[GRASS-SVN] r62627 - grass/trunk/temporal/t.unregister/testsuite
Wed Nov 5 12:31:54 PST 2014
Author: huhabla
Date: 2014-11-05 12:31:54 -0800 (Wed, 05 Nov 2014)
New Revision: 62627
   grass/trunk/temporal/t.unregister/testsuite/test_unregister.py
temporal modules: Fixed docs and function names
Modified: grass/trunk/temporal/t.unregister/testsuite/test_unregister.py
--- grass/trunk/temporal/t.unregister/testsuite/test_unregister.py	2014-11-05 20:30:53 UTC (rev 62626)
+++ grass/trunk/temporal/t.unregister/testsuite/test_unregister.py	2014-11-05 20:31:54 UTC (rev 62627)
@@ -27,12 +27,12 @@
     @classmethod
     def tearDownClass(cls):
-        """!Remove the temporary region
+        """Remove the temporary region
         cls.del_temp_region()
     def setUp(self):
-        """Create input data for transient groundwater flow computation
+        """Create input data
         self.runModule("r.mapcalc", expression="a1 = 100",  overwrite=True)
         self.runModule("r.mapcalc", expression="a2 = 200",  overwrite=True)
@@ -62,8 +62,8 @@
         self.runModule("g.remove", type="rast",
                                    name="a1,a2,a3,a4,a5,a6")
-    def test_selection(self):
-        """Perform a simple selection by datetime"""
+    def test_1(self):
+        """Perform several unregistration operations"""
         # Prepare some strings for the tests
         new_line = os.linesep
