[GRASS-SVN] r62673 - grass-addons/grass7/vector/v.fixed.segmentpoints
svn_grass at osgeo.org
Sat Nov 8 12:40:30 PST 2014
Author: hellik
Date: 2014-11-08 12:40:30 -0800 (Sat, 08 Nov 2014)
New Revision: 62673
grass-addons/grass7/vector/v.fixed.segmentpoints/v.fixed.segmentpoints.html
v.fixed.segmentpoints: manual update
Modified: grass-addons/grass7/vector/v.fixed.segmentpoints/v.fixed.segmentpoints.html
--- grass-addons/grass7/vector/v.fixed.segmentpoints/v.fixed.segmentpoints.html 2014-11-08 17:55:08 UTC (rev 62672)
+++ grass-addons/grass7/vector/v.fixed.segmentpoints/v.fixed.segmentpoints.html 2014-11-08 20:40:30 UTC (rev 62673)
@@ -1,15 +1,16 @@
<h2>DESCRIPTION</h2>
-<em>v.fixed.segmenpoints</em> creates segment points along a vector line
+<em>v.fixed.segmentpoints</em> creates segment points along a vector line
with fixed distances by using the <em>v.segment</em> module. A category
-of 1 line has to be given. Start and end point of the line will be
-considered.
+of one line has to be given. Start and end point of the line will be
+considered. The distance option is limited to an integer number. As result
+the vectors vlinesingle and segmentpoints are created.
<h2>EXAMPLE</h2>
<div class="code">
<pre>
- # nc sampe data set
+ # NC sample data set
v.fixed.segmentpoints vector=streams at PERMANENT cat=40102 dir=C:\tmp distance=25
</pre>
</div>
