[GRASS-SVN] r62670 - grass-addons/grass7/vector/v.fixed.segmentpoints
svn_grass at osgeo.org
Sat Nov 8 08:28:24 PST 2014
Author: hellik
Date: 2014-11-08 08:28:23 -0800 (Sat, 08 Nov 2014)
New Revision: 62670
grass-addons/grass7/vector/v.fixed.segmentpoints/Makefile
grass-addons/grass7/vector/v.fixed.segmentpoints/v.fixed.segmentpoints.html
grass-addons/grass7/vector/v.fixed.segmentpoints/v.fixed.segmentpoints.py
v.fixed.segmentpoints addon svn propset
Modified: grass-addons/grass7/vector/v.fixed.segmentpoints/Makefile
--- grass-addons/grass7/vector/v.fixed.segmentpoints/Makefile 2014-11-08 16:23:59 UTC (rev 62669)
+++ grass-addons/grass7/vector/v.fixed.segmentpoints/Makefile 2014-11-08 16:28:23 UTC (rev 62670)
@@ -1,7 +1,7 @@
-MODULE_TOPDIR = ../..
-PGM = v.fixed.segmentpoints
-include $(MODULE_TOPDIR)/include/Make/Script.make
-default: script
+MODULE_TOPDIR = ../..
+PGM = v.fixed.segmentpoints
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Property changes on: grass-addons/grass7/vector/v.fixed.segmentpoints/Makefile
___________________________________________________________________
Added: svn:mime-type
+ text/x-makefile
Added: svn:eol-style
+ native
Modified: grass-addons/grass7/vector/v.fixed.segmentpoints/v.fixed.segmentpoints.html
--- grass-addons/grass7/vector/v.fixed.segmentpoints/v.fixed.segmentpoints.html 2014-11-08 16:23:59 UTC (rev 62669)
+++ grass-addons/grass7/vector/v.fixed.segmentpoints/v.fixed.segmentpoints.html 2014-11-08 16:28:23 UTC (rev 62670)
@@ -1,39 +1,39 @@
-<h2>DESCRIPTION</h2>
-<em>v.fixed.segmenpoints</em> creates segment points along a vector line
-with fixed distances by using the <em>v.segment</em> module. A category
-of 1 line has to be given. Start and end point of the line will be
-considered.
-<h2>EXAMPLE</h2>
-<div class="code">
- <pre>
- # nc sampe data set
- v.fixed.segmentpoints vector=streams at PERMANENT cat=40102 dir=C:\tmp distance=25
- </pre>
-</div>
-<h2>DEPENDENCIES</h2>
-<ul>
-<li>v.segment</li>
-</ul>
-<h2>SEE ALSO</h2>
-<em>
-<a href="v.segment.html">v.segment</a>
-</em>
-<h2>TODO</h2>
-Join exported text file back to segment point vector.
-<h2>AUTHOR</h2>
-Helmut Kudrnovsky
-<p>
-<i>Last changed: $Date: 2014-05-13 23:17:32 +0200 (Di, 13 Mai 2014) $</i>
+<h2>DESCRIPTION</h2>
+<em>v.fixed.segmenpoints</em> creates segment points along a vector line
+with fixed distances by using the <em>v.segment</em> module. A category
+of 1 line has to be given. Start and end point of the line will be
+considered.
+<h2>EXAMPLE</h2>
+<div class="code">
+ <pre>
+ # nc sampe data set
+ v.fixed.segmentpoints vector=streams at PERMANENT cat=40102 dir=C:\tmp distance=25
+ </pre>
+</div>
+<h2>DEPENDENCIES</h2>
+<ul>
+<li>v.segment</li>
+</ul>
+<h2>SEE ALSO</h2>
+<em>
+<a href="v.segment.html">v.segment</a>
+</em>
+<h2>TODO</h2>
+Join exported text file back to segment point vector.
+<h2>AUTHOR</h2>
+Helmut Kudrnovsky
+<p>
+<i>Last changed: $Date$</i>
</p>
\ No newline at end of file
Property changes on: grass-addons/grass7/vector/v.fixed.segmentpoints/v.fixed.segmentpoints.html
+ text/html
Added: svn:keywords
+ Author Date Id
+ native
Modified: grass-addons/grass7/vector/v.fixed.segmentpoints/v.fixed.segmentpoints.py
--- grass-addons/grass7/vector/v.fixed.segmentpoints/v.fixed.segmentpoints.py 2014-11-08 16:23:59 UTC (rev 62669)
+++ grass-addons/grass7/vector/v.fixed.segmentpoints/v.fixed.segmentpoints.py 2014-11-08 16:28:23 UTC (rev 62670)
@@ -1,159 +1,159 @@
-#!/usr/bin/env python
-MODULE: v.fixed.segmentpoints
-AUTHOR(S): Helmut Kudrnovsky <alectoria AT gmx at>
-PURPOSE: Creates segment points along a vector line with fixed distances
- by using the v.segment module
-COPYRIGHT: (C) 2014 by the GRASS Development Team
- This program is free software under the GNU General Public
- License (>=v2). Read the file COPYING that comes with GRASS
- for details.
