[GRASS-SVN] r62700 - grass-addons/grass7/vector/v.kriging
Tue Nov 11 02:34:52 PST 2014
Author: neteler
Date: 2014-11-11 02:34:52 -0800 (Tue, 11 Nov 2014)
New Revision: 62700
   grass-addons/grass7/vector/v.kriging/v.kriging.html
v.kriging manual: fix broken submission
Modified: grass-addons/grass7/vector/v.kriging/v.kriging.html
--- grass-addons/grass7/vector/v.kriging/v.kriging.html	2014-11-11 05:34:45 UTC (rev 62699)
+++ grass-addons/grass7/vector/v.kriging/v.kriging.html	2014-11-11 10:34:52 UTC (rev 62700)
@@ -1,19 +1,22 @@
-<<<<<<< .mine
 <h2>DESCRIPTION</h2>
-<em>v.kriging</em> interpolates unknown values using method <i>ordinary kriging</i>. Output can be 2D (temporarily denied) or 3D.
+<em>v.kriging</em> interpolates unknown values using method <i>ordinary
+kriging</i>. Output can be 2D (temporarily denied) or 3D.
-<h2>EXAMPLES</h2>
-Input layer should contain 3D coordinates (xyz) and values to be interpolated (in attribute table). The commands can look like this:
+<h2>EXAMPLES</h2> Input layer should contain 3D coordinates (xyz) and
+values to be interpolated (in attribute table). The commands can look
+like this:
 <div class="code"><pre>
-v.kriging phase=initial in=input_layer icol=name report=report_file.txt file=png --o
+v.kriging phase=initial in=input_layer icol=name report=report_file.txt file=png
 </pre></div>
-v.kriging in=input_layer phase=middle hz_fun=exponential vert_fun=exponential ic=name file=png hz_nugget=0 vert_nugget=0 hz_range=double vert_range=double --o -b
+v.kriging in=input_layer phase=middle hz_fun=exponential vert_fun=exponential \
+  ic=name file=png hz_nugget=0 vert_nugget=0 hz_range=double vert_range=double -b
 </pre></div>
-v.kriging in=input_layer phase=final final_fun=bivariate icol=name file=png out=name crossval=crossval_file.txt --o
+v.kriging in=input_layer phase=final final_fun=bivariate icol=name file=png \
+  out=name crossval=crossval_file.txt
 </pre></div>
 <h2>SEE ALSO</h2>
@@ -27,39 +30,17 @@
 <ul>
 <li><b>Gnuplot</b> graphing utility, <a href="http://www.gnuplot.info/">more</a><br>
 <li><b>LAPACK / BLAS</b> (libraries for numerical computing) for
-GMATH library (GRASS Numerical Library)<br>
-<a href="http://www.netlib.org/lapack">http://www.netlib.org/lapack</a> (usually available on Linux distros)
+    GMATH library (GRASS Numerical Library)<br>
+    <a href="http://www.netlib.org/lapack">http://www.netlib.org/lapack</a>
+    (usually available on Linux distros)
 <li><a href="http://pointclouds.org">Point Cloud Library</a>
 </ul>
 <h2>AUTHOR</h2>
 Eva Stopkova<br>
-functions taken from another modules are cited above the function or at the beginning of the file (e.g. <i>quantile.cpp</i> that uses slightly modified functions taken from the module <i>r.quantile</i> (Clemens, G.))
+functions taken from another modules are cited above the function or at
+the beginning of the file (e.g. <i>quantile.cpp</i> that uses slightly
+modified functions taken from the module <i>r.quantile</i> (Clemens, G.))
 <p>
 <i>Last changed: $Date$</i>
-<h2>DESCRIPTION</h2>
-TODO
-<h2>EXAMPLES</h2>
-TODO
-<h2>REQUIREMENTS</h2>
-<ul>
-  <li><b>LAPACK / BLAS</b> (libraries for numerical computing) for
-    GMATH library (GRASS Numerical Library)<br>
-    <a href="http://www.netlib.org/lapack">http://www.netlib.org/lapack</a> (usually available on Linux distros)
-  <li><a href="http://pointclouds.org">Point Cloud Library</a>
-</ul>
-<h2>AUTHOR</h2>
-Eva Stopkova
-<p>
-<i>Last changed: $Date$</i>
->>>>>>> .r62698
