[GRASS-SVN] r62707 - in grass/trunk/lib/python/pygrass/vector: . testsuite
svn_grass at osgeo.org
Tue Nov 11 07:43:54 PST 2014
Author: zarch
Date: 2014-11-11 07:43:54 -0800 (Tue, 11 Nov 2014)
New Revision: 62707
grass/trunk/lib/python/pygrass/vector/table.py
grass/trunk/lib/python/pygrass/vector/testsuite/test_table.py
pygrass: Fix Table update and Column add methods, Fix test.
Modified: grass/trunk/lib/python/pygrass/vector/table.py
--- grass/trunk/lib/python/pygrass/vector/table.py 2014-11-11 15:23:43 UTC (rev 62706)
+++ grass/trunk/lib/python/pygrass/vector/table.py 2014-11-11 15:43:54 UTC (rev 62707)
@@ -398,7 +398,7 @@
>>> remove('mycensus', 'vect')
- def check_col(col_type):
+ def check(col_type):
"""Check the column type if it is supported by GRASS
:param col_type: the type of column
@@ -409,24 +409,16 @@
if 'VARCHAR' in col_type or col_type.upper() not in valid_type:
str_err = "Type is not supported, supported types are: %s"
raise TypeError(str_err % ", ".join(valid_type))
+ return col_type
- if isinstance(col_name, unicode):
- check_col(col_type)
- else:
- if len(col_name) == len(col_type):
- cvars = []
- for name, ctype in zip(col_name, col_type):
- check_col(ctype)
- cvars.append('%s %s' % (name, ctype))
- col_name = ''
- col_type = ','.join(cvars)
- else:
- str_err = "The lenghts of the columns are different:\n%r\n%r"
- raise TypeError(str_err % (col_name, col_type))
+ col_type = ([check(col_type), ] if isinstance(col_type, (str, unicode))
+ else [check(col) for col in col_type])
+ col_name = ([col_name, ] if isinstance(col_name, (str, unicode))
+ else col_name)
+ sqlcode = [sql.ADD_COL.format(tname=self.tname, cname=cn, ctype=ct)
+ for cn, ct in zip(col_name, col_type)]
cur = self.conn.cursor()
- cur.execute(sql.ADD_COL.format(tname=self.tname,
- cname=col_name,
- ctype=col_type))
+ cur.executescript('\n'.join(sqlcode))
self.conn.commit()
cur.close()
self.update_odict()
@@ -1022,7 +1014,7 @@
cur = cursor if cursor else self.conn.cursor()
if self.exist(cursor=cur):
used = db_table_in_vector(self.name)
- if len(used) > 0 and not force:
+ if used is not None and len(used) > 0 and not force:
print(_("Deleting table <%s> which is attached"
" to following map(s):") % self.name)
for vect in used:
@@ -1125,7 +1117,8 @@
:type cursor: Cursor object
- return cur.execute(self.columns.update_str, values)
+ vals = list(values) + [key, ]
+ return cur.execute(self.columns.update_str, vals)
def create(self, cols, name=None, overwrite=False, cursor=None):
"""Create a new table
Modified: grass/trunk/lib/python/pygrass/vector/testsuite/test_table.py
--- grass/trunk/lib/python/pygrass/vector/testsuite/test_table.py 2014-11-11 15:23:43 UTC (rev 62706)
+++ grass/trunk/lib/python/pygrass/vector/testsuite/test_table.py 2014-11-11 15:43:54 UTC (rev 62707)
@@ -195,10 +195,11 @@
def test_update(self):
"""Test Table.update method"""
- vals = (1111, 0.1111, 'test')
+ vals = (1122, 0.1122, 'test')
cat = 1
cur = self.connection.cursor()
self.table.update(cat, list(vals), cursor=cur)
+ self.connection.commit()
sqlquery = "SELECT cint, creal, ctxt FROM %s WHERE cat=%d"
cur.execute(sqlquery % (self.tname, cat))
self.assertTupleEqual(vals, cur.fetchone())
