[GRASS-SVN] r62613 - in grass/trunk/temporal/t.unregister: . testsuite
svn_grass at osgeo.org
Wed Nov 5 05:32:06 PST 2014
Author: huhabla
Date: 2014-11-05 05:32:06 -0800 (Wed, 05 Nov 2014)
New Revision: 62613
Added:
grass/trunk/temporal/t.unregister/testsuite/
grass/trunk/temporal/t.unregister/testsuite/test_unregister.py
temporal modules: New test for t.unregister
Added: grass/trunk/temporal/t.unregister/testsuite/test_unregister.py
--- grass/trunk/temporal/t.unregister/testsuite/test_unregister.py (rev 0)
+++ grass/trunk/temporal/t.unregister/testsuite/test_unregister.py 2014-11-05 13:32:06 UTC (rev 62613)
@@ -0,0 +1,139 @@
+"""Test t.unregister
+(C) 2014 by the GRASS Development Team
+This program is free software under the GNU General Public
+License (>=v2). Read the file COPYING that comes with GRASS
+for details.
+:authors: Soeren Gebbert
+import os
+import grass.pygrass.modules as pymod
+import grass.temporal as tgis
+from grass.gunittest.case import TestCase
+from grass.gunittest.gmodules import SimpleModule
+class TestUnregister(TestCase):
+ @classmethod
+ def setUpClass(cls):
+ """!Initiate the temporal GIS and set the region
+ tgis.init()
+ cls.use_temp_region()
+ cls.runModule("g.gisenv", set="TGIS_USE_CURRENT_MAPSET=1")
+ cls.runModule("g.region", s=0, n=80, w=0, e=120, b=0,
+ t=50, res=10, res3=10)
+ @classmethod
+ def tearDownClass(cls):
+ """!Remove the temporary region
+ cls.del_temp_region()
+ def setUp(self):
+ """Create input data for transient groundwater flow computation
+ self.runModule("r.mapcalc", expression="a1 = 100", overwrite=True)
+ self.runModule("r.mapcalc", expression="a2 = 200", overwrite=True)
+ self.runModule("r.mapcalc", expression="a3 = 300", overwrite=True)
+ self.runModule("r.mapcalc", expression="a4 = 400", overwrite=True)
+ self.runModule("r.mapcalc", expression="a5 = 500", overwrite=True)
+ self.runModule("r.mapcalc", expression="a6 = 600", overwrite=True)
+ self.runModule("t.create", type="strds", temporaltype="absolute",
+ output="A", title="A test",
+ description="A test", overwrite=True)
+ self.runModule("t.register", flags="i", type="rast", input="A",
+ maps="a1,a2,a3,a4,a5,a6",
+ start="2001-01-01", increment="3 months",
+ overwrite=True)
+ output="B", title="B test",
+ description="B test", overwrite=True)
+ self.runModule("t.register", flags="i", type="rast", input="B",
+ overwrite=True)
+ def tearDown(self):
+ """Remove generated data"""
+ self.runModule("g.remove", type="rast",
+ name="a1,a2,a3,a4,a5,a6")
+ def test_selection(self):
+ """Perform a simple selection by datetime"""
+ # Prepare some strings for the tests
+ new_line = os.linesep
+ a = ["a1","a2","a3","a4","a5","a6"]
+ al = new_line.join(a)
+ al += new_line
+ a123 = new_line.join(a[:3])
+ a123 += new_line
+ a456 = new_line.join(a[3:])
+ a456 += new_line
+ # Unregister maps a1, a2 and a3 from STRDS A
+ self.assertModule("t.unregister", input="A", maps="a1,a2,a3")
+ lister = SimpleModule("t.rast.list", input="A", columns="name",
+ flags="s")
+ self.runModule(lister)
+ self.assertEqual(a456, lister.outputs.stdout)
+ # Check if all maps are present in STRDS B
+ lister = SimpleModule("t.rast.list", input="B", columns="name",
+ flags="s")
+ self.assertEqual(al, lister.outputs.stdout)
+ # Check if maps a1, a2 and a3 are still present in the temporal database
+ lister = SimpleModule("t.list", type="rast", columns="name",
+ where='mapset = "%s" AND (name = "a1" OR name = "a2" OR name = "a3")'%(tgis.get_current_mapset()))
+ self.assertEqual(a123, lister.outputs.stdout)
+ # Unregister maps a1, a2 and a3 from the temporal database
+ self.assertModule("t.unregister", maps="a1,a2,a3")
+ self.assertEqual("", lister.outputs.stdout)
+ # Check that masp a1, a2 and a3 are not present in STRDS B
+ flags="s")
+ # Remove STRDS A and B and chceck if maps a4, a5 and a6 are still in the temporal database
+ self.assertModule("t.remove", type="strds", inputs="A,B")
+ where='mapset = "%s" AND (name = "a4" OR name = "a5" OR name = "a6")'%(tgis.get_current_mapset()))
+ # Unregister maps a4, a5 and a6 from the temporal database
+ self.assertModule("t.unregister", maps="a4,a5,a6")
+if __name__ == '__main__':
+ from grass.gunittest.main import test
+ test()
