[GRASS-SVN] r62645 - grass/trunk/lib/python/script
Thu Nov 6 14:10:22 PST 2014
Author: annakrat
Date: 2014-11-06 14:10:22 -0800 (Thu, 06 Nov 2014)
New Revision: 62645
   grass/trunk/lib/python/script/vector.py
pythonlib: fix for comment:4:ticket:2431 - object_pairs_hook not implemented in python 2.6, it's needed for using OrderedDict instead of normal dict, but vector_what will still work, only the order in which the results are presented is not defined
Modified: grass/trunk/lib/python/script/vector.py
--- grass/trunk/lib/python/script/vector.py	2014-11-06 22:07:42 UTC (rev 62644)
+++ grass/trunk/lib/python/script/vector.py	2014-11-06 22:10:22 UTC (rev 62645)
@@ -370,11 +370,15 @@
         except ImportError:
             orderedDict = dict
+    kwargs = {}
     if encoding:
-        result = json.loads(ret, object_pairs_hook=orderedDict, encoding=encoding)
-    else:
-        result = json.loads(ret, object_pairs_hook=orderedDict)
+        kwargs['encoding'] = encoding
+    if sys.version_info[0:2] > (2, 6):
+        kwargs['object_pairs_hook'] = orderedDict
+    result = json.loads(ret, **kwargs)
     for vmap in result['Maps']:
         cats = vmap.pop('Categories', None)
         if cats:
