z\| ]+[,])?([\|&+=]?[+-])\}'
- t_L_SPAREN = r'\['
- t_R_SPAREN = r'\]'
+ t_MOD = r'[\%]'
+ t_DIV = r'[\/]'
+ t_MULT = r'[\*]'
+ t_ADD = r'[\+]'
+ t_SUB = r'[-]'
+ t_T_ARITH1_OPERATOR = r'\{[\%\*\/][,]?[a-zA-Z\| ]*([,])?([lrudi]|left|right|union|disjoint|intersect)?\}'
+ t_T_ARITH2_OPERATOR = r'\{[+-][,]?[a-zA-Z\| ]*([,])?([lrudi]|left|right|union|disjoint|intersect)?\}'
+ t_L_SPAREN = r'\['
+ t_R_SPAREN = r'\]'
# Parse symbols
@@ -166,14 +117,14 @@
t.type = TemporalRasterAlgebraLexer.conditional_functions.get(t.value)
elif t.value in TemporalRasterAlgebraLexer.mapcalc_functions.keys():
t.type = TemporalRasterAlgebraLexer.mapcalc_functions.get(t.value)
+ elif t.value in TemporalRasterAlgebraLexer.map_functions.keys():
+ t.type = TemporalRasterAlgebraLexer.map_functions.get(t.value)
else:
t.type = 'NAME'
return t
class TemporalRasterBaseAlgebraParser(TemporalAlgebraParser):
"""The temporal algebra class"""
@@ -182,13 +133,13 @@
# Setting equal precedence level for select and hash operations.
precedence = (
- ('left', 'T_SELECT_OPERATOR', 'T_SELECT', 'T_NOT_SELECT'), # 1
- ('left', 'ADD', 'SUB', 'T_ARITH2_OPERATOR'), #2
+ ('left', 'T_SELECT_OPERATOR', 'T_SELECT', 'T_NOT_SELECT'), # 1
+ ('left', 'ADD', 'SUB', 'T_ARITH2_OPERATOR'), #2
('left', 'AND', 'OR', 'T_COMP_OPERATOR', 'MOD', 'DIV', 'MULT',
'T_ARITH1_OPERATOR'))
- def __init__(self, pid=None, run=True, debug=False, spatial=False,
+ def __init__(self, pid=None, run = True, debug = False, spatial = False, \
+ nprocs = 1, register_null = False):
TemporalAlgebraParser.__init__(self, pid, run, debug, spatial)
self.nprocs = nprocs
self.empty_maps = {}
@@ -202,73 +153,384 @@
return "null()"
######################### Temporal functions ##############################
+ def get_temporal_topo_list(self, maplistA, maplistB = None, topolist = ["EQUAL"],
+ assign_val = False, count_map = False, compare_bool = False,
+ compare_cmd = False, compop = None, aggregate = None,
+ new = False, convert = False, operator_cmd = False):
+ """Build temporal topology for two space time data sets, copy map objects
+ for given relation into map list.
+ :param maplistA: List of maps.
+ :param topolist: List of strings of temporal relations.
+ :param assign_val: Boolean for assigning a boolean map value based on
+ the map_values from the compared map list by
+ topological relationships.
+ :param count_map: Boolean if the number of topological related maps
+ should be returned.
+ :param compare_bool: Boolean for comparing boolean map values based on
+ related map list and compariosn operator.
+ :param compare_cmd: Boolean for comparing command list values based on
+ :param compop: Comparison operator, && or ||.
+ :param aggregate: Aggregation operator for relation map list, & or |.
+ :param new: Boolean if new temporary maps should be created.
+ :param convert: Boolean if conditional values should be converted to
+ r.mapcalc command strings.
+ :param operator_cmd: Boolean for aggregate arithmetic operators implicitly
+ in command list values based on related map lists.
+ :return: List of maps from maplistA that fulfil the topological relationships
+ to maplistB specified in topolist.
+ topologylist = ["EQUAL", "FOLLOWS", "PRECEDES", "OVERLAPS", "OVERLAPPED", \
+ "DURING", "STARTS", "FINISHES", "CONTAINS", "STARTED", \
+ "FINISHED"]
+ complementdict = {"EQUAL": "EQUAL", "FOLLOWS" : "PRECEDES",
+ "PRECEDES" : "FOLLOWS", "OVERLAPS" : "OVERLAPPED",
+ "OVERLAPPED" : "OVERLAPS", "DURING" : "CONTAINS",
+ "CONTAINS" : "DURING", "STARTS" : "STARTED",
+ "STARTED" : "STARTS", "FINISHES" : "FINISHED",
+ "FINISHED" : "FINISHES"}
+ resultdict = {}
+ # Check if given temporal relation are valid.
+ for topo in topolist:
+ if topo.upper() not in topologylist:
+ raise SyntaxError("Unpermitted temporal relation name '" + topo + "'")
- def eval_toperator(self, operator, comparison=False):
- """This function evaluates a string containing temporal operations.
+ # Create temporal topology for maplistA to maplistB.
+ tb = SpatioTemporalTopologyBuilder()
+ # Dictionary with different spatial variables used for topology builder.
+ spatialdict = {'strds' : '2D', 'stvds' : '2D', 'str3ds' : '3D'}
+ # Build spatial temporal topology
+ if self.spatial:
+ tb.build(maplistA, maplistB, spatial = spatialdict[self.stdstype])
+ else:
+ tb.build(maplistA, maplistB)
+ # Iterate through maps in maplistA and search for relationships given
+ # in topolist.
+ for map_i in maplistA:
+ tbrelations = map_i.get_temporal_relations()
+ # Check for boolean parameters for further calculations.
+ if assign_val:
+ self.assign_bool_value(map_i, tbrelations, topolist)
+ elif compare_bool:
+ self.compare_bool_value(map_i, tbrelations, compop, aggregate, topolist)
+ elif compare_cmd:
+ self.compare_cmd_value(map_i, tbrelations, compop, aggregate, topolist, convert)
+ elif operator_cmd:
+ self.operator_cmd_value(map_i, tbrelations, compop, topolist)
+ if topo.upper() in tbrelations.keys():
+ if count_map:
+ relationmaplist = tbrelations[topo.upper()]
+ gvar = GlobalTemporalVar()
+ gvar.td = len(relationmaplist)
+ if "map_value" in dir(map_i):
+ map_i.map_value.append(gvar)
+ else:
+ map_i.map_value = gvar
+ resultlist = resultdict.values()
+ # Sort list of maps chronological.
+ resultlist = sorted(resultlist, key = AbstractDatasetComparisonKeyStartTime)
+ return(resultlist)
+ def build_command_string(self, map_i, relmap, operator = None, cmd_type = None):
+ """This function build the r.mapcalc command string for conditionals,
+ spatial variable combinations and boolean comparisons.
+ For Example: 'if(a1 == 1, b1, c2)' or 'exist(a1) && sin(b1)'
+ :param map_i: map object with temporal extent and built relations.
+ :param relmap: map object with defined temporal relation to map_i.
+ :param operator: String representing operator between two spatial variables
+ :param cmd_type: map object with defined temporal relation to map_i:
+ condition, conclusion or operator.
+ :return: the resulting command string for conditionals or spatial variable
+ combinations
+ def sub_cmdstring(map_i):
+ """This function search for command string in a map object and
+ return substitute string (contained commandstring or map name)"""
+ if "cmd_list" in dir(map_i):
+ map_sub = map_i.cmd_list
+ elif "map_value" in dir(map_i) and len(map_i.map_value) > 0 and map_i.map_value[0].get_type() == "timediff":
+ map_sub = map_i.map_value[0].get_type_value()[0]
+ else:
+ try:
+ map_sub = map_i.get_id()
+ except:
+ map_sub = map_i
+ return(map_sub)
+ # Check for type of operation, conditional or spatial variable combination
+ # and Create r.mapcalc expression string for the operation.
+ cmdstring = ""
+ if cmd_type == 'condition':
+ conditionsub = sub_cmdstring(map_i)
+ conclusionsub = sub_cmdstring(relmap)
+ cmdstring = "if(%s, %s)" %(conditionsub, conclusionsub)
+ elif cmd_type == 'conclusion':
+ thensub = sub_cmdstring(map_i)
+ elsesub = sub_cmdstring(relmap)
+ cmdstring = "%s, %s" %(thensub, elsesub)
+ elif cmd_type == 'operator':
+ leftsub = sub_cmdstring(map_i)
+ rightsub = sub_cmdstring(relmap)
+ if operator == None:
+ self.msgr.fatal("Error: Can't build command string for map %s, operator is missing" \
+ %(map_i.get_map_id()))
+ cmdstring = "(%s %s %s)" %(leftsub, operator, rightsub)
+ return(cmdstring)
- :param operator: String of temporal operations, e.g. {equal|during,=!:}.
+ def compare_cmd_value(self, map_i, tbrelations, compop, aggregate,
+ topolist = ["EQUAL"], convert = False):
+ """ Function to evaluate two map lists with boolean values by boolean
+ comparison operator. Extended temporal algebra version with command
+ list builder for temporal raster algebra.
+ :param map_i: Map object with temporal extent.
+ :param tbrelations: List of temporal relation to map_i.
+ :param topolist: List of strings for given temporal relations.
- :return: List of temporal relations (equal, during), the given
- function (!:) and the interval/instances (=).
+ :return: Map object with conditional value that has been evaluated by
+ comparison operators.
+ # Build comandlist list with elements from related maps and given relation operator.
+ if convert and "condition_value" in dir(map_i):
+ if map_i.condition_value != []:
+ cmdstring = str(int(map_i.condition_value[0]))
+ map_i.cmd_list = cmdstring
+ leftcmd = map_i.cmd_list
+ cmd_value_list = [leftcmd]
+ count = 0
+ if count == 0 and "cmd_list" in dir(map_i):
+ cmd_value_list.append(compop)
+ cmd_value_list.append('(')
+ for relationmap in relationmaplist:
+ if convert and "condition_value" in dir(relationmap):
+ if relationmap.condition_value != []:
+ cmdstring = str(int(relationmap.condition_value[0]))
+ relationmap.cmd_list = cmdstring
+ if "cmd_list" in dir(relationmap):
+ if count > 0:
+ cmd_value_list.append(aggregate + aggregate)
+ cmd_value_list.append(relationmap.cmd_list)
+ count = count + 1
+ if count > 0:
+ cmd_value_list.append(')')
+ cmd_value_str = ''.join(map(str, cmd_value_list))
+ # Add command list to result map.
+ map_i.cmd_list = cmd_value_str
+ return(cmd_value_str)
- .. code-block:: python
+ def operator_cmd_value(self, map_i, tbrelations, operator, topolist = ["EQUAL"]):
+ """ Function to evaluate two map lists by given arithmetic operator.
+ :param operator: Arithmetic operator, +-*/%.
- >>> init(True)
- >>> p = TemporalRasterBaseAlgebraParser()
- >>> operator = "{equal,:}"
- >>> p.eval_toperator(operator)
- (['EQUAL'], '=', ':')
- >>> operator = "{equal|during,:}"
- (['EQUAL', 'DURING'], '=', ':')
- >>> operator = "{equal,!:}"
- (['EQUAL'], '=', '!:')
- >>> operator = "{equal|during,!:}"
- (['EQUAL', 'DURING'], '=', '!:')
- >>> operator = "{equal|during,=!:}"
- >>> operator = "{equal|during|starts,#}"
- (['EQUAL', 'DURING', 'STARTS'], '=', '#')
- >>> operator = "{!:}"
- >>> operator = "{=:}"
- >>> operator = "{#}"
- (['EQUAL'], '=', '#')
- >>> operator = "{equal|during}"
- (['EQUAL', 'DURING'], None, None)
- >>> operator = "{equal}"
- (['EQUAL'], None, None)
- >>> operator = "{equal,||}"
- >>> p.eval_toperator(operator, True)
- (['EQUAL'], '=', '||')
- >>> operator = "{equal|during,&&}"
- (['EQUAL', 'DURING'], '=', '&&')
+ :return: Map object with command list with operators that has been
+ evaluated by implicit aggregration.
+ leftcmd = map_i
+ cmdstring = ""
+ # Create r.mapcalc expression string for the operation.
+ cmdstring = self.build_command_string(leftcmd,
+ relationmap,
+ operator = operator,
+ cmd_type = "operator")
+ leftcmd = cmdstring
+ return(cmdstring)
+ def set_temporal_extent_list(self, maplist, topolist = ["EQUAL"], temporal = 'l' ,
+ cmd_bool = False, cmd_type = None, operator = None):
+ """ Change temporal extent of map list based on temporal relations to
+ other map list and given temporal operator.
+ :param maplist: List of map objects for which relations has been build
+ correctely.
+ :param temporal: The temporal operator specifying the temporal
+ extent operation (intersection, union, disjoint
+ union, right reference, left reference).
+ :param cmd_bool: Boolean if command string should be merged for related maps.
+ :param operator: String defining the type of operator.
+ :return: Map list with specified temporal extent and optional command string.
- p = TemporalRasterOperatorParser()
- p.parse(operator, comparison)
- p.relations = [rel.upper() for rel in p.relations]
+ resultdict = {}
+ for map_i in maplist:
+ # Loop over temporal related maps and create overlay modules.
+ # Generate an intermediate map for the result map list.
+ map_new = self.generate_new_map(base_map=map_i, bool_op = 'and',
+ copy = True, rename = True)
+ # Combine temporal and spatial extents of intermediate map with related maps.
+ if topo in tbrelations.keys():
+ for map_j in (tbrelations[topo]):
+ if temporal == 'r':
+ # Create overlayed map extent.
+ returncode = self.overlay_map_extent(map_new, map_j, 'and', \
+ temp_op = temporal)
+ # Stop the loop if no temporal or spatial relationship exist.
+ if returncode == 0:
+ break
+ # Append map to result map list.
+ elif returncode == 1:
+ # print(map_new.cmd_list)
+ # resultlist.append(map_new)
+ if cmd_bool:
+ cmdstring = self.build_command_string(map_i,
+ map_j,
+ cmd_type = cmd_type)
+ # Conditional append of module command.
+ map_new.cmd_list = cmdstring
+ # Write map object to result dictionary.
+ resultdict[map_new.get_id()] = map_new
+ break
+ #if returncode == 1:
+ # Get sorted map objects as values from result dictionoary.
+ def build_condition_cmd_list(self, iflist, thenlist, elselist = None,
+ condition_topolist = ["EQUAL"],
+ conclusion_topolist = ["EQUAL"],
+ temporal = 'l', null = False):
+ """This function build the r.mapcalc command strings for spatial conditionals.
- return(p.relations, p.temporal, p.function)
+ :param iflist: Map list with temporal extents and command list.
+ :param thenlist: Map list with temporal extents and command list or numeric string.
+ :param elselist: Map list with temporal extents and command list or numeric string.
+ :param condition_topolist: List of strings for given temporal relations between
+ conditions and conclusions.
+ :param conclusion_topolist: List of strings for given temporal relations between
+ conditions (then and else).
+ :param null: Boolean if null map support should be activated.
+ :return: map list with resulting command string for given condition type.
+ resultlist = []
+ # First merge conclusion command maplists or strings.
+ # Check if alternative conclusion map list is given.
+ if all([isinstance(thenlist, list), isinstance(elselist, list)]):
+ # Build conclusion command map list.
+ conclusiontopolist = self.get_temporal_topo_list(thenlist, elselist, conclusion_topolist)
+ conclusionlist = self.set_temporal_extent_list(conclusiontopolist,
+ topolist = conclusion_topolist,
+ temporal = temporal ,
+ cmd_bool = True,
+ cmd_type = "conclusion")
+ # Check if any conclusion is a numeric statements.
+ elif any([isinstance(thenlist, str), isinstance(elselist, str)]):
+ conclusionlist = []
+ # Check if only alternative conclusion is a numeric statements.
+ if all([isinstance(thenlist, list), isinstance(elselist, str)]):
+ listinput = thenlist
+ numinput = elselist
+ for map_i in listinput:
+ cmdstring = self.build_command_string( map_i,
+ numinput,
+ cmd_type = 'conclusion')
+ conclusionlist.append(map_i)
+ # Check if only direct conclusion is a numeric statements.
+ elif all([isinstance(thenlist, str), isinstance(elselist, list)]):
+ listinput = elselist
+ numinput = thenlist
+ cmdstring = self.build_command_string(numinput,
+ map_i,
+ elif all([isinstance(thenlist, str), isinstance(elselist, str)]):
+ conclusionlist = thenlist + ',' + elselist
+ else:
+ # The direct conclusion is used.
+ # Use the conclusion map or string to merge it with the condition and
+ # return maplist.
+ if isinstance(conclusionlist, str):
+ resultlist = []
+ for map_i in iflist:
+ conclusionlist,
+ cmd_type = 'condition')
+ resultlist.append(map_i)
+ elif isinstance(conclusionlist, list):
+ # Build result command map list between conditions and conclusions.
+ conditiontopolist = self.get_temporal_topo_list(iflist, conclusionlist,
+ topolist = condition_topolist)
+ resultlist = self.set_temporal_extent_list(conditiontopolist,
+ topolist = condition_topolist,
+ temporal = 'r' ,
+ cmd_bool = True,
+ cmd_type = "condition")
def p_statement_assign(self, t):
statement : stds EQUALS expr
if self.run:
# Create the process queue for parallel mapcalc processing
@@ -276,20 +538,19 @@
num = len(t[3])
count = 0
+ returncode = 0
register_list = []
for i in range(num):
rastername = self.basename + "_" + str(i) + "@" + self.mapset
rastermap = RasterDataset(rastername)
- if rastermap.map_exists() and self.overwrite is False:
- self.msgr.fatal("Error raster maps with basename %s "
- "exist. Use --o flag to overwrite "
- "existing file" % (rastername))
+ if rastermap.map_exists() and self.overwrite == False:
+ %(rastername))
map_test_list = []
for map_i in t[3]:
- print(newident + ' = ' + map_i.cmd_list)
# Build r.mapcalc module and execute expression.
# Change map name to given basename.
# Create deepcopy of r.mapcalc module.
@@ -304,31 +565,39 @@
m.inputs["expression"].value = str(m_expression)
+ elif map_i.map_exists():
+ map_test = map_i.get_new_instance(newident + "@" + self.mapset)
+ map_test.set_temporal_extent(map_i.get_temporal_extent())
+ map_test.set_spatial_extent(map_i.get_spatial_extent())
+ map_test_list.append(map_test)
+ m = copy.deepcopy(self.m_mapcalc)
+ m_expression = newident + "=" + map_i.get_map_id()
+ m.inputs["expression"].value = str(m_expression)
else:
- map_i.set_id(newident + "@" + self.mapset)
- map_test_list.append(map_i)
- count += 1
+ self.msgr.error(_("Error computing map <%s>"%(map_i.get_id()) ))
+ count += 1
for map_i in map_test_list:
- if not map_test.map_exists():
- self.msgr.error(_("Error computing map <%s>" %
- (map_i.get_id())))
- else:
- register_list.append(map_i)
- resultstds = open_new_stds(t[1], self.stdstype, 'absolute',
- t[1], t[1], 'mean', self.dbif,
map_i.load()
@@ -339,12 +608,10 @@
- elif map_i.is_in_db(dbif) and self.overwrite is False:
- self.msgr.fatal("Error vector map %s exist in temporal"
- " database. Use overwrite flag. : "
- "\n%s" % (map_i.get_map_id(),
- cmd.popen.stderr))
+ self.msgr.fatal("Error raster map %s exist in temporal database. Use overwrite flag. : \n%s" \
else:
map_i.insert(dbif)
@@ -355,7 +622,45 @@
t[0] = register_list
self.remove_empty_maps()
+ def p_expr_spmap_function(self, t):
+ # Examples:
+ # R = map(A)
+ mapexpr : MAP LPAREN stds RPAREN
+ if self.run:
+ input = t[3]
+ id_input = input
+ else:
+ else:
+ # Create command list for map object.
+ cmdstring = "(%s)" %(map_i.get_map_id())
+ t[0] = cmdstring
+ else:
+ t[0] = "map(" + t[3] + ")"
+ if self.debug:
+ print "map(" + t[3] + ")"
def p_arith1_operation(self, t):
expr : stds MOD stds
@@ -380,23 +685,21 @@
# Check input stds.
topolist = self.get_temporal_topo_list(maplistA, maplistB)
if self.run:
resultlist = []
for map_i in topolist:
- map_new = self.generate_new_map(base_map=map_i, bool_op='and',
- copy=True)
- # Set first input for overlay module.
