[GRASS-SVN] r62695 - grass/branches/releasebranch_7_0/vector/v.sample
svn_grass at osgeo.org
Mon Nov 10 13:57:14 PST 2014
Author: neteler
Date: 2014-11-10 13:57:14 -0800 (Mon, 10 Nov 2014)
New Revision: 62695
grass/branches/releasebranch_7_0/vector/v.sample/v.sample.html
v.sample manual: example updated
Modified: grass/branches/releasebranch_7_0/vector/v.sample/v.sample.html
--- grass/branches/releasebranch_7_0/vector/v.sample/v.sample.html 2014-11-10 21:56:51 UTC (rev 62694)
+++ grass/branches/releasebranch_7_0/vector/v.sample/v.sample.html 2014-11-10 21:57:14 UTC (rev 62695)
@@ -29,27 +29,29 @@
<h2>EXAMPLE</h2>
-Comparison of "elevation.dem" and "elevation.10m" Spearfish maps
-at random places:
+Comparison of "elev_ned_30m" and "elev_srtm_30m" North Carolina
+sample dataset elevation models at random positions:
<div class="code"><pre>
-#generate random points:
+# set computational region:
+ g.region rast=elev_srtm_30m -p
+# generate random points:
v.random output=random n=100
-#add table with one column:
- v.db.addtable random col="el10 double"
-#transfer elevations at random points into table:
- v.what.rast rast=elevation.10m vect=random col=el10
-#verify:
+# add table with one column:
+ v.db.addtable random col="elev_srtm30 double precision"
+# transfer elevations at random points into table:
+ v.what.rast map=random rast=elev_srtm_30m col=elev_srtm30
+# verify:
v.db.select random
-#generate sampling from other elevation map:
- v.sample in=random col=el10 rast=elevation.dem out=elev_sample
+# perform sampling on other elevation map:
+ v.sample in=random col=elev_srtm30 rast=elev_ned_30m out=elev_samples
#verify:
- v.db.select elev_sample
+ v.db.select elev_samples
#univariate statistics of differences between elevation maps:
- v.univar elev_sample col=diff type=point
+ v.univar elev_samples column=diff type=point
</pre></div>
