[GRASS-SVN] r62686 - in grass-addons/grass7/raster: r.stream.basins r.stream.channel r.stream.distance r.stream.order r.stream.segment r.stream.snap r.stream.stats
svn_grass at osgeo.org
Sun Nov 9 06:51:02 PST 2014
Author: mmetz
Date: 2014-11-09 06:51:02 -0800 (Sun, 09 Nov 2014)
New Revision: 62686
grass-addons/grass7/raster/r.stream.basins/basins_fill.c
grass-addons/grass7/raster/r.stream.basins/basins_inputs.c
grass-addons/grass7/raster/r.stream.basins/io.c
grass-addons/grass7/raster/r.stream.basins/io.h
grass-addons/grass7/raster/r.stream.basins/main.c
grass-addons/grass7/raster/r.stream.channel/io.c
grass-addons/grass7/raster/r.stream.channel/io.h
grass-addons/grass7/raster/r.stream.channel/local_proto.h
grass-addons/grass7/raster/r.stream.channel/local_vars.h
grass-addons/grass7/raster/r.stream.channel/main.c
grass-addons/grass7/raster/r.stream.channel/stream_topology.c
grass-addons/grass7/raster/r.stream.channel/stream_write.c
grass-addons/grass7/raster/r.stream.distance/distance_calc.c
grass-addons/grass7/raster/r.stream.distance/io.c
grass-addons/grass7/raster/r.stream.distance/io.h
grass-addons/grass7/raster/r.stream.distance/main.c
grass-addons/grass7/raster/r.stream.order/io.c
grass-addons/grass7/raster/r.stream.order/io.h
grass-addons/grass7/raster/r.stream.order/main.c
grass-addons/grass7/raster/r.stream.order/stream_init.c
grass-addons/grass7/raster/r.stream.order/stream_raster_close.c
grass-addons/grass7/raster/r.stream.order/stream_topology.c
grass-addons/grass7/raster/r.stream.segment/io.c
grass-addons/grass7/raster/r.stream.segment/io.h
grass-addons/grass7/raster/r.stream.segment/local_vars.h
grass-addons/grass7/raster/r.stream.segment/main.c
grass-addons/grass7/raster/r.stream.segment/stream_segment.c
grass-addons/grass7/raster/r.stream.segment/stream_topology.c
grass-addons/grass7/raster/r.stream.snap/io.c
grass-addons/grass7/raster/r.stream.snap/io.h
grass-addons/grass7/raster/r.stream.snap/main.c
grass-addons/grass7/raster/r.stream.snap/snap.c
grass-addons/grass7/raster/r.stream.stats/io.c
grass-addons/grass7/raster/r.stream.stats/io.h
grass-addons/grass7/raster/r.stream.stats/main.c
grass-addons/grass7/raster/r.stream.stats/stats_calculate.c
grass-addons/grass7/raster/r.stream.stats/stats_prepare.c
grass-addons/grass7/raster/r.stream.stats/stats_print.c
r.stream.* addons: fix NULL handling and memory usage
Modified: grass-addons/grass7/raster/r.stream.basins/basins_fill.c
--- grass-addons/grass7/raster/r.stream.basins/basins_fill.c 2014-11-09 14:47:35 UTC (rev 62685)
+++ grass-addons/grass7/raster/r.stream.basins/basins_fill.c 2014-11-09 14:51:02 UTC (rev 62686)
@@ -1,3 +1,5 @@
+#include "local_proto.h"
Link: a channel between junction
Outlet: is final cell of every segment
@@ -18,7 +20,6 @@
/* removal point: head + 1 */
/* head == tail if last point removed or if only one free slot left */
-#include "local_proto.h"
static int tail, head, fifo_count;
int fifo_insert(POINT point)
@@ -32,6 +33,7 @@
tail = 0;
fifo_count++;
return 0;
@@ -94,6 +96,7 @@
int next_r, next_c;
int r, c, val, i, j;
POINT n_cell;
+ int dirs_cell, basins_cell;
tail = 0;
head = -1;
@@ -115,8 +118,11 @@
continue;
j = DIAG(i);
+ dirs_cell = dirs[next_r][next_c];
+ basins_cell = basins[next_r][next_c];
/* contributing cell, not yet assigned to a basin */
- if (dirs[next_r][next_c] == j && basins[next_r][next_c] == 0) {
+ if (dirs_cell == j && basins_cell == 0) {
basins[next_r][next_c] = val;
n_cell.r = next_r;
n_cell.c = next_c;
@@ -128,6 +134,7 @@
r = n_cell.r;
c = n_cell.c;
} /* end while */
return 0;
@@ -158,10 +165,10 @@
continue;
j = DIAG(i);
- /* contributing cell, not yet assigned to a basin */
Segment_get(basins, &basins_cell, next_r, next_c);
Segment_get(dirs, &dirs_cell, next_r, next_c);
+ /* contributing cell, not yet assigned to a basin */
Segment_put(basins, &val, next_r, next_c);
n_cell.r = next_r;
@@ -173,7 +180,6 @@
n_cell = fifo_return_del();
r = n_cell.r;
c = n_cell.c;
} /* end while */
return 0;
Modified: grass-addons/grass7/raster/r.stream.basins/basins_inputs.c
--- grass-addons/grass7/raster/r.stream.basins/basins_inputs.c 2014-11-09 14:47:35 UTC (rev 62685)
+++ grass-addons/grass7/raster/r.stream.basins/basins_inputs.c 2014-11-09 14:51:02 UTC (rev 62686)
@@ -1,12 +1,10 @@
#include <grass/gis.h>
#include <grass/vector.h>
#include <grass/glocale.h>
int process_coors(char **answers)
int n, outlets_num;
double X, Y;
struct Cell_head window;
@@ -97,8 +95,9 @@
int i, cat;
int r, c, d; /* d: direction */
- int outlets_num = 0;
- int next_stream = -1, cur_stream;
+ int outlets_num;
+ int next_stream, cur_stream;
+ int streams_cell, dirs_cell;
int out_max = ncols + nrows;
categories = NULL;
@@ -117,34 +116,37 @@
G_message("Finding nodes...");
outlets = (OUTLET *) G_malloc((out_max) * sizeof(OUTLET));
+ outlets_num = 0;
- for (r = 0; r < nrows; ++r)
- for (c = 0; c < ncols; ++c)
- if (streams[r][c] > 0) {
+ for (r = 0; r < nrows; ++r) {
+ G_percent(r, nrows, 4);
+ for (c = 0; c < ncols; ++c) {
+ streams_cell = streams[r][c];
+ if (streams_cell > 0) {
if (outlets_num > 6 * (out_max - 1))
G_fatal_error(_("Stream and direction maps probably do not match"));
- if (outlets_num > (out_max - 1))
+ if (outlets_num > (out_max - 1)) {
outlets =
(OUTLET *) G_realloc(outlets,
out_max * 6 * sizeof(OUTLET));
- d = abs(dirs[r][c]); /* r.watershed */
+ dirs_cell = dirs[r][c];
+ d = abs(dirs_cell); /* r.watershed */
- if (NOT_IN_REGION(d))
+ if (NOT_IN_REGION(d) || d == 0)
next_stream = -1; /* border */
- else
- next_stream = (streams[NR(d)][NC(d)] > 0) ?
