[GRASS-SVN] r62729 - in grass/branches/releasebranch_7_0: . vector/v.what
Thu Nov 13 20:02:06 PST 2014
Author: annakrat
Date: 2014-11-13 20:02:06 -0800 (Thu, 13 Nov 2014)
New Revision: 62729
   grass/branches/releasebranch_7_0/
   grass/branches/releasebranch_7_0/vector/v.what/main.c
   grass/branches/releasebranch_7_0/vector/v.what/what.c
   grass/branches/releasebranch_7_0/vector/v.what/what.h
v.what: add json format to simplify parsing output and thus to fix #2431 (merge from trunk, r62469, r62654)
Property changes on: grass/branches/releasebranch_7_0
___________________________________________________________________
Modified: svn:mergeinfo
   - /grass/trunk:60817,61096,61141,62179-62180,62182,62403,62422,62424,62437,62466,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62570,62573,62575,62585,62588,62597,62603,62606,62608-62609,62614,62618,62628,62632,62638,62642,62648-62649,62652,62655-62657,62666,62723
   + /grass/trunk:60817,61096,61141,62179-62180,62182,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62570,62573,62575,62585,62588,62597,62603,62606,62608-62609,62614,62618,62628,62632,62638,62642,62648-62649,62652,62654-62657,62666,62723
Modified: grass/branches/releasebranch_7_0/vector/v.what/main.c
--- grass/branches/releasebranch_7_0/vector/v.what/main.c	2014-11-13 22:06:04 UTC (rev 62728)
+++ grass/branches/releasebranch_7_0/vector/v.what/main.c	2014-11-14 04:02:06 UTC (rev 62729)
@@ -33,7 +33,7 @@
 int main(int argc, char **argv)
     struct {
-	struct Flag *print, *topo, *shell;
+	struct Flag *print, *topo, *shell, *json;
     } flag;
     struct {
 	struct Option *map, *field, *coords, *maxdist, *type;
@@ -97,6 +97,11 @@
     flag.shell->key = 'g';
     flag.shell->description = _("Print the stats in shell script style");
     flag.shell->guisection = _("Print");
+    flag.json = G_define_flag();
+    flag.json->key = 'j';
+    flag.json->description = _("Print the stats in JSON");
+    flag.json->guisection = _("Print");
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
@@ -112,6 +117,9 @@
     else
 	G_fatal_error(_("No input vector maps!"));
+    if (flag.shell->answer && flag.json->answer)
+        G_fatal_error(_("Flags g and j are mutually exclusive"));
     maxd = atof(opt.maxdist->answer);
     type = Vect_option_to_types(opt.type);
@@ -178,7 +186,7 @@
 	    ret = sscanf(buf, "%lf%c%lf", &xval, &ch, &yval);
 	    if (ret == 3 && (ch == ',' || ch == ' ' || ch == '\t')) {
 		what(Map, nvects, vect, xval, yval, maxd, type, flag.topo->answer,
-		     flag.print->answer, flag.shell->answer, field);
+		     flag.print->answer, flag.shell->answer, flag.json->answer, field);
 	    else {
 		G_warning(_("Unknown input format, skipping: '%s'"), buf);
@@ -192,7 +200,7 @@
 	    xval = atof(opt.coords->answers[i]);
 	    yval = atof(opt.coords->answers[i + 1]);
Modified: grass/branches/releasebranch_7_0/vector/v.what/what.c
--- grass/branches/releasebranch_7_0/vector/v.what/what.c	2014-11-13 22:06:04 UTC (rev 62728)
