[GRASS-SVN] r62733 - grass/trunk/vector/v.neighbors
Fri Nov 14 03:37:52 PST 2014
Author: neteler
Date: 2014-11-14 03:37:52 -0800 (Fri, 14 Nov 2014)
New Revision: 62733
   grass/trunk/vector/v.neighbors/main.c
v.neighbors: more informative error message
Modified: grass/trunk/vector/v.neighbors/main.c
--- grass/trunk/vector/v.neighbors/main.c	2014-11-14 09:31:04 UTC (rev 62732)
+++ grass/trunk/vector/v.neighbors/main.c	2014-11-14 11:37:52 UTC (rev 62733)
@@ -36,7 +36,7 @@
     struct Option *in_opt, *out_opt, *field_opt;
     struct Option *method_opt, *size_opt;
     struct Map_info In;
-    double radius;
+    double radius, raster_res;
     struct boxlist *List;
     struct Cell_head region;
     struct bound_box box;
@@ -156,8 +156,13 @@
     Vect_close(&In);
     Rast_close(out_fd);
-    if (count_sum < 1)
-	G_warning(_("No points found"));
+    if (count_sum < 1) {
+	raster_res = (region.ew_res + region.ns_res)/2.;
+	G_warning(_("No points found (using raster resolution: %.1f, moving window size: %.1f)"),
+			raster_res, (box.E - box.W) * raster_res );
+	G_message(_("You can calculate the distance statistics between the vector point using:\nv.univar -d %s"), in_opt->answer);
+	exit(EXIT_FAILURE);
     exit(EXIT_SUCCESS);