- mapainput = map_i.get_id()
+ map_new = self.generate_new_map(base_map=map_i, bool_op = 'and', copy = True)
count = 0
for map_j in (tbrelations['EQUAL']):
- returncode = self.overlay_map_extent(map_new, map_j, 'and',
- temp_op='=')
+ temp_op = 'l')
if returncode == 0:
break
@@ -407,28 +710,12 @@
name = self.generate_map_name()
- if "map_value" in dir(map_j) and len(map_j.map_value) > 0 and map_j.map_value[0].get_type() == "timediff":
- mapbinput = map_j.map_value[0].get_type_value()[0]
- else:
- mapbinput = map_j.get_id()
- if "cmd_list" in dir(map_new) and "cmd_list" not in dir(map_j):
- cmdstring = "(%s %s %s)" % (map_new.cmd_list, t[2],
- mapbinput)
- elif "cmd_list" in dir(map_j) and "cmd_list" not in dir(map_new):
- cmdstring = "(%s %s %s)" % (mapainput, t[2],
- map_j.cmd_list)
- elif "cmd_list" in dir(map_j) and "cmd_list" in dir(map_new):
- map_j.cmd_list)
- else:
- cmdstring = "(%s %s %s)" % (mapainput, t[2], mapbinput)
+ cmdstring = self.build_command_string(map_i, map_j,
+ operator = t[2],
- # Set new map name to temporary map name.
- mapainput = name
count += 1
if returncode == 1:
@@ -443,11 +730,23 @@
def p_arith1_operation_numeric1(self, t):
expr : stds MOD number
- | expr MOD number
- | stds DIV number
- | expr DIV number
- | stds MULT number
- | expr MULT number
+ | expr MOD number
+ | stds DIV number
+ | expr DIV number
+ | stds MULT number
+ | expr MULT number
+ | stds MOD numberstr
+ | expr MOD numberstr
+ | stds DIV numberstr
+ | expr DIV numberstr
+ | stds MULT numberstr
+ | expr MULT numberstr
+ | stds MOD mapexpr
+ | expr MOD mapexpr
+ | stds DIV mapexpr
+ | expr DIV mapexpr
+ | stds MULT mapexpr
+ | expr MULT mapexpr
# Check input stds.
@@ -458,9 +757,9 @@
mapinput = map_i.get_id()
- cmdstring = "(%s %s %s)" % (map_i.cmd_list, t[2], t[3])
+ cmdstring = "(%s %s %s)" %(map_i.cmd_list, t[2], t[3])
else:
- cmdstring = "(%s %s %s)" % (mapinput, t[2], t[3])
+ cmdstring = "(%s %s %s)" %(mapinput, t[2], t[3])
@@ -472,14 +771,27 @@
for map in resultlist:
print map.cmd_list
def p_arith1_operation_numeric2(self, t):
expr : number MOD stds
- | number MOD expr
- | number DIV stds
- | number DIV expr
- | number MULT stds
- | number MULT expr
+ | number MOD expr
+ | number DIV stds
+ | number DIV expr
+ | number MULT stds
+ | number MULT expr
+ | numberstr MOD stds
+ | numberstr MOD expr
+ | numberstr DIV stds
+ | numberstr DIV expr
+ | numberstr MULT stds
+ | numberstr MULT expr
+ | mapexpr MOD stds
+ | mapexpr MOD expr
+ | mapexpr DIV stds
+ | mapexpr DIV expr
+ | mapexpr MULT stds
+ | mapexpr MULT expr
# Check input stds.
@@ -490,9 +802,9 @@
- cmdstring = "(%s %s %s)" % (t[1], t[2], map_i.cmd_list)
+ cmdstring = "(%s %s %s)" %(t[1], t[2], map_i.cmd_list)
else:
- cmdstring = "(%s %s %s)" % (t[1], t[2], mapinput)
+ cmdstring = "(%s %s %s)" %(t[1], t[2], mapinput)
@@ -504,6 +816,7 @@
print map.cmd_list
def p_arith2_operation(self, t):
expr : stds ADD stds
@@ -529,17 +842,15 @@
resultlist = []
- copy=True)
count = 0
- temp_op='=')
+ temp_op = 'l')
if returncode == 0:
break
@@ -549,29 +860,13 @@
else:
- else:
- mapbinput)
- map_j.cmd_list)
- map_j.cmd_list)
- else:
+ operator = t[2],
- mapainput = name
count += 1
@@ -587,9 +882,17 @@
def p_arith2_operation_numeric1(self, t):
expr : stds ADD number
- | expr ADD number
- | stds SUB number
- | expr SUB number
+ | expr ADD number
+ | stds SUB number
+ | expr SUB number
+ | stds ADD numberstr
+ | expr ADD numberstr
+ | stds SUB numberstr
+ | expr SUB numberstr
+ | stds ADD mapexpr
+ | expr ADD mapexpr
+ | stds SUB mapexpr
+ | expr SUB mapexpr
# Check input stds.
@@ -600,9 +903,9 @@
else:
@@ -617,9 +920,17 @@
def p_arith2_operation_numeric2(self, t):
expr : number ADD stds
- | number ADD expr
- | number SUB stds
- | number SUB expr
+ | number ADD expr
+ | number SUB stds
+ | number SUB expr
+ | numberstr ADD stds
+ | numberstr ADD expr
+ | numberstr SUB stds
+ | numberstr SUB expr
+ | mapexpr ADD stds
+ | mapexpr ADD expr
+ | mapexpr SUB stds
+ | mapexpr SUB expr
# Check input stds.
@@ -630,9 +941,9 @@
else:
@@ -653,85 +964,20 @@
| stds T_ARITH1_OPERATOR t_td_var
| expr T_ARITH1_OPERATOR t_td_var
- # Check input stds.
- relations, temporal, function = self.eval_toperator(t[2])
- topolist = self.get_temporal_topo_list(maplistA, maplistB,
- topolist=relations)
+ if self.run:
+ # Check input stds.
+ relations, temporal, function, aggregate = self.eval_toperator(t[2], optype = 'raster')
+ complist = self.get_temporal_topo_list(maplistA, maplistB, topolist = relations,
+ operator_cmd = True, compop = function)
+ t[0] = resultlist
- if self.run:
- resultlist = []
- for map_i in topolist:
- # Generate an intermediate map for the result map list.
- copy=True)
- # Loop over temporal related maps and create overlay modules.
- tbrelations = map_i.get_temporal_relations()
- count = 0
- for topo in relations:
- if topo in tbrelations.keys():
- for map_j in (tbrelations[topo]):
- # Create overlayed map extent.
- map_j, 'and',
- temp_op=temporal)
- print(returncode)
- # Stop the loop if no temporal or spatial
- # relationship exist.
- if returncode == 0:
- break
- if count == 0:
- # Set map name.
- name = map_new.get_id()
- else:
- name = self.generate_map_name()
- map_new.set_id(name + "@" + mapset)
- # Set second input for overlay module.
- else:
- # Create r.mapcalc expression string for the operation.
- if "cmd_list" in dir(map_new):
- function,
- mapbinput)
- print('with cmd in a: ' + map_j.get_id())
- elif "cmd_list" in dir(map_j):
- function,
- map_j.cmd_list)
- print('with cmd in b')
- function,
- map_j.cmd_list)
- else:
- function,
- mapbinput)
- print(cmdstring)
- # Conditional append of module command.
- map_new.cmd_list = cmdstring
- mapainput = name
- count += 1
- break
- # Append map to result map list.
- if returncode == 1:
- resultlist.append(map_new)
- t[0] = resultlist
if self.debug:
print map.cmd_list
@@ -745,84 +991,39 @@
| stds T_ARITH2_OPERATOR t_td_var
| expr T_ARITH2_OPERATOR t_td_var
- if self.run:
- resultlist = []
- copy=True)
- count = 0
- map_j, 'and',
- temp_op=temporal)
- break
- if count == 0:
- # Set map name.
- else:
- map_new.set_id(name + "@" + self.mapset)
- else:
- function,
- mapbinput)
- function,
- map_j.cmd_list)
- function,
- map_j.cmd_list)
- else:
- function,
- mapbinput)
- mapainput = name
- count += 1
- break
- t[0] = resultlist
+ if self.run:
+ t[0] = resultlist
if self.debug:
print map.cmd_list
+ def p_arith_operation_numeric_string(self, t):
+ numberstr : number ADD number
+ | number SUB number
+ | number DIV number
+ | number MULT number
+ | number MOD number
+ numstring = "(%s %s %s)" %(t[1], t[2], t[3])
+ t[0] = numstring
+ if self.debug:
+ print(numstring)
def p_mapcalc_function(self, t):
# Supported mapcalc functions.
@@ -845,7 +1046,8 @@
print map.cmd_list
- def p_mapcalc_operation(self, t):
+ def p_mapcalc_operation1(self, t):
# Examples:
# sin(A)
# log(B)
@@ -861,9 +1063,9 @@
- cmdstring = "%s(%s)" % (t[1].lower(), map_i.cmd_list)
+ cmdstring = "%s(%s)" %(t[1].lower(), map_i.cmd_list)
else:
- cmdstring = "%s(%s)" % (t[1].lower(), map_i.get_id())
+ cmdstring = "%s(%s)" %(t[1].lower(), map_i.get_id())
@@ -875,8 +1077,25 @@
print map.cmd_list
- def p_s_var_expr(self, t):
+ def p_mapexpr_operation(self, t):
# Examples:
+ # sin(map(a))
+ mapexpr : mapcalc_arith LPAREN mapexpr RPAREN
+ mapstring = t[3]
+ if self.run:
+ cmdstring = "%s(%s)" %(t[1].lower(), mapstring)
+ t[0] = cmdstring
+ if self.debug:
+ print mapstring
+ def p_s_var_expr_1(self, t):
+ # Examples:
# isnull(A)
s_var_expr : ISNULL LPAREN stds RPAREN
@@ -890,9 +1109,9 @@
else:
@@ -904,7 +1123,7 @@
print map.cmd_list
- def p_s_var_expr_1(self, t):
+ def p_s_var_expr_2(self, t):
# Examples:
# isntnull(A)
@@ -919,9 +1138,9 @@
- cmdstring = "!isnull(%s)" % (map_i.cmd_list)
+ cmdstring = "!isnull(%s)" %(map_i.cmd_list)
else:
- cmdstring = "!isnull(%s)" % (map_i.get_id())
+ cmdstring = "!isnull(%s)" %(map_i.get_id())
@@ -933,7 +1152,7 @@
print map.cmd_list
- def p_s_var_expr2(self, t):
+ def p_s_var_expr_3(self, t):
# Examples:
# A <= 2
@@ -948,9 +1167,9 @@
- cmdstring = "%s %s %s" % (map_i.cmd_list, t[2], t[3])
+ cmdstring = "%s %s %s" %(map_i.cmd_list, t[2], t[3])
else:
- cmdstring = "%s %s %s" % (map_i.get_id(), t[2], t[3])
+ cmdstring = "%s %s %s" %(map_i.get_id(), t[2], t[3])
@@ -962,75 +1181,8 @@
print map.cmd_list
- def p_s_var_expr3(self, t):
+ def p_s_var_expr_4(self, t):
# Examples:
- # A <= 2 || B == 10
- # A < 3 && A > 1
- s_var_expr : s_var_expr AND AND s_var_expr
- | s_var_expr OR OR s_var_expr
- maplistB = self.check_stds(t[4])
- topolist = self.get_temporal_topo_list(maplistA, maplistB)
- if self.run:
- resultlist = []
- count = 0
- for map_j in (tbrelations['EQUAL']):
- bool_op='and', copy=True)
- temp_op='=')
- # Stop the loop if no temporal or spatial relationship exist.
- break
- if count == 0:
- # Set map name.
- else:
- cmdstring = "%s %s %s" % (map_new.cmd_list,
- t[2] + t[3], mapbinput)
- cmdstring = "%s %s %s" % (mapainput, t[2] + t[3],
- map_j.cmd_list)
- t[2] + t[3], map_j.cmd_list)
- else:
- mapbinput)
- #mapainput = name
- count += 1
- t[0] = resultlist
- if self.debug:
- for map in resultlist:
- print map.cmd_list
- def p_s_var_expr4(self, t):
- # Examples:
# exist(B)
s_var_expr : EXIST LPAREN stds RPAREN
@@ -1044,9 +1196,9 @@
- cmdstring = "%s" % (map_i.cmd_list)
+ cmdstring = "%s" %(map_i.cmd_list)
else:
- cmdstring = "%s" % (map_i.get_id())
+ cmdstring = "%s" %(map_i.get_id())
@@ -1057,7 +1209,62 @@
if self.debug:
print map.cmd_list
+ def p_s_var_expr_comp(self, t):
+ # Examples:
+ # A <= 2 || B == 10
+ # A < 3 && A > 1
+ s_var_expr : s_var_expr AND AND s_var_expr
+ | s_var_expr OR OR s_var_expr
+ if self.run:
+ s_var_exprA = self.check_stds(t[1])
+ s_var_exprB = self.check_stds(t[4])
+ temporal = "l"
+ aggregate = t[2]
+ complist = self.get_temporal_topo_list(s_var_exprA, s_var_exprB, topolist = relations,
+ compare_cmd = True, compop = function, aggregate = aggregate)
+ t[0] = resultlist
+ if self.debug:
+ for map in resultlist:
+ print map.cmd_list
+ def p_s_var_expr_comp_op(self, t):
+ # Examples:
+ # A <= 2 {||} B == 10
+ # A < 3 {&&, equal} A > 1
+ s_var_expr : s_var_expr T_COMP_OPERATOR s_var_expr
+ if self.run:
+ s_var_exprB = self.check_stds(t[3])
+ t[0] = resultlist
+ if self.debug:
def p_s_expr_condition_if(self, t):
# Examples:
# if(s_var_expr, B)
@@ -1065,57 +1272,16 @@
expr : IF LPAREN s_var_expr COMMA stds RPAREN
| IF LPAREN s_var_expr COMMA expr RPAREN
+ | IF LPAREN ts_var_expr COMMA stds RPAREN
+ | IF LPAREN ts_var_expr COMMA expr RPAREN
ifmaplist = self.check_stds(t[3])
thenmaplist = self.check_stds(t[5])
- topolist = self.get_temporal_topo_list(ifmaplist, thenmaplist)
- resultlist = []
- #print(map_i.get_id())
- count = 0
- copy=True)
- temp_op='=')
- break
- if count == 0:
- # Set map name.
- else:
- cmdstring = "if(%s,%s)" % (map_new.cmd_list, mapbinput)
- cmdstring = "if(%s,%s)" % (mapainput, map_j.cmd_list)
- map_j.cmd_list)
- else:
- cmdstring = "if(%s,%s)" % (mapainput, mapbinput)
- #mapainput = name
- count += 1
+ resultlist = self.build_condition_cmd_list(ifmaplist, thenmaplist,
+ elselist = None,
+ temporal = 'r', null = False)
t[0] = resultlist
if self.debug:
@@ -1129,23 +1295,20 @@
expr : IF LPAREN s_var_expr COMMA number RPAREN
| IF LPAREN s_var_expr COMMA NULL LPAREN RPAREN RPAREN
+ | IF LPAREN ts_var_expr COMMA number RPAREN
+ | IF LPAREN ts_var_expr COMMA NULL LPAREN RPAREN RPAREN
resultlist = []
# Select input for r.mapcalc expression based on length of PLY object.
if len(t) == 7:
- numinput = t[5]
+ numinput = str(t[5])
elif len(t) == 9:
- numinput = self.check_null(t[5])
+ numinput = str(t[5] + t[6] + t[7])
# Iterate over condition map list.
for map_i in ifmaplist:
- mapinput = map_i.get_id()
- if "cmd_list" in dir(map_i):
- cmdstring = "if(%s,%s)" % (map_i.cmd_list, numinput)
- else:
- cmdstring = "if(%s,%s)" % (mapinput, numinput)
+ cmdstring = self.build_command_string(map_i, numinput, cmd_type = 'condition')
@@ -1163,65 +1326,18 @@
expr : IF LPAREN T_REL_OPERATOR COMMA s_var_expr COMMA stds RPAREN
| IF LPAREN T_REL_OPERATOR COMMA s_var_expr COMMA expr RPAREN
+ | IF LPAREN T_REL_OPERATOR COMMA ts_var_expr COMMA stds RPAREN
+ | IF LPAREN T_REL_OPERATOR COMMA ts_var_expr COMMA expr RPAREN
- relations, temporal, function = self.eval_toperator(t[3])
+ relations, temporal, function, aggregation = self.eval_toperator(t[3],
+ optype = 'relation')
ifmaplist = self.check_stds(t[5])
thenmaplist = self.check_stds(t[7])
- topolist = self.get_temporal_topo_list(ifmaplist, thenmaplist,
- resultlist = []
- # Loop over temporal related maps.
- count = 0
- bool_op='and',
- copy=True)
- 'and',
- temp_op='=')
- break
- if count == 0:
- # Set map name.
- else:
- #print(mapbinput)
- #mapbinput = mapbinput.split('@')[0]
- mapbinput)
- map_j.cmd_list)
- map_j.cmd_list)
- else:
- #mapainput = name
- count += 1
+ elselist = None,
+ condition_topolist = relations,
t[0] = resultlist
if self.debug:
@@ -1236,136 +1352,22 @@
| IF LPAREN s_var_expr COMMA stds COMMA expr RPAREN
| IF LPAREN s_var_expr COMMA expr COMMA stds RPAREN
| IF LPAREN s_var_expr COMMA expr COMMA expr RPAREN
+ | IF LPAREN ts_var_expr COMMA stds COMMA stds RPAREN
+ | IF LPAREN ts_var_expr COMMA stds COMMA expr RPAREN
+ | IF LPAREN ts_var_expr COMMA expr COMMA stds RPAREN
+ | IF LPAREN ts_var_expr COMMA expr COMMA expr RPAREN
+ # Check map list inputs.
elsemaplist = self.check_stds(t[7])
- resultlist = []
- thendict = {}
- elsedict = {}
- # Get topologies for the appropriate conclusion term.
- thentopolist = self.get_temporal_topo_list(ifmaplist, thenmaplist)
- # Fill dictionaries with related maps for both conclusion terms.
- for map_i in thentopolist:
- thenrelations = map_i.get_temporal_relations()
- relationmaps = thenrelations['EQUAL']
- thendict[map_i.get_id()] = relationmaps
- # Get topologies for the alternative conclusion term.
- elsetopolist = self.get_temporal_topo_list(ifmaplist, elsemaplist)
- for map_i in elsetopolist:
- elserelations = map_i.get_temporal_relations()
- relationmaps = elserelations['EQUAL']
- elsedict[map_i.get_id()] = relationmaps
- # Loop through conditional map list.
- for map_i in ifmaplist:
- if map_i.get_id() in thendict.keys():
- thenlist = thendict[map_i.get_id()]
- else:
- thenlist = []
- if map_i.get_id() in elsedict.keys():
- elselist = elsedict[map_i.get_id()]
- else:
- elselist = []
- # Set iteration amount to maximal or minimum number of related
- # conclusion maps, depending on null map creation flag.
- if self.null:
- iternum = max(len(thenlist), len(elselist))
- else:
- iternum = min(len(thenlist), len(elselist))
- # Calculate difference in conclusion lengths.
- iterthen = iternum - len(thenlist)
- iterelse = iternum - len(elselist)
- # Extend null maps to the list to get conclusions with same length.
- if iterthen != 0:
- for i in range(iterthen):
- thenlist.extend(['null()'])
- if iterelse != 0:
- for i in range(iterelse):
- elselist.extend(['null()'])
+ # Create conditional command map list.
+ elselist = elsemaplist,
- # Combine the conclusions in a paired list.
- conclusionlist = zip(thenlist, elselist)
- for i in range(iternum):
- conclusionmaps = conclusionlist[i]
- copy=True)
- mapifinput = map_i.get_id()
- # Get conclusion maps.
- map_then = conclusionmaps[0]
- map_else = conclusionmaps[1]
- # Check if conclusions are map objects.
- if map_then != 'null()':
- returncode = self.overlay_map_extent(map_new, map_then,
- 'and', temp_op='=')
- maptheninput = map_then.get_id()
- # Continue the loop if no temporal or spatial relationship exist.
- continue
- else:
- maptheninput = 'null()'
- if map_else != 'null()':
- returncode = self.overlay_map_extent(map_new, map_else,
- mapelseinput = map_else.get_id()
- continue
- else:
- mapelseinput = 'null()'
- #if map_then != 'null()' and map_else != 'null()':
- if "cmd_list" in dir(map_new) and "cmd_list" not in dir(map_then) \
- and "cmd_list" not in dir(map_else):
- cmdstring = "if(%s, %s, %s)" % (map_new.cmd_list,
- maptheninput,
- mapelseinput)
- elif "cmd_list" in dir(map_new) and "cmd_list" in dir(map_then) \
- map_then.cmd_list,
- mapelseinput)
- elif "cmd_list" in dir(map_new) and "cmd_list" not in dir(map_then) \
- and "cmd_list" in dir(map_else):
- maptheninput,
- map_else.cmd_list)
- elif "cmd_list" not in dir(map_new) and "cmd_list" in dir(map_then) \
- cmdstring = "if(%s, %s, %s)" % (mapifinput,
- mapelseinput)
- elif "cmd_list" not in dir(map_new) and "cmd_list" not in dir(map_then) \
- maptheninput,
- else:
- maptheninput,
- mapelseinput)
t[0] = resultlist
if self.debug:
@@ -1381,6 +1383,10 @@
| IF LPAREN s_var_expr COMMA NULL LPAREN RPAREN COMMA number RPAREN
| IF LPAREN s_var_expr COMMA number COMMA NULL LPAREN RPAREN RPAREN
| IF LPAREN s_var_expr COMMA NULL LPAREN RPAREN COMMA NULL LPAREN RPAREN RPAREN
+ | IF LPAREN ts_var_expr COMMA number COMMA number RPAREN
+ | IF LPAREN ts_var_expr COMMA NULL LPAREN RPAREN COMMA number RPAREN
+ | IF LPAREN ts_var_expr COMMA number COMMA NULL LPAREN RPAREN RPAREN
+ | IF LPAREN ts_var_expr COMMA NULL LPAREN RPAREN COMMA NULL LPAREN RPAREN RPAREN
resultlist = []
@@ -1397,19 +1403,14 @@
elif len(t) == 13:
numthen = t[5] + t[6] + t[7]
numelse = t[9] + t[10] + t[11]
- # Iterate over condition map list.