- streams[NR(d)][NC(d)] : -1;
+ else {
+ next_stream = streams[NR(d)][NC(d)];
+ if (next_stream < 1)
+ next_stream = -1;
- if (d == 0)
- next_stream = -1;
+ cur_stream = streams_cell;
- cur_stream = streams[r][c];
if (lasts) {
if (next_stream < 0) { /* is outlet! */
if (categories)
if (categories[cur_stream] == -1) /* but not in list */
continue;
@@ -157,9 +159,7 @@
else { /* not lasts */
if (cur_stream != next_stream) { /* is node or outlet! */
if (categories)
continue;
@@ -172,6 +172,9 @@
} /* end if else lasts */
} /* end if streams */
return outlets_num;
@@ -183,8 +186,8 @@
int i, cat;
int outlets_num;
- int streams_cell, dirs_cell, streams_next_cell;
categories = NULL;
@@ -204,7 +207,8 @@
outlets_num = 0;
Segment_get(streams, &streams_cell, r, c);
@@ -220,21 +224,17 @@
Segment_get(dirs, &dirs_cell, r, c);
d = abs(dirs_cell); /* abs */
else {
- Segment_get(streams, &streams_next_cell, NR(d), NC(d));
- next_stream =
- (streams_next_cell > 0) ? streams_next_cell : -1;
+ Segment_get(streams, &next_stream, NR(d), NC(d));
+ next_stream = -1;
- if (d == 0)
- next_stream = -1;
if (lasts) {
if (categories)
@@ -248,7 +248,6 @@
if (cur_stream != next_stream) { /* is outlet or node! */
if (categories)
@@ -263,5 +262,8 @@
} /* end for */
return outlets_num;
Modified: grass-addons/grass7/raster/r.stream.basins/io.c
--- grass-addons/grass7/raster/r.stream.basins/io.c 2014-11-09 14:47:35 UTC (rev 62685)
+++ grass-addons/grass7/raster/r.stream.basins/io.c 2014-11-09 14:51:02 UTC (rev 62686)
@@ -44,7 +44,7 @@
int ram_read_map(MAP * map, char *input_map_name, int check_res,
- RASTER_MAP_TYPE check_data_type)
+ RASTER_MAP_TYPE check_data_type, DCELL nullval)
* Function read external map and put it in MAP structure (created with create_map)
@@ -79,7 +79,7 @@
G_fatal_error(_("Region resolution and raster map <%s> resolution differs. "
"Run 'g.region rast=%s' to set proper region resolution."),
input_map_name, input_map_name);
/* checking if input map is of required type */
if (check_data_type != map->data_type)
G_debug(1,
@@ -125,9 +125,9 @@
Rast_get_row(input_map_fd, input_buffer, r, input_data_type);
input_pointer = input_buffer;
- for (c = 0; c < map->ncols; ++c)
+ for (c = 0; c < map->ncols; ++c) {
if (!Rast_is_null_value
- (input_pointer + c * input_data_size, input_data_type))
+ (input_pointer + c * input_data_size, input_data_type)) {
switch (map->data_type) {
case CELL_TYPE:
((CELL **) map->map)[r][c] =
@@ -148,23 +148,82 @@
G_fatal_error(_("Wrong internal data type"));
break;
+ else {
+ switch (map->data_type) {
+ case CELL_TYPE:
+ ((CELL **) map->map)[r][c] =
+ Rast_get_c_value(&nullval, DCELL_TYPE);
+ break;
+ case FCELL_TYPE:
+ ((FCELL **) map->map)[r][c] =
+ Rast_get_f_value(&nullval, DCELL_TYPE);
+ break;
+ case DCELL_TYPE:
+ ((DCELL **) map->map)[r][c] =
+ Rast_get_d_value(&nullval, DCELL_TYPE);
+ break;
+ default:
+ G_fatal_error(_("Wrong internal data type"));
+ break;
} /*end for r */
+ G_percent(r, map->nrows, 2);
+ Rast_close(input_map_fd);
G_free(input_buffer);
- G_percent(r, map->nrows, 2);
- Rast_close(input_map_fd);
return 0;
-} /* end create floating point map */
-int ram_reset_map(MAP * map, int value)
+int ram_reset_map(MAP * map, DCELL value)
* set all cells in the map to value
- int r;
+ int r, c;
- for (r = 0; r < map->nrows; ++r)
- memset((map->map)[r], value, map->ncols * map->data_size);
+ case CELL_TYPE:
+ CELL v = Rast_get_c_value(&value, DCELL_TYPE);
+ for (r = 0; r < map->nrows; ++r) {
+ ((CELL **) map->map)[r][c] = v;
+ break;
+ case FCELL_TYPE:
+ FCELL v = Rast_get_f_value(&value, DCELL_TYPE);
+ ((FCELL **) map->map)[r][c] = v;
+ break;
+ case DCELL_TYPE:
+ DCELL v = Rast_get_d_value(&value, DCELL_TYPE);
+ ((DCELL **) map->map)[r][c] = v;
+ break;
+ default:
+ break;
return 0;
@@ -218,7 +277,8 @@
Rast_set_d_null_value(row + c * (map->data_size), 1);
break;
default:
- G_debug(1, "ram_null:Cannot convert to null at: %d %d", r, c);
+ break;
@@ -239,7 +299,7 @@
* free memory allocated for map, set pointer to null;
int r;
G_free((map->map)[r]);
G_free(map->map);
@@ -311,7 +371,7 @@
close(fd);
if (0 > (fd = open(filename, 2))) {
unlink(filename);
- G_fatal_error(_("Unable re-open file '%s'"), filename);
+ G_fatal_error(_("Unable to re-open file '%s'"), filename);
if (0 > (fd = Segment_init(&(seg->seg), fd, number_of_segs))) {
@@ -325,7 +385,7 @@
int seg_read_map(SEG * seg, char *input_map_name, int check_res,
@@ -353,8 +413,10 @@
if (mapset == NULL)
G_fatal_error(_("Raster map <%s> not found"),
input_map_name);
- seg->mapset = mapset;
+ seg->map_name = G_store(input_map_name);
+ seg->mapset = G_store(mapset);
/* checking if region and input are the same */
G_get_window(&this_window);
Rast_get_cellhd(input_map_name, mapset, &cellhd);
@@ -365,7 +427,7 @@
this_window.ns_res != cellhd.ns_res)
- input_map_name, input_map_name);
+ input_map_name, input_map_name);
if (check_data_type != seg->data_type)
G_debug(1,
@@ -401,7 +463,7 @@
/* end opening and checking */
- G_message(_("Reading map <%s>"), input_map_name);
+ G_message(_("Reading raster map <%s>..."), input_map_name);
input_buffer = Rast_allocate_buf(input_data_type);
target_buffer = Rast_allocate_buf(seg->data_type);
@@ -410,9 +472,8 @@
G_percent(r, seg->nrows, 2);
Rast_get_row(input_fd, input_buffer, r, input_data_type);
- memset(target_buffer, 0, seg->ncols * seg->data_size);
- for (c = 0; c < seg->ncols; ++c)
+ for (c = 0; c < seg->ncols; ++c) {
switch (seg->data_type) {
@@ -436,6 +497,26 @@
break;
+ else {
+ switch (seg->data_type) {
+ case CELL_TYPE:
+ ((CELL *) target_buffer)[c] =
+ break;
+ case FCELL_TYPE:
+ ((FCELL *) target_buffer)[c] =
+ break;
+ case DCELL_TYPE:
+ ((DCELL *) target_buffer)[c] =
+ break;
+ default:
+ break;
if (0 > Segment_put_row(&(seg->seg), target_buffer, r)) {
@@ -445,29 +526,61 @@
r, input_map_name);
} /* end for row */
+ G_percent(r, seg->nrows, 2);
- G_percent(r, seg->nrows, 2);
Rast_close(input_fd);
G_free(target_buffer);
- seg->map_name = G_store(input_map_name);
- seg->mapset = G_store(mapset);
return 0;
-int seg_reset_map(SEG * seg, int value)
+int seg_reset_map(SEG * seg, DCELL value)
int r, c;
- for (r = 0; r < seg->nrows; ++r)
- Segment_put(&(seg->seg), &value, r, c);
+ case CELL_TYPE:
+ for (r = 0; r < seg->nrows; ++r) {
+ Segment_put(&(seg->seg), &v, r, c);
+ break;
+ case FCELL_TYPE:
+ break;
+ case DCELL_TYPE:
+ break;
+ default:
+ break;
return 0;
@@ -528,8 +641,8 @@
Rast_set_d_null_value(row + c * (seg->data_size), 1);
break;
default:
- G_warning(_("Unable to convert to null at: %d %d"), r,
- c);
+ break;
Rast_put_row(output_fd, output_buffer, output_data_type);
Modified: grass-addons/grass7/raster/r.stream.basins/io.h
--- grass-addons/grass7/raster/r.stream.basins/io.h 2014-11-09 14:47:35 UTC (rev 62685)
+++ grass-addons/grass7/raster/r.stream.basins/io.h 2014-11-09 14:51:02 UTC (rev 62686)
@@ -17,8 +17,8 @@
#define INDEX(r,c) ((r) * ncols + (c))
#define DIAG(x) (((x) + 4) > 8 ? ((x) - 4) : ((x) + 4))
-#define SROWS 256
-#define SCOLS 256
+#define SROWS 128
+#define SCOLS 128
typedef struct {
