[GRASS-SVN] r62691 - grass/trunk/gui/wxpython/gui_core
svn_grass at osgeo.org
Mon Nov 10 07:29:52 PST 2014
Author: annakrat
Date: 2014-11-10 07:29:52 -0800 (Mon, 10 Nov 2014)
New Revision: 62691
grass/trunk/gui/wxpython/gui_core/gselect.py
wxGUI: handle CalledModuleError coming from checking db connection in d.vect dialog
Modified: grass/trunk/gui/wxpython/gui_core/gselect.py
--- grass/trunk/gui/wxpython/gui_core/gselect.py 2014-11-10 07:25:02 UTC (rev 62690)
+++ grass/trunk/gui/wxpython/gui_core/gselect.py 2014-11-10 15:29:52 UTC (rev 62691)
@@ -52,6 +52,7 @@
import grass.script as grass
from grass.script import task as gtask
+from grass.exceptions import CalledModuleError
try:
from grass.pygrass import messages
except ImportError as e:
@@ -727,12 +728,14 @@
def _CheckDBConnection(self):
"""Check DB connection"""
- # if map is not defined (happens with vnet initialization)
- if not self.map:
+ nuldev = file(os.devnull, 'w+')
+ # if map is not defined (happens with vnet initialization) or it doesn't exist
+ try:
+ self.layers = grass.vector_db(map=self.map, stderr=nuldev)
+ except CalledModuleError:
return False
- nuldev = file(os.devnull, 'w+')
- self.layers = grass.vector_db(map = self.map, stderr = nuldev)
- nuldev.close()
+ finally: # always close nuldev
+ nuldev.close()
return bool(len(self.layers.keys()) > 0)