- cmdstring = "if(%s, %s, %s)" % (map_i.cmd_list, numthen,
- numelse)
- else:
- cmdstring = "if(%s, %s, %s)" % (mapinput, numthen, numelse)
- map_i.cmd_list = cmdstring
- resultlist.append(map_i)
+ numthen = str(numthen)
+ numelse = str(numelse)
+ print(numthen + " " +numelse )
+ resultlist = self.build_condition_cmd_list(ifmaplist, numthen, numelse,
t[0] = resultlist
@@ -1430,110 +1431,39 @@
| IF LPAREN s_var_expr COMMA stds COMMA NULL LPAREN RPAREN RPAREN
| IF LPAREN s_var_expr COMMA expr COMMA number RPAREN
| IF LPAREN s_var_expr COMMA expr COMMA NULL LPAREN RPAREN RPAREN
+ | IF LPAREN ts_var_expr COMMA number COMMA stds RPAREN
+ | IF LPAREN ts_var_expr COMMA NULL LPAREN RPAREN COMMA stds RPAREN
+ | IF LPAREN ts_var_expr COMMA number COMMA expr RPAREN
+ | IF LPAREN ts_var_expr COMMA NULL LPAREN RPAREN COMMA expr RPAREN
+ | IF LPAREN ts_var_expr COMMA stds COMMA number RPAREN
+ | IF LPAREN ts_var_expr COMMA stds COMMA NULL LPAREN RPAREN RPAREN
+ | IF LPAREN ts_var_expr COMMA expr COMMA number RPAREN
+ | IF LPAREN ts_var_expr COMMA expr COMMA NULL LPAREN RPAREN RPAREN
- resultlist = []
- thenmaplist = []
- numthen = ''
- elsemaplist = []
- numelse = ''
if len(t) == 9:
- try:
- thenmaplist = self.check_stds(t[5])
- except:
- numthen = self.check_null(t[5])
- try:
- elsemaplist = self.check_stds(t[7])
- except:
- numelse = self.check_null(t[7])
+ if isinstance(t[5], int):
+ theninput = str(t[5])
+ elseinput = self.check_stds(t[7])
+ elif isinstance(t[7], int):
+ theninput = self.check_stds(t[5])
+ elseinput = str(t[7])
elif len(t) == 11:
- try:
- except:
- try:
- elsemaplist = self.check_stds(t[9])
- except:
+ if t[5] == 'null':
+ theninput = str(t[5] + t[6] + t[7])
+ elseinput = self.check_stds(t[9])
+ elif t[7] == 'null':
+ elseinput = str(t[7] + t[8] + t[9])
+ print(theninput)
+ print(elseinput)
+ resultlist = self.build_condition_cmd_list(ifmaplist, theninput, elseinput,
- if thenmaplist != []:
- elif elsemaplist != []:
- topolist = self.get_temporal_topo_list(ifmaplist, elsemaplist)
- if numthen != '':
- numinput = numthen
- elif numelse != '':
- numinput = numelse
- # Iterate over condition map lists with temporal relations.
- count = 0
- copy=True)
- temp_op='=')
- break
- if count == 0:
- # Set map name.
- else:
- cmdstring = "if(%s,%s,%s)" % (map_new.cmd_list,
- mapbinput,
- numinput)
- cmdstring = "if(%s,%s,%s)" % (mapainput,
- map_j.cmd_list,
- numinput)
- map_j.cmd_list,
- numinput)
- else:
- mapbinput, numinput)
- if elsemaplist != []:
- numinput,
- mapbinput)
- numinput,
- map_j.cmd_list)
- numinput,
- map_j.cmd_list)
- else:
- cmdstring = "if(%s,%s,%s)" % (mapainput, numinput,
- mapbinput)
- #mapainput = name
- count += 1
t[0] = resultlist
if self.debug:
@@ -1553,125 +1483,46 @@
| IF LPAREN T_REL_OPERATOR COMMA s_var_expr COMMA stds COMMA NULL LPAREN RPAREN RPAREN
| IF LPAREN T_REL_OPERATOR COMMA s_var_expr COMMA expr COMMA number RPAREN
| IF LPAREN T_REL_OPERATOR COMMA s_var_expr COMMA expr COMMA NULL LPAREN RPAREN RPAREN
+ | IF LPAREN T_REL_OPERATOR COMMA ts_var_expr COMMA number COMMA stds RPAREN
+ | IF LPAREN T_REL_OPERATOR COMMA ts_var_expr COMMA NULL LPAREN RPAREN COMMA stds RPAREN
+ | IF LPAREN T_REL_OPERATOR COMMA ts_var_expr COMMA number COMMA expr RPAREN
+ | IF LPAREN T_REL_OPERATOR COMMA ts_var_expr COMMA NULL LPAREN RPAREN COMMA expr RPAREN
+ | IF LPAREN T_REL_OPERATOR COMMA ts_var_expr COMMA stds COMMA number RPAREN
+ | IF LPAREN T_REL_OPERATOR COMMA ts_var_expr COMMA stds COMMA NULL LPAREN RPAREN RPAREN
+ | IF LPAREN T_REL_OPERATOR COMMA ts_var_expr COMMA expr COMMA number RPAREN
+ | IF LPAREN T_REL_OPERATOR COMMA ts_var_expr COMMA expr COMMA NULL LPAREN RPAREN RPAREN
+ relations, temporal, function, aggregation = self.eval_toperator(t[3], optype = 'relation')
- resultlist = []
- thenmaplist = []
- numthen = ''
- elsemaplist = []
- numelse = ''
if len(t) == 11:
- try:
- thenmaplist = self.check_stds(t[7])
- except:
- numthen = self.check_null(t[7])
- try:
- except:
- numelse = self.check_null(t[9])
+ if isinstance(t[7], int):
+ theninput = str(t[7])
+ elif isinstance(t[9], int):
+ theninput = self.check_stds(t[7])
+ elseinput = str(t[9])
elif len(t) == 13:
- try:
- except:
- try:
- elsemaplist = self.check_stds(t[11])
- except:
+ theninput = str(t[7] + t[8] + t[9])
+ elseinput = self.check_stds(t[11])
+ elseinput = str(t[9] + t[10] + t[11])
- topolist = self.get_temporal_topo_list(ifmaplist, elsemaplist,
- if numthen != '':
- count = 0
- bool_op='and',
- copy=True)
- 'and',
- temp_op='=')
- break
- if count == 0:
- # Set map name.
- else:
- mapbinput,
- numinput)
- map_j.cmd_list,
- numinput)
- map_j.cmd_list,
- numinput)
- else:
- mapbinput,
- numinput)
- numinput,
- mapbinput)
- numinput,
- map_j.cmd_list)
- numinput,
- map_j.cmd_list)
- else:
- numinput,
- mapbinput)
- #mapainput = name
- count += 1
t[0] = resultlist
if self.debug:
print map.cmd_list
def p_s_expr_condition_elif_relation(self, t):
# Examples:
# if({equal||during}, s_var_expr, A, B)
@@ -1680,145 +1531,22 @@
| IF LPAREN T_REL_OPERATOR COMMA s_var_expr COMMA stds COMMA expr RPAREN
| IF LPAREN T_REL_OPERATOR COMMA s_var_expr COMMA expr COMMA stds RPAREN
| IF LPAREN T_REL_OPERATOR COMMA s_var_expr COMMA expr COMMA expr RPAREN
+ | IF LPAREN T_REL_OPERATOR COMMA ts_var_expr COMMA stds COMMA stds RPAREN
+ | IF LPAREN T_REL_OPERATOR COMMA ts_var_expr COMMA stds COMMA expr RPAREN
+ | IF LPAREN T_REL_OPERATOR COMMA ts_var_expr COMMA expr COMMA stds RPAREN
+ | IF LPAREN T_REL_OPERATOR COMMA ts_var_expr COMMA expr COMMA expr RPAREN
- resultlist = []
- thendict = {}
- elsedict = {}
- thentopolist = self.get_temporal_topo_list(ifmaplist, thenmaplist,
- relationmaps = []
- if topo in thenrelations.keys():
- relationmaps = relationmaps + thenrelations[topo]
- elsetopolist = self.get_temporal_topo_list(ifmaplist, elsemaplist,
- relationmaps = []
- if topo in elserelations.keys():
- relationmaps = relationmaps + elserelations[topo]
- # Loop trough conditional map list.
- else:
- thenlist = []
- else:
- elselist = []
- if self.null:
- else:
- if iterthen != 0:
- if iterelse != 0:
+ resultlist = self.build_condition_cmd_list(ifmaplist, thenmaplist, elsemaplist,
- copy=True)
- continue
- else:
- continue
- else:
- maptheninput,
- mapelseinput)
- mapelseinput)
- maptheninput,
- mapelseinput)
- maptheninput,
- else:
- maptheninput,
- mapelseinput)
t[0] = resultlist
if self.debug:
@@ -1846,963 +1574,56 @@
| s_var_expr OR OR ts_var_expr
| t_var_expr OR OR ts_var_expr
- # Check whether inputs are map lists or global temporal variables and
- # store each in separate lists.
- ts_var_dict = {"temporal": [], "spatial": []}
- temporal_list = []
- spatial_list = []
- operator = t[2] + t[3]
- temporalop = GlobalTemporalVar()
- temporalop.relationop = operator
- temporalop.topology.append("EQUAL")
+ if self.run:
+ relations = ["EQUAL"]
+ temporal = "l"
+ function = t[2] + t[3]
+ aggregate = t[2]
+ # Build conditional values based on topological relationships.
+ topolist = relations, compare_cmd = True,
+ compop = function, aggregate = aggregate,
+ convert = True)
+ # Set temporal extent based on topological relationships.
+ resultlist = self.set_temporal_extent_list(complist, topolist = relations,
+ temporal = temporal)
- if isinstance(t[1], dict) and "spatial" in t[1]:
- temporal_list = temporal_list + t[1]["temporal"]
- spatial_list.append(t[1]["spatial"])
- elif isinstance(t[1], list):
- if all([isinstance(i, ta.GlobalTemporalVar) for i in t[1]]):
- else:
- tsexprA = self.check_stds(t[1])
- spatial_list.append(tsexprA)
- elif isinstance(t[1], ta.GlobalTemporalVar):
- temporal_list.append(t[1])
- if temporal_list != [] and isinstance(t[4], ta.GlobalTemporalVar):
- temporal_list.append(temporalop)
- if temporal_list != [] and \
- isinstance(t[4], list) and \
- all([isinstance(i, ta.GlobalTemporalVar) for i in t[4]]):
- if isinstance(t[4], dict) and "spatial" in t[4]:
- temporal_list = temporal_list + t[4]["temporal"]
- spatial_list.append(t[4]["spatial"])
- elif isinstance(t[4], list):
- if all([isinstance(i, ta.GlobalTemporalVar) for i in t[4]]):
- else:
- tsexprB = self.check_stds(t[4])
- spatial_list.append(tsexprB)
- elif isinstance(t[4], ta.GlobalTemporalVar):
- temporal_list.append(t[4])
- ts_var_dict["temporal"] = temporal_list
- # Condition for two map lists in spatio temporal expression.
- if len(spatial_list) == 2:
- # Build topology for both map lists in spatio temporal expression.
- topolist = self.get_temporal_topo_list(spatial_list[0],
- spatial_list[1])
- resultlist = []
- count = 0
- break
- if count == 0:
- # Set map name.
- else:
- cmdstring = "%s %s %s" % (map_new.cmd_list, operator,
- mapbinput)
- cmdstring = "%s %s %s" % (mapainput, operator,
- map_j.cmd_list)
- map_j.cmd_list)
- else:
- mapbinput)
- #mapainput = name
- count += 1
- # Return dictionary with spatial map list of temporal
- # intersected maps and temporal expression in list form.
- ts_var_dict["spatial"] = resultlist
- # Condition for only one map list in spatio temporal expression.
- elif len(spatial_list) == 1:
- ts_var_dict["spatial"] = spatial_list[0]
- t[0] = ts_var_dict
- def p_ts_expr_condition_if(self, t):
- # Examples:
- # if(ts_var_expr, A)
- # if(start_year == 2013 || B != 5, A)
- expr : IF LPAREN ts_var_expr COMMA stds RPAREN
- | IF LPAREN ts_var_expr COMMA expr RPAREN
- ts_var_dict = t[3]
- spatialcond = ts_var_dict["spatial"]
- # Extract spatial map list from condition.
- ifmaplist = self.check_stds(spatialcond)
- resultlist = []
- resultspatial = []
- count = 0
- copy=True)
- temp_op='=')
- break
- if count == 0:
- # Set map name.
- else:
- map_j.cmd_list)
- else:
- #mapainput = name
- count += 1
- resultspatial.append(map_new)
- # Evaluate temporal statements in spatio temporal condition.
- #if len(ts_var_dict["temporal"]) == 1:
- #temporalcond = ts_var_dict["temporal"][0]
- #else:
- temporalcond = ts_var_dict["temporal"]
- resultspatial = self.check_stds(resultspatial)
- thencond = self.build_condition_list(temporalcond, resultspatial)
- thenresult = self.eval_condition_list(thencond)
- # Clear the map list.
- resultlist = self.check_stds(thenresult, clear=True)
t[0] = resultlist
- if self.debug:
- def p_ts_expr_condition_if_relation(self, t):
- # Examples:
- # if({equal||during}, ts_var_expr, A)
- # if({starts||during}, B > 2 || end_month() == 4, A)
+ def p_hash_operation(self, t):
+ # Calculate the number of maps within an interval of another map from a
+ # second space time dataset.
+ # A # B
+ # A {equal,r#} B
- expr : IF LPAREN T_REL_OPERATOR COMMA ts_var_expr COMMA stds RPAREN
- | IF LPAREN T_REL_OPERATOR COMMA ts_var_expr COMMA expr RPAREN
+ expr : t_hash_var
- ts_var_dict = t[5]
- count = 0
- bool_op='and',
- copy=True)
- 'and',
- temp_op='=')
- break
- if count == 0:
- # Set map name.
- else:
+ maplist = self.check_stds(t[1])
- mapbinput)
- map_j.cmd_list)
- map_j.cmd_list)
- else:
- #mapainput = name
- count += 1
- #else:
- thencond = self.build_condition_list(temporalcond, resultspatial,
- relations)
- t[0] = resultlist
- if self.debug:
- def p_ts_numeric_condition_if(self, t):
- # Examples:
- # if(ts_var_expr, 1)
- # if(A == 5 && start_day() > 5, 10)
- expr : IF LPAREN ts_var_expr COMMA number RPAREN
- | IF LPAREN ts_var_expr COMMA NULL LPAREN RPAREN RPAREN
- # Select input for r.mapcalc expression based on length of PLY object.
- if len(t) == 7:
- numinput = t[5]
- elif len(t) == 9:
- numinput = t[5] + t[6] + t[7]
- else:
- resultspatial.append(map_i)
- t[0] = resultlist
- if self.debug:
- def p_ts_expr_condition_elif(self, t):
- # Examples:
- # if(s_var_expr, A, B)
- # if(start_day() < 20 && B > 2, A, B)
- expr : IF LPAREN ts_var_expr COMMA stds COMMA stds RPAREN
- | IF LPAREN ts_var_expr COMMA stds COMMA expr RPAREN
- | IF LPAREN ts_var_expr COMMA expr COMMA stds RPAREN
- | IF LPAREN ts_var_expr COMMA expr COMMA expr RPAREN
- thendict = {}
- elsedict = {}
- else:
- thenlist = []
- else:
- elselist = []
- if self.null:
- else:
- if iterthen != 0:
- if iterelse != 0:
- continue
- else:
- continue
- else:
+ if self.run:
+ resultlist = []
+ for obj in map_i.map_value:
+ if isinstance(obj, GlobalTemporalVar):
+ n_maps = obj.td
+ mapinput = map_i.get_id()
- maptheninput,
- mapelseinput)
- mapelseinput)
- maptheninput,
- mapelseinput)
- maptheninput,
- else:
- maptheninput,
- mapelseinput)
+ cmdstring = "(%s)" %(n_maps)
+ # Append module command.
- #elseresult = self.eval_condition_list(thencond, inverse = True)
- # Combine and sort else and then statement to result map list.
- #combilist = thenresult + elseresult
- #resultlist = sorted(combilist, key = AbstractDatasetComparisonKeyStartTime)
- #resultlist = self.check_stds(resultlist, clear = True)
+ t[0] = resultlist
- t[0] = resultlist
if self.debug:
print map.cmd_list
- def p_ts_expr_condition_elif_relation(self, t):
- # Examples:
- # if({equal||during}, s_var_expr, A, B)
- # if({contains}, start_day() == 3 || C != 2, A, B)
- expr : IF LPAREN T_REL_OPERATOR COMMA ts_var_expr COMMA stds COMMA stds RPAREN
- | IF LPAREN T_REL_OPERATOR COMMA ts_var_expr COMMA stds COMMA expr RPAREN
- | IF LPAREN T_REL_OPERATOR COMMA ts_var_expr COMMA expr COMMA stds RPAREN
- | IF LPAREN T_REL_OPERATOR COMMA ts_var_expr COMMA expr COMMA expr RPAREN
- thendict = {}
- elsedict = {}
- relationmaps = []
- relationmaps = []
- else:
- thenlist = []
- else:
- elselist = []
- if self.null:
- else:
- if iterthen != 0:
- if iterelse != 0:
- copy=True)
- continue
- else:
- continue
- else:
- maptheninput,
- mapelseinput)
- mapelseinput)
- maptheninput,
- mapelseinput)
- cmdstring = "if(%s, %s, %s)" % (mapifinput, maptheninput,
- else:
- mapelseinput)
- relations)
- t[0] = resultlist
- if self.debug:
- def p_ts_numeric_condition_elif(self, t):
- # Examples:
- # if(ts_var_expr, 1, 2)
- # if(A == 1 || end_year == 2013, 10, null())
- expr : IF LPAREN ts_var_expr COMMA number COMMA number RPAREN
- | IF LPAREN ts_var_expr COMMA NULL LPAREN RPAREN COMMA number RPAREN
- | IF LPAREN ts_var_expr COMMA number COMMA NULL LPAREN RPAREN RPAREN
- | IF LPAREN ts_var_expr COMMA NULL LPAREN RPAREN COMMA NULL LPAREN RPAREN RPAREN
- if len(t) == 9:
- numthen = t[5]
- numelse = t[7]
- elif len(t) == 11:
- elif len(t) == 13:
- numelse)
- else:
- t[0] = resultlist
- def p_ts_numeric_expr_condition_elif(self, t):
- # Examples:
- # if(ts_var_expr, 1, A)
- # if(A == 5 && start_day() > 5, A, null())
- expr : IF LPAREN ts_var_expr COMMA number COMMA stds RPAREN
- | IF LPAREN ts_var_expr COMMA NULL LPAREN RPAREN COMMA stds RPAREN
- | IF LPAREN ts_var_expr COMMA number COMMA expr RPAREN
- | IF LPAREN ts_var_expr COMMA NULL LPAREN RPAREN COMMA expr RPAREN
- | IF LPAREN ts_var_expr COMMA stds COMMA number RPAREN
- | IF LPAREN ts_var_expr COMMA stds COMMA NULL LPAREN RPAREN RPAREN
- | IF LPAREN ts_var_expr COMMA expr COMMA number RPAREN
- | IF LPAREN ts_var_expr COMMA expr COMMA NULL LPAREN RPAREN RPAREN
- thenmaplist = []
- numthen = ''
- elsemaplist = []
- numelse = ''
- if len(t) == 9:
- try:
- except:
- numthen = t[5]
- try:
- except:
- numelse = t[7]
- try:
- except:
- numthen = t[5] + t[6] + t[7]
- try:
- except:
- numelse = t[7] + t[8] + t[9]
- if numthen != '':
- count = 0
- copy=True)
- temp_op='=')
- break
- if count == 0:
- # Set map name.