void **map; /* matrix of data */
@@ -44,15 +44,15 @@
/* all in ram functions */
int ram_create_map(MAP *, RASTER_MAP_TYPE);
-int ram_read_map(MAP *, char *, int, RASTER_MAP_TYPE);
-int ram_reset_map(MAP *, int);
+int ram_read_map(MAP *, char *, int, RASTER_MAP_TYPE, DCELL);
+int ram_reset_map(MAP *, DCELL);
int ram_write_map(MAP *, char *, RASTER_MAP_TYPE, int, double);
int ram_release_map(MAP *);
int ram_destory_map(MAP *);
/* memory swap functions */
int seg_create_map(SEG *, int, int, int, RASTER_MAP_TYPE);
-int seg_read_map(SEG *, char *, int, RASTER_MAP_TYPE);
-int seg_reset_map (SEG *, int);
+int seg_read_map(SEG *, char *, int, RASTER_MAP_TYPE, DCELL);
+int seg_reset_map (SEG *, DCELL);
int seg_write_map(SEG *, char *, RASTER_MAP_TYPE, int, double);
int seg_release_map(SEG *);
Modified: grass-addons/grass7/raster/r.stream.basins/main.c
--- grass-addons/grass7/raster/r.stream.basins/main.c 2014-11-09 14:47:35 UTC (rev 62685)
+++ grass-addons/grass7/raster/r.stream.basins/main.c 2014-11-09 14:51:02 UTC (rev 62686)
@@ -40,12 +40,15 @@
int segmentation, zerofill, lasts, cats;
int i, outlets_num = 0;
int max_number_of_streams;
+ struct Range range;
+ CELL min, max;
+ struct Colors colors;
G_gisinit(argv[0]);
module = G_define_module();
module->label = _("Delineates basins according stream network.");
- module->description = _("Input can be stream network, vector point map with outlets or outlet coordinates.");
+ module->description = _("Input can be stream network, vector point map with outlets or outlet coordinates.");
G_add_keyword(_("raster"));
G_add_keyword(_("hydrology"));
G_add_keyword(_("stream network"));
@@ -141,13 +144,12 @@
MAP map_dirs, map_streams, map_basins;
CELL **streams = NULL, **dirs, **basins;
- G_message("All in RAM calculation...");
+ G_message(_("All in RAM calculation..."));
ram_create_map(&map_dirs, CELL_TYPE);
- ram_read_map(&map_dirs, in_dir_opt->answer, 1, CELL_TYPE);
+ ram_read_map(&map_dirs, in_dir_opt->answer, 1, CELL_TYPE, 0);
dirs = (CELL **) map_dirs.map;
switch (b_test) {
case 1:
G_message(_("Calculating basins using coordinates..."));
@@ -157,7 +159,7 @@
case 2:
G_message(_("Calculating basins using streams..."));
ram_create_map(&map_streams, CELL_TYPE);
- ram_read_map(&map_streams, in_stm_opt->answer, 1, CELL_TYPE);
+ ram_read_map(&map_streams, in_stm_opt->answer, 1, CELL_TYPE, 0);
streams = (CELL **) map_streams.map;
max_number_of_streams = (int)map_streams.max + 1;
outlets_num = ram_process_streams(in_stm_cat_opt->answers,
@@ -173,13 +175,18 @@
ram_create_map(&map_basins, CELL_TYPE);
+ ram_reset_map(&map_basins, 0);
basins = (CELL **) map_basins.map;
ram_add_outlets(basins, outlets_num);
fifo_max = 4 * (nrows + ncols);
fifo_points = (POINT *) G_malloc((fifo_max + 1) * sizeof(POINT));
- for (i = 0; i < outlets_num; ++i)
+ G_message(_("Delineating basins for %d outlets..."), outlets_num);
+ for (i = 0; i < outlets_num; ++i) {
+ G_percent(i, outlets_num, 4);
ram_fill_basins(outlets[i], basins, dirs);
G_free(fifo_points);
ram_write_map(&map_basins, opt_basins->answer, CELL_TYPE, zerofill,
@@ -188,23 +195,28 @@
ram_release_map(&map_basins);
} /* end ram */
/* SEGMENT VERSION */
- if (segmentation) {
+ else {
SEG map_dirs, map_streams, map_basins;
SEGMENT *streams = NULL, *dirs, *basins;
- int number_of_segs, num_maps;
+ int number_of_segs;
+ double seg_size;
G_message(_("Memory swap calculation (may take some time)..."));
- num_maps = b_test == 2 ? 3 : 2;
- number_of_segs = (int)atof(opt_swapsize->answer);
- number_of_segs = number_of_segs < 32 ? (int)(32 / 0.12) :
- (int)(number_of_segs * 4.0 / num_maps);
+ number_of_segs = atoi(opt_swapsize->answer);
+ if (number_of_segs < 3)
+ number_of_segs = 3;
+ /* segment size in MB */
+ seg_size = sizeof(CELL) * 2.0 * SROWS * SCOLS / (1 << 20);
+ number_of_segs = (int)(number_of_segs / seg_size);
+ if (number_of_segs < 10)
+ number_of_segs = 10;
seg_create_map(&map_dirs, SROWS, SCOLS, number_of_segs, CELL_TYPE);
- seg_read_map(&map_dirs, in_dir_opt->answer, 1, CELL_TYPE);
+ seg_read_map(&map_dirs, in_dir_opt->answer, 1, CELL_TYPE, 0);
dirs = &map_dirs.seg;
switch (b_test) {
@@ -217,7 +229,7 @@
seg_create_map(&map_streams, SROWS, SCOLS, number_of_segs,
CELL_TYPE);
- seg_read_map(&map_streams, in_stm_opt->answer, 1, CELL_TYPE);
+ seg_read_map(&map_streams, in_stm_opt->answer, 1, CELL_TYPE, 0);
streams = &map_streams.seg;
outlets_num = seg_process_streams(in_stm_cat_opt->answers,
@@ -227,19 +239,24 @@
break;
case 4:
- G_message(_("Calculate basins using vector point map..."));
+ G_message(_("Calculating basins using vector point map..."));
outlets_num = process_vector(in_point_opt->answer);
break;
seg_create_map(&map_basins, SROWS, SCOLS, number_of_segs, CELL_TYPE);
+ seg_reset_map(&map_basins, 0);
basins = &map_basins.seg;
seg_add_outlets(basins, outlets_num);
seg_fill_basins(outlets[i], basins, dirs);
seg_write_map(&map_basins, opt_basins->answer, CELL_TYPE, zerofill,
0);
@@ -247,5 +264,10 @@
seg_release_map(&map_basins);
+ Rast_read_range(opt_basins->answer, G_mapset(), &range);
+ Rast_get_range_min_max(&range, &min, &max);
+ Rast_make_random_colors(&colors, min, max);
+ Rast_write_colors(opt_basins->answer, G_mapset(), &colors);
exit(EXIT_SUCCESS);
Modified: grass-addons/grass7/raster/r.stream.channel/io.c
--- grass-addons/grass7/raster/r.stream.channel/io.c 2014-11-09 14:47:35 UTC (rev 62685)
+++ grass-addons/grass7/raster/r.stream.channel/io.c 2014-11-09 14:51:02 UTC (rev 62686)
@@ -44,7 +44,7 @@
@@ -125,9 +125,9 @@
case CELL_TYPE:
break;
+ else {
+ case CELL_TYPE:
+ break;
+ case FCELL_TYPE:
+ break;
+ case DCELL_TYPE:
+ break;
+ default:
+ break;
} /*end for r */
return 0;
- int r;
+ int r, c;
+ case CELL_TYPE:
+ break;
+ case FCELL_TYPE:
+ break;
+ case DCELL_TYPE:
+ break;
+ default:
+ break;
return 0;
@@ -218,7 +277,8 @@
break;
default:
+ break;
@@ -235,9 +295,9 @@
int ram_release_map(MAP *map)
- * free memory allocated for map, set pointer to null;
+ * free memory allocated for map, set pointer to null;
int r;
@@ -325,7 +385,7 @@
if (mapset == NULL)
input_map_name);
@@ -410,9 +472,8 @@
break;
+ else {
+ case CELL_TYPE:
+ break;
+ case FCELL_TYPE:
+ break;
+ case DCELL_TYPE:
+ break;
+ default:
+ break;
r, input_map_name);
} /* end for row */
return 0;
int r, c;
+ case CELL_TYPE:
+ break;
+ case FCELL_TYPE:
+ break;
+ case DCELL_TYPE:
+ break;
+ default:
+ break;
return 0;
@@ -528,7 +641,8 @@
break;
default:
- G_warning(_("Unable to convert to NULL at: %d %d"), r, c);
+ break;
Modified: grass-addons/grass7/raster/r.stream.channel/io.h
--- grass-addons/grass7/raster/r.stream.channel/io.h 2014-11-09 14:47:35 UTC (rev 62685)
+++ grass-addons/grass7/raster/r.stream.channel/io.h 2014-11-09 14:51:02 UTC (rev 62686)
@@ -17,8 +17,8 @@
-#define SROWS 256
-#define SCOLS 256
+#define SROWS 128
+#define SCOLS 128
typedef struct {
@@ -44,15 +44,15 @@
Modified: grass-addons/grass7/raster/r.stream.channel/local_proto.h
--- grass-addons/grass7/raster/r.stream.channel/local_proto.h 2014-11-09 14:47:35 UTC (rev 62685)