-#%module
-#% description: segment points along a vector line with fixed distances
-#% keywords: vector
-#%end
-#%option G_OPT_V_INPUT
-#% key: vector
-#% description: Name of habitat vector map
-#% required: yes
-#%end
-#%option G_OPT_V_CAT
-#% key: cat
-#% description: Category of a vector line
-#% required: yes
-#%end
-#%option G_OPT_M_DIR
-#% key: dir
-#% description: Directory where the output will be found
-#% required : yes
-#%end
-#%option
-#% key: distance
-#% type: double
-#% key_desc: double
-#% description: fixed distance between segment points
-#% required : no
-#% answer: 100
-#%end
-import sys
-import os
-import math
-import grass.script as grass
-if not os.environ.has_key("GISBASE"):
- grass.message( "You must be in GRASS GIS to run this program." )
- sys.exit(1)
-def main():
- vlines = options['vector'].split('@')[0]
- vcat = options['cat']
- directory = options['dir']
- sdistance = options['distance']
- fpoints = 'segmentpoints.txt'
- global tmp
- # Extract vector line
- grass.message( "Extract vector line for which segment points should be calculated ..." )
- grass.run_command('v.extract', input = vlines,
- output = 'vlinesingle',
- cats = vcat)
- grass.message( "Extraction done." )
- grass.message( "----" )
- # Calculate vector line length and populate it to the attribute table
- grass.message( "Calculate vector line length and populate it to the attribute table ..." )
- grass.run_command("v.db.addcolumn", map = 'vlinesingle',
- layer = 1,
- columns = "vlength double")
- grass.run_command("v.to.db", map = 'vlinesingle',
- option = 'length',
- layer = 1,
- columns = 'vlength',
- overwrite = True)
- grass.message( "Calculate vector line length done." )
- # Read length
- tmp = grass.read_command('v.to.db', map = 'vlinesingle',
- type = 'line',
- layer = 1,
- qlayer = 1,
- units = 'meters',
- column = 'vlength',
- flags = 'p')
- vector_line_length = float(tmp.split('\n')[1].split('|')[1])
- # Print vector line length
- grass.message( "Vector line length in meter:" )
- grass.message( vector_line_length )
- # Calculation number of segment points (start and end point included)
- # number of segment points without end point
- number_segmentpoints_without_end = math.floor( vector_line_length / float(sdistance) )
- number_segmentpoints_with_end = int(number_segmentpoints_without_end + 1)
- grass.message( "Number of segment points (start and end point included):" )
- grass.message( number_segmentpoints_with_end )
- segmentpointsrange_without_end = range(1, number_segmentpoints_with_end, 1)
- max_distancerange = float(sdistance) * number_segmentpoints_with_end
- distancesrange_without_end = range(0, int(max_distancerange), int(sdistance))
- # Write segment point input file for g.segment to G_OPT_M_DIR
- grass.message( "Write segment point input file for g.segment" )
- segment_points_file = os.path.join( directory, fpoints )
- file = open(segment_points_file, 'a')
- for f, b in zip(segmentpointsrange_without_end, distancesrange_without_end):
- file.write("P %s %s %s\n" % (f, vcat, b))
- file.close()
- file.write("P %s %s -0" % (number_segmentpoints_with_end, vcat))
- file.close()
- # Give information where output file
- grass.message( "Segment points file:" )
- grass.message( segment_points_file )
- # Run v.segment with the segment point input
- grass.run_command("v.segment", input = 'vlinesingle',
- output = 'segmentpoints',
- file = segment_points_file)
- grass.run_command("v.db.addtable", map = 'segmentpoints')
-# TODO join point segment file to point vector
-# grass.run_command("db.in.ogr", dsn = segment_points_file,
-# output = 't_segment_points_file')
- grass.message( "Segment points file created" )
- # v.fixed.segmentpoints done!
- grass.message( "v.fixed.segmentpoints done!" )
-if __name__ == "__main__":
- options, flags = grass.parser()
- sys.exit(main())
+#!/usr/bin/env python
+MODULE: v.fixed.segmentpoints
+AUTHOR(S): Helmut Kudrnovsky <alectoria AT gmx at>
+PURPOSE: Creates segment points along a vector line with fixed distances
+ by using the v.segment module
+COPYRIGHT: (C) 2014 by the GRASS Development Team
+ This program is free software under the GNU General Public
+ License (>=v2). Read the file COPYING that comes with GRASS
+ for details.
+#%module
+#% description: segment points along a vector line with fixed distances
+#% keywords: vector
+#%end
+#%option G_OPT_V_INPUT
+#% key: vector
+#% description: Name of habitat vector map
+#% required: yes
+#%end
+#%option G_OPT_V_CAT
+#% key: cat
+#% description: Category of a vector line
+#% required: yes
+#%end
+#%option G_OPT_M_DIR
+#% key: dir
+#% description: Directory where the output will be found
+#% required : yes
+#%end
+#%option
+#% key: distance
+#% type: double
+#% key_desc: double
+#% description: fixed distance between segment points
+#% required : no
+#% answer: 100
+#%end
+import sys
+import os
+import math
+import grass.script as grass
+if not os.environ.has_key("GISBASE"):
+ grass.message( "You must be in GRASS GIS to run this program." )
+ sys.exit(1)
+def main():
+ vlines = options['vector'].split('@')[0]
+ vcat = options['cat']
+ directory = options['dir']
+ sdistance = options['distance']
+ fpoints = 'segmentpoints.txt'
+ global tmp
+ # Extract vector line
+ grass.message( "Extract vector line for which segment points should be calculated ..." )
+ grass.run_command('v.extract', input = vlines,
+ output = 'vlinesingle',
+ cats = vcat)
+ grass.message( "Extraction done." )
+ grass.message( "----" )
+ # Calculate vector line length and populate it to the attribute table
+ grass.message( "Calculate vector line length and populate it to the attribute table ..." )
+ grass.run_command("v.db.addcolumn", map = 'vlinesingle',
+ layer = 1,
+ columns = "vlength double")
+ grass.run_command("v.to.db", map = 'vlinesingle',
+ option = 'length',
+ layer = 1,
+ columns = 'vlength',
+ overwrite = True)
+ grass.message( "Calculate vector line length done." )
+ # Read length
+ tmp = grass.read_command('v.to.db', map = 'vlinesingle',
+ type = 'line',
+ layer = 1,
+ qlayer = 1,
+ units = 'meters',
+ column = 'vlength',
+ flags = 'p')
+ vector_line_length = float(tmp.split('\n')[1].split('|')[1])
+ # Print vector line length
+ grass.message( "Vector line length in meter:" )
+ grass.message( vector_line_length )
+ # Calculation number of segment points (start and end point included)
+ # number of segment points without end point
+ number_segmentpoints_without_end = math.floor( vector_line_length / float(sdistance) )
+ number_segmentpoints_with_end = int(number_segmentpoints_without_end + 1)
+ grass.message( "Number of segment points (start and end point included):" )
+ grass.message( number_segmentpoints_with_end )
+ segmentpointsrange_without_end = range(1, number_segmentpoints_with_end, 1)
+ max_distancerange = float(sdistance) * number_segmentpoints_with_end
+ distancesrange_without_end = range(0, int(max_distancerange), int(sdistance))
+ # Write segment point input file for g.segment to G_OPT_M_DIR
+ grass.message( "Write segment point input file for g.segment" )
+ segment_points_file = os.path.join( directory, fpoints )
+ file = open(segment_points_file, 'a')
+ for f, b in zip(segmentpointsrange_without_end, distancesrange_without_end):
+ file.write("P %s %s %s\n" % (f, vcat, b))
+ file.close()
+ file.write("P %s %s -0" % (number_segmentpoints_with_end, vcat))
+ file.close()
+ # Give information where output file
+ grass.message( "Segment points file:" )
+ grass.message( segment_points_file )
+ # Run v.segment with the segment point input
+ grass.run_command("v.segment", input = 'vlinesingle',
+ output = 'segmentpoints',
+ file = segment_points_file)
+ grass.run_command("v.db.addtable", map = 'segmentpoints')
+# TODO join point segment file to point vector
+# grass.run_command("db.in.ogr", dsn = segment_points_file,
+# output = 't_segment_points_file')
+ grass.message( "Segment points file created" )
+ # v.fixed.segmentpoints done!
+ grass.message( "v.fixed.segmentpoints done!" )
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ sys.exit(main())
Property changes on: grass-addons/grass7/vector/v.fixed.segmentpoints/v.fixed.segmentpoints.py
+ text/x-python
+ native