- else:
- mapbinput,
- numinput)
- map_j.cmd_list,
- numinput)
- map_j.cmd_list,
- numinput)
- else:
- cmdstring = "if(%s,%s,%s)" % (mapainput, mapbinput,
- numinput)
- numinput,
- mapbinput)
- map_j.cmd_list)
- numinput, map_j.cmd_list)
- else:
- mapbinput)
- #mapainput = name
- count += 1
- t[0] = resultlist
- if self.debug:
- def p_ts_numeric_expr_condition_elif_relation(self, t):
- # Examples:
- # if({during},ts_var_expr, 1, A)
- # if({during}, A == 5 && start_day() > 5, A, null())
- expr : IF LPAREN T_REL_OPERATOR COMMA ts_var_expr COMMA number COMMA stds RPAREN
- | IF LPAREN T_REL_OPERATOR COMMA ts_var_expr COMMA NULL LPAREN RPAREN COMMA stds RPAREN
- | IF LPAREN T_REL_OPERATOR COMMA ts_var_expr COMMA number COMMA expr RPAREN
- | IF LPAREN T_REL_OPERATOR COMMA ts_var_expr COMMA NULL LPAREN RPAREN COMMA expr RPAREN
- | IF LPAREN T_REL_OPERATOR COMMA ts_var_expr COMMA stds COMMA number RPAREN
- | IF LPAREN T_REL_OPERATOR COMMA ts_var_expr COMMA stds COMMA NULL LPAREN RPAREN RPAREN
- | IF LPAREN T_REL_OPERATOR COMMA ts_var_expr COMMA expr COMMA number RPAREN
- | IF LPAREN T_REL_OPERATOR COMMA ts_var_expr COMMA expr COMMA NULL LPAREN RPAREN RPAREN
- thenmaplist = []
- numthen = ''
- elsemaplist = []
- numelse = ''
- if len(t) == 11:
- try:
- except:
- numthen = t[7]
- try:
- except:
- numelse = t[9]
- try:
- except:
- numthen = t[9] + t[10] + t[11]
- try:
- except:
- numelse = t[9] + t[10] + t[11]
- if numthen != '':
- count = 0
- bool_op='and',
- copy=True)
- 'and',
- temp_op='=')
- break
- if count == 0:
- # Set map name.
- else:
- mapbinput,
- numinput)
- map_j.cmd_list,
- numinput)
- map_j.cmd_list,
- numinput)
- else:
- mapbinput,
- numinput)
- numinput,
- mapbinput)
- numinput,
- map_j.cmd_list)
- numinput,
- map_j.cmd_list)
- else:
- numinput,
- mapbinput)
- #mapainput = name
- count += 1
- t[0] = resultlist
- if self.debug:
if __name__ == "__main__":
Deleted: grass/trunk/lib/python/temporal/temporal_raster_operator.py
--- grass/trunk/lib/python/temporal/temporal_raster_operator.py 2014-11-04 15:04:13 UTC (rev 62593)
+++ grass/trunk/lib/python/temporal/temporal_raster_operator.py 2014-11-04 15:45:52 UTC (rev 62594)
@@ -1,389 +0,0 @@
-Temporal operator evaluation with PLY
-(C) 2013 by the GRASS Development Team
-This program is free software under the GNU General Public
-License (>=v2). Read the file COPYING that comes with GRASS
-for details.
-:authors: Thomas Leppelt and Soeren Gebbert
-.. code-block:: python
- >>> p = TemporalRasterOperatorParser()
- >>> expression = "{equal| during | follows,+!:}"
- >>> p.parse(expression)
- >>> print(p.relations, p.temporal, p.function)
- (['equal', 'during', 'follows'], '+', '!:')
- >>> expression = "{equal| during,!:}"
- (['equal', 'during'], '=', '!:')
- >>> expression = "{!:}"
- (['equal'], '=', '!:')
- >>> expression = "{|#}"
- (['equal'], '|', '#')
- >>> expression = "{equal|during,=!:}"
- >>> expression = "{equal|during|starts}"
- (['equal', 'during', 'starts'], None, None)
- >>> expression = "{equal,++}"
- (['equal'], '+', '+')
- >>> expression = "{equal | during,|%}"
- (['equal', 'during'], '|', '%')
- >>> expression = "{||}"
- (['equal'], '=', '||')
- >>> expression = "{equal,||}"
- >>> expression = "{equal | during | contains,&&}"
- (['equal', 'during', 'contains'], '=', '&&')
- >>> expression = "{equal | during | contains,/}"
- (['equal', 'during', 'contains'], '=', '/')
- >>> expression = "{equal | during | contains,|*}"
- (['equal', 'during', 'contains'], '|', '*')
-try:
- import ply.lex as lex
- import ply.yacc as yacc
-except:
- pass
-class TemporalRasterOperatorLexer(object):
- """Lexical analyzer for the GRASS GIS temporal operator"""
- # Functions that defines topological relations.
- relations = {
- 'equal': "EQUAL",
- 'follows': "FOLLOWS",
- 'precedes': "PRECEDES",
- 'overlaps': "OVERLAPS",
- 'overlapped': "OVERLAPPED",
- 'during': "DURING",
- 'starts': "STARTS",
- 'finishes': "FINISHES",
- 'contains': "CONTAINS",
- 'started': "STARTED",
- 'finished': "FINISHED",
- 'over': "OVER"
- # This is the list of token names.
- tokens = (
- 'COMMA',
- 'LEFTREF',
- 'HASH',
- 'OR',
- 'AND',
- 'MOD',
- 'DIV',
- 'MULT',
- 'ADD',
- 'SUB',
- 'T_SELECT',
- 'T_NOT_SELECT',
- 'CLPAREN',
- 'CRPAREN',
- # Build the token list
- tokens = tokens + tuple(relations.values())
- # Regular expression rules for simple tokens
- t_T_SELECT = r':'
- t_T_NOT_SELECT = r'!:'
- t_COMMA = r','
- t_LEFTREF = r'='
- t_HASH = r'\#'
- t_OR = r'[\|]'
- t_AND = r'[&]'
- t_MOD = r'[\%]'
- t_DIV = r'[\/]'
- t_MULT = r'[\*]'
- t_ADD = r'[\+]'
- t_SUB = r'[-]'
- t_CLPAREN = r'\{'
- t_CRPAREN = r'\}'
- # These are the things that should be ignored.
- t_ignore = ' \t'
- # Track line numbers.
- def t_newline(self, t):
- r'\n+'
- t.lineno += len(t.value)
- def t_NAME(self, t):
- r'[a-zA-Z_][a-zA-Z_0-9]*'
- self.temporal_symbol(t)
- return t
- # Parse symbols
- def temporal_symbol(self, t):
- # Check for reserved words
- if t.value in TemporalRasterOperatorLexer.relations.keys():
- t.type = TemporalRasterOperatorLexer.relations.get(t.value)
- #else:
- # t.type = 'NAME'
- return(t)
- # Handle errors.
- def t_error(self, t):
- raise SyntaxError("syntax error on line %d near '%s'" %
- (t.lineno, t.value))
- # Build the lexer
- def build(self, **kwargs):
- self.lexer = lex.lex(module=self, **kwargs)
- # Just for testing
- def test(self, data):
- self.name_list = {}
- print(data)
- self.lexer.input(data)
- while True:
- tok = self.lexer.token()
- if not tok: break
- print tok
-class TemporalRasterOperatorParser(object):
- """The temporal algebra class"""
- def __init__(self):
- self.lexer = TemporalRasterOperatorLexer()
- self.lexer.build()
- self.parser = yacc.yacc(module=self)
- def parse(self, expression, comparison=False):
- self.comparison = comparison
- self.parser.parse(expression)
- # Error rule for syntax errors.
- def p_error(self, t):
- raise SyntaxError("invalid syntax")
- # Get the tokens from the lexer class
- tokens = TemporalRasterOperatorLexer.tokens
- def p_relation_only(self, t):
- # The expression should always return a list of maps.
- operator : CLPAREN relation CRPAREN
- | CLPAREN relationlist CRPAREN
- # Set three operator components.
- if isinstance(t[2], list):
- self.relations = t[2]
- else:
- self.relations = [t[2]]
- self.temporal = None
- self.function = None
- t[0] = t[2]
- def p_operator(self, t):
- operator : CLPAREN select CRPAREN
- | CLPAREN HASH CRPAREN
- | CLPAREN arithmetic CRPAREN
- self.relations = ['equal']
- self.temporal = "="
- self.function = t[2]
- t[0] = t[2]
- def p_comparison(self, t):
- operator : CLPAREN temporal AND CRPAREN
- | CLPAREN temporal OR CRPAREN
- if t[2] == t[3]:
- self.function = t[2] + t[3]
- else:
- t[0] = t[2]
- def p_operator_temporal(self, t):
- operator : CLPAREN temporal select CRPAREN
- | CLPAREN temporal HASH CRPAREN
- | CLPAREN temporal arithmetic CRPAREN
- self.temporal = t[2]
- self.function = t[3]
- t[0] = t[3]
- def p_operator_relation(self, t):
- operator : CLPAREN relation COMMA select CRPAREN
- | CLPAREN relationlist COMMA select CRPAREN
- | CLPAREN relation COMMA HASH CRPAREN
- | CLPAREN relationlist COMMA HASH CRPAREN
- | CLPAREN relation COMMA arithmetic CRPAREN
- | CLPAREN relationlist COMMA arithmetic CRPAREN
- else:
- self.function = t[4]
- t[0] = t[4]
- def p_comparison_relation(self, t):
- operator : CLPAREN relation COMMA temporal AND CRPAREN
- | CLPAREN relation COMMA temporal OR CRPAREN
- | CLPAREN relationlist COMMA temporal AND CRPAREN
- | CLPAREN relationlist COMMA temporal OR CRPAREN
- else:
- if t[4] == t[5]:
- self.function = t[4] + t[5]
- else:
- t[0] = t[4]
- def p_operator_relation_temporal(self, t):
- operator : CLPAREN relation COMMA temporal select CRPAREN
- | CLPAREN relationlist COMMA temporal select CRPAREN
- | CLPAREN relation COMMA temporal HASH CRPAREN
- | CLPAREN relationlist COMMA temporal HASH CRPAREN
- | CLPAREN relation COMMA temporal arithmetic CRPAREN
- | CLPAREN relationlist COMMA temporal arithmetic CRPAREN
- else:
- self.temporal = t[4]
- self.function = t[5]
- t[0] = t[5]
- def p_relation(self, t):
- # The list of relations.
- relation : EQUAL
- | FOLLOWS
- | PRECEDES
- | OVERLAPS
- | OVERLAPPED
- | DURING
- | STARTS
- | FINISHES
- | CONTAINS
- | STARTED
- | FINISHED
- t[0] = t[1]
- def p_over(self, t):
- relation : OVER
- over_list = ["overlaps", "overlapped"]
- t[0] = over_list
- def p_relationlist(self, t):
- relationlist : relation OR relation
- | relation OR relationlist
- rel_list = []
- rel_list.append(t[1])
- if isinstance(t[3], list):
- rel_list = rel_list + t[3]
- else:
- rel_list.append(t[3])
- t[0] = rel_list
- def p_temporal_operator(self, t):
- temporal : LEFTREF
- | OR
- | AND
- | ADD
- t[0] = t[1]
- def p_select_operator(self, t):
- select : T_SELECT
- | T_NOT_SELECT
- t[0] = t[1]
- def p_arithmetic_operator(self, t):
- arithmetic : MOD
- | DIV
- | MULT
- | ADD
- | SUB
- t[0] = t[1]
-if __name__ == "__main__":
- import doctest
- doctest.testmod()
Modified: grass/trunk/lib/python/temporal/temporal_vector_algebra.py
--- grass/trunk/lib/python/temporal/temporal_vector_algebra.py 2014-11-04 15:04:13 UTC (rev 62593)
+++ grass/trunk/lib/python/temporal/temporal_vector_algebra.py 2014-11-04 15:45:52 UTC (rev 62594)
@@ -1,4 +1,5 @@
+"""@package grass.temporal
Temporal vector algebra
(C) 2014 by the GRASS Development Team
@@ -15,286 +16,6 @@
>>> p = tgis.TemporalVectorAlgebraLexer()
>>> p.build()
>>> p.debug = True
- >>> expression = "C = A : B"
- >>> p.test(expression)
- C = A : B
- LexToken(NAME,'C',1,0)
- LexToken(EQUALS,'=',1,2)
- LexToken(NAME,'A',1,4)
- LexToken(T_SELECT,':',1,6)
- LexToken(NAME,'B',1,8)
- >>> expression = "C = test1 !: test2"
- C = test1 !: test2
- LexToken(NAME,'test1',1,4)
- LexToken(T_NOT_SELECT,'!:',1,10)
- LexToken(NAME,'test2',1,13)
- >>> expression = "C = test1 {equal,:} test2"
- C = test1 {equal,:} test2
- LexToken(T_SELECT_OPERATOR,'{equal,:}',1,10)
- LexToken(NAME,'test2',1,20)
- >>> expression = "C = test1 {equal,!:} test2"
- C = test1 {equal,!:} test2
- LexToken(T_SELECT_OPERATOR,'{equal,!:}',1,10)
- LexToken(NAME,'test2',1,21)
- >>> expression = "C = test1 # test2"
- C = test1 # test2
- LexToken(HASH,'#',1,10)
- LexToken(NAME,'test2',1,12)
- >>> expression = "C = test1 {#} test2"
- C = test1 {#} test2
- LexToken(T_HASH_OPERATOR,'{#}',1,10)
- LexToken(NAME,'test2',1,14)
- >>> expression = "C = test1 {equal,#} test2"
- C = test1 {equal,#} test2
- LexToken(T_HASH_OPERATOR,'{equal,#}',1,10)
- >>> expression = "C = test1 {equal|during,#} test2"
- C = test1 {equal|during,#} test2
- LexToken(T_HASH_OPERATOR,'{equal|during,#}',1,10)
- LexToken(NAME,'test2',1,27)
- >>> expression = "E = test1 : test2 !: test1"
- E = test1 : test2 !: test1
- LexToken(NAME,'E',1,0)
- LexToken(T_SELECT,':',1,10)
- LexToken(T_NOT_SELECT,'!:',1,18)
- LexToken(NAME,'test1',1,21)
- >>> expression = 'D = buff_t(test1,"10 months")'
- D = buff_t(test1,"10 months")
- LexToken(NAME,'D',1,0)
- LexToken(BUFF_T,'buff_t',1,4)
- LexToken(LPAREN,'(',1,10)
- LexToken(NAME,'test1',1,11)
- LexToken(COMMA,',',1,16)
- LexToken(QUOTE,'"',1,17)
- LexToken(INT,10,1,18)
- LexToken(NAME,'months',1,21)
- LexToken(QUOTE,'"',1,27)
- LexToken(RPAREN,')',1,28)
- >>> expression = 'H = tsnap(test1)'
- H = tsnap(test1)
- LexToken(NAME,'H',1,0)
- LexToken(TSNAP,'tsnap',1,4)
- LexToken(LPAREN,'(',1,9)
- LexToken(NAME,'test1',1,10)
- LexToken(RPAREN,')',1,15)
- >>> expression = 'H = tsnap(test2 {during,:} buff_t(test1, "1 days"))'
- H = tsnap(test2 {during,:} buff_t(test1, "1 days"))
- LexToken(NAME,'test2',1,10)
- LexToken(T_SELECT_OPERATOR,'{during,:}',1,16)
- LexToken(BUFF_T,'buff_t',1,27)
- LexToken(LPAREN,'(',1,33)
- LexToken(NAME,'test1',1,34)
- LexToken(COMMA,',',1,39)
- LexToken(QUOTE,'"',1,41)
- LexToken(INT,1,1,42)
- LexToken(NAME,'days',1,44)
- LexToken(QUOTE,'"',1,48)
- LexToken(RPAREN,')',1,49)
- LexToken(RPAREN,')',1,50)
- >>> expression = 'H = tshift(test2 {during,:} buff_t(test1, "1 days"), "1 months")'
- H = tshift(test2 {during,:} buff_t(test1, "1 days"), "1 months")
- LexToken(TSHIFT,'tshift',1,4)
- LexToken(NAME,'test2',1,11)
- LexToken(T_SELECT_OPERATOR,'{during,:}',1,17)
- LexToken(BUFF_T,'buff_t',1,28)
- LexToken(LPAREN,'(',1,34)
- LexToken(NAME,'test1',1,35)
- LexToken(COMMA,',',1,40)
- LexToken(QUOTE,'"',1,42)
- LexToken(INT,1,1,43)
- LexToken(NAME,'days',1,45)
- LexToken(QUOTE,'"',1,49)
- LexToken(COMMA,',',1,51)
- LexToken(QUOTE,'"',1,53)
- LexToken(INT,1,1,54)
- LexToken(NAME,'months',1,56)
- LexToken(QUOTE,'"',1,62)
- LexToken(RPAREN,')',1,63)
- >>> expression = 'H = tshift(A , 10)'
- H = tshift(A , 10)
- LexToken(NAME,'A',1,11)
- LexToken(COMMA,',',1,13)
- LexToken(INT,10,1,15)
- LexToken(RPAREN,')',1,17)
- >>> expression = 'H = if(td(A) > 10, A)'
- H = if(td(A) > 10, A)
- LexToken(IF,'if',1,4)
- LexToken(LPAREN,'(',1,6)
- LexToken(TD,'td',1,7)
- LexToken(NAME,'A',1,10)
- LexToken(RPAREN,')',1,11)
- LexToken(GREATER,'>',1,13)
- LexToken(COMMA,',',1,17)
- LexToken(NAME,'A',1,19)
- LexToken(RPAREN,')',1,20)
- >>> expression = 'H = if(td(A) > 10, A, B)'
- H = if(td(A) > 10, A, B)
- LexToken(COMMA,',',1,20)
- LexToken(NAME,'B',1,22)
- LexToken(RPAREN,')',1,23)
- >>> expression = 'I = if(equals,td(A) > 10 {equals,||} td(B) < 10, A)'
- I = if(equals,td(A) > 10 {equals,||} td(B) < 10, A)
- LexToken(NAME,'I',1,0)
- LexToken(NAME,'equals',1,7)
- LexToken(TD,'td',1,14)
- LexToken(LPAREN,'(',1,16)
- LexToken(NAME,'A',1,17)
- LexToken(RPAREN,')',1,18)
- LexToken(GREATER,'>',1,20)
- LexToken(INT,10,1,22)
- LexToken(T_OVERLAY_OPERATOR,'{equals,||}',1,25)
- LexToken(TD,'td',1,37)
- LexToken(LPAREN,'(',1,39)
- LexToken(NAME,'B',1,40)
- LexToken(RPAREN,')',1,41)
- LexToken(LOWER,'<',1,43)
- LexToken(INT,10,1,45)
- LexToken(COMMA,',',1,47)
- LexToken(NAME,'A',1,49)
- >>> expression = 'I = if(equals,td(A) > 10 || start_day() < 10, A)'
- I = if(equals,td(A) > 10 || start_day() < 10, A)
- LexToken(OR,'|',1,25)
- LexToken(OR,'|',1,26)
- LexToken(START_DAY,'start_day',1,28)
- LexToken(LPAREN,'(',1,37)
- LexToken(RPAREN,')',1,38)
- LexToken(LOWER,'<',1,40)
- LexToken(INT,10,1,42)
- LexToken(COMMA,',',1,44)
- LexToken(NAME,'A',1,46)
- LexToken(RPAREN,')',1,47)
- >>> expression = 'E = if({equals},td(A) >= 4 {contain,&&} td(B) == 2, C : D)'
- E = if({equals},td(A) >= 4 {contain,&&} td(B) == 2, C : D)
- LexToken(T_REL_OPERATOR,'{equals}',1,7)
- LexToken(COMMA,',',1,15)
- LexToken(TD,'td',1,16)
- LexToken(LPAREN,'(',1,18)
- LexToken(GREATER_EQUALS,'>=',1,22)
- LexToken(INT,4,1,25)
- LexToken(T_OVERLAY_OPERATOR,'{contain,&&}',1,27)
- LexToken(TD,'td',1,40)
- LexToken(LPAREN,'(',1,42)
- LexToken(NAME,'B',1,43)
- LexToken(RPAREN,')',1,44)
- LexToken(CEQUALS,'==',1,46)
- LexToken(INT,2,1,49)
- LexToken(COMMA,',',1,50)
- LexToken(NAME,'C',1,52)
- LexToken(T_SELECT,':',1,54)
- LexToken(NAME,'D',1,56)
- LexToken(RPAREN,')',1,57)
- >>> expression = 'F = if({equals},A {equal,#}, B, C : D)'
- F = if({equals},A {equal,#}, B, C : D)
- LexToken(NAME,'F',1,0)
- LexToken(NAME,'A',1,16)
- LexToken(T_HASH_OPERATOR,'{equal,#}',1,18)
- LexToken(COMMA,',',1,27)
- LexToken(NAME,'B',1,29)
- LexToken(COMMA,',',1,30)
- LexToken(NAME,'C',1,32)
- LexToken(T_SELECT,':',1,34)
- LexToken(NAME,'D',1,36)
- LexToken(RPAREN,')',1,37)
>>> expression = 'E = A : B ^ C : D'
>>> p.test(expression)
E = A : B ^ C : D
@@ -307,18 +28,6 @@
LexToken(NAME,'C',1,12)
LexToken(T_SELECT,':',1,14)
LexToken(NAME,'D',1,16)
- >>> expression = 'E = A : B {|^} C : D'
- E = A : B {|^} C : D
- LexToken(T_OVERLAY_OPERATOR,'{|^}',1,10)
- LexToken(NAME,'C',1,15)
- LexToken(T_SELECT,':',1,17)
- LexToken(NAME,'D',1,19)
>>> expression = 'E = buff_a(A, 10)'
>>> p.test(expression)
E = buff_a(A, 10)
@@ -330,100 +39,15 @@
LexToken(COMMA,',',1,12)
LexToken(INT,10,1,14)
LexToken(RPAREN,')',1,16)
- >>> p = tgis.TemporalVectorAlgebraParser()
- >>> p.run = False
- >>> p.debug = True
- >>> expression = "D = A : (B !: C)"
- B* = B !: C
- A* = A : B*
- D = A*
- >>> expression = "D = A {!:} B {during,:} C"
- >>> print(expression)
- D = A {!:} B {during,:} C
- A* = A {!:} B
- A** = A* {during,:} C
- D = A**
- >>> expression = "D = A {:} B {during,!:} C"
- D = A {:} B {during,!:} C
- A* = A {:} B
- A** = A* {during,!:} C
- D = A**
- >>> expression = "D = A {:} (B {during,!:} (C : E))"
- D = A {:} (B {during,!:} (C : E))
- C* = C : E
- B* = B {during,!:} C*
- A* = A {:} B*
- D = A*
- >>> p.run = False
- >>> p.debug = False
- >>> expression = "C = test1 : test2"
- C = test1 : test2
- >>> p.parse(expression, 'stvds')
- >>> expression = 'E = test2 {during,:} buff_t(test1,"1 days")'
- E = test2 {during,:} buff_t(test1,"1 days")
- >>> expression = 'F = test2 {equal,:} buff_t(test1,"1 days")'
- F = test2 {equal,:} buff_t(test1,"1 days")
- test1* = buff_t( test1 , " 1 days " )
- test2* = test2 {during,:} test1*
- test2** = tsnap( test2* )
- H = test2**
- >>> expression = 'H = tshift(test2 {during,:} test1, "1 days")'
- test2** = tshift( test2* , " 1 days " )
- H = test2**
- >>> expression = 'H = tshift(H, 3)'
- H* = tshift( H , 3 )
- H = H*
- >>> expression = 'C = if(td(A) == 2, A)'
- td(A)
- td(A) == 2
- A* = if condition True then A
- C = A*
- >>> expression = 'C = if(td(A) == 5 || start_date() >= "2010-01-01", A, B)'
- td(A)
- td(A) == 5
- start_date >= "2010-01-01"
- True || True
- A* = if condition True then A else B
- C = A*
- >>> expression = 'C = if(td(A) == 5, A, B)'
- td(A)
- td(A) == 5
- C = A*
import grass.pygrass.modules as pygrass
-from temporal_vector_operator import *
+from temporal_operator import *
from temporal_algebra import *
class TemporalVectorAlgebraLexer(TemporalAlgebraLexer):
"""Lexical analyzer for the GRASS GIS temporal vector algebra"""
@@ -432,9 +56,9 @@
# Buffer functions from v.buffer
vector_buff_functions = {
- 'buff_p': 'BUFF_POINT',
- 'buff_l': 'BUFF_LINE',
- 'buff_a': 'BUFF_AREA',
+ 'buff_p' : 'BUFF_POINT',
+ 'buff_l' : 'BUFF_LINE',
+ 'buff_a' : 'BUFF_AREA',
@@ -446,14 +70,16 @@
- tokens = TemporalAlgebraLexer.tokens + vector_tokens \
- + tuple(vector_buff_functions.values())
+ tokens = TemporalAlgebraLexer.tokens \
+ + vector_tokens \
+ + tuple(vector_buff_functions.values())
- t_DISOR = r'\+'
- t_XOR = r'\^'
- t_NOT = r'\~'
- t_T_OVERLAY_OPERATOR = r'\{([a-zA-Z\|]+[,])?([\|&+=]?[\|&+=\^\~])\}'
+ t_DISOR = r'\+'
+ t_XOR = r'\^'
+ t_NOT = r'\~'
+ #t_T_OVERLAY_OPERATOR = r'\{([a-zA-Z\|]+[,])?([\|&+=]?[\|&+=\^\~])\}'
+ t_T_OVERLAY_OPERATOR = r'\{[\|&+\^\~][,]?[a-zA-Z\| ]*([,])?([lrudi]|left|right|union|disjoint|intersect)?\}'
# Parse symbols
@@ -472,7 +98,6 @@
class TemporalVectorAlgebraParser(TemporalAlgebraParser):
@@ -481,21 +106,21 @@
# Setting equal precedence level for select and hash operations.
precedence = (
- ('left', 'T_SELECT_OPERATOR', 'T_SELECT', 'T_NOT_SELECT'), # 1
- ('left', 'AND', 'OR', 'T_COMP_OPERATOR', 'T_OVERLAY_OPERATOR', 'DISOR',
- 'NOT', 'XOR'), # 2
+ ('left', 'T_SELECT_OPERATOR', 'T_SELECT', 'T_NOT_SELECT'), # 1
+ ('left', 'AND', 'OR', 'T_COMP_OPERATOR', 'T_OVERLAY_OPERATOR', 'DISOR', \
+ 'NOT', 'XOR'), #2
- def __init__(self, pid=None, run=False, debug=True, spatial=False):
+ def __init__(self, pid=None, run=False, debug=True, spatial = False):
TemporalAlgebraParser.__init__(self, pid, run, debug, spatial)
self.m_overlay = pygrass.Module('v.overlay', quiet=True, run_=False)
self.m_rename = pygrass.Module('g.rename', quiet=True, run_=False)
self.m_patch = pygrass.Module('v.patch', quiet=True, run_=False)
- self.m_remove = pygrass.Module('g.remove', quiet=True, run_=False)
+ self.m_mremove = pygrass.Module('g.remove', quiet=True, run_=False)
self.m_buffer = pygrass.Module('v.buffer', quiet=True, run_=False)
- def parse(self, expression, basename=None, overwrite=False):
+ def parse(self, expression, basename = None, overwrite = False):
self.lexer = TemporalVectorAlgebraLexer()
self.lexer.build()
self.parser = yacc.yacc(module=self, debug=self.debug)
@@ -503,6 +128,8 @@
self.overwrite = overwrite
self.count = 0
self.stdstype = "stvds"
+ self.maptype = "vect"
+ self.mapclass = VectorDataset
self.basename = basename
self.expression = expression
@@ -519,105 +146,207 @@
for chunk in chunklist:
stringlist = ",".join(chunk)
if self.debug:
- print "g.remove type=vect name=%s" % (stringlist)
+ print "g.remove type=vect name=%s"%(stringlist)
if self.run:
- m = copy.deepcopy(self.m_remove)
+ m = copy.deepcopy(self.m_mremove)
m.inputs["type"].value = "vect"
m.inputs["name"].value = stringlist
m.flags["f"].value = True
m.run()
- def eval_toperator(self, operator, comparison=False):
- """This function evaluates a string containing temporal operations.
+ def get_temporal_topo_list(self, maplistA, maplistB = None, topolist = ["EQUAL"],
+ assign_val = False, count_map = False, compare_bool = False,
+ compare_cmd = False, compop = None, aggregate = None,
+ new = False, convert = False, overlay_cmd = False):
+ """Build temporal topology for two space time data sets, copy map objects
+ for given relation into map list.
+ :param maplistA List of maps.
+ :param maplistB List of maps.
+ :param topolist List of strings of temporal relations.
+ :param assign_val Boolean for assigning a boolean map value based on
+ the map_values from the compared map list by
+ topological relationships.
+ :param count_map Boolean if the number of topological related maps
+ should be returned.
+ :param compare_bool Boolean for comparing boolean map values based on
+ related map list and compariosn operator.
+ :param compare_cmd Boolean for comparing command list values based on
+ :param compop Comparison operator, && or ||.
+ :param aggregate Aggregation operator for relation map list, & or |.
+ :param new Boolean if new temporary maps should be created.
+ :param convert Boolean if conditional values should be converted to
+ r.mapcalc command strings.
+ :param overlay_cmd Boolean for aggregate overlay operators implicitly
+ in command list values based on related map lists.
+ :return: List of maps from maplistA that fulfil the topological relationships
+ to maplistB specified in topolist.
+ topologylist = ["EQUAL", "FOLLOWS", "PRECEDES", "OVERLAPS", "OVERLAPPED", \
+ "DURING", "STARTS", "FINISHES", "CONTAINS", "STARTED", \
+ "FINISHED"]
+ complementdict = {"EQUAL": "EQUAL", "FOLLOWS" : "PRECEDES",
+ "PRECEDES" : "FOLLOWS", "OVERLAPS" : "OVERLAPPED",
+ "OVERLAPPED" : "OVERLAPS", "DURING" : "CONTAINS",
+ "CONTAINS" : "DURING", "STARTS" : "STARTED",
+ "STARTED" : "STARTS", "FINISHES" : "FINISHED",
+ "FINISHED" : "FINISHES"}
+ resultdict = {}
+ # Check if given temporal relation are valid.
+ for topo in topolist:
+ if topo.upper() not in topologylist:
+ raise SyntaxError("Unpermitted temporal relation name '" + topo + "'")
- :param operator: String of temporal operations, e.g.
- {equal|during,=!:}.
+ # Create temporal topology for maplistA to maplistB.
+ tb = SpatioTemporalTopologyBuilder()
+ # Dictionary with different spatial variables used for topology builder.
+ spatialdict = {'strds' : '2D', 'stvds' : '2D', 'str3ds' : '3D'}
+ # Build spatial temporal topology
+ if self.spatial:
+ tb.build(maplistA, maplistB, spatial = spatialdict[self.stdstype])
+ else:
+ tb.build(maplistA, maplistB)
+ # Iterate through maps in maplistA and search for relationships given
+ # in topolist.
+ for map_i in maplistA:
+ tbrelations = map_i.get_temporal_relations()
+ # Check for boolean parameters for further calculations.
+ if assign_val:
+ self.assign_bool_value(map_i, tbrelations, topolist)
+ elif compare_bool:
+ self.compare_bool_value(map_i, tbrelations, compop, aggregate, topolist)
+ elif compare_cmd:
+ self.compare_cmd_value(map_i, tbrelations, compop, aggregate, topolist, convert)
+ elif overlay_cmd:
+ self.overlay_cmd_value(map_i, tbrelations, compop, topolist)
+ if topo.upper() in tbrelations.keys():
+ if count_map:
+ relationmaplist = tbrelations[topo.upper()]
+ gvar = GlobalTemporalVar()
+ gvar.td = len(relationmaplist)
+ if "map_value" in dir(map_i):
+ map_i.map_value.append(gvar)
+ else:
+ map_i.map_value = gvar
+ resultdict[map_i.get_id()] = map_i
+ resultlist = resultdict.values()
+ # Sort list of maps chronological.
+ resultlist = sorted(resultlist, key = AbstractDatasetComparisonKeyStartTime)
+ return(resultlist)
- :return: List of temporal relations (equal, during), the given
- function (!:) and the interval/instances (=).
- .. code-block:: python
- >>> import grass.temporal as tgis
- >>> tgis.init(True)
- >>> operator = "{equal,:}"
- >>> p.eval_toperator(operator)
- (['EQUAL'], '=', ':')
- >>> operator = "{equal|during,:}"
- (['EQUAL', 'DURING'], '=', ':')
- >>> operator = "{equal,!:}"
- (['EQUAL'], '=', '!:')
- >>> operator = "{equal|during,!:}"
- (['EQUAL', 'DURING'], '=', '!:')
- >>> operator = "{equal|during,=!:}"
- >>> operator = "{equal|during|starts,#}"
- (['EQUAL', 'DURING', 'STARTS'], '=', '#')
- >>> operator = "{!:}"
- >>> operator = "{=:}"
- >>> operator = "{#}"
- (['EQUAL'], '=', '#')
- >>> operator = "{equal|during}"
- (['EQUAL', 'DURING'], None, None)
- >>> operator = "{equal}"
- (['EQUAL'], None, None)
- >>> operator = "{equal,||}"
- >>> p.eval_toperator(operator, True)
- (['EQUAL'], '=', '||')
- >>> operator = "{equal|during,&&}"
- (['EQUAL', 'DURING'], '=', '&&')
- >>> operator = "{&}"
- (['EQUAL'], '=', '&')
+ def overlay_cmd_value(self, map_i, tbrelations, function, topolist = ["EQUAL"]):
+ """ Function to evaluate two map lists by given overlay operator.
+ :param map_i Map object with temporal extent.
+ :param tbrelations List of temporal relation to map_i.
+ :param topolist List of strings for given temporal relations.
+ :param function Overlay operator, &|+^~.
+ :return: Map object with command list with operators that has been
+ evaluated by implicit aggregration.
+ # Build comandlist list with elements from related maps and given relation operator.
+ resultlist = []
+ # Define overlay operation dictionary.
+ overlaydict = {"&":"and", "|":"or", "^":"xor", "~":"not", "+":"disor"}
+ operator = overlaydict[function]
+ # Set first input for overlay module.
+ mapainput = map_i.get_id()
+ # Append command list of given map to result command list.
+ if "cmd_list" in dir(map_i):
+ resultlist = resultlist + map_i.cmd_list
+ for relationmap in relationmaplist:
+ if "cmd_list" in dir(relationmap):
+ resultlist = resultlist + relationmap.cmd_list
+ # Generate an intermediate name
+ name = self.generate_map_name()
+ map_i.set_id(name + "@" + self.mapset)
+ # Set second input for overlay module.
+ mapbinput = relationmap.get_id()
+ # Create module command in PyGRASS for v.overlay and v.patch.
+ if operator != "disor":
+ m = copy.deepcopy(self.m_overlay)
+ m.run_ = False
+ m.inputs["operator"].value = operator
+ m.inputs["ainput"].value = str(mapainput)
+ m.inputs["binput"].value = str(mapbinput)
+ m.outputs["output"].value = name
+ m.flags["overwrite"].value = self.overwrite
+ else:
+ patchinput = str(mapainput) + ',' + str(mapbinput)
+ m = copy.deepcopy(self.m_patch)
+ m.run_ = False
+ m.inputs["input"].value = patchinput
+ # Conditional append of module command.
+ resultlist.append(m)
+ # Set new map name to temporary map name.
+ mapainput = name
+ # Add command list to result map.
+ map_i.cmd_list = resultlist
- p = TemporalVectorOperatorParser()
- p.parse(operator, comparison)
- p.relations = [rel.upper() for rel in p.relations]
+ def set_temporal_extent_list(self, maplist, topolist = ["EQUAL"], temporal = 'l' ):
+ """ Change temporal extent of map list based on temporal relations to
+ other map list and given temporal operator.
- return(p.relations, p.temporal, p.function)
+ :param maplist List of map objects for which relations has been build
+ correctely.
+ :param temporal The temporal operator specifying the temporal
+ extent operation (intersection, union, disjoint
+ union, right reference, left reference).
- def overlay_map_extent(self, mapA, mapB, bool_op=None, temp_op='=',
- copy=False):
- """Compute the spatio-temporal extent of two topological related maps
- :param mapA: The first map
- :param mapB: The second maps
- :param bool_op: The boolean operator specifying the spatial extent
- operation (intersection, union, disjoint union)
- :param temp_op: The temporal operator specifying the temporal
- exntent operation (intersection, union, disjoint union)
- :param copy: Specifies if the temporal extent of mapB should be
- copied to mapA
+ :return: Map list with specified temporal extent.
- returncode = TemporalAlgebraParser.overlay_map_extent(self, mapA, mapB,
- bool_op, temp_op,
- copy)
- if not copy and returncode == 1:
- # Conditional append of command list.
- if "cmd_list" in dir(mapA) and "cmd_list" in dir(mapB):
- mapA.cmd_list = mapA.cmd_list + mapB.cmd_list
- elif "cmd_list" not in dir(mapA) and "cmd_list" in dir(mapB):
- mapA.cmd_list = mapB.cmd_list
- return(returncode)
+ resultdict = {}
+ for map_i in maplist:
+ # Loop over temporal related maps and create overlay modules.
+ # Generate an intermediate map for the result map list.
+ map_new = self.generate_new_map(base_map=map_i, bool_op = 'and',
+ copy = True, rename = False)
+ # Combine temporal and spatial extents of intermediate map with related maps.
+ if topo in tbrelations.keys():
+ for map_j in (tbrelations[topo]):
+ if temporal == 'r':
+ # Create overlayed map extent.
+ returncode = self.overlay_map_extent(map_new, map_j, 'and', \
+ temp_op = temporal)
+ # Stop the loop if no temporal or spatial relationship exist.
+ if returncode == 0:
+ break
+ # Append map to result map list.
+ elif returncode == 1:
+ # resultlist.append(map_new)
+ resultdict[map_new.get_id()] = map_new
+ break
+ #if returncode == 1:
+ # Get sorted map objects as values from result dictionoary.
def p_statement_assign(self, t):
@@ -636,20 +365,18 @@
for i in range(num):
# Check if resultmap names exist in GRASS database.
vectorname = self.basename + "_" + str(i)
- vectormap = VectorDataset(vectorname + "@" +
- get_current_mapset())
- if vectormap.map_exists() and self.overwrite is False:
- self.msgr.fatal(_("Error vector maps with basename %s"
- " exist. Use --o flag to overwrite"
- " existing file") % (vectorname))
+ vectormap = VectorDataset(vectorname + "@" + get_current_mapset())
+ if vectormap.map_exists() and self.overwrite == False:
+ self.msgr.fatal(_("Error vector maps with basename %s exist. "
+ "Use --o flag to overwrite existing file") \
+ %(vectorname))
for map_i in t[3]:
# Execute command list.
for cmd in map_i.cmd_list:
try:
- # We need to check if the input maps have
- # areas in case of v.overlay otherwise
- # v.overlay will break
+ # We need to check if the input maps have areas in case of v.overlay
+ # otherwise v.overlay will break
if cmd.name == "v.overlay":
for name in (cmd.inputs["ainput"].value,
cmd.inputs["binput"].value):
@@ -672,16 +399,14 @@
self.msgr.message("Run command:\n" + cmd.get_bash())
cmd.run()
if cmd.popen.returncode != 0:
- self.msgr.fatal(_("Error starting %s : \n%s")
- % (cmd.get_bash(),
- cmd.popen.stderr))
+ self.msgr.fatal(_("Error starting %s : \n%s") \
+ %(cmd.get_bash(), \
+ cmd.popen.stderr))
mapname = cmd.outputs['output'].value
if mapname.find("@") >= 0:
map_test = map_i.get_new_instance(mapname)
else:
- map_test = map_i.get_new_instance(mapname +
- self.mapset)
+ map_test = map_i.get_new_instance(mapname + "@" + self.mapset)
if not map_test.map_exists():
returncode = 1
break
@@ -693,8 +418,7 @@
# Change map name to given basename.
newident = self.basename + "_" + str(count)
m = copy.deepcopy(self.m_rename)
- m.inputs["vect"].value = (map_i.get_name(),
- newident)
+ m.inputs["vect"].value = (map_i.get_name(),newident)
m.run()
#m(vect = (map_i.get_name(),newident), \
@@ -707,45 +431,41 @@
if len(register_list) > 0:
# Open connection to temporal database.
- dbif, connected = init_dbif(dbif=self.dbif)
+ dbif, connect = init_dbif(dbif=self.dbif)
# Create result space time dataset.
- resultstds = open_new_stds(t[1], self.stdstype, 'absolute',
- t[1], t[1],
- "temporal vector algebra",
- dbif=dbif,
- overwrite=self.overwrite)
+ resultstds = open_new_stds(t[1], self.stdstype, \
+ 'absolute', t[1], t[1], \
+ "temporal vector algebra", self.dbif,
+ overwrite = self.overwrite)
for map_i in register_list:
- # Check if modules should be executed from command list
+ # Check if modules should be executed from command list.
# Get meta data from grass database.
map_i.load()
if map_i.is_in_db(dbif=dbif) and self.overwrite:
# Update map in temporal database.
map_i.update_all(dbif=dbif)
- elif map_i.is_in_db(dbif=dbif) and self.overwrite is False:
- # Raise error if map exists and no overwrite
- # flag is given.
- self.msgr.fatal(_("Error vector map %s exist"
- " in temporal database. Use "
- "overwrite flag. : \n%s") %
- (map_i.get_map_id(),
+ elif map_i.is_in_db(dbif=dbif) and self.overwrite == False:
+ # Raise error if map exists and no overwrite flag is given.
+ self.msgr.fatal(_("Error vector map %s exist in temporal database. "
+ "Use overwrite flag. : \n%s") \
+ %(map_i.get_map_id(), cmd.popen.stderr))
else:
# Insert map into temporal database.
map_i.insert(dbif=dbif)
else:
- # Get metadata from temporal database.
- map_i.select(dbif=dbif)
+ #Get metadata from temporal database.