+++ grass-addons/grass7/raster/r.stream.channel/local_proto.h 2014-11-09 14:51:02 UTC (rev 62686)
@@ -9,7 +9,6 @@
int ram_number_of_streams(CELL **streams, CELL **dirs);
int ram_find_contributing_cell(int r, int c, CELL **dirs, FCELL **elevation);
-int ram_set_null_output(DCELL **output);
int ram_calculate_identifiers(CELL **identifier, int number_of_streams,
int downstream);
int ram_calculate_difference(DCELL **output, int number_of_streams,
@@ -36,7 +35,6 @@
int seg_find_contributing_cell(int r, int c, SEGMENT *dirs,
SEGMENT *elevation);
-int seg_set_null_output(SEGMENT *output);
int seg_calculate_identifiers(SEGMENT *identifier, int number_of_streams,
int downstream);
int seg_calculate_difference(SEGMENT *output, int number_of_streams,
Modified: grass-addons/grass7/raster/r.stream.channel/local_vars.h
--- grass-addons/grass7/raster/r.stream.channel/local_vars.h 2014-11-09 14:47:35 UTC (rev 62685)
+++ grass-addons/grass7/raster/r.stream.channel/local_vars.h 2014-11-09 14:51:02 UTC (rev 62686)
@@ -12,7 +12,7 @@
int stream_num;
int number_of_cells;
int order;
- unsigned long int * points;
+ long int * points;
float * elevation;
double * distance;
unsigned int init_r;
Modified: grass-addons/grass7/raster/r.stream.channel/main.c
--- grass-addons/grass7/raster/r.stream.channel/main.c 2014-11-09 14:47:35 UTC (rev 62685)
+++ grass-addons/grass7/raster/r.stream.channel/main.c 2014-11-09 14:51:02 UTC (rev 62686)
@@ -150,15 +150,19 @@
CELL **streams, **dirs, **identifier = NULL;
FCELL **elevation;
DCELL **output;
+ DCELL nullval;
G_message(_("All in RAM calculation - direction <%s>..."),
method_name[downstream]);
+ Rast_set_d_null_value(&nullval, 1);
ram_create_map(&map_elevation, FCELL_TYPE);
- ram_read_map(&map_elevation, in_elev_opt->answer, 0, -1);
+ ram_read_map(&map_elevation, in_elev_opt->answer, 0, -1, nullval);
@@ -168,11 +172,13 @@
ram_build_streamlines(streams, dirs, elevation, number_of_streams);
ram_release_map(&map_streams);
ram_release_map(&map_dirs);
+ ram_release_map(&map_elevation);
ram_create_map(&map_output, DCELL_TYPE);
output = (DCELL **) map_output.map; /* one output for all maps */
if (out_identifier_opt->answer) {
ram_create_map(&map_identifier, CELL_TYPE);
+ ram_reset_map(&map_identifier, 0);
identifier = (CELL **) map_identifier.map;
ram_calculate_identifiers(identifier, number_of_streams,
downstream);
@@ -182,7 +188,7 @@
if (out_difference_opt->answer) {
- ram_set_null_output(output);
+ ram_reset_map(&map_output, nullval);
if (local)
ram_calculate_difference(output, number_of_streams,
downstream);
@@ -193,7 +199,7 @@
if (out_distance_opt->answer) {
if (local && !cells)
ram_calculate_local_distance(output, number_of_streams,
downstream);
@@ -206,7 +212,7 @@
if (out_gradient_opt->answer) {
if (local)
ram_calculate_local_gradient(output, number_of_streams,
downstream);
@@ -217,7 +223,7 @@
if (out_curvature_opt->answer) {
ram_calculate_curvature(output, number_of_streams, downstream);
ram_write_map(&map_output, out_curvature_opt->answer, DCELL_TYPE,
0, 0);
@@ -225,25 +231,35 @@
ram_release_map(&map_output);
+ else {
SEG map_dirs, map_streams, map_elevation, map_output, map_identifier;
SEGMENT *streams, *dirs, *elevation, *output, *identifier;
+ DCELL nullval;
+ double seg_size;
G_message(_("Calculating segments in direction <%s> (may take some time)..."),
- number_of_segs = number_of_segs < 32 ? (int)(32 / 0.18) : number_of_segs / 0.18;
+ seg_size = (sizeof(CELL) * 2.0 + sizeof(FCELL)) * SROWS * SCOLS / (1 << 20);
seg_create_map(&map_streams, SROWS, SCOLS, number_of_segs, CELL_TYPE);
seg_create_map(&map_elevation, SROWS, SCOLS, number_of_segs,
FCELL_TYPE);
- seg_read_map(&map_elevation, in_elev_opt->answer, 0, -1);
+ seg_read_map(&map_elevation, in_elev_opt->answer, 0, -1, nullval);
@@ -253,12 +269,14 @@
seg_build_streamlines(streams, dirs, elevation, number_of_streams);
seg_release_map(&map_streams);
seg_release_map(&map_dirs);
+ seg_release_map(&map_elevation);
seg_create_map(&map_output, SROWS, SCOLS, number_of_segs, DCELL_TYPE);
output = &map_output.seg; /* one output for all maps */
seg_create_map(&map_identifier, SROWS, SCOLS, number_of_segs,
CELL_TYPE);
+ seg_reset_map(&map_identifier, 0);
identifier = &map_identifier.seg;
seg_calculate_identifiers(identifier, number_of_streams,
downstream);
@@ -268,7 +286,7 @@
- seg_set_null_output(output);
+ seg_reset_map(&map_output, nullval);
if (local)
seg_calculate_difference(output, number_of_streams,
downstream);
@@ -279,7 +297,7 @@
seg_calculate_local_distance(output, number_of_streams,
downstream);
@@ -292,7 +310,7 @@
if (local)
seg_calculate_local_gradient(output, number_of_streams,
downstream);
@@ -303,7 +321,7 @@
seg_calculate_curvature(output, number_of_streams, downstream);
seg_write_map(&map_output, out_curvature_opt->answer, DCELL_TYPE,
0, 0);
@@ -312,5 +330,6 @@
seg_release_map(&map_output);
free_attributes(number_of_streams);
exit(EXIT_SUCCESS);
Modified: grass-addons/grass7/raster/r.stream.channel/stream_topology.c
--- grass-addons/grass7/raster/r.stream.channel/stream_topology.c 2014-11-09 14:47:35 UTC (rev 62685)
+++ grass-addons/grass7/raster/r.stream.channel/stream_topology.c 2014-11-09 14:51:02 UTC (rev 62686)
@@ -34,7 +34,7 @@
trib_num++;
- if (trib_num > 1)
+ if (trib_num > 1) {
for (i = 1; i < 9; ++i) {
if (NOT_IN_REGION(i))
continue;
@@ -47,6 +47,7 @@
dirs[next_r][next_c] == j)
trib_num--;
if (trib_num > 5)
G_fatal_error(_("Error finding inits. Stream and direction maps probably do not match"));
@@ -63,11 +64,15 @@
int r, c;
int stream_num = 0;
+ if (streams[r][c] > 0) {
if (ram_trib_nums(r, c, streams, dirs) != 1)
stream_num++;
return stream_num;
@@ -90,9 +95,9 @@
G_message(_("Finding inits..."));
SA = stream_attributes;
- if (streams[r][c])
if (ram_trib_nums(r, c, streams, dirs) != 1) { /* adding inits */
if (stream_num > number_of_streams)
@@ -101,6 +106,9 @@
SA[stream_num].init_r = r;
SA[stream_num++].init_c = c;
for (i = 1; i < stream_num; ++i) {
@@ -123,8 +131,8 @@
for (i = 1; i < number_of_streams; ++i) {
- SA[i].points = (unsigned long int *)
- G_malloc((SA[i].number_of_cells) * sizeof(unsigned long int));
+ SA[i].points = (long int *)
+ G_malloc((SA[i].number_of_cells) * sizeof(long int));
SA[i].elevation = (float *)
G_malloc((SA[i].number_of_cells) * sizeof(float));
SA[i].distance = (double *)
@@ -137,16 +145,20 @@
prev_c = NC(contrib_cell);
/* add one point contributing to init to calculate parameters */
- /* what to do if there is no contributing points? */
+ /* what to do if there are no contributing points? */
SA[i].points[0] = (contrib_cell == 0) ? -1 : INDEX(prev_r, prev_c);
- SA[i].elevation[0] = (contrib_cell == 0) ? -99999 :
- elevation[prev_r][prev_c];
+ SA[i].elevation[0] = -99999;
+ if (contrib_cell != 0 && !Rast_is_f_null_value(&elevation[prev_r][prev_c]))
+ SA[i].elevation[0] = elevation[prev_r][prev_c];
d = (contrib_cell == 0) ? dirs[r][c] : dirs[prev_r][prev_c];
SA[i].distance[0] = (contrib_cell == 0) ? get_distance(r, c, d) :
get_distance(prev_r, prev_c, d);
SA[i].points[1] = INDEX(r, c);