+++ grass/branches/releasebranch_7_0/vector/v.what/what.c	2014-11-14 04:02:06 UTC (rev 62729)
@@ -17,7 +17,7 @@
 static void F_generate(const char *drvname, const char *dbname,
 		       const char *tblname, const char *key, int keyval,
-		       char **form)
+		       int script, int json, char **form)
     int col, ncols, sqltype, more;
     char buf[5000];
@@ -87,8 +87,14 @@
 	    colname = db_get_column_name(column);
 	    G_debug(2, "%s: %s", colname, db_get_string(&str));
-	    sprintf(buf, "%s : %s\n", colname, db_get_string(&str));
+	    if (json) {
+		sprintf(buf, "%s\"%s\": \"%s\"", col == 0 ? "" : ",\n",
+			colname, db_get_string(&str));
+	    else if (script)
+		sprintf(buf, "%s=%s\n", colname, db_get_string(&str));
+	    else
+		sprintf(buf, "%s : %s\n", colname, db_get_string(&str));
 	    db_append_string(&html, buf);
@@ -106,7 +112,7 @@
 void what(struct Map_info *Map, int nvects, char **vect, double east, double north,
-          double maxdist, int qtype, int topo, int showextra, int script, int *field)
+          double maxdist, int qtype, int topo, int showextra, int script, int json, int *field)
     int type;
     char east_buf[40], north_buf[40];
@@ -173,6 +179,10 @@
 		    fprintf(stdout, "East=%s\nNorth=%s\n", east_buf,
 			    north_buf);
+		else if (json) {
+		    fprintf(stdout, "{\"Coordinates\": {\"East\": \"%s\", \"North\": \"%s\"}",
+			    east_buf, north_buf);
 		else {
 		    fprintf(stdout, "East: %s\nNorth: %s\n", east_buf,
 			    north_buf);
@@ -189,6 +199,19 @@
 	    fprintf(stdout, "\nMap=%s\nMapset=%s\n", Map[i].name,
 		    Map[i].mapset);
+	else if (json) {
+	    if (!i) {
+		if (line + area > 0 || G_verbose() >= G_verbose_std())
+		    fprintf(stdout, ",\n\"Maps\":\n[{\"Map\": \"%s\",\n\"Mapset\": \"%s\"",
+			    Map[i].name, Map[i].mapset);
+		else
+		    fprintf(stdout, "{\"Maps\":\n[{\"Map\": \"%s\",\n\"Mapset\": \"%s\"",
+	    else
+		fprintf(stdout, ",\n{\"Map\": \"%s\",\n\"Mapset\": \"%s\"",
 	else {
 	    fprintf(stdout, "%s", SEP);
 	    fprintf(stdout, "\nMap: %s \nMapset: %s\n", Map[i].name,
@@ -198,9 +221,10 @@
 	nlines++;
 	if (line + area == 0) {
-	    if (!script) {
-		fprintf(stdout, _("Nothing Found.\n"));
+	    if (json)
+		fprintf(stdout, "}\n");
+	    else if (!script)
+		fprintf(stdout, _("Nothing found.\n"));
 	    nlines++;
 	    continue;
@@ -208,8 +232,12 @@
 	if (line > 0) {
 	    type = Vect_read_line(&Map[i], Points, Cats, line);
-	    if (field[i] != -1 && !Vect_cat_get(Cats, field[i], NULL))
-	      continue;
+	    if (field[i] != -1 && !Vect_cat_get(Cats, field[i], NULL)) {
+		if (json) {
+		continue;
 	    switch (type) {
 	    case GV_POINT:
@@ -252,6 +280,12 @@
 			    "Id=%d\nType=%s\nLeft=%d\nRight=%d\n",
 			    line, buf, left, right);
+		else if (json) {
+		    fprintf(stdout, ",\n\"Feature_max_distance\": %f", maxdist);
+		    fprintf(stdout,
+			    ",\n\"Id\": %d,\n\"Type\": \"%s\",\n\"Left\": %d,\n\"Right\": %d",
+			    line, buf, left, right);
 		else {
 		    fprintf(stdout, "Looking for features within: %f\n",