+ #map_i.select(dbif=dbif)
+ map_i.load()
# Register map in result space time dataset.
- resultstds.register_map(map_i, dbif=dbif)
+ success = resultstds.register_map(map_i, dbif=dbif)
#count += 1
#if count % 10 == 0:
# grass.percent(count, num, 1)
- resultstds.update_from_registered_maps(dbif=dbif)
- if connected:
- dbif.close()
+ resultstds.update_from_registered_maps(dbif)
+ dbif.close()
self.remove_intermediate_vector_maps()
- t[0] = register_list
+ t[0] = t[3]
def p_overlay_operation(self, t):
@@ -770,16 +490,24 @@
| stds DISOR expr
| expr DISOR expr
- # Check input stds.
- maplistA = self.check_stds(t[1])
- maplistB = self.check_stds(t[3])
if self.run:
- t[0] = self.create_overlay_operations(maplistA, maplistB,
- ("EQUAL",), "=", t[2])
- else:
- t[0] = t[1]
+ # Check input stds and operator.
+ maplistA = self.check_stds(t[1])
+ maplistB = self.check_stds(t[3])
+ temporal = 'l'
+ function = t[2]
+ # Build commmand list for related maps.
+ complist = self.get_temporal_topo_list(maplistA, maplistB, topolist = relations,
+ compop = function, overlay_cmd = True)
+ t[0] = resultlist
+ if self.debug:
+ str(t[1]) + t[2] + str(t[3])
def p_overlay_operation_relation(self, t):
expr : stds T_OVERLAY_OPERATOR stds
@@ -787,113 +515,24 @@
| stds T_OVERLAY_OPERATOR expr
| expr T_OVERLAY_OPERATOR expr
- relations, temporal, function = self.eval_toperator(t[2])
if self.run:
- function)
- else:
- t[0] = t[1]
+ relations, temporal, function, aggregate = self.eval_toperator(t[2], optype = 'overlay')
+ t[0] = resultlist
+ if self.debug:
- def create_overlay_operations(self, maplistA, maplistB, relations,
- temporal, function):
- """Create the spatial overlay operation commad list
- :param maplistA: A list of map objects
- :param maplistB: A list of map objects
- :param relations: The temporal relationships that must be
- fullfilled as list of strings("EQUAL", "DURING",
- :param temporal: The temporal operator as string "=" or "&", ...
- :param function: The spatial overlay operations as string "&", "|",
- :return: Return the list of maps with overlay commands
+ def p_buffer_operation(self,t):
- topolist = self.get_temporal_topo_list(maplistA, maplistB,
- topolist=relations)
- # Select operation name.
- if function == "&":
- opname = "and"
- elif function == "|":
- opname = "or"
- elif function == "^":
- opname = "xor"
- elif function == "~":
- opname = "not"
- elif function == "+":
- opname = "disor"
- if self.run:
- resultlist = []
- for map_i in topolist:
- # Generate an intermediate name for the result map list.
- map_new = self.generate_new_map(base_map=map_i, bool_op=opname,
- copy=True)
- # Set first input for overlay module.
- mapainput = map_i.get_id()
- # Loop over temporal related maps and create overlay modules.
- tbrelations = map_i.get_temporal_relations()
- count = 0
- for topo in relations:
- if topo in tbrelations.keys():
- for map_j in (tbrelations[topo]):
- # Create overlayed map extent.
- map_j, opname,
- temp_op=temporal)
- # relationship exist.
- if returncode == 0:
- break
- if count == 0:
- # Set map name.
- name = map_new.get_id()
- else:
- name = self.generate_map_name()
- map_new.set_id(name + "@" + mapset)
- # Set second input for overlay module.
- mapbinput = map_j.get_id()
- # Create module command in PyGRASS for v.overlay
- # and v.patch.
- if opname != "disor":
- m = copy.deepcopy(self.m_overlay)
- m.run_ = False
- m.inputs["operator"].value = opname
- m.inputs["ainput"].value = str(mapainput)
- m.inputs["binput"].value = str(mapbinput)
- m.outputs["output"].value = name
- m.flags["overwrite"].value = self.overwrite
- else:
- patchinput = str(mapainput) + ',' + str(mapbinput)
- m = copy.deepcopy(self.m_patch)
- m.run_ = False
- m.inputs["input"].value = patchinput
- # Conditional append of module command.
- if "cmd_list" in dir(map_new):
- map_new.cmd_list.append(m)
- else:
- map_new.cmd_list = [m]
- # Set new map name to temporary map name.
- mapainput = name
- count += 1
- break
- # Append map to result map list.
- if returncode == 1:
- resultlist.append(map_new)
- return resultlist
- def p_buffer_operation(self, t):
expr : buff_function LPAREN stds COMMA number RPAREN
| buff_function LPAREN expr COMMA number RPAREN
@@ -944,7 +583,7 @@
# Handle errors.
raise SyntaxError("syntax error on line %d near '%s' expression '%s'" %
- (t.lineno, t.value, self.expression))
+ (t.lineno, t.value, self.expression))
Deleted: grass/trunk/lib/python/temporal/temporal_vector_operator.py
--- grass/trunk/lib/python/temporal/temporal_vector_operator.py 2014-11-04 15:04:13 UTC (rev 62593)
+++ grass/trunk/lib/python/temporal/temporal_vector_operator.py 2014-11-04 15:45:52 UTC (rev 62594)
@@ -1,348 +0,0 @@
-Temporal vector operator evaluation with PLY
-(C) 2014 by the GRASS Development Team
-for details.
- >>> p = tgis.TemporalVectorOperatorParser()
- >>> expression = "{equal| during,&&}"
- >>> p.parse(expression, True)
- (['equal', 'during'], '=', '&&')
- >>> expression = "{equal| during | follows,&&}"
- (['equal', 'during', 'follows'], '&', '&')
- >>> expression = "{&&}"
- (['equal'], '=', '&&')
- (['equal'], '&', '&')
- (['equal'], '|', '|')
- >>> expression = "{over| equal,||}"
- ([['overlaps', 'overlapped'], 'equal'], '|', '|')
-try:
-except:
- pass
-class TemporalVectorOperatorLexer(object):
- """Lexical analyzer for the GRASS GIS temporal vector operators"""
- relations = {
- 'equal': "EQUAL",
- 'over': "OVER"
- tokens = (
- 'COMMA',
- 'LEFTREF',
- 'HASH',
- 'OR',
- 'AND',
- 'DISOR',
- 'XOR',
- 'NOT',
- 'T_SELECT',
- 'T_NOT_SELECT',
- 'CLPAREN',
- 'CRPAREN',
- t_T_SELECT = r':'
- t_COMMA = r','
- t_LEFTREF = r'='
- t_HASH = r'\#'
- t_OR = r'[\|]'
- t_AND = r'[&]'
- t_DISOR = r'\+'
- t_XOR = r'\^'
- t_NOT = r'\~'
- t_CLPAREN = r'\{'
- t_CRPAREN = r'\}'
- t_ignore = ' \t'
- r'\n+'
- return t
- # Parse symbols
- if t.value in TemporalVectorOperatorLexer.relations.keys():
- t.type = TemporalVectorOperatorLexer.relations.get(t.value)
- #else:
- # t.type = 'NAME'
- return(t)
- # Handle errors.
- # Build the lexer
- print(data)
- while True:
- if not tok: break
- print tok
-class TemporalVectorOperatorParser(object):
- """The parser for the GRASS GIS temporal vector operators"""
- self.lexer = TemporalVectorOperatorLexer()
- tokens = TemporalVectorOperatorLexer.tokens
- else:
- t[0] = t[2]
- | CLPAREN overlay CRPAREN
- t[0] = t[2]
- | CLPAREN temporal overlay CRPAREN
- if self.comparison:
- else:
- t[0] = t[3]
- | CLPAREN relation COMMA overlay CRPAREN
- | CLPAREN relationlist COMMA overlay CRPAREN
- else:
- t[0] = t[4]
- | CLPAREN relation COMMA temporal overlay CRPAREN
- | CLPAREN relationlist COMMA temporal overlay CRPAREN
- else:
- else:
- t[0] = t[5]
- relation : EQUAL
- | FOLLOWS
- | PRECEDES
- | OVERLAPS
- | OVERLAPPED
- | DURING
- | STARTS
- | FINISHES
- | CONTAINS
- | STARTED
- | FINISHED
- t[0] = t[1]
- relation : OVER
- t[0] = over_list
- rel_list = []
- else:
- t[0] = rel_list
- | OR
- | AND
- | DISOR
- t[0] = t[1]
- select : T_SELECT
- | T_NOT_SELECT
- t[0] = t[1]
- def p_overlay_operator(self, t):
- overlay : OR
- | AND
- | DISOR
- | XOR
- | NOT
- t[0] = t[1]
- import doctest
- doctest.testmod()
Modified: grass/trunk/lib/python/temporal/testsuite/test_doctests.py
--- grass/trunk/lib/python/temporal/testsuite/test_doctests.py 2014-11-04 15:04:13 UTC (rev 62593)
+++ grass/trunk/lib/python/temporal/testsuite/test_doctests.py 2014-11-04 15:45:52 UTC (rev 62594)
@@ -42,10 +42,8 @@
tests.addTests(doctest.DocTestSuite(grass.temporal.temporal_raster3d_algebra))
tests.addTests(doctest.DocTestSuite(grass.temporal.temporal_raster_algebra))
tests.addTests(doctest.DocTestSuite(grass.temporal.temporal_raster_base_algebra))
- tests.addTests(doctest.DocTestSuite(grass.temporal.temporal_raster_operator))
- # TODO: Fix tests
- #tests.addTests(doctest.DocTestSuite(grass.temporal.temporal_vector_algebra))
- tests.addTests(doctest.DocTestSuite(grass.temporal.temporal_vector_operator))
+ tests.addTests(doctest.DocTestSuite(grass.temporal.temporal_operator))
+ tests.addTests(doctest.DocTestSuite(grass.temporal.temporal_vector_algebra))
return tests
if __name__ == '__main__':
Modified: grass/trunk/lib/python/temporal/testsuite/test_register_function.py
--- grass/trunk/lib/python/temporal/testsuite/test_register_function.py 2014-11-04 15:04:13 UTC (rev 62593)
+++ grass/trunk/lib/python/temporal/testsuite/test_register_function.py 2014-11-04 15:45:52 UTC (rev 62594)
@@ -1,4 +1,4 @@
-"""!Unit test to register raster maps with absolute and relative
+"""Unit test to register raster maps with absolute and relative
time using tgis.register_maps_in_space_time_dataset()
@@ -6,7 +6,7 @@
for details.
- at author Soeren Gebbert
+:authors: Soeren Gebbert
@@ -14,12 +14,11 @@
import datetime
import os
class TestRegisterFunctions(grass.gunittest.TestCase):
@classmethod
def setUpClass(cls):
- """!Initiate the temporal GIS and set the region
+ """Initiate the temporal GIS and set the region
os.putenv("GRASS_OVERWRITE", "1")
# Use always the current mapset as temporal database
@@ -31,12 +30,12 @@
@classmethod
def tearDownClass(cls):
- """!Remove the temporary region
+ """Remove the temporary region
cls.del_temp_region()
def setUp(self):
- """!Create the test maps and the space time raster datasets
+ """Create the test maps and the space time raster datasets
self.runModule("r.mapcalc", overwrite=True, quiet=True,
expression="register_map_1 = 1")
@@ -49,7 +48,7 @@
title="Test strds", descr="Test strds", semantic="field")
def tearDown(self):
- """!Remove maps from temporal database
+ """Remove maps from temporal database
self.runModule("t.unregister", maps="register_map_1,register_map_2", quiet=True)
self.runModule("g.remove", flags='f', type="rast", name="register_map_1,register_map_2", quiet=True)
@@ -57,7 +56,7 @@
self.strds_rel.delete()
def test_absolute_time_strds_1(self):
- """!Test the registration of maps with absolute time in a
+ """Test the registration of maps with absolute time in a
tgis.register_maps_in_space_time_dataset(type="rast", name=self.strds_abs.get_name(),
@@ -82,7 +81,7 @@
self.assertEqual(end, datetime.datetime(2001, 1, 3))
def test_absolute_time_strds_2(self):
space time raster dataset.
The timestamps are set using the C-Interface beforehand, so that the register function needs
to read the timetsamp from the map metadata.
@@ -113,7 +112,7 @@
def test_absolute_time_1(self):
tgis.register_maps_in_space_time_dataset(type="rast", name=None,
@@ -132,7 +131,7 @@
def test_absolute_time_2(self):
@@ -149,7 +148,7 @@
self.assertEqual(start, datetime.datetime(2001, 1, 1, 18, 30, 1))
def test_absolute_time_3(self):
- """!Test the registration of maps with absolute time.
+ """Test the registration of maps with absolute time.
@@ -172,7 +171,7 @@
def test_relative_time_strds_1(self):
- """!Test the registration of maps with relative time in a
+ """Test the registration of maps with relative time in a
@@ -201,7 +200,7 @@
self.assertEqual(unit, "day")
def test_relative_time_strds_2(self):
space time raster dataset. The timetsamps are set for the maps using the
C-interface before registration.
@@ -233,7 +232,7 @@
self.assertEqual(unit, "seconds")
def test_relative_time_1(self):
@@ -254,7 +253,7 @@
def test_relative_time_2(self):
@@ -275,7 +274,7 @@
def test_relative_time_3(self):
- """!Test the registration of maps with relative time. The timetsamps are set beforhand using
+ """Test the registration of maps with relative time. The timetsamps are set beforhand using
the C-interface.
ciface = tgis.get_tgis_c_library_interface()
Deleted: grass/trunk/lib/python/temporal/testsuite/test_temporal_raster3d_algebra.py
--- grass/trunk/lib/python/temporal/testsuite/test_temporal_raster3d_algebra.py 2014-11-04 15:04:13 UTC (rev 62593)
+++ grass/trunk/lib/python/temporal/testsuite/test_temporal_raster3d_algebra.py 2014-11-04 15:45:52 UTC (rev 62594)
@@ -1,84 +0,0 @@
- time using tgis.register_maps_in_space_time_dataset()
-for details.
-import grass.script
-import grass.temporal as tgis
-import grass.gunittest as gunittest
-import datetime
-import os
-class TestRegisterFunctions(gunittest.TestCase):
- @classmethod
- def setUpClass(cls):
- os.putenv("GRASS_OVERWRITE", "1")
- tgis.init(True) # Raise on error instead of exit(1)
- grass.script.use_temp_region()
- ret = grass.script.run_command("g.region", n=80.0, s=0.0, e=120.0,
- w=0.0, t=100.0, b=0.0, res=10.0)
- ret += grass.script.run_command("r3.mapcalc", overwrite=True, quiet=True, expression="a1 = 1")
- ret += grass.script.run_command("r3.mapcalc", overwrite=True, quiet=True, expression="a2 = 2")
- ret += grass.script.run_command("r3.mapcalc", overwrite=True, quiet=True, expression="a3 = 3")
- ret += grass.script.run_command("r3.mapcalc", overwrite=True, quiet=True, expression="a4 = 4")
- tgis.open_new_stds(name="A", type="str3ds", temporaltype="absolute",
- title="A", descr="A", semantic="field", overwrite=True)
- tgis.register_maps_in_space_time_dataset(type="rast3d", name="A", maps="a1,a2,a3,a4",
- start="2001-01-01", increment="1 day", interval=True)
- def test_temporal_neighbors_1(self):
- """Simple temporal neighborhood computation test"""
- tra = tgis.TemporalRaster3DAlgebraParser(run = True, debug = True)
- tra.parse(expression='D = A[-1] + A[1]',
- basename="d", overwrite=True)
- D = tgis.open_old_stds("D", type="str3ds")
- D.select()
- self.assertEqual(D.metadata.get_number_of_maps(), 2)
- self.assertEqual(D.metadata.get_min_min(), 4) # 1 + 3
- self.assertEqual(D.metadata.get_max_max(), 6) # 2 + 4
- start, end = D.get_absolute_time()
- self.assertEqual(start, datetime.datetime(2001, 1, 2))
- self.assertEqual(end, datetime.datetime(2001, 1, 4))
- def test_temporal_neighbors_2(self):
- tra.parse(expression='D = A[0,0,0,-1] + A[0,0,0,1]',
- D.select()
- def tearDown(self):
- ret = grass.script.run_command("t.remove", type="str3ds", flags="rf", input="D", quiet=True)
- @classmethod
- def tearDownClass(cls):
- ret = grass.script.run_command("t.remove", type="str3ds", flags="rf", input="A", quiet=True)
- grass.script.del_temp_region()
-if __name__ == '__main__':
- gunittest.test()
Deleted: grass/trunk/lib/python/temporal/testsuite/test_temporal_raster_algebra.py
--- grass/trunk/lib/python/temporal/testsuite/test_temporal_raster_algebra.py 2014-11-04 15:04:13 UTC (rev 62593)
+++ grass/trunk/lib/python/temporal/testsuite/test_temporal_raster_algebra.py 2014-11-04 15:45:52 UTC (rev 62594)
@@ -1,375 +0,0 @@
-for details.
-import datetime
-import os
- @classmethod
- w=0.0, t=1.0, b=0.0, res=10.0)
- ret += grass.script.run_command("r.mapcalc", overwrite=True, quiet=True, expression="a1 = 1")
- ret += grass.script.run_command("r.mapcalc", overwrite=True, quiet=True, expression="a2 = 2")
- ret += grass.script.run_command("r.mapcalc", overwrite=True, quiet=True, expression="a3 = 3")
- ret += grass.script.run_command("r.mapcalc", overwrite=True, quiet=True, expression="a4 = 4")
- ret += grass.script.run_command("r.mapcalc", overwrite=True, quiet=True, expression="b1 = 5")
- ret += grass.script.run_command("r.mapcalc", overwrite=True, quiet=True, expression="b2 = 6")
- ret += grass.script.run_command("r.mapcalc", overwrite=True, quiet=True, expression="c1 = 7")
- tgis.open_new_stds(name="A", type="strds", temporaltype="absolute",
- tgis.open_new_stds(name="B", type="strds", temporaltype="absolute",
- title="B", descr="B", semantic="field", overwrite=True)
- tgis.open_new_stds(name="C", type="strds", temporaltype="absolute",
- title="B", descr="C", semantic="field", overwrite=True)
- tgis.register_maps_in_space_time_dataset(type="rast", name="A", maps="a1,a2,a3,a4",
- tgis.register_maps_in_space_time_dataset(type="rast", name="B", maps="b1,b2",
- start="2001-01-01", increment="2 day", interval=True)
- tgis.register_maps_in_space_time_dataset(type="rast", name="C", maps="c1",
- start="2001-01-02", increment="2 day", interval=True)
- def test_temporal_conditional_time_dimension_bug(self):
- """Testing the conditional time dimension bug, that uses the time
- dimension of the conditional statement instead the time dimension
- of the then/else statement."""