- SA[i].elevation[1] = elevation[r][c];
+ SA[i].elevation[1] = -99999;
+ if (!Rast_is_f_null_value(&elevation[r][c]))
+ SA[i].elevation[1] = elevation[r][c];
SA[i].distance[1] = get_distance(r, c, d);
@@ -157,6 +169,9 @@
if (NOT_IN_REGION(d) || d == 0) {
SA[i].points[cell_num] = -1;
SA[i].distance[cell_num] = SA[i].distance[cell_num - 1];
+ /* what if SA[i].elevation[cell_num - 1] == -99999 ||
+ * SA[i].elevation[cell_num - 2] == -99999
SA[i].elevation[cell_num] =
2 * SA[i].elevation[cell_num - 1] -
SA[i].elevation[cell_num - 2];
@@ -166,6 +181,8 @@
c = NC(d);
SA[i].points[cell_num] = INDEX(r, c);
SA[i].elevation[cell_num] = elevation[r][c];
+ if (Rast_is_f_null_value(&SA[i].elevation[cell_num]))
+ SA[i].elevation[cell_num] = -99999;
next_d = (abs(dirs[r][c]) == 0) ? d : abs(dirs[r][c]);
SA[i].distance[cell_num] = get_distance(r, c, next_d);
cell_num++;
@@ -173,6 +190,9 @@
G_fatal_error(_("To many points in stream line"));
} while (streams[r][c] == SA[i].order);
+ /* what if SA[i].elevation[1] == -99999 ||
+ * SA[i].elevation[2] == -99999
if (SA[i].elevation[0] == -99999)
SA[i].elevation[0] = 2 * SA[i].elevation[1] - SA[i].elevation[2];
@@ -203,7 +223,7 @@
trib_num++;
- if (trib_num > 1)
continue;
@@ -216,6 +236,7 @@
if (streams_next_cell == streams_cell && dirs_next_cell == j)
trib_num--;
if (trib_num > 5)
G_fatal_error(_("Error finding inits. Stream and direction maps probably do not match..."));
@@ -231,14 +252,16 @@
int stream_num = 0;
int streams_cell;
- if (streams_cell > 0)
if (seg_trib_nums(r, c, streams, dirs) != 1)
stream_num++;
- G_message("%d", stream_num);
return stream_num;
@@ -256,18 +279,17 @@
stream_num = 1;
stream_attributes =
(STREAM *) G_malloc(number_of_streams * sizeof(STREAM));
G_message("Finding inits...");
/* finding inits */
- if (streams_cell)
if (seg_trib_nums(r, c, streams, dirs) != 1) { /* adding inits */
@@ -276,7 +298,9 @@
/* building streamline */
@@ -319,12 +343,13 @@
Segment_get(elevation, &elevation_prev_cell, prev_r, prev_c);
- elevation_prev_cell;
+ if (contrib_cell != 0 && !Rast_is_f_null_value(&elevation_prev_cell))
+ SA[i].elevation[0] = elevation_prev_cell;
if (contrib_cell == 0)
Segment_get(dirs, &d, r, c);
@@ -335,6 +360,9 @@
Segment_get(elevation, &(SA[i].elevation[1]), r, c);
+ if (Rast_is_f_null_value(&SA[i].elevation[1]))
@@ -346,6 +374,9 @@
@@ -355,6 +386,8 @@
c = NC(d);
Segment_get(elevation, &(SA[i].elevation[cell_num]), r, c);
Segment_get(dirs, &next_d, r, c);
next_d = (abs(next_d) == 0) ? d : abs(next_d);
@@ -364,6 +397,9 @@
G_fatal_error(_("To much points in stream line..."));
} while (streams_cell == SA[i].order);
@@ -383,6 +419,7 @@
next_r = NR(i);
next_c = NC(i);
if (dirs[next_r][next_c] == DIAG(i) &&
+ !Rast_is_f_null_value(&elevation[next_r][next_c]) &&
elevation[next_r][next_c] < elev_min) {
elev_min = elevation[next_r][next_c];
j = i;
@@ -397,9 +434,9 @@
int i, j = 0;
int next_r, next_c;
- float elev_min = 9999;
+ FCELL elev_min = 9999;
int dirs_next_cell;
- float elevation_next_cell;
+ FCELL elevation_next_cell;
@@ -408,7 +445,9 @@
next_c = NC(i);
Segment_get(dirs, &dirs_next_cell, next_r, next_c);
Segment_get(elevation, &elevation_next_cell, next_r, next_c);
- if (dirs_next_cell == DIAG(i) && elevation_next_cell < elev_min) {
+ if (dirs_next_cell == DIAG(i) &&
+ !Rast_is_f_null_value(&elevation_next_cell) &&
+ elevation_next_cell < elev_min) {
elev_min = elevation_next_cell;
j = i;
Modified: grass-addons/grass7/raster/r.stream.channel/stream_write.c
--- grass-addons/grass7/raster/r.stream.channel/stream_write.c 2014-11-09 14:47:35 UTC (rev 62685)
+++ grass-addons/grass7/raster/r.stream.channel/stream_write.c 2014-11-09 14:51:02 UTC (rev 62686)
@@ -1,29 +1,5 @@
- int r;
- Rast_set_d_null_value(output[r], ncols);
- return 0;
- int r, c;
- double output_cell;
- for (r = 0; r < nrows; ++r) {
- for (c = 0; c < ncols; ++c) {
- Rast_set_d_null_value(&output_cell, 1);
- Segment_put(output, &output_cell, r, c);
- return 0;
int downstream)
@@ -79,20 +55,22 @@
cum_length = 0;
- if (!downstream)
+ if (!downstream) {
for (j = 1; j < SA[i].number_of_cells - 1; ++j) {
cum_length += SA[i].distance[j];
r = (int)SA[i].points[j] / ncols;
c = (int)SA[i].points[j] % ncols;
output[r][c] = cum_length;
- else
+ else {
for (j = SA[i].number_of_cells - 2; j > 0; --j) {
return 0;
@@ -110,20 +88,22 @@
cum_length = 0;
- if (!downstream)
Segment_put(output, &cum_length, r, c);
- else
+ else {
return 0;
@@ -187,6 +167,7 @@
+ /* what if any elevation is -99999 ? */
result = downstream ?
SA[i].elevation[j - 1] - SA[i].elevation[j] :
SA[i].elevation[j] - SA[i].elevation[j + 1];
@@ -212,6 +193,7 @@
output_cell = downstream ?
@@ -234,6 +216,7 @@
if (!downstream) {
init = SA[i].elevation[1];
@@ -267,6 +250,7 @@
if (!downstream) {
@@ -303,6 +287,7 @@
cum_length = 0;
if (!downstream) {
init = SA[i].elevation[0];
@@ -340,6 +325,7 @@
cum_length = 0;
if (!downstream) {
@@ -381,6 +367,7 @@
elev_diff =
(SA[i].elevation[j] - SA[i].elevation[j + 1]) <
0 ? 0 : (SA[i].elevation[j] - SA[i].elevation[j + 1]);
@@ -407,6 +394,7 @@
elev_diff =
@@ -478,6 +466,7 @@
first_derivative =
(SA[i].elevation[j - 1] -
SA[i].elevation[j + 1]) / (SA[i].distance[j - 1] +
@@ -512,6 +501,7 @@
first_derivative =
Modified: grass-addons/grass7/raster/r.stream.distance/distance_calc.c
--- grass-addons/grass7/raster/r.stream.distance/distance_calc.c 2014-11-09 14:47:35 UTC (rev 62685)
+++ grass-addons/grass7/raster/r.stream.distance/distance_calc.c 2014-11-09 14:51:02 UTC (rev 62686)
@@ -105,6 +105,7 @@
} /* end stream mode */
if (elevation) {
+ /* TODO: check for NULL value */
elevation[next_r][next_c] =
elevation[next_r][next_c] - target_elev;
n_cell.target_elev = target_elev;
@@ -212,6 +213,7 @@
if (elevation) {
Segment_get(elevation, &elevation_cell, next_r, next_c);
elevation_cell -= target_elev;
Segment_put(elevation, &elevation_cell, next_r, next_c);
@@ -232,6 +234,7 @@
target_elev = n_cell.target_elev;
} /* end while */
return 0;
@@ -354,12 +357,13 @@
if (elevation) {
elevation_data_size = Rast_cell_size(DCELL_TYPE);
memcpy(tmp_elevation[r], elevation[r],
ncols * elevation_data_size);
@@ -379,11 +383,12 @@
else if (dirs[r][c] > 0)
distance[r][c] = -1;
d_inits = (POINT *) G_malloc(n_inits * sizeof(POINT));
k = 0;
if (distance[r][c] == 1) {
@@ -401,13 +406,14 @@
d_inits[k].c = c;
d_inits[k].cur_dist = 0;
if (elevation)
d_inits[k].target_elev = tmp_elevation[r][c];
k++;
counter = n_inits = k;
/* return 0; */
@@ -444,6 +450,7 @@
if (done) {
distance[next_r][next_c] = cur_dist;
if (elevation) {
target_elev - tmp_elevation[next_r][next_c];
@@ -454,6 +461,7 @@
d_inits[k].c = next_c;
d_inits[k].cur_dist = cur_dist;
if (elevation)
d_inits[k].target_elev = target_elev;
k++;
@@ -462,6 +470,7 @@
n_inits = k;
G_percent((counter - n_inits), counter, 10);
return 0;
@@ -493,14 +502,15 @@
if (elevation) {
/* elevation_data_size = Rast_cell_size(DCELL_TYPE); */
Segment_get(elevation, &elevation_cell, r, c);
Segment_put(tmp_elevation, &elevation_cell, r, c);
Segment_get(distance, &distance_cell, r, c);
@@ -531,11 +541,12 @@
k = 0;