 			    maxdist);
@@ -283,6 +317,11 @@
 				_("Node[%d]=%d\nNumber_lines=%d\nCoordinates=%.6f,%.6f,%.6f\n"),
 				n, node[n], nnlines, nx, ny, nz);
+		    else if (json) {
+			fprintf(stdout,
+				_(",\n\"Node[%d]\": %d,\n\"Number_lines\": %d,\n\"Coordinates\": %.6f,%.6f,%.6f"),
+				n, node[n], nnlines, nx, ny, nz);
 		    else {
 			fprintf(stdout,
 				_("Node[%d]: %d\nNumber of lines: %d\nCoordinates: %.6f, %.6f, %.6f\n"),
@@ -298,13 +337,16 @@
 			    fprintf(stdout, "Id=%5d\nAngle=%.8f\n",
 				    nodeline, angle);
+			else if (json) {
+			    fprintf(stdout, ",\n\"Id\": %5d,\n\"Angle\": %.8f",
+				    nodeline, angle);
 			else {
 			    fprintf(stdout, _("Id: %5d\nAngle: %.8f\n"),
 				    nodeline, angle);
 	    else {
 		if (script) {
@@ -313,6 +355,12 @@
 		    if (type & GV_LINES)
 			fprintf(stdout, "Length=%f\n", l);
+		else if (json) {
+		    fprintf(stdout, ",\n\"Type\": \"%s\"", buf);
+		    fprintf(stdout, ",\n\"Id\": %d", line);
+		    if (type & GV_LINES)
+			fprintf(stdout, ",\n\"Length\": %f", l);
 		else {
 		    fprintf(stdout, _("Type: %s\n"), buf);
 		    fprintf(stdout, _("Id: %d\n"), line);
@@ -330,6 +378,9 @@
 		    if (script) {
 			fprintf(stdout, "Point_height=%f\n", Points->z[0]);
+		    else if (json) {
+			fprintf(stdout, ",\n\"Point_height\": %f", Points->z[0]);
 		    else {
 			fprintf(stdout, _("Point height: %f\n"),
 				Points->z[0]);
@@ -347,6 +398,9 @@
 			if (script) {
 			    fprintf(stdout, "Line_height=%f\n", min);
+			else if (json) {
+			    fprintf(stdout, ",\n\"Line_height\": %f", min);
 			else {
 			    fprintf(stdout, _("Line height: %f\n"), min);
@@ -357,6 +411,11 @@
 				    "Line_height_min=%f\nLine_height_max=%f\n",
 				    min, max);
+			else if (json) {
+			    fprintf(stdout,
+				    ",\n\"Line_height_min\": %f,\n\"Line_height_max\": %f",
+				    min, max);
 			else {
 			    fprintf(stdout,
 				    _("Line height min: %f\nLine height max: %f\n"),
@@ -372,6 +431,9 @@
 		if (script) {
 		    fprintf(stdout, "Type=Area\nArea_height=%f\n", z);
+		else if (json) {
+		    fprintf(stdout, ",\n\"Type\": \"Area\",\n\"Area_height\": %f", z);
 		else {
 		fprintf(stdout, _("Type: Area\nArea height: %f\n"), z);
@@ -380,6 +442,9 @@
 		if (script) {
 		    fprintf(stdout, "Type=Area\n");
+		else if (json) {
+		    fprintf(stdout, ",\n\"Type\": \"Area\"");
 		else {
 		    fprintf(stdout, _("Type: Area\n"));
@@ -402,6 +467,10 @@
 		    fprintf(stdout, "Area=%d\nNumber_isles=%d\n", area,
 			    nisles);
+		else if (json) {
+		    fprintf(stdout, ",\n\"Area\": %d,\n\"Number_isles\": %d", area,
+			    nisles);
 		else {
 		    fprintf(stdout, _("Area: %d\nNumber of isles: %d\n"),
 			    area, nisles);
@@ -412,6 +481,9 @@
 		    if (script) {
 			fprintf(stdout, "Isle[%d]=%d\n", isleidx, isle);
+		    else if (json) {
+			fprintf(stdout, ",\n\"Isle[%d]\": %d", isleidx, isle);
 		    else {
 			fprintf(stdout, _("Isle[%d]: %d\n"), isleidx, isle);
@@ -425,6 +497,10 @@