- tra = tgis.TemporalRasterAlgebraParser(run = True, debug = True)
- tra.parse(expression="D = if({contains}, B == 5, A - 1, A + 1)", basename="d", overwrite=True)
- D = tgis.open_old_stds("D", type="strds")
- D.select()
- self.assertEqual(D.metadata.get_number_of_maps(), 4)
- self.assertEqual(D.metadata.get_min_min(), 0) # 1 - 1
- self.assertEqual(D.metadata.get_max_max(), 5) # 4 + 1
- self.assertEqual(start, datetime.datetime(2001, 1, 1))
- self.assertEqual(end, datetime.datetime(2001, 1, 5))
- self.assertEqual( D.check_temporal_topology(), True)
- self.assertEqual(D.get_granularity(), u'1 day')
- def test_simple_arith_hash_1(self):
- """Simple arithmetic test including the hash operator"""
- tra.parse(expression='D = A + A{equal,=#}A', basename="d", overwrite=True)
- D.select()
- self.assertEqual(D.metadata.get_min_min(), 2)
- def test_simple_arith_td_1(self):
- """Simple arithmetic test"""
- tra.parse(expression='D = A + td(A)', basename="d", overwrite=True)
- D.select()
- def test_simple_arith_td_2(self):
- tra.parse(expression='D = A / td(A)', basename="d", overwrite=True)
- D.select()
- self.assertEqual(D.metadata.get_min_min(), 1)
- self.assertEqual(D.metadata.get_max_max(), 4)
- def test_simple_arith_td_3(self):
- tra.parse(expression='D = A {equal,+} td(A)', basename="d", overwrite=True)
- D.select()
- def test_simple_arith_td_4(self):
- tra.parse(expression='D = A {equal,/} td(A)', basename="d", overwrite=True)
- D.select()
- def test_simple_arith_if_1(self):
- """Simple arithmetic test with if condition"""
- tra.parse(expression='D = if({equal}, start_date() >= "2001-01-02", A + A)', basename="d", overwrite=True)
- D.select()
- self.assertEqual(D.metadata.get_number_of_maps(), 3)
- self.assertEqual(D.metadata.get_max_max(), 8)
- def test_simple_arith_if_2(self):
- tra.parse(expression='D = if({equal}, A#A == 1, A - A)', basename="d", overwrite=True)
- D.select()
- self.assertEqual(D.metadata.get_max_max(), 0)
- def test_complex_arith_if_1(self):
- """Complex arithmetic test with if condition"""
- tra.parse(expression='D = if(start_date() < "2001-01-03" && A#A == 1, A{starts,=+}C, A{finishes,=+}C)', \
- D.select()
- self.assertEqual(D.metadata.get_min_min(), 9) # 2 + 7 a2 + c1
- self.assertEqual(D.metadata.get_max_max(), 10) # 3 + 7 a3 + c1
- def test_simple_arith_1(self):
- tra.parse(expression="D = A {equal,*} A {equal,+} A", basename="d", overwrite=True)
- D.select()
- self.assertEqual(D.metadata.get_min_min(), 2) # 1*1 + 1
- self.assertEqual(D.metadata.get_max_max(), 20) # 4*4 + 4
- def test_simple_arith_2(self):
- """Simple arithmetic test that creates an empty strds"""
- tra.parse(expression="D = A {during,*} A {during,+} A", basename="d", overwrite=True)
- D.select()
- self.assertEqual(D.metadata.get_number_of_maps(), 0)
- def test_simple_arith_3(self):
- tra.parse(expression="D = A / A + A*A/A", basename="d", overwrite=True)
- D.select()
- self.assertEqual(D.metadata.get_min_min(), 2) # 1/1 + 1*1/1
- self.assertEqual(D.metadata.get_max_max(), 5) # 4/4 + 4*4/4
- def test_temporal_intersection_1(self):
- """Simple temporal intersection test"""
- tra.parse(expression="D = A {equal,&+} B", basename="d", overwrite=True)
- D.select()
- def test_temporal_intersection_2(self):
- tra.parse(expression="D = A {during,&+} B", basename="d", overwrite=True)
- D.select()
- self.assertEqual(D.metadata.get_min_min(), 6) # 1 + 5
- self.assertEqual(D.metadata.get_max_max(), 10) # 4 + 6
- def test_temporal_intersection_3(self):
- tra.parse(expression="D = A {starts,&+} B", basename="d", overwrite=True)
- D.select()
- self.assertEqual(D.metadata.get_max_max(), 9) # 3 + 6
- def test_temporal_intersection_4(self):
- tra.parse(expression="D = A {finishes,&+} B", basename="d", overwrite=True)
- D.select()
- self.assertEqual(D.metadata.get_min_min(), 7) # 2 + 5
- def test_temporal_intersection_5(self):
- tra.parse(expression="D = A {starts|finishes,&+} B", basename="d", overwrite=True)
- D.select()
- def test_temporal_intersection_6(self):
- tra.parse(expression="D = B {overlaps,|+} C", basename="d", overwrite=True)
- D.select()
- self.assertEqual(D.metadata.get_number_of_maps(), 1)
- self.assertEqual(D.metadata.get_min_min(), 12) # 5 + 7
- self.assertEqual(D.metadata.get_max_max(), 12) # 5 + 7
- def test_temporal_intersection_7(self):
- tra.parse(expression="D = B {overlapped,|+} C", basename="d", overwrite=True)
- D.select()
- self.assertEqual(D.metadata.get_min_min(), 13) # 6 + 7
- self.assertEqual(D.metadata.get_max_max(), 13) # 6 + 7
- def test_temporal_intersection_8(self):
- tra.parse(expression='D = A {during,=+} buff_t(C, "1 day") ',
- D.select()
- self.assertEqual(D.metadata.get_min_min(), 8) # 1 + 7 a1 + c1
- self.assertEqual(D.metadata.get_max_max(), 11) # 4 + 7 a4 + c1
- D.select()
- tra.parse(expression='D = A[0,0,-1] + A[0,0,1]',
- D.select()
- ret = grass.script.run_command("t.remove", flags="rf", input="D", quiet=True)
- @classmethod
- ret = grass.script.run_command("t.remove", flags="rf", input="A,B,C", quiet=True)
- gunittest.test()
Added: grass/trunk/lib/python/temporal/testsuite/unittests_temporal_algebra.py
--- grass/trunk/lib/python/temporal/testsuite/unittests_temporal_algebra.py (rev 0)
+++ grass/trunk/lib/python/temporal/testsuite/unittests_temporal_algebra.py 2014-11-04 15:45:52 UTC (rev 62594)
@@ -0,0 +1,352 @@
+(C) 2013 by the GRASS Development Team
+This program is free software under the GNU General Public
+License (>=v2). Read the file COPYING that comes with GRASS
+for details.
+:authors: Soeren Gebbert and Thomas Leppelt
+import grass.script
+import grass.temporal as tgis
+import grass.gunittest
+import datetime
+import os
+class TestTemporalAlgebra(grass.gunittest.TestCase):
+ @classmethod
+ def setUpClass(cls):
+ tgis.init(True) # Raise on error instead of exit(1)
+ cls.use_temp_region()
+ cls.runModule("g.region", n=80.0, s=0.0, e=120.0,
+ w=0.0, t=1.0, b=0.0, res=10.0)
+ cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="a1 = 1")
+ cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="a2 = 2")
+ cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="a3 = 3")
+ cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="a4 = 4")
+ cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="b1 = 5")
+ cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="b2 = 6")
+ cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="c1 = 7")
+ cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="d1 = 8")
+ cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="d2 = 9")
+ cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="d3 = 10")
+ cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="singletmap = 99")
+ tgis.open_new_stds(name="A", type="strds", temporaltype="absolute",
+ title="A", descr="A", semantic="field", overwrite=True)
+ tgis.open_new_stds(name="B", type="strds", temporaltype="absolute",
+ title="B", descr="B", semantic="field", overwrite=True)
+ tgis.open_new_stds(name="C", type="strds", temporaltype="absolute",
+ title="C", descr="C", semantic="field", overwrite=True)
+ tgis.open_new_stds(name="D", type="strds", temporaltype="absolute",
+ title="D", descr="D", semantic="field", overwrite=True)
+ tgis.register_maps_in_space_time_dataset(type="rast", name="A", maps="a1,a2,a3,a4",
+ start="2001-01-01", increment="1 day", interval=True)
+ tgis.register_maps_in_space_time_dataset(type="rast", name="B", maps="b1,b2",
+ start="2001-01-01", increment="2 day", interval=True)
+ tgis.register_maps_in_space_time_dataset(type="rast", name="C", maps="c1",
+ start="2001-01-02", increment="2 day", interval=True)
+ tgis.register_maps_in_space_time_dataset(type="rast", name="D", maps="d1,d2,d3",
+ start="2001-01-03", increment="1 day", interval=True)
+ tgis.register_maps_in_space_time_dataset(type="rast", name=None, maps="singletmap",
+ start="2001-01-03", end="2001-01-04", interval=True)
+ def tearDown(self):
+ self.runModule("t.remove", inputs="R", quiet=True)
+ @classmethod
+ def tearDownClass(cls):
+ cls.runModule("t.remove", flags="rf", inputs="A,B,C,D", quiet=True)
+ cls.del_temp_region()
+ def test_temporal_select1(self):
+ """Testing the temporal select operator with equal relations. """
+ ta = tgis.TemporalAlgebraParser(run = True, debug = True)
+ ta.parse(expression="R = A : A", basename="r", overwrite=True)
+ D = tgis.open_old_stds("R", type="strds")
+ D.select()
+ self.assertEqual(D.metadata.get_number_of_maps(), 4)
+ self.assertEqual(D.metadata.get_min_min(), 1)
+ self.assertEqual(D.metadata.get_max_max(), 4)
+ start, end = D.get_absolute_time()
+ self.assertEqual(start, datetime.datetime(2001, 1, 1))
+ self.assertEqual(end, datetime.datetime(2001, 1, 5))
+ self.assertEqual( D.check_temporal_topology(), True)
+ self.assertEqual(D.get_granularity(), u'1 day')
+ def test_temporal_select2(self):
+ ta.parse(expression="R = A : D", basename="r", overwrite=True)
+ D.select()
+ self.assertEqual(D.metadata.get_number_of_maps(), 2)
+ self.assertEqual(D.metadata.get_min_min(), 3)
+ self.assertEqual(start, datetime.datetime(2001, 1, 3))
+ def test_temporal_select3(self):
+ ta.parse(expression="R = A !: D", basename="r", overwrite=True)
+ D.select()
+ self.assertEqual(D.metadata.get_max_max(), 2)
+ self.assertEqual(end, datetime.datetime(2001, 1, 3))
+ def test_temporal_select_operators1(self):
+ """Testing the temporal select operator. Including temporal relations. """
+ ta.parse(expression="R = A {:,during} C", basename="r", overwrite=True)
+ D.select()
+ self.assertEqual(D.metadata.get_min_min(), 2)
+ self.assertEqual(D.metadata.get_max_max(), 3)
+ self.assertEqual(start, datetime.datetime(2001, 1, 2))
+ self.assertEqual(end, datetime.datetime(2001, 1, 4))
+ def test_temporal_select_operators2(self):
+ ta.parse(expression="R = A {:,equal|during} C", basename="r", overwrite=True)
+ D.select()
+ def test_temporal_select_operators3(self):
+ and negation operation. """
+ ta.parse(expression="R = A {!:,during} C", basename="r", overwrite=True)
+ D.select()
+ def test_temporal_select_operators4(self):
+ """Testing the temporal select operator. Including temporal relations and
+ temporal operators. """
+ ta.parse(expression="R = A {:,during,d} C", basename="r", overwrite=True)
+ D.select()
+ maplist = D.get_registered_maps_as_objects()
+ start_map, end_map = map_i.get_absolute_time()
+ self.assertEqual(start_map, datetime.datetime(2001, 1, 2))
+ self.assertEqual(end_map, datetime.datetime(2001, 1, 4))
+ self.assertEqual( D.check_temporal_topology(), False)
+ self.assertEqual(D.get_granularity(), u'2 days')
+ def test_temporal_select_operators5(self):
+ ta.parse(expression="R = C {:,contains} A", basename="r", overwrite=True)
+ D.select()
+ self.assertEqual(D.metadata.get_number_of_maps(), 1)
+ self.assertEqual(D.metadata.get_min_min(), 7)
+ self.assertEqual(D.metadata.get_max_max(), 7)
+ def test_temporal_extent1(self):
+ """Testing the temporal extent operators. """
+ ta.parse(expression="R = A {:,during,r} C", basename="r", overwrite=True)
+ D.select()
+ def test_temporal_extent2(self):
+ D.select()
+ def test_temporal_extent3(self):
+ ta.parse(expression="R = A {:,during,u} C", basename="r", overwrite=True)
+ D.select()
+ def test_temporal_hash1(self):
+ """Testing the hash function in conditional statement. """
+ ta.parse(expression="R = if(A # D == 1, A)", basename="r", overwrite=True)
+ D.select()
+ def test_temporal_hash_operator1(self):
+ """Testing the hash operator function in conditional statement. """
+ ta.parse(expression="R = if(A {#,during} C == 1, A)", basename="r", overwrite=True)
+ D.select()
+ def test_temporal_hash_operator2(self):
+ ta.parse(expression="R = if({during}, C {#,contains} A == 2, A)", basename="r", overwrite=True)
+ D.select()
+ def test_tmap_function1(self):
+ """Testing the tmap function. """
+ ta.parse(expression='R = tmap(singletmap)', basename="r", overwrite=True)
+ D.select()
+ self.assertEqual(D.metadata.get_min_min(), 99)
+ self.assertEqual(D.metadata.get_max_max(), 99)
+ def test_tmap_function2(self):
+ ta.parse(expression='R = A : tmap(singletmap)', basename="r", overwrite=True)
+ D.select()
+if __name__ == '__main__':
+ grass.gunittest.test()
Added: grass/trunk/lib/python/temporal/testsuite/unittests_temporal_conditionals.py
--- grass/trunk/lib/python/temporal/testsuite/unittests_temporal_conditionals.py (rev 0)
+++ grass/trunk/lib/python/temporal/testsuite/unittests_temporal_conditionals.py 2014-11-04 15:45:52 UTC (rev 62594)
@@ -0,0 +1,356 @@
+(C) 2014 by the GRASS Development Team
+for details.
+:authors: Thomas leppelt and Soeren Gebbert
+import datetime
+import os
+class TestTemporalConditionals(grass.gunittest.TestCase):
+ @classmethod
+ cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="e1 = 11")
+ cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="e2 = 12")
+ cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="e3 = 13")
+ tgis.open_new_stds(name="E", type="strds", temporaltype="absolute",
+ title="E", descr="E", semantic="field", overwrite=True)
+ tgis.register_maps_in_space_time_dataset(type="rast", name="E", maps="e1,e2,e3",
+ start="2000-12-31", increment="2 day", interval=True)
+ @classmethod
+ cls.runModule("t.remove", flags="rf", inputs="A,B,C,D,E", quiet=True)
+ def test_temporal_condition_1(self):
+ ta.parse(expression='R = if(start_date(A) >= "2001-01-03", A)', basename="r", overwrite=True)
+ D.select()
+ def test_temporal_condition_2(self):
+ ta.parse(expression='R = if(td(A) == 1, A)', basename="r", overwrite=True)
+ D.select()
+ def test_temporal_condition_3(self):
+ ta.parse(expression='R = if(td(A) == 1 || start_date(A) >= "2001-01-03", A)', basename="r", overwrite=True)
+ D.select()
+ def test_temporal_condition_4(self):
+ D.select()
+ def test_temporal_condition_5(self):
+ ta.parse(expression='R = if(start_day(A) <= 2, A)', basename="r", overwrite=True)
+ D.select()
+ def test_temporal_condition_6(self):
+ ta.parse(expression='R = if(td(A) == 1 {||,during} start_date(C) < "2001-01-02", A)', basename="r", overwrite=True)
+ D.select()
+ def test_temporal_condition_7(self):
+ ta.parse(expression='R = if({over},start_date(C) == "2001-01-02" {&&,contains} td(A) == 1, B)', basename="r", overwrite=True)
+ D.select()
+ self.assertEqual(D.metadata.get_min_min(), 5)
+ self.assertEqual(D.metadata.get_max_max(), 6)
+ def test_temporal_condition_8(self):
+ ta.parse(expression='R = if(start_date(B) <= "2001-01-01" {||,over,|} td(E) == 2, B)', basename="r", overwrite=True)
+ D.select()
+ def test_temporal_condition_9(self):
+ ta.parse(expression='R = if(start_date(B) <= "2001-01-01" {&&,over,&} td(E) == 2, B)', basename="r", overwrite=True)
+ D.select()
+ self.assertEqual(D.metadata.get_max_max(), 5)
+ def test_temporal_condition_10(self):
+ ta.parse(expression='R = if(start_date(B) <= "2001-01-01" {||,over,|,r} td(E) == 2, E)', basename="r", overwrite=True)
+ D.select()
+ self.assertEqual(D.metadata.get_number_of_maps(), 3)
+ self.assertEqual(D.metadata.get_min_min(), 11)
+ self.assertEqual(D.metadata.get_max_max(), 13)
+ self.assertEqual(start, datetime.datetime(2000, 12, 31))
+ self.assertEqual(end, datetime.datetime(2001, 1, 6))
+ def test_temporal_condition_11(self):
+ ta.parse(expression='R = if(start_date(B) <= "2001-01-01" {&&,over,r} td(E) == 2, E)', basename="r", overwrite=True)
+ D.select()
+ self.assertEqual(D.metadata.get_max_max(), 11)
+ self.assertEqual(end, datetime.datetime(2001, 1, 2))
+ def test_temporal_condition_12(self):
+ ta.parse(expression='R = if(start_date(B) <= "2001-01-01" {&&,over,|,r} td(E) == 2, E)', basename="r", overwrite=True)
+ D.select()
+ def test_temporal_conditional_13(self):
+ ta.parse(expression='R = if({equal|during},td(B) == 2 {&&,contains} td(A) == 1, A)', basename="r", overwrite=True)
+ D.select()
+ def test_temporal_condition_else_1(self):
+ ta.parse(expression='R = if(start_date(A) <= "2001-01-03", A, D)', basename="r", overwrite=True)
+ D.select()
+ self.assertEqual(D.metadata.get_max_max(), 9)
+ def test_temporal_condition_else_2(self):
+ ta.parse(expression='R = if(td(D) == 1 && start_date(A) >= "2001-01-04", A, D)', basename="r", overwrite=True)
+ D.select()
+ self.assertEqual(D.metadata.get_min_min(), 4)
+ self.assertEqual(D.metadata.get_max_max(), 8)
+ def test_temporal_condition_else_3(self):
+ ta.parse(expression='R = if({during},td(B) == 2 {&&,contains} start_date(D) >= "2001-01-04", A, D)', basename="r", overwrite=True)
+ D.select()
+ self.assertEqual(D.metadata.get_min_min(), 8)
+ def test_temporal_condition_else_4(self):
+ ta.parse(expression='R = if({equal|over},start_date(B) <= "2001-01-01" {&&,over,|,r} td(E) == 2, E, B)', basename="r", overwrite=True)
+ D.select()
+ for map in D.get_registered_maps_as_objects():
+ print(map.get_map_id())
Added: grass/trunk/lib/python/temporal/testsuite/unittests_temporal_raster3d_algebra.py
--- grass/trunk/lib/python/temporal/testsuite/unittests_temporal_raster3d_algebra.py (rev 0)
+++ grass/trunk/lib/python/temporal/testsuite/unittests_temporal_raster3d_algebra.py 2014-11-04 15:45:52 UTC (rev 62594)
@@ -0,0 +1,83 @@
+for details.
+import grass.gunittest as gunittest
+import datetime
+import os
+class TestTemporalRaster3dAlgebra(gunittest.TestCase):
+ @classmethod
+ ret = grass.script.run_command("g.region", n=80.0, s=0.0, e=120.0,
+ w=0.0, t=100.0, b=0.0, res=10.0)
+ cls.runModule("r3.mapcalc", overwrite=True, quiet=True, expression="a1 = 1")
+ cls.runModule("r3.mapcalc", overwrite=True, quiet=True, expression="a2 = 2")
+ cls.runModule("r3.mapcalc", overwrite=True, quiet=True, expression="a3 = 3")
+ cls.runModule("r3.mapcalc", overwrite=True, quiet=True, expression="a4 = 4")
+ tgis.open_new_stds(name="A", type="str3ds", temporaltype="absolute",
+ tgis.register_maps_in_space_time_dataset(type="rast3d", name="A", maps="a1,a2,a3,a4",
+ self.runModule("t.remove", type="str3ds", flags="rf", inputs="D", quiet=True)
+ @classmethod
+ cls.runModule("t.remove", type="str3ds", flags="rf", inputs="A", quiet=True)
+ def test_temporal_neighbors_1(self):
+ """Simple temporal neighborhood computation test"""
+ tra = tgis.TemporalRaster3DAlgebraParser(run = True, debug = True)
+ tra.parse(expression='D = A[-1] + A[1]',
+ basename="d", overwrite=True)
+ D = tgis.open_old_stds("D", type="str3ds")
+ D.select()
+ self.assertEqual(D.metadata.get_min_min(), 4) # 1 + 3
+ self.assertEqual(D.metadata.get_max_max(), 6) # 2 + 4
+ def test_temporal_neighbors_2(self):
+ tra.parse(expression='D = A[0,0,0,-1] + A[0,0,0,1]',
+ D.select()
Added: grass/trunk/lib/python/temporal/testsuite/unittests_temporal_raster_algebra.py
--- grass/trunk/lib/python/temporal/testsuite/unittests_temporal_raster_algebra.py (rev 0)
+++ grass/trunk/lib/python/temporal/testsuite/unittests_temporal_raster_algebra.py 2014-11-04 15:45:52 UTC (rev 62594)
@@ -0,0 +1,696 @@
+ time using tgis.register_maps_in_space_time_dataset()
+for details.
+ at author Soeren Gebbert
+import datetime
+import os
+class TestTemporalRasterAlgebra(gunittest.TestCase):
+ @classmethod
+ cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="singlemap = 100")
+ title="B", descr="C", semantic="field", overwrite=True)
+ self.runModule("t.remove", flags="rf", inputs="R", quiet=True)
+ @classmethod
+ cls.runModule("t.unregister", maps="singletmap", quiet=True)
+ def test_temporal_conditional_time_dimension_bug(self):
+ """Testing the conditional time dimension bug, that uses the time
+ dimension of the conditional statement instead the time dimension
+ of the then/else statement."""