@@ -561,6 +572,7 @@
k++;
@@ -601,6 +613,7 @@
if (done) {
Segment_put(distance, &cur_dist, next_r, next_c);
if (elevation) {
Segment_get(tmp_elevation, &tmp_elevation_cell, next_r,
next_c);
tmp_elevation_cell = target_elev - tmp_elevation_cell;
@@ -616,6 +629,7 @@
if (elevation)
k++;
@@ -624,5 +638,6 @@
n_inits = k;
G_percent(1, 1, 1);
return 0;
Modified: grass-addons/grass7/raster/r.stream.distance/io.c
--- grass-addons/grass7/raster/r.stream.distance/io.c 2014-11-09 14:47:35 UTC (rev 62685)
+++ grass-addons/grass7/raster/r.stream.distance/io.c 2014-11-09 14:51:02 UTC (rev 62686)
@@ -44,7 +44,7 @@
@@ -125,9 +125,9 @@
case CELL_TYPE:
break;
+ else {
+ case CELL_TYPE:
+ break;
+ case FCELL_TYPE:
+ break;
+ case DCELL_TYPE:
+ break;
+ default:
+ break;
} /*end for r */
return 0;
- int r;
+ int r, c;
+ case CELL_TYPE:
+ break;
+ case FCELL_TYPE:
+ break;
+ case DCELL_TYPE:
+ break;
+ default:
+ break;
return 0;
@@ -218,7 +277,8 @@
break;
default:
+ break;
@@ -235,9 +295,9 @@
int r;
@@ -325,7 +385,7 @@
if (mapset == NULL)
input_map_name);
@@ -410,9 +472,8 @@
break;
+ else {
+ case CELL_TYPE:
+ break;
+ case FCELL_TYPE:
+ break;
+ case DCELL_TYPE:
+ break;
+ default:
+ break;
r, input_map_name);
} /* end for row */
return 0;
int r, c;
+ case CELL_TYPE:
+ break;
+ case FCELL_TYPE:
+ break;
+ case DCELL_TYPE:
+ break;
+ default:
+ break;
return 0;
@@ -528,7 +641,8 @@
break;
default:
+ break;
Modified: grass-addons/grass7/raster/r.stream.distance/io.h
--- grass-addons/grass7/raster/r.stream.distance/io.h 2014-11-09 14:47:35 UTC (rev 62685)
+++ grass-addons/grass7/raster/r.stream.distance/io.h 2014-11-09 14:51:02 UTC (rev 62686)
@@ -17,8 +17,8 @@
-#define SROWS 256
-#define SCOLS 256
+#define SROWS 128
+#define SCOLS 128
typedef struct {
@@ -44,15 +44,15 @@
Modified: grass-addons/grass7/raster/r.stream.distance/main.c
--- grass-addons/grass7/raster/r.stream.distance/main.c 2014-11-09 14:47:35 UTC (rev 62685)
+++ grass-addons/grass7/raster/r.stream.distance/main.c 2014-11-09 14:51:02 UTC (rev 62686)
@@ -123,7 +123,8 @@
if (out_diff_opt->answer && !in_elev_opt->answer)
G_fatal_error(_("Output elevation difference raster map requires "
"input elevation raster map to be specified"));
+ method = -1;
if (!strcmp(in_method_opt->answer, "upstream"))
method = UPSTREAM;
else if (!strcmp(in_method_opt->answer, "downstream"))
@@ -142,19 +143,23 @@
if (!segmentation) {
- G_message(_("All in RAM calculation - method <%s>..."),
- method_name[method]);
MAP map_dirs, map_streams, map_distance, map_elevation,
map_tmp_elevation;
CELL **streams, **dirs;
DCELL **distance;
DCELL **elevation = NULL;
DCELL **tmp_elevation = NULL;
+ DCELL nullval;
+ G_message(_("All in RAM calculation - method <%s>..."),
+ method_name[method]);
ram_create_map(&map_distance, DCELL_TYPE);
@@ -169,11 +174,10 @@
if (in_elev_opt->answer) {
ram_create_map(&map_elevation, DCELL_TYPE);
elevation = (DCELL **) map_elevation.map;
} /* map elevation will be replaced by elevation difference map */
if (method == DOWNSTREAM) {
G_message(_("Calculate downstream parameters..."));
for (j = 0; j < outlets_num; ++j) {
@@ -182,20 +186,23 @@
outlets[j], outs);
G_percent(j, outlets_num, 1);
else if (method == UPSTREAM) {
- if (out_diff_opt->answer) {
+ if (elevation) {
ram_create_map(&map_tmp_elevation, DCELL_TYPE);
tmp_elevation = (DCELL **) map_tmp_elevation.map;
ram_fill_basins(outlets[j], distance, dirs);
ram_calculate_upstream(distance, dirs, elevation, tmp_elevation,
near);
+ if (elevation) {
+ ram_release_map(&map_tmp_elevation);
else {
G_fatal_error(_("Unrecognised method of processing"));
@@ -216,29 +223,41 @@
- if (in_elev_opt->answer && method == UPSTREAM)
- ram_release_map(&map_tmp_elevation);
- G_message(_("Calculating segments in direction <%s> (may take some time)..."),
+ else {
SEG map_dirs, map_streams, map_distance, map_elevation,
map_tmp_elevation;
SEGMENT *streams, *dirs, *distance;
SEGMENT *elevation = NULL;
SEGMENT *tmp_elevation = NULL;
+ DCELL nullval;
+ double seg_size;
- if (method == DOWNSTREAM)
- else /* two elevation maps */
- number_of_segs = number_of_segs < 32 ? (int)(32 / 0.24) : number_of_segs / 0.24;
+ G_message(_("Calculating segments in direction <%s> (may take some time)..."),
+ if (method == UPSTREAM && in_elev_opt->answer) {
+ seg_size = (sizeof(CELL) * 2.0 + sizeof(DCELL) * 2.0) * SROWS * SCOLS / (1 << 20);
+ else {
+ seg_size = (sizeof(CELL) * 2.0 + sizeof(DCELL) * 1.0) * SROWS * SCOLS / (1 << 20);
seg_create_map(&map_distance, SROWS, SCOLS, number_of_segs,
DCELL_TYPE);
@@ -255,7 +274,7 @@
DCELL_TYPE);
elevation = &map_elevation.seg;
@@ -271,7 +290,7 @@
+ if (elevation) {
seg_create_map(&map_tmp_elevation, SROWS, SCOLS,
tmp_elevation = &map_tmp_elevation.seg;
@@ -279,9 +298,12 @@
seg_fill_basins(outlets[j], distance, dirs);
seg_calculate_upstream(distance, dirs, elevation, tmp_elevation,
near);
+ if (elevation) {
+ seg_release_map(&map_tmp_elevation);
else {
@@ -302,10 +324,9 @@
- seg_release_map(&map_tmp_elevation);
exit(EXIT_SUCCESS);
Modified: grass-addons/grass7/raster/r.stream.order/io.c
--- grass-addons/grass7/raster/r.stream.order/io.c 2014-11-09 14:47:35 UTC (rev 62685)
+++ grass-addons/grass7/raster/r.stream.order/io.c 2014-11-09 14:51:02 UTC (rev 62686)
@@ -44,7 +44,7 @@
@@ -125,9 +125,9 @@
case CELL_TYPE:
break;
+ else {
+ case CELL_TYPE:
+ break;
+ case FCELL_TYPE:
+ break;
+ case DCELL_TYPE:
+ break;
+ default:
+ break;
} /*end for r */
return 0;
- int r;
+ int r, c;
+ case CELL_TYPE:
+ break;
+ case FCELL_TYPE:
+ break;
+ case DCELL_TYPE:
+ break;
+ default:
+ break;
return 0;
@@ -218,7 +277,8 @@
break;
default:
+ break;
@@ -235,9 +295,9 @@
int r;
@@ -325,7 +385,7 @@
if (mapset == NULL)
input_map_name);
@@ -410,9 +472,8 @@
break;
+ else {
+ case CELL_TYPE:
+ break;
+ case FCELL_TYPE:
+ break;
+ case DCELL_TYPE:
+ break;
+ default:
+ break;
r, input_map_name);
} /* end for row */
return 0;
int r, c;
+ case CELL_TYPE:
+ break;
+ case FCELL_TYPE:
+ break;
+ case DCELL_TYPE:
+ break;
+ default:
+ break;
return 0;
@@ -528,7 +641,8 @@
break;
default:
+ break;
Modified: grass-addons/grass7/raster/r.stream.order/io.h
--- grass-addons/grass7/raster/r.stream.order/io.h 2014-11-09 14:47:35 UTC (rev 62685)
+++ grass-addons/grass7/raster/r.stream.order/io.h 2014-11-09 14:51:02 UTC (rev 62686)
@@ -17,8 +17,8 @@
-#define SROWS 256
-#define SCOLS 256
+#define SROWS 128
+#define SCOLS 128
typedef struct {
@@ -44,15 +44,15 @@
Modified: grass-addons/grass7/raster/r.stream.order/main.c
--- grass-addons/grass7/raster/r.stream.order/main.c 2014-11-09 14:47:35 UTC (rev 62685)
+++ grass-addons/grass7/raster/r.stream.order/main.c 2014-11-09 14:51:02 UTC (rev 62686)
@@ -35,8 +35,8 @@
{"accumulation", NO, _("Name of input accumulation raster map")}
- /* add new basic rdering here and in local_vars.h declaration
- * it will be added to output without addational programing.
+ /* add new basic ordering here and in local_vars.h declaration
+ * it will be added to output without additional programing.
* Ordering functions are to be added in stream_order.c file.
