[GRASS-SVN] r62727 - grass-addons/grass7/vector/v.fixed.segmentpoints
svn_grass at osgeo.org
Thu Nov 13 13:45:46 PST 2014
Author: hellik
Date: 2014-11-13 13:45:46 -0800 (Thu, 13 Nov 2014)
New Revision: 62727
grass-addons/grass7/vector/v.fixed.segmentpoints/v.fixed.segmentpoints.py
v.fixed.segmentpoints: prefix added for multiple runs
Modified: grass-addons/grass7/vector/v.fixed.segmentpoints/v.fixed.segmentpoints.py
--- grass-addons/grass7/vector/v.fixed.segmentpoints/v.fixed.segmentpoints.py 2014-11-13 15:30:56 UTC (rev 62726)
+++ grass-addons/grass7/vector/v.fixed.segmentpoints/v.fixed.segmentpoints.py 2014-11-13 21:45:46 UTC (rev 62727)
@@ -38,6 +38,14 @@
#%end
#%option
+#% key: prefix
+#% type: string
+#% key_desc: prefix
+#% description: output prefix (must start with a letter)
+#% required: yes
+#%end
+#%option
#% key: distance
#% type: integer
#% key_desc: integer
@@ -60,26 +68,29 @@
vcat = options['cat']
directory = options['dir']
sdistance = options['distance']
- fpointscsv = 't_segmentpoints.csv'
- fpointscsv_export = 'segmentpoints.csv'
- fpoints = 'segmentpoints.txt'
+ prefix = options['prefix']
+ voutline = prefix+'_singleline'
+ voutpoint = prefix+'_segmentpoints'
+ fpointscsv = prefix+'_t_segmentpoints.csv'
+ fpointscsv_export = prefix+'_segmentpoints.csv'
+ fpoints = prefix+'_segmentpoints.txt'
global tmp
# Extract vector line
grass.message( "Extract vector line for which segment points should be calculated ..." )
grass.run_command('v.extract', input = vlines,
- output = 'vlinesingle',
+ output = voutline,
cats = vcat)
grass.message( "Extraction done." )
grass.message( "----" )
# Calculate vector line length and populate it to the attribute table
grass.message( "Calculate vector line length and populate it to the attribute table ..." )
- grass.run_command("v.db.addcolumn", map = 'vlinesingle',
+ grass.run_command("v.db.addcolumn", map = voutline,
layer = 1,
columns = "vlength double")
- grass.run_command("v.to.db", map = 'vlinesingle',
+ grass.run_command("v.to.db", map = voutline,
option = 'length',
layer = 1,
columns = 'vlength',
@@ -89,7 +100,7 @@
# Read length
- tmp = grass.read_command('v.to.db', map = 'vlinesingle',
+ tmp = grass.read_command('v.to.db', map = voutline,
type = 'line',
layer = 1,
qlayer = 1,
@@ -138,22 +149,22 @@
# Run v.segment with the segment point input
grass.message( "Run v.segment ..." )
- grass.run_command("v.segment", input = 'vlinesingle',
- output = 'segmentpoints',
+ grass.run_command("v.segment", input = voutline,
+ output = voutpoint,
file = segment_points_file)
- grass.run_command("v.db.addtable", map = 'segmentpoints')
+ grass.run_command("v.db.addtable", map = voutpoint)
grass.message( "v.segment done." )
# Adding coordinates to segment points attribute table.
grass.message( "Adding coordinates to segment points attribute table ..." )
- grass.run_command("v.db.addcolumn", map = 'segmentpoints',
+ grass.run_command("v.db.addcolumn", map = voutpoint,
layer = 1,
columns = "xcoor double,ycoor double")
- grass.run_command("v.to.db", map = 'segmentpoints',
+ grass.run_command("v.to.db", map = voutpoint,
option = 'coor',
layer = 1,
columns = 'xcoor,ycoor')
@@ -170,9 +181,9 @@
new_line = line.replace(" ", ";")
f.write(new_line)
- grass.run_command("db.in.ogr", dsn = "%s" % segment_points_file_csv)
+ grass.run_command("db.in.ogr", output = 't_segmentpoints_csv', dsn = "%s" % segment_points_file_csv)
- grass.run_command("v.db.join", map = 'segmentpoints',
+ grass.run_command("v.db.join", map = voutpoint,
column = 'cat',
otable = 't_segmentpoints_csv',
ocolumn = 'field_2',
@@ -181,19 +192,19 @@
grass.run_command("db.droptable", table = 't_segmentpoints_csv',
flags = 'f')
layer = 1,
columns = "cat_2 integer,distance double")
- grass.run_command("db.execute", sql = "UPDATE segmentpoints SET cat_2 = field_2")
- grass.run_command("db.execute", sql = "UPDATE segmentpoints SET distance = field_4")
- grass.run_command("db.execute", sql = "UPDATE segmentpoints SET distance = %s WHERE cat = %s" %(vector_line_length, number_segmentpoints_with_end))
+ grass.run_command("db.execute", sql = "UPDATE %s SET cat_2 = field_2" % (voutpoint))
+ grass.run_command("db.execute", sql = "UPDATE %s SET distance = field_4" % (voutpoint))
+ grass.run_command("db.execute", sql = "UPDATE %s SET distance = %s WHERE cat = %s" %(voutpoint, vector_line_length, number_segmentpoints_with_end))
- grass.run_command("db.dropcolumn", table = 'segmentpoints',
+ grass.run_command("db.dropcolumn", table = voutpoint,
column = 'field_2',
flags = 'f')
column = 'field_4',
flags = 'f')
@@ -205,7 +216,7 @@
csv_to_export = os.path.join( directory, fpointscsv_export )
- grass.run_command("db.out.ogr", input = 'segmentpoints',
+ grass.run_command("db.out.ogr", input = voutpoint,
dsn = '%s' % (csv_to_export),
format = 'CSV')