 			fprintf(stdout, "Island=%d\nIsland_area=%d\n", isle,
 				isle_area);
+		    else if (json) {
+			fprintf(stdout, ",\n\"Island\": %d,\n\"Island_area\": %d", isle,
+				isle_area);
 		    else {
 			fprintf(stdout, _("Island: %d In area: %d\n"), isle,
 				isle_area);
@@ -438,6 +514,12 @@
 		    fprintf(stdout, "Acres=%.3f\nSq_Miles=%.4f\n",
 			    acres, sq_miles);
+		else if (json) {
+		    fprintf(stdout, ",\n\"Sq_Meters\": %.3f,\n\"Hectares\": %.3f",
+			    sq_meters, hectares);
+		    fprintf(stdout, ",\n\"Acres\": %.3f,\n\"Sq_Miles\": %.4f",
+			    acres, sq_miles);
 		else {
 		    fprintf(stdout, _("Sq Meters: %.3f\nHectares: %.3f\n"),
@@ -454,8 +536,10 @@
 	if (Cats->n_cats > 0) {
 	    int j;
-	    char *formbuf1, *formbuf2;
+	    char *formbuf1;
+	    if (json) {
+		fprintf(stdout, ",\n\"Categories\": [");
 	    for (j = 0; j < Cats->n_cats; j++) {
 		G_debug(2, "field = %d  category = %d\n", Cats->field[j],
 			Cats->cat[j]);
@@ -463,6 +547,10 @@
 		    fprintf(stdout, "Layer=%d\nCategory=%d\n", Cats->field[j],
 			    Cats->cat[j]);
+		else if (json) {
+		    fprintf(stdout, "%s\n{\"Layer\": %d, \"Category\": %d", j == 0 ? "": ",",
+			    Cats->field[j], Cats->cat[j]);
 		else {
 		    fprintf(stdout, _("Layer: %d\nCategory: %d\n"),
@@ -474,29 +562,46 @@
 				"Driver=%s\nDatabase=%s\nTable=%s\nKey_column=%s\n",
 				Fi->driver, Fi->database, Fi->table, Fi->key);
+		    else if (json) {
+			fprintf(stdout,
+				",\n\"Driver\": \"%s\",\n\"Database\": \"%s\",\n\"Table\": \"%s\",\n\"Key_column\": \"%s\"",
+				Fi->driver, Fi->database, Fi->table, Fi->key);
 		    else {
 			fprintf(stdout,
 				_("\nDriver: %s\nDatabase: %s\nTable: %s\nKey column: %s\n"),
 		    F_generate(Fi->driver, Fi->database, Fi->table,
-			       Fi->key, Cats->cat[j], &form);
+			       Fi->key, Cats->cat[j], script, json, &form);
 		    if (script) {
-			formbuf1 = G_str_replace(form, " : ", "=");
-			formbuf2 = G_str_replace(formbuf1, " ", "_");
-			fprintf(stdout, "%s", formbuf2);
+			formbuf1 = G_str_replace(form, " ", "_");
+			fprintf(stdout, "%s", formbuf1);
 			G_free(formbuf1);
-			G_free(formbuf2);
+		    else if (json)
+			fprintf(stdout, ",\n\"Attributes\": {%s}", form);
 		    else
 			fprintf(stdout, "%s", form);
 		    G_free(form);
 		    G_free(Fi);
+		if (json) {
+		    fprintf(stdout, "}"); /* for cat */
+	    if (json) {
+		fprintf(stdout, "]"); /* for list of cats */
-    }				/* for nvects */
+	if (json) {
+	    fprintf(stdout, "}"); /* for map */
+    if (json) {
+        fprintf(stdout, "]}\n"); /* for nvects */
     fflush(stdout);
Modified: grass/branches/releasebranch_7_0/vector/v.what/what.h
--- grass/branches/releasebranch_7_0/vector/v.what/what.h	2014-11-13 22:06:04 UTC (rev 62728)
+++ grass/branches/releasebranch_7_0/vector/v.what/what.h	2014-11-14 04:02:06 UTC (rev 62729)
@@ -1,3 +1,3 @@
 /* what.c */
 void what(struct Map_info *, int, char **,
-	  double, double, double, int, int, int, int, int *);
+	  double, double, double, int, int, int, int, int, int *);