* Addational operations may shall be done in common part sections
* derivative orders (like Scheideggers/Shreve) shall be added only
@@ -57,7 +57,6 @@
struct Flag *flag_zerofill, *flag_accum, *flag_segmentation;
int output_num = 0;
- /* int num_seg; */ /* number of segments */
int segmentation, zerofill;
int i; /* iteration vars */
int number_of_segs;
@@ -132,9 +131,6 @@
use_accum = (flag_accum->answer != 0);
use_vector = (opt_vector->answer != NULL);
- number_of_segs = number_of_segs < 32 ? (int)(32 / 0.12) : number_of_segs / 0.12;
if (use_vector)
if (!opt_input[o_elev]->answer || !opt_input[o_accum]->answer)
G_fatal_error(_("To calculate vector map both accumulation and elevation raster maps are required"));
@@ -167,14 +163,15 @@
/* ALL IN RAM VERSION */
- G_message(_("All in RAM calculation..."));
MAP map_streams, map_dirs;
- ram_read_map(&map_streams, in_streams, 1, CELL_TYPE);
+ ram_read_map(&map_streams, in_streams, 1, CELL_TYPE, 0);
- ram_read_map(&map_dirs, in_dirs, 1, CELL_TYPE);
+ ram_read_map(&map_dirs, in_dirs, 1, CELL_TYPE, 0);
stream_init((int)map_streams.min, (int)map_streams.max);
number_of_streams = (int)(map_streams.max + 1);
@@ -218,18 +215,29 @@
/* end ram section */
/* SEGMENTATION VERSION */
- G_message(_("Memory swap calculation (may take some time)..."));
+ else {
SEG map_streams, map_dirs;
SEGMENT *streams, *dirs;
+ double seg_size;
+ G_message(_("Memory swap calculation (may take some time)..."));
- seg_read_map(&map_streams, in_streams, 1, CELL_TYPE);
+ seg_read_map(&map_streams, in_streams, 1, CELL_TYPE, 0);
- seg_read_map(&map_dirs, in_dirs, 1, CELL_TYPE);
+ seg_read_map(&map_dirs, in_dirs, 1, CELL_TYPE, 0);
@@ -274,7 +282,6 @@
/* end segmentation section */
/* free */
G_free(stream_attributes);
G_free(init_streams);
@@ -282,5 +289,4 @@
G_free(init_cells);
exit(EXIT_SUCCESS);
Modified: grass-addons/grass7/raster/r.stream.order/stream_init.c
--- grass-addons/grass7/raster/r.stream.order/stream_init.c 2014-11-09 14:47:35 UTC (rev 62685)
+++ grass-addons/grass7/raster/r.stream.order/stream_init.c 2014-11-09 14:51:02 UTC (rev 62686)
@@ -92,6 +92,7 @@
input_data_type = Rast_map_type(input_map_name, mapset);
input_data_size = Rast_cell_size(input_data_type);
+ input_ptr = input_buffer;
for (i = 0; i < (number_of_streams); ++i) {
if (pointers_to_stream[i]->stream == -1)
@@ -106,9 +107,9 @@
c = (int)pointers_to_stream[i]->init % ncols;
- if (r > cur_row) {
+ if (r != cur_row) {
- input_ptr = input_buffer;
+ cur_row = r;
switch (what) {
case 0: /* inits for elev */
@@ -130,5 +131,6 @@
G_free(pointers_to_stream);
return 0;
Modified: grass-addons/grass7/raster/r.stream.order/stream_raster_close.c
--- grass-addons/grass7/raster/r.stream.order/stream_raster_close.c 2014-11-09 14:47:35 UTC (rev 62685)
+++ grass-addons/grass7/raster/r.stream.order/stream_raster_close.c 2014-11-09 14:51:02 UTC (rev 62686)
@@ -38,7 +38,8 @@
Rast_set_c_null_value(output_buffer, ncols);
- if (streams_buffer[c])
+ if (!Rast_is_c_null_value(&streams_buffer[c]) &&
+ streams_buffer[c] > 0)
output_buffer[c] = all_orders[i][streams_buffer[c]];
Rast_put_c_row(output_fd[i], output_buffer);
@@ -106,7 +107,8 @@
- if (!Rast_is_c_null_value(&streams_buffer[c]))
Modified: grass-addons/grass7/raster/r.stream.order/stream_topology.c
--- grass-addons/grass7/raster/r.stream.order/stream_topology.c 2014-11-09 14:47:35 UTC (rev 62685)
+++ grass-addons/grass7/raster/r.stream.order/stream_topology.c 2014-11-09 14:51:02 UTC (rev 62686)
@@ -48,7 +48,7 @@
- if (streams[r][c]) {
trib_num = ram_number_of_tribs(r, c, streams, dirs);
trib = 0;
d = abs(dirs[r][c]); /* r.watershed! */
@@ -261,7 +261,7 @@
- if (streams_cell) {
trib_num = seg_number_of_tribs(r, c, streams, dirs);
trib = 0;
Modified: grass-addons/grass7/raster/r.stream.segment/io.c
--- grass-addons/grass7/raster/r.stream.segment/io.c 2014-11-09 14:47:35 UTC (rev 62685)
+++ grass-addons/grass7/raster/r.stream.segment/io.c 2014-11-09 14:51:02 UTC (rev 62686)
@@ -44,7 +44,7 @@
@@ -125,9 +125,9 @@
case CELL_TYPE:
break;
+ else {
+ case CELL_TYPE:
+ break;
+ case FCELL_TYPE:
+ break;
+ case DCELL_TYPE:
+ break;
+ default:
+ break;
} /*end for r */
return 0;
- int r;
+ int r, c;
+ case CELL_TYPE:
+ break;
+ case FCELL_TYPE:
+ break;
+ case DCELL_TYPE:
+ break;
+ default:
+ break;
return 0;
@@ -218,7 +277,8 @@
break;
default:
+ break;
@@ -235,9 +295,9 @@
int r;
@@ -325,7 +385,7 @@
if (mapset == NULL)
input_map_name);
@@ -410,9 +472,8 @@
break;
+ else {
+ case CELL_TYPE:
+ break;
+ case FCELL_TYPE:
+ break;
+ case DCELL_TYPE:
+ break;
+ default:
+ break;
r, input_map_name);
} /* end for row */
return 0;
int r, c;
+ case CELL_TYPE:
+ break;
+ case FCELL_TYPE:
+ break;
+ case DCELL_TYPE:
+ break;
+ default:
+ break;
return 0;
@@ -528,7 +641,8 @@
break;
default:
+ break;
Modified: grass-addons/grass7/raster/r.stream.segment/io.h
--- grass-addons/grass7/raster/r.stream.segment/io.h 2014-11-09 14:47:35 UTC (rev 62685)
+++ grass-addons/grass7/raster/r.stream.segment/io.h 2014-11-09 14:51:02 UTC (rev 62686)
@@ -17,8 +17,8 @@
-#define SROWS 256
-#define SCOLS 256
+#define SROWS 128
+#define SCOLS 128
typedef struct {
@@ -44,15 +44,15 @@
Modified: grass-addons/grass7/raster/r.stream.segment/local_vars.h
--- grass-addons/grass7/raster/r.stream.segment/local_vars.h 2014-11-09 14:47:35 UTC (rev 62685)
+++ grass-addons/grass7/raster/r.stream.segment/local_vars.h 2014-11-09 14:51:02 UTC (rev 62686)
@@ -15,7 +15,7 @@
int next_stream;
int order;
float * elevation;
double * distance;
unsigned long int init;
Modified: grass-addons/grass7/raster/r.stream.segment/main.c
--- grass-addons/grass7/raster/r.stream.segment/main.c 2014-11-09 14:47:35 UTC (rev 62685)
+++ grass-addons/grass7/raster/r.stream.segment/main.c 2014-11-09 14:51:02 UTC (rev 62686)
@@ -139,20 +139,22 @@
Rast_get_window(&window);
G_begin_distance_calculations();
MAP map_dirs, map_streams, map_elevation, map_unique_streams;
CELL **streams, **dirs, **unique_streams = NULL;
FCELL **elevation;
+ DCELL nullval;
@@ -176,25 +178,36 @@
+ else {
SEG map_dirs, map_streams, map_elevation, map_unique_streams;
SEGMENT *streams, *dirs, *unique_streams = NULL;
SEGMENT *elevation;
+ DCELL nullval;
int number_of_segs;
+ double seg_size;
FCELL_TYPE);
@@ -286,6 +299,6 @@
create_sector_vector(out_sector_opt->answer, number_of_streams, radians);
- G_message("Done");
exit(EXIT_SUCCESS);
Modified: grass-addons/grass7/raster/r.stream.segment/stream_segment.c
--- grass-addons/grass7/raster/r.stream.segment/stream_segment.c 2014-11-09 14:47:35 UTC (rev 62685)
+++ grass-addons/grass7/raster/r.stream.segment/stream_segment.c 2014-11-09 14:51:02 UTC (rev 62686)
@@ -44,7 +44,7 @@
double seg_treshold)
DIRCELLS *streamline;
- unsigned long int *P; /* alias for points */
+ long int *P; /* alias for points */
int i, prev_i = 0;
@@ -223,7 +223,7 @@
int cell_up, cell_down;
int r, c, r_up, c_up, r_down, c_down;
STREAM *SA = stream_attributes;
- unsigned long int *P = cur_stream->points;
+ long int *P = cur_stream->points;
int next_stream = cur_stream->next_stream;
unsigned int outlet = cur_stream->outlet;
int last_cell = cur_stream->number_of_cells - 1;
Modified: grass-addons/grass7/raster/r.stream.segment/stream_topology.c
--- grass-addons/grass7/raster/r.stream.segment/stream_topology.c 2014-11-09 14:47:35 UTC (rev 62685)
+++ grass-addons/grass7/raster/r.stream.segment/stream_topology.c 2014-11-09 14:51:02 UTC (rev 62686)
@@ -203,8 +203,8 @@
@@ -325,8 +325,8 @@
Modified: grass-addons/grass7/raster/r.stream.snap/io.c
--- grass-addons/grass7/raster/r.stream.snap/io.c 2014-11-09 14:47:35 UTC (rev 62685)
+++ grass-addons/grass7/raster/r.stream.snap/io.c 2014-11-09 14:51:02 UTC (rev 62686)
@@ -44,7 +44,7 @@
@@ -125,9 +125,9 @@
case CELL_TYPE:
break;
+ else {
+ case CELL_TYPE:
+ break;
+ case FCELL_TYPE:
+ break;
+ case DCELL_TYPE:
+ break;
+ default:
+ break;
} /*end for r */
return 0;
- int r;
+ int r, c;
+ case CELL_TYPE:
+ break;
+ case FCELL_TYPE:
+ break;
+ case DCELL_TYPE:
+ break;
+ default:
+ break;
return 0;
@@ -218,7 +277,8 @@
break;
default:
+ break;
@@ -235,9 +295,9 @@
int r;
@@ -325,7 +385,7 @@
if (mapset == NULL)
input_map_name);
@@ -410,9 +472,8 @@
break;
+ else {
+ case CELL_TYPE:
+ break;
+ case FCELL_TYPE:
+ break;
+ case DCELL_TYPE:
+ break;
+ default:
+ break;
r, input_map_name);
} /* end for row */
return 0;
int r, c;
+ case CELL_TYPE:
+ break;
+ case FCELL_TYPE:
+ break;
+ case DCELL_TYPE:
+ break;
+ default:
+ break;
return 0;
@@ -528,7 +641,8 @@
break;
default:
+ break;
Modified: grass-addons/grass7/raster/r.stream.snap/io.h
--- grass-addons/grass7/raster/r.stream.snap/io.h 2014-11-09 14:47:35 UTC (rev 62685)
+++ grass-addons/grass7/raster/r.stream.snap/io.h 2014-11-09 14:51:02 UTC (rev 62686)
@@ -17,8 +17,8 @@
-#define SROWS 256
-#define SCOLS 256
+#define SROWS 128
+#define SCOLS 128
typedef struct {
@@ -44,15 +44,15 @@
Modified: grass-addons/grass7/raster/r.stream.snap/main.c
--- grass-addons/grass7/raster/r.stream.snap/main.c 2014-11-09 14:47:35 UTC (rev 62685)
+++ grass-addons/grass7/raster/r.stream.snap/main.c 2014-11-09 14:51:02 UTC (rev 62686)
@@ -36,7 +36,9 @@
int i;
SEG map_streams, map_accum;
SEGMENT *streams = NULL, *accum = NULL;
+ DCELL nullval;
int number_of_segs;
+ double seg_size;
int number_of_points;
int radius;
double accum_treshold;
@@ -94,9 +96,6 @@
if (G_parser(argc, argv)) /* parser */
exit(EXIT_FAILURE);
radius = atoi(opt_distance_treshold->answer);
accum_treshold = atof(opt_accum_treshold->answer);
@@ -113,18 +112,36 @@
if (!in_accum_opt->answer)
accum_treshold = -1;
/* SEGMENT VERSION ONLY */
+ seg_size = 0;
+ if (in_stream_opt->answer)
+ seg_size = sizeof(CELL);
+ if (in_accum_opt->answer)
+ seg_size += sizeof(DCELL);
+ seg_size = seg_size * SROWS * SCOLS / (1 << 20);
if (in_stream_opt->answer) {
- seg_read_map(&map_streams, in_stream_opt->answer, 1, CELL_TYPE);
+ seg_read_map(&map_streams, in_stream_opt->answer, 1, CELL_TYPE, 0);
if (in_accum_opt->answer) {
seg_create_map(&map_accum, SROWS, SCOLS, number_of_segs, DCELL_TYPE);
- seg_read_map(&map_accum, in_accum_opt->answer, 0, -1);
+ seg_read_map(&map_accum, in_accum_opt->answer, 0, -1, nullval);
accum = &map_accum.seg;
Modified: grass-addons/grass7/raster/r.stream.snap/snap.c
--- grass-addons/grass7/raster/r.stream.snap/snap.c 2014-11-09 14:47:35 UTC (rev 62685)
+++ grass-addons/grass7/raster/r.stream.snap/snap.c 2014-11-09 14:51:02 UTC (rev 62686)
@@ -104,8 +104,9 @@
/* TODO: this should be fixed by someone who knows the code */
- if (sumaccum > 0)
+ if (sumaccum > 0) {
/* accum_treshold=(sumaccum/naccum+maxaccum)/2 */ ;
accum_treshold = sumaccum / naccum;
for (i = -radius; i <= radius; ++i)
Modified: grass-addons/grass7/raster/r.stream.stats/io.c
--- grass-addons/grass7/raster/r.stream.stats/io.c 2014-11-09 14:47:35 UTC (rev 62685)
+++ grass-addons/grass7/raster/r.stream.stats/io.c 2014-11-09 14:51:02 UTC (rev 62686)
@@ -44,7 +44,7 @@
@@ -125,9 +125,9 @@
case CELL_TYPE:
break;
+ else {
+ case CELL_TYPE:
+ break;
+ case FCELL_TYPE:
+ break;
+ case DCELL_TYPE:
+ break;
+ default:
+ break;
} /*end for r */
return 0;
- int r;
+ int r, c;
+ case CELL_TYPE:
+ break;
+ case FCELL_TYPE:
+ break;
+ case DCELL_TYPE:
+ break;
+ default:
+ break;
return 0;
@@ -218,7 +277,8 @@
break;
default:
+ break;
@@ -235,9 +295,9 @@
int r;
@@ -325,7 +385,7 @@
if (mapset == NULL)
input_map_name);
@@ -410,9 +472,8 @@
break;
+ else {
+ case CELL_TYPE:
+ break;
+ case FCELL_TYPE:
+ break;
+ case DCELL_TYPE:
+ break;
+ default:
+ break;
r, input_map_name);
} /* end for row */
return 0;
int r, c;
+ case CELL_TYPE:
+ break;
+ case FCELL_TYPE:
+ break;
+ case DCELL_TYPE:
+ break;
+ default:
+ break;
return 0;
@@ -528,7 +641,8 @@
break;
default:
+ break;
Modified: grass-addons/grass7/raster/r.stream.stats/io.h
--- grass-addons/grass7/raster/r.stream.stats/io.h 2014-11-09 14:47:35 UTC (rev 62685)
+++ grass-addons/grass7/raster/r.stream.stats/io.h 2014-11-09 14:51:02 UTC (rev 62686)
@@ -17,8 +17,8 @@
-#define SROWS 256
-#define SCOLS 256
+#define SROWS 128
+#define SCOLS 128
typedef struct {
@@ -44,15 +44,15 @@
Modified: grass-addons/grass7/raster/r.stream.stats/main.c
--- grass-addons/grass7/raster/r.stream.stats/main.c 2014-11-09 14:47:35 UTC (rev 62685)
+++ grass-addons/grass7/raster/r.stream.stats/main.c 2014-11-09 14:51:02 UTC (rev 62686)
@@ -113,15 +113,18 @@
MAP map_dirs, map_streams, map_elevation;
FCELL **elevation;
+ DCELL nullval;
@@ -151,19 +154,31 @@
if (segmentation) {
SEG map_dirs, map_streams, map_elevation;
SEGMENT *streams, *dirs, *elevation;
+ DCELL nullval;
+ double seg_size;
FCELL_TYPE);
Modified: grass-addons/grass7/raster/r.stream.stats/stats_calculate.c
--- grass-addons/grass7/raster/r.stream.stats/stats_calculate.c 2014-11-09 14:47:35 UTC (rev 62685)
+++ grass-addons/grass7/raster/r.stream.stats/stats_calculate.c 2014-11-09 14:51:02 UTC (rev 62686)
@@ -1,7 +1,7 @@
double stats_linear_reg(int max_order, double *statistic)
int i;
double avg_x = 0, avg_y = 0;
double sum_x_square = 0;
@@ -24,6 +24,7 @@
result = (avg_x_y - avg_x * avg_y) / (avg_x_square - avg_x * avg_x);
return result;
Modified: grass-addons/grass7/raster/r.stream.stats/stats_prepare.c
--- grass-addons/grass7/raster/r.stream.stats/stats_prepare.c 2014-11-09 14:47:35 UTC (rev 62685)
+++ grass-addons/grass7/raster/r.stream.stats/stats_prepare.c 2014-11-09 14:51:02 UTC (rev 62686)
@@ -12,6 +12,7 @@
tail = 0;
fifo_count++;
return 0;
@@ -37,8 +38,8 @@
outlets = (POINT *) G_malloc((out_max) * sizeof(POINT));
outlets_num = 0;
out_max *= 2;
@@ -71,7 +72,8 @@
stat_streams = (STREAM *) G_malloc((outlets_num) * sizeof(STREAM));
@@ -91,11 +93,10 @@
G_free(outlets);
return 0;
int seg_init_streams(SEGMENT *streams, SEGMENT *dirs, SEGMENT *elevation)
int d, i; /* d: direction, i: iteration */
@@ -108,7 +109,7 @@
outlets_num = 0;
@@ -147,6 +148,7 @@
@@ -169,13 +171,12 @@
G_free(outlets);
return 0;
int ram_calculate_streams(CELL **streams, CELL **dirs, FCELL **elevation)
int i, j, s, d; /* s - streams index */
int done = 1;
int r, c;
@@ -233,7 +234,9 @@
G_distance(next_easting, next_northing, cur_easting,
cur_northing);
diff_elev = elevation[next_r][next_c] - elevation[r][c];
- diff_elev = (diff_elev < 0) ? 0. : diff_elev; /* water cannot flow up */
+ /* water cannot flow up
+ * but DEMs are not perfect */
+ diff_elev = (diff_elev < 0) ? 0. : diff_elev;
stat_streams[s].length += cur_length;
stat_streams[s].slope += (diff_elev / cur_length);
@@ -246,13 +249,10 @@
} /* end for i */
} /* end while */
} /* end for s */
return 0;
int seg_calculate_streams(SEGMENT *streams, SEGMENT *dirs,
SEGMENT *elevation)
@@ -324,7 +324,9 @@
next_c);
diff_elev = elevation_next_cell - elevation_cell;
@@ -337,6 +339,7 @@
} /* end for i */
} /* end while */
} /* end for s */
return 0;
@@ -374,10 +377,10 @@
r = n_cell.r;
c = n_cell.c;
} /* end while */
return area;
int ram_calculate_basins(CELL **dirs)
int i;
@@ -398,6 +401,7 @@
return 0;
@@ -438,6 +442,7 @@
r = n_cell.r;
c = n_cell.c;
} /* end while */
return area;
@@ -460,5 +465,6 @@
return 0;
Modified: grass-addons/grass7/raster/r.stream.stats/stats_print.c
--- grass-addons/grass7/raster/r.stream.stats/stats_print.c 2014-11-09 14:47:35 UTC (rev 62685)
+++ grass-addons/grass7/raster/r.stream.stats/stats_print.c 2014-11-09 14:51:02 UTC (rev 62686)
@@ -2,7 +2,6 @@
int print_stats(int order_max)
int i;
fflush(stdout);
@@ -94,6 +93,7 @@
ord_stats[i].stream_frequency * 1000000);
fflush(stdout);
return 0;
@@ -119,12 +119,12 @@
fprintf(stdout, "Gradient ratio: %2.4f \n",
stats_total.reg_gradient_ratio);
fflush(stdout);
return 0;
int print_stats_orders(int order_max)
int i;
fflush(stdout);
@@ -145,5 +145,6 @@
ord_stats[i].sum_area / 1000000);
fflush(stdout);
return 0;