+ tra = tgis.TemporalRasterAlgebraParser(run = True, debug = True)
+ tra.parse(expression="R = if({contains}, B == 5, A - 1, A + 1)", basename="r", overwrite=True)
+ D.select()
+ self.assertEqual(D.metadata.get_min_min(), 0) # 1 - 1
+ self.assertEqual(D.metadata.get_max_max(), 5) # 4 + 1
+ def test_simple_arith_hash_1(self):
+ """Simple arithmetic test including the hash operator"""
+ tra.parse(expression='R = A + A {#, equal,l} A', basename="r", overwrite=True)
+ D.select()
+ def test_simple_arith_td_1(self):
+ """Simple arithmetic test"""
+ tra.parse(expression='R = A + td(A)', basename="r", overwrite=True)
+ D.select()
+ def test_simple_arith_td_2(self):
+ tra.parse(expression='R = A / td(A)', basename="r", overwrite=True)
+ D.select()
+ def test_simple_arith_td_3(self):
+ tra.parse(expression='R = A {+,equal} td(A)', basename="r", overwrite=True)
+ D.select()
+ def test_simple_arith_td_4(self):
+ tra.parse(expression='R = A {/, equal} td(A)', basename="r", overwrite=True)
+ D.select()
+ def test_simple_arith_if_1(self):
+ """Simple arithmetic test with if condition"""
+ tra.parse(expression='R = if({equal}, start_date(A) >= "2001-01-02", A + A)', basename="r", overwrite=True)
+ D.select()
+ def test_simple_arith_if_2(self):
+ tra.parse(expression='R = if({equal}, A#A == 1, A - A)', basename="r", overwrite=True)
+ D.select()
+ self.assertEqual(D.metadata.get_max_max(), 0)
+ def test_complex_arith_if_1(self):
+ """Complex arithmetic test with if condition"""
+ tra.parse(expression='R = if(start_date(A) < "2001-01-03" && A#A == 1, A{+, starts,l}C, A{+, finishes,l}C)', \
+ basename="r", overwrite=True)
+ D.select()
+ self.assertEqual(D.metadata.get_min_min(), 9) # 2 + 7 a2 + c1
+ self.assertEqual(D.metadata.get_max_max(), 10) # 3 + 7 a3 + c1
+ def test_simple_arith_1(self):
+ tra.parse(expression="R = A {*, equal} A {+, equal} A", basename="r", overwrite=True)
+ D.select()
+ self.assertEqual(D.metadata.get_min_min(), 2) # 1*1 + 1
+ self.assertEqual(D.metadata.get_max_max(), 20) # 4*4 + 4
+ def test_simple_arith_2(self):
+ """Simple arithmetic test that creates an empty strds"""
+ tra.parse(expression="R = A {*, during} A {+, during} A", basename="r", overwrite=True)
+ D.select()
+ self.assertEqual(D.metadata.get_number_of_maps(), 0)
+ def test_simple_arith_3(self):
+ tra.parse(expression="R = A / A + A*A/A", basename="r", overwrite=True)
+ D.select()
+ self.assertEqual(D.metadata.get_min_min(), 2) # 1/1 + 1*1/1
+ self.assertEqual(D.metadata.get_max_max(), 5) # 4/4 + 4*4/4
+ def test_temporal_intersection_1(self):
+ """Simple temporal intersection test"""
+ tra.parse(expression="R = A {+,equal,i} B", basename="r", overwrite=True)
+ D.select()
+ def test_temporal_intersection_2(self):
+ tra.parse(expression="R = A {+,during,i} B", basename="r", overwrite=True)
+ D.select()
+ self.assertEqual(D.metadata.get_min_min(), 6) # 1 + 5
+ self.assertEqual(D.metadata.get_max_max(), 10) # 4 + 6
+ def test_temporal_intersection_3(self):
+ tra.parse(expression="R = A {+,starts,i} B", basename="r", overwrite=True)
+ D.select()
+ self.assertEqual(D.metadata.get_max_max(), 9) # 3 + 6
+ def test_temporal_intersection_4(self):
+ tra.parse(expression="R = A {+,finishes,intersect} B", basename="r", overwrite=True)
+ D.select()
+ self.assertEqual(D.metadata.get_min_min(), 7) # 2 + 5
+ def test_temporal_intersection_5(self):
+ tra.parse(expression="R = A {+,starts|finishes,i} B", basename="r", overwrite=True)
+ D.select()
+ def test_temporal_intersection_6(self):
+ tra.parse(expression="R = B {+,overlaps,u} C", basename="r", overwrite=True)
+ D.select()
+ self.assertEqual(D.metadata.get_min_min(), 12) # 5 + 7
+ self.assertEqual(D.metadata.get_max_max(), 12) # 5 + 7
+ def test_temporal_intersection_7(self):
+ tra.parse(expression="R = B {+,overlapped,u} C", basename="r", overwrite=True)
+ D.select()
+ self.assertEqual(D.metadata.get_min_min(), 13) # 6 + 7
+ self.assertEqual(D.metadata.get_max_max(), 13) # 6 + 7
+ def test_temporal_intersection_8(self):
+ tra.parse(expression='R = A {+,during,l} buff_t(C, "1 day") ',
+ D.select()
+ self.assertEqual(D.metadata.get_min_min(), 8) # 1 + 7 a1 + c1
+ self.assertEqual(D.metadata.get_max_max(), 11) # 4 + 7 a4 + c1
+ tra.parse(expression='R = A[-1] + A[1]',
+ D.select()
+ tra.parse(expression='R = A[0,0,-1] + A[0,0,1]',
+ D.select()
+ tra.parse(expression='R = tmap(singletmap)', basename="r", overwrite=True)
+ D.select()
+ tra.parse(expression='R = tmap(singletmap) + 1', basename="r", overwrite=True)
+ D.select()
+ self.assertEqual(D.metadata.get_min_min(), 100)
+ self.assertEqual(D.metadata.get_max_max(), 100)
+ def test_map_function1(self):
+ """Testing the map function. """
+ tra.parse(expression='R = map(singlemap) + A', basename="r", overwrite=True)
+ D.select()
+ self.assertEqual(D.metadata.get_min_min(), 101)
+ self.assertEqual(D.metadata.get_max_max(), 104)
+ def test_map_function2(self):
+ tra.parse(expression='R = A * map(singlemap)', basename="r", overwrite=True)
+ D.select()
+ self.assertEqual(D.metadata.get_max_max(), 400)
+ def test_temporal_select(self):
+ """Testing the temporal select operator. """
+ tra.parse(expression="R = A : A", basename="r", overwrite=True)
+ D.select()
+ tra.parse(expression="R = A : D", basename="r", overwrite=True)
+ D.select()
+ D.select()
+ tra.parse(expression="R = A {!:,during} C", basename="r", overwrite=True)
+ D.select()
+ different temporal operators (lr|+&)"""
+ tra.parse(expression="R = A {:,during,d} B", basename="r", overwrite=True)
+ D.select()
+ tra.parse(expression="R = A {:,equal|during,r} C", basename="r", overwrite=True)
+ D.select()
+ """Testing the temporal hash operator in the raster algebra. """
+ tra.parse(expression="R = if(A # D == 1, A)", basename="r", overwrite=True)
+ D.select()
+ tra.parse(expression="R = A # D", basename="r", overwrite=True)
+ D.select()
+ self.assertEqual(D.metadata.get_max_max(), 1)
+ def test_temporal_hash_operator3(self):
+ tra.parse(expression="R = C {#,contains} A", basename="r", overwrite=True)
+ D.select()
+ def test_temporal_hash_operator4(self):
+ tra.parse(expression="R = if({contains},A # D == 1, C {#,contains} A)", basename="r", overwrite=True)
+ D.select()
+ def test_raster_arithmetic_relation_1(self):
+ """Arithmetic test with temporal intersection"""
+ tra.parse(expression="R = B {+,contains,l} A ", basename="r", overwrite=True)
+ D.select()
+ def test_raster_arithmetic_relation_2(self):
+ tra.parse(expression="R = B {*,contains,l} A ", basename="r", overwrite=True)
+ D.select()
+ self.assertEqual(D.metadata.get_min_min(), 10)
+ self.assertEqual(D.metadata.get_max_max(), 72)
+ def test_raster_arithmetic_relation_3(self):
+ D.select()
+ def test_raster_arithmetic_relation_4(self):
+ tra.parse(expression="R = B {+,contains,r} A ", basename="r", overwrite=True)
+ D.select()
+ self.assertEqual(D.metadata.get_number_of_maps(),4)
+ def test_raster_arithmetic_relation_5(self):
+ """Complex arithmetic test with temporal intersection"""
+ tra.parse(expression="R = tmap(singletmap) {+,equal| precedes| follows,l} A + map(singlemap)", basename="r", overwrite=True)
+ D.select()
+ self.assertEqual(D.metadata.get_number_of_maps(),1)
+ self.assertEqual(D.metadata.get_min_min(), 208)
+ self.assertEqual(D.metadata.get_max_max(), 208)
+ gunittest.test()
Added: grass/trunk/lib/python/temporal/testsuite/unittests_temporal_raster_conditionals.py
--- grass/trunk/lib/python/temporal/testsuite/unittests_temporal_raster_conditionals.py (rev 0)
+++ grass/trunk/lib/python/temporal/testsuite/unittests_temporal_raster_conditionals.py 2014-11-04 15:45:52 UTC (rev 62594)
@@ -0,0 +1,498 @@
+for details.
+:authors: Thomas Leppelt
+import datetime
+import os
+class TestTemporalRasterAlgebraConditionals(gunittest.TestCase):
+ @classmethod
+ cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="d4 = 11")
+ tgis.register_maps_in_space_time_dataset(type="rast", name="D", maps="d1,d2,d3,d4",
+ @classmethod
+ tra.parse(expression='R = if({contains}, B == 5, A - 1, A + 1)', basename="r", overwrite=True)
+ R = tgis.open_old_stds("R", type="strds")
+ R.select()
+ self.assertEqual(R.metadata.get_number_of_maps(), 4)
+ self.assertEqual(R.metadata.get_min_min(), 0) # 1 - 1
+ self.assertEqual(R.metadata.get_max_max(), 5) # 4 + 1
+ start, end = R.get_absolute_time()
+ self.assertEqual( R.check_temporal_topology(), True)
+ self.assertEqual(R.get_granularity(), u'1 day')
+ def test_temporal_conditional_1(self):
+ tra.parse(expression='R = if(td(A) == 1, D * 2, D)', basename="r", overwrite=True)
+ R.select()
+ self.assertEqual(R.metadata.get_number_of_maps(), 2)
+ self.assertEqual(R.metadata.get_min_min(), 16)
+ self.assertEqual(R.metadata.get_max_max(), 18)
+ def test_temporal_conditional_relation_1(self):
+ tra.parse(expression='R = if({during},exist(A), B - 1, B + 1)', basename="r", overwrite=True)
+ R.select()
+ self.assertEqual(R.metadata.get_min_min(), 4)
+ self.assertEqual( R.check_temporal_topology(), False)
+ self.assertEqual(R.get_granularity(), u'2 days')
+ def test_spatial_conditional_1(self):
+ """Testing the spatial conditionals combined by AND/OR operators.
+ Evaluation """
+ tra.parse(expression='R = if(A > 1 && A < 4 && isntnull(A), A)', basename="r", overwrite=True)
+ R.select()
+ self.assertEqual(R.metadata.get_max_max(), 3)
+ def test_spatial_conditional_2(self):
+ Evaluation """
+ tra.parse(expression='R = if(A > 1 && A < 4 && isntnull(A), A, null())', basename="r", overwrite=True)
+ R.select()
+ self.assertEqual(R.metadata.get_min_min(), 2)
+ def test_spatial_conditional_3(self):
+ Evaluation """
+ tra.parse(expression='R = if(A > 1, A, D)', basename="r", overwrite=True)
+ R.select()
+ self.assertEqual(R.metadata.get_min_min(), 3)
+ self.assertEqual(R.metadata.get_max_max(), 4)
+ def test_spatial_conditional_4(self):
+ Evaluation """
+ tra.parse(expression='R = if(A > 0, A)', basename="r", overwrite=True)
+ R.select()
+ self.assertEqual(R.metadata.get_min_min(), 1)
+ def test_spatial_conditional_5(self):
+ Evaluation """
+ tra.parse(expression='R = if(B > 5 {&&,contains,l} A < 5, B)', basename="r", overwrite=True)
+ R.select()
+ self.assertEqual(R.metadata.get_max_max(), 6)
+ def test_spatial_conditional_relation_1(self):
+ Evaluation """
+ tra.parse(expression='R = if({contains},B > 5, D)', basename="r", overwrite=True)
+ R.select()
+ self.assertEqual(R.metadata.get_min_min(), 8)
+ self.assertEqual(R.metadata.get_max_max(), 9)
+ def test_spatial_conditional_relation_2(self):
+ """Testing the spatial conditionals with numeric conclusions"""
+ tra.parse(expression='R = if({contains}, B <= 5, A, A * 2)', basename="r", overwrite=True)
+ R.select()
+ self.assertEqual(R.metadata.get_max_max(), 8)
+ def test_spatial_conditional_numeric_relation_1(self):
+ tra.parse(expression='R = if({contains}, B > 5, A, 10)', basename="r", overwrite=True)
+ R.select()
+ self.assertEqual(R.metadata.get_max_max(), 10)
+ def test_spatial_conditional_numeric_relation_2(self):
+ Evaluation """
+ tra.parse(expression='R = if({contains},B > 5, A + 2 / 4.0)', basename="r", overwrite=True)
+ R.select()
+ self.assertEqual(R.metadata.get_max_max(), 4.5)
+ def test_spatial_conditional_numeric_1(self):
+ tra.parse(expression='R = if(A > 2, 0, A)', basename="r", overwrite=True)
+ R.select()
+ self.assertEqual(R.metadata.get_max_max(), 2)
+ def test_spatial_conditional_numeric_2(self):
+ tra.parse(expression='R = if(A > 2, A, 8)', basename="r", overwrite=True)
+ R.select()
+ def test_spatial_conditional_numeric_3(self):
+ tra.parse(expression='R = if(A > 2, 1, 0)', basename="r", overwrite=True)
+ R.select()
+ self.assertEqual(R.metadata.get_max_max(), 1)
+ def test_spatial_conditional_numeric_4(self):
+ tra.parse(expression='R = if(A > 2, null())', basename="r", overwrite=True)
+ R.select()
+ self.assertEqual(R.metadata.get_max_max(), 0)
+ def test_spatiotemporal_conditional_1(self):
+ tra.parse(expression='R = if(A < 2 && start_date(A) < "2001-01-03", A)', basename="r", overwrite=True)
+ R.select()
+ def test_spatiotemporal_conditional_2(self):
+ tra.parse(expression='R = if(A < 3 || start_date(A) < "2001-01-04", A + 1, A - 1)', basename="r", overwrite=True)
+ R.select()
+ self.assertEqual(R.metadata.get_min_min(),2)
+ self.assertEqual(R.metadata.get_max_max(),4)
+ def test_spatiotemporal_conditional_relation_1(self):
+ tra.parse(expression='R = if({contains},B > 5 && start_day(B) < 3, D)', basename="r", overwrite=True)
+ R.select()
+ self.assertEqual(R.metadata.get_min_min(),0)
+ self.assertEqual(R.metadata.get_max_max(),0)
+ def test_spatiotemporal_conditional_relation_2(self):
+ tra.parse(expression='R = if({contains}, start_date(B) < "2001-01-03" || B <= 5, A, A * 2)', basename="r", overwrite=True)
+ R.select()
+ def test_spatiotemporal_conditional_numeric_relation_1(self):
+ tra.parse(expression='R = if({contains}, start_date(B) >= "2001-01-03" && B > 5, A, 10)', basename="r", overwrite=True)
+ R.select()
+ def test_spatiotemporal_conditional_numeric_relation_2(self):
+ Evaluation """
+ tra.parse(expression='R = if({contains},td(B) == 2 && start_date(B) == "2001-01-03" && B > 5 , A + 2 / 4.0)', basename="r", overwrite=True)
+ R.select()
+ def test_spatiotemporal_conditional_numeric_1(self):
+ tra.parse(expression='R = if(start_date(A) < "2001-01-04" && A > 2, 0, A)', basename="r", overwrite=True)
+ R.select()
+ def test_spatiotemporal_conditional_numeric_2(self):
+ tra.parse(expression='R = if(A > 2 || start_date(A) > "2001-01-01" && start_date(A) < "2001-01-04", A, 8)', basename="r", overwrite=True)
+ R.select()
+ def test_spatiotemporal_conditional_numeric_3(self):
+ tra.parse(expression='R = if(start_date(A) < "2001-01-04" && A > 2, 1, 0)', basename="r", overwrite=True)
+ R.select()
+ def test_spatiotemporal_conditional_numeric_4(self):
+ tra.parse(expression='R = if(A > 2 || start_date(A) > "2001-01-01", null())', basename="r", overwrite=True)
+ R.select()
+ self.assertEqual(R.metadata.get_number_of_maps(), 1)
+ gunittest.test()
Added: grass/trunk/lib/python/temporal/testsuite/unittests_temporal_vector_algebra.py
--- grass/trunk/lib/python/temporal/testsuite/unittests_temporal_vector_algebra.py (rev 0)
+++ grass/trunk/lib/python/temporal/testsuite/unittests_temporal_vector_algebra.py 2014-11-04 15:45:52 UTC (rev 62594)
@@ -0,0 +1,193 @@
+for details.
+import datetime
+import os
+class TestTemporalVectorAlgebra(gunittest.TestCase):
+ @classmethod
+ cls.runModule("v.random", overwrite=True, quiet=True, n=20, seed=1, output='a1')
+ cls.runModule("v.random", overwrite=True, quiet=True, n=20, seed=1, output='a2')
+ cls.runModule("v.random", overwrite=True, quiet=True, n=20, seed=1, output='a3')
+ cls.runModule("v.random", overwrite=True, quiet=True, n=20, seed=1, output='a4')
+ cls.runModule("v.random", overwrite=True, quiet=True, n=20, seed=2, output='b1')
+ cls.runModule("v.random", overwrite=True, quiet=True, n=20, seed=2, output='b2')
+ cls.runModule("v.random", overwrite=True, quiet=True, n=20, seed=3, output='c1')
+ cls.runModule("v.random", overwrite=True, quiet=True, n=20, seed=4, output='d1')
+ cls.runModule("v.random", overwrite=True, quiet=True, n=20, seed=4, output='d2')
+ cls.runModule("v.random", overwrite=True, quiet=True, n=20, seed=4, output='d3')
+ cls.runModule("v.random", overwrite=True, quiet=True, n=20, seed=5, output='singletmap')
+ cls.runModule("v.random", overwrite=True, quiet=True, n=20, seed=6, output='singlemap')
+ tgis.open_new_stds(name="A", type="stvds", temporaltype="absolute",
+ tgis.open_new_stds(name="B", type="stvds", temporaltype="absolute",
+ tgis.open_new_stds(name="C", type="stvds", temporaltype="absolute",
+ tgis.open_new_stds(name="D", type="stvds", temporaltype="absolute",
+ tgis.register_maps_in_space_time_dataset(type="vect", name="A", maps="a1,a2,a3,a4",
+ tgis.register_maps_in_space_time_dataset(type="vect", name="B", maps="b1,b2",
+ tgis.register_maps_in_space_time_dataset(type="vect", name="C", maps="c1",
+ tgis.register_maps_in_space_time_dataset(type="vect", name="D", maps="d1,d2,d3",
+ tgis.register_maps_in_space_time_dataset(type="vect", name=None, maps="singletmap",
+ self.runModule("t.remove", type="stvds", inputs="R", quiet=True)
+ @classmethod
+ cls.runModule("t.remove", flags="rf", inputs="A,B,C,D", type='stvds', quiet=True)
+ tva = tgis.TemporalVectorAlgebraParser(run = True, debug = True)
+ tva.parse(expression="R = A : A", basename="r", overwrite=True)
+ D = tgis.open_old_stds("R", type="stvds")
+ D.select()
+ self.assertEqual(D.metadata.get_number_of_points(), 80)
+ self.assertEqual(D.metadata.get_number_of_areas(), 0)
+ self.assertEqual(D.metadata.get_number_of_centroids(), 0)
+ def test_temporal_select_operators(self):
+ tva.parse(expression="R = A {:,during} C", basename="r", overwrite=True)
+ D.select()
+ self.assertEqual(D.metadata.get_number_of_points(), 40)
+ def test_temporal_buff_operators_1(self):
+ """Testing the bufferoperator."""
+ tva.parse(expression="R = buff_p(A,0.5)", basename="r", overwrite=True)
+ D.select()
+ self.assertEqual(D.metadata.get_number_of_points(), 0)
+ self.assertEqual(D.metadata.get_number_of_areas(), 80)
+ self.assertEqual(D.metadata.get_number_of_centroids(), 80)
+ def test_temporal_buff_operators_2(self):
+ tva.parse(expression="R = buff_a(buff_p(A,1),10)", basename="r", overwrite=True)
+ D.select()
+ self.assertEqual(D.metadata.get_number_of_areas(), 20)
+ self.assertEqual(D.metadata.get_number_of_centroids(), 20)
+ def test_temporal_overlay_operators_1(self):
+ """Testing the spatial overlay operator."""
+ tva.parse(expression="R = buff_p(A,2) & buff_p(D,2)", basename="r", overwrite=True)
+ D.select()
+ self.assertEqual(D.metadata.get_number_of_areas(), 6)
+ self.assertEqual(D.metadata.get_number_of_centroids(), 6)
+ def test_temporal_overlay_operators_2(self):
+ tva.parse(expression="R = buff_p(A,1.5) {&,during,r} buff_p(B,1.5)", basename="r", overwrite=True)
+ D.select()
+ self.assertEqual(D.metadata.get_number_of_areas(), 8)
+ self.assertEqual(D.metadata.get_number_of_centroids(), 8)
+ def test_temporal_overlay_operators_3(self):
+ tva.parse(expression="R = buff_p(A,2.5) {&,during,l} buff_p(C,2.5)", basename="r", overwrite=True)
+ D.select()
+ gunittest.test()
